SDK包名称:rk356x_linux_release_v1.3.0b_20221213_split_dir
SDK修改内容:RK3568打入实时补丁
Log日志:rk3568_log.zip
目前定位问题出现在mmc_blk_data_init函数中,但是此函数并不开源,麻烦大佬们帮忙看下,此问题如何解决?
问题日志信息:
mmc0: new HS200 MMC card at address 0001
[2024/1/11 16:15:42 600] [ 2.551509] Loading compiled-in X.509 certificates
[2024/1/11 16:15:42 600] [ 2.552399] mmcblk0: mmc0:0001 Y2P032 29.1 GiB
[2024/1/11 16:15:42 600] [ 2.553213] pstore: Using compression: deflate
[2024/1/11 16:15:42 600] [ 2.553953] mmcblk0boot0: mmc0:0001 Y2P032 partition 1 4.00 MiB
[2024/1/11 16:15:42 600] [ 2.555269] mmcblk0boot1: mmc0:0001 Y2P032 partition 2 4.00 MiB
[2024/1/11 16:15:42 609] [ 2.555335] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.17
[2024/1/11 16:15:42 609] [ 2.555910] rochchip_p3phy_init: lock failed 0x6890000, check input refclk and power supply
[2024/1/11 16:15:42 609] [ 2.555924] phy phy-fe8c0000.phy.7: phy init failed → -11
[2024/1/11 16:15:42 609] [ 2.555929] rk-pcie 3c0800000.pcie: fail to init phy, err -110
[2024/1/11 16:15:42 609] [ 2.555933] rk-pcie 3c0800000.pcie: phy init failed
[2024/1/11 16:15:42 609] [ 2.556086] rk-pcie 3c0800000.pcie: Dropping the link to regulator.17
[2024/1/11 16:15:42 609] [ 2.557118] rga2: Driver loaded successfully ver:3.2.63318
[2024/1/11 16:15:42 609] [ 2.557524] rga2: Module initialized.
[2024/1/11 16:15:42 609] [ 2.560613] mmcblk0rpmb: mmc0:0001 Y2P032 partition 3 16.0 MiB, chardev (240:0)
[2024/1/11 16:15:42 618] [ 2.563981] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[2024/1/11 16:15:42 618] [ 2.568795] Unable to handle kernel paging request at virtual address fffffffffffffbc8
[2024/1/11 16:15:42 618] [ 2.569530] Mem abort info:
[2024/1/11 16:15:42 618] [ 2.569847] ESR = 0x96000005
[2024/1/11 16:15:42 618] [ 2.570133] Exception class = DABT (current EL), IL = 32 bits
[2024/1/11 16:15:42 618] [ 2.570716] SET = 0, FnV = 0
[2024/1/11 16:15:42 618] [ 2.570999] EA = 0, S1PTW = 0
[2024/1/11 16:15:42 618] [ 2.571288] Data abort info:
[2024/1/11 16:15:42 618] [ 2.571579] ISV = 0, ISS = 0x00000005
[2024/1/11 16:15:42 618] [ 2.571932] CM = 0, WnR = 0
[2024/1/11 16:15:42 618] [ 2.572209] swapper pgtable: 4k pages, 39-bit VAs, pgdp = 000000005691ad88
[2024/1/11 16:15:42 628] [ 2.572859] [fffffffffffffbc8] pgd=0000000000000000, pud=0000000000000000
[2024/1/11 16:15:42 628] [ 2.573488] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[2024/1/11 16:15:42 628] [ 2.573492] Modules linked in:
[2024/1/11 16:15:42 628] [ 2.573498] Process kworker/1:1 (pid: 60, stack limit = 0x00000000159bbe27)
[2024/1/11 16:15:42 628] [ 2.573504] CPU: 1 PID: 60 Comm: kworker/1:1 Not tainted 4.19.232-rt104 #125
[2024/1/11 16:15:42 628] [ 2.573505] Hardware name: AIO-3568J HDMI (Linux) (DT)
[2024/1/11 16:15:42 628] [ 2.573520] Workqueue: events_freezable mmc_rescan
[2024/1/11 16:15:42 628] [ 2.573525] pstate: 00c00009 (nzcv daif +PAN +UAO)
[2024/1/11 16:15:42 628] [ 2.573531] pc : mmc_blk_data_init+0x44/0x90
[2024/1/11 16:15:42 628] [ 2.573535] lr : mmc_blk_probe+0x3b4/0x660
[2024/1/11 16:15:42 628] [ 2.573537] sp : ffffff8009e9b9d0
[2024/1/11 16:15:42 628] [ 2.573539] x29: ffffff8009e9b9d0 x28: ffffffc00a032000
[2024/1/11 16:15:42 628] [ 2.573542] x27: ffffff80099d8000 x26: 0000000000000003
[2024/1/11 16:15:42 628] [ 2.573546] x25: ffffffc00a03252c x24: ffffffc0778b0000
[2024/1/11 16:15:42 629] [ 2.573549] x23: ffffffc00a29cc00 x22: ffffff80091f0228
[2024/1/11 16:15:42 629] [ 2.573554] x21: 0000000000000000 x20: ffffffc00a032008
[2024/1/11 16:15:42 629] [ 2.573557] x19: ffffffc00a29cc00 x18: 0000000000000000
[2024/1/11 16:15:42 629] [ 2.573560] x17: 00000000a9423c8c x16: 000000000000002d
[2024/1/11 16:15:42 629] [ 2.573563] x15: 000000000000000a x14: 0000000000000003
[2024/1/11 16:15:42 638] [ 2.573567] x13: ffffffffffffffff x12: 0000000000000038
[2024/1/11 16:15:42 638] [ 2.573570] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[2024/1/11 16:15:42 638] [ 2.573573] x9 : ff6d6e5e7164766e x8 : 7f7f7f7f7f7f7f7f
[2024/1/11 16:15:42 638] [ 2.573576] x7 : 6f5e7377646d5e6b x6 : 0000000000000080
[2024/1/11 16:15:42 638] [ 2.573580] x5 : ffffffc077c2c458 x4 : ffffffc077c2cde8
[2024/1/11 16:15:42 638] [ 2.573583] x3 : ffffff80099d8fe8 x2 : fffffffffffffb58
[2024/1/11 16:15:42 638] [ 2.573586] x1 : fffffffffffffb58 x0 : ffffff80099d8000
[2024/1/11 16:15:42 638] [ 2.573590] Call trace:
[2024/1/11 16:15:42 638] [ 2.573595] mmc_blk_data_init+0x44/0x90
[2024/1/11 16:15:42 638] [ 2.573598] mmc_blk_probe+0x3b4/0x660
[2024/1/11 16:15:42 638] [ 2.573602] mmc_bus_probe+0x2c/0x38
[2024/1/11 16:15:42 638] [ 2.573609] really_probe+0x2a4/0x398
[2024/1/11 16:15:42 638] [ 2.573612] driver_probe_device+0x128/0x138
[2024/1/11 16:15:42 638] [ 2.573616] __device_attach_driver+0xd0/0x10c
[2024/1/11 16:15:42 638] [ 2.573619] bus_for_each_drv+0xa8/0xcc
[2024/1/11 16:15:42 638] [ 2.573622] __device_attach+0xe0/0x170
[2024/1/11 16:15:42 638] [ 2.573625] device_initial_probe+0x28/0x34
[2024/1/11 16:15:42 638] [ 2.573629] bus_probe_device+0x3c/0x9c
[2024/1/11 16:15:42 638] [ 2.573633] device_add+0x544/0x668
[2024/1/11 16:15:42 638] [ 2.573636] mmc_add_card+0x124/0x280
[2024/1/11 16:15:42 638] [ 2.573639] mmc_attach_mmc+0x118/0x17c
[2024/1/11 16:15:42 638] [ 2.573642] mmc_rescan+0x394/0x3dc
[2024/1/11 16:15:42 639] [ 2.573648] process_one_work+0x220/0x3b4
[2024/1/11 16:15:42 639] [ 2.573651] worker_thread+0x220/0x300
[2024/1/11 16:15:42 639] [ 2.573655] kthread+0x158/0x168
[2024/1/11 16:15:42 639] [ 2.573660] ret_from_fork+0x10/0x18
[2024/1/11 16:15:42 650] [ 2.573665]
[2024/1/11 16:15:42 650] [ 2.573665] X4: 0xffffffc077c2cde8:
[2024/1/11 16:15:42 650] [ 2.573666] cbe8 33a8dae3 00000000 77c2bd48 ffffffc0 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 650] [ 2.573677] cc08 00000000 00000000 00000000 00000000 00006fbf 00000001 a1ff0014 00000000
[2024/1/11 16:15:42 651] [ 2.573687] cc28 00000000 00000000 77c2cc38 ffffffc0 00000001 00000000 7acd4d48 ffffffc0
[2024/1/11 16:15:42 651] [ 2.573697] cc48 77c2d000 ffffffc0 0a69d2c0 ffffffc0 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 651] [ 2.573707] cc68 00000000 00000000 26d38750 00000000 77c2bd48 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 651] [ 2.573717] cc88 00000000 00000000 00000000 00000000 00000000 00000000 00006fc0 00000001
[2024/1/11 16:15:42 651] [ 2.573727] cca8 a1ff0014 00000000 00000000 00000000 77c2ccc0 ffffffc0 00000002 00000000
[2024/1/11 16:15:42 651] [ 2.573737] ccc8 77c2bd48 ffffffc0 093b631b ffffff80 77c2c239 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 651] [ 2.573747] cce8 00000000 00000000 00000000 00000000 380d1264 00000000 00000000 00000000
[2024/1/11 16:15:42 651] [ 2.573757] cd08 00000000 00000000 7ba34f00 ffffffc0 00000000 00000000 77c2d080 ffffffc0
[2024/1/11 16:15:42 651] [ 2.573767] cd28 00006fc1 00000001 41ed0011 00000000 00000000 00000000 77c2cd48 ffffffc0
[2024/1/11 16:15:42 651] [ 2.573777] cd48 00000002 00000000 77c2bd48 ffffffc0 093f263d ffffff80 77c2c568 ffffffc0
[2024/1/11 16:15:42 651] [ 2.573786] cd68 00000000 00000000 00000000 00000000 00000000 00000000 7e2a34f1 00000000
[2024/1/11 16:15:42 651] [ 2.573796] cd88 00000000 00000000 00000000 00000000 7ba34f00 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 651] [ 2.573806] cda8 77c2d100 ffffffc0 00006fc2 00000001 41ed0011 00000000 00000000 00000000
[2024/1/11 16:15:42 651] [ 2.573816] cdc8 77c2cdd0 ffffffc0 00000001 00000000 77c2bd48 ffffffc0 093c135c ffffff80
[2024/1/11 16:15:42 661] [ 2.573826] cde8* 77c2c459 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 661] [ 2.573835] ce08 5eda61a1 00000000 77c2b3b8 ffffffc0 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 661] [ 2.573845] ce28 00000000 00000000 00000000 00000000 00006fc3 00000001 a1ff0014 00000000
[2024/1/11 16:15:42 661] [ 2.573855] ce48 00000000 00000000 77c2ce58 ffffffc0 00000006 00000000 77c2bd48 ffffffc0
[2024/1/11 16:15:42 661] [ 2.573865] ce68 093eea70 ffffff80 77c2c459 ffffffc0 77c22c50 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 661] [ 2.573875] ce88 00000000 00000000 5807a702 00000000 00000000 00000000 77c2cef8 ffffffc0
[2024/1/11 16:15:42 661] [ 2.573885] cea8 7ba34f00 ffffffc0 00000000 00000000 0a035080 ffffffc0 00006fc4 00000001
[2024/1/11 16:15:42 661] [ 2.573895] cec8 41ed0011 00000000 00000000 00000000 77c2cee0 ffffffc0 00000001 00000000
[2024/1/11 16:15:42 661] [ 2.573904] cee8 77c2ce58 ffffffc0 093fa586 ffffff80 00000001 00000000 77c29018 ffffffc0
[2024/1/11 16:15:42 661] [ 2.573914] cf08 77c2cf80 ffffffc0 00000000 00000000 6f9730b6 00000000 09076860 ffffff80
[2024/1/11 16:15:42 661] [ 2.573924] cf28 00000000 00000000 00001000 00000000 00000000 00000000 09797810 ffffff80
[2024/1/11 16:15:42 661] [ 2.573934] cf48 00006fc5 00000001 81a40052 00000000 00000000 00000000 77c2cf68 ffffffc0
[2024/1/11 16:15:42 661] [ 2.573944] cf68 00000001 00000000 77c2ce58 ffffffc0 093b9dc7 ffffff80 77c2cef9 ffffffc0
[2024/1/11 16:15:42 672] [ 2.573954] cf88 77c290a0 ffffffc0 77c29128 ffffffc0 00000000 00000000 16f7dbb7 00000000
[2024/1/11 16:15:42 672] [ 2.573964] cfa8 09076860 ffffff80 00000000 00000000 00001000 00000000 00000000 00000000
[2024/1/11 16:15:42 672] [ 2.573973] cfc8 097977f0 ffffff80 00006fc6 00000001 81a40052 00000000 00000000 00000000
[2024/1/11 16:15:42 672] [ 2.573984]
[2024/1/11 16:15:42 672] [ 2.573984] X5: 0xffffffc077c2c458:
[2024/1/11 16:15:42 672] [ 2.573985] c258 3fdff3e2 00000000 09076860 ffffff80 00000000 00000000 00001000 00000000
[2024/1/11 16:15:42 672] [ 2.573995] c278 00000000 00000000 097e8010 ffffff80 00006fad 00000001 81240052 00000000
[2024/1/11 16:15:42 672] [ 2.574005] c298 00000000 00000000 77c2c2a8 ffffffc0 00000001 00000000 77c2bd48 ffffffc0
[2024/1/11 16:15:42 672] [ 2.574015] c2b8 0942dc6e ffffff80 77c2c4e0 ffffffc0 77c2c3d0 ffffffc0 77c291b0 ffffffc0
[2024/1/11 16:15:42 672] [ 2.574025] c2d8 00000000 00000000 4f84eb5c 00000000 09076860 ffffff80 00000000 00000000
[2024/1/11 16:15:42 672] [ 2.574035] c2f8 00001000 00000000 00000000 00000000 097e7ff0 ffffff80 00006fae 00000001
[2024/1/11 16:15:42 672] [ 2.574045] c318 81240052 00000000 00000000 00000000 77c2c330 ffffffc0 00000001 00000000
[2024/1/11 16:15:42 672] [ 2.574055] c338 77c2bd48 ffffffc0 093f2734 ffffff80 77c2c0a0 ffffffc0 77c2c5f0 ffffffc0
[2024/1/11 16:15:42 672] [ 2.574065] c358 77c2c018 ffffffc0 00000000 00000000 20a72c0f 00000000 09076860 ffffff80
[2024/1/11 16:15:42 672] [ 2.574075] c378 00000000 00000000 00001000 00000000 00000000 00000000 097e7fd0 ffffff80
[2024/1/11 16:15:42 672] [ 2.574085] c398 00006faf 00000001 81240052 00000000 00000000 00000000 77c2c3b8 ffffffc0
[2024/1/11 16:15:42 682] [ 2.574094] c3b8 00000001 00000000 77c2bd48 ffffffc0 093f2722 ffffff80 77c2c2c1 ffffffc0
[2024/1/11 16:15:42 682] [ 2.574104] c3d8 00000000 00000000 00000000 00000000 00000000 00000000 54cc013f 00000000
[2024/1/11 16:15:42 682] [ 2.574114] c3f8 09076860 ffffff80 00000000 00000000 00001000 00000000 00000000 00000000
[2024/1/11 16:15:42 682] [ 2.574124] c418 097e7fb0 ffffff80 00006fb0 00000001 81240052 00000000 00000000 00000000
[2024/1/11 16:15:42 682] [ 2.574134] c438 77c2c440 ffffffc0 00000001 00000000 77c2bd48 ffffffc0 093c5852 ffffff80
[2024/1/11 16:15:42 683] [ 2.574144] c458* 77c2c1b0 ffffffc0 77c2cde8 ffffffc0 77c2ce70 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 683] [ 2.574154] c478 5eaa11d9 00000000 09076860 ffffff80 00000000 00000000 00001000 00000000
[2024/1/11 16:15:42 683] [ 2.574164] c498 00000000 00000000 097e7f90 ffffff80 00006fb1 00000001 81240052 00000000
[2024/1/11 16:15:42 683] [ 2.574173] c4b8 00000000 00000000 77c2c4c8 ffffffc0 00000001 00000000 77c2bd48 ffffffc0
[2024/1/11 16:15:42 683] [ 2.574183] c4d8 093e7d11 ffffff80 77c2be71 ffffffc0 77c2c2c0 ffffffc0 77c2c238 ffffffc0
[2024/1/11 16:15:42 683] [ 2.574193] c4f8 00000000 00000000 41a201b2 00000000 09076860 ffffff80 00000000 00000000
[2024/1/11 16:15:42 683] [ 2.574203] c518 00001000 00000000 00000000 00000000 097e7f70 ffffff80 00006fb2 00000001
[2024/1/11 16:15:42 683] [ 2.574213] c538 81240052 00000000 00000000 00000000 77c2c550 ffffffc0 00000001 00000000
[2024/1/11 16:15:42 683] [ 2.574223] c558 77c2bd48 ffffffc0 093f2719 ffffff80 77c2c1b1 ffffffc0 77c2cd60 ffffffc0
[2024/1/11 16:15:42 683] [ 2.574233] c578 77c2c128 ffffffc0 00000000 00000000 74a4fb33 00000000 09076860 ffffff80
[2024/1/11 16:15:42 692] [ 2.574243] c598 00000000 00000000 00001000 00000000 00000000 00000000 097e7f50 ffffff80
[2024/1/11 16:15:42 692] [ 2.574253] c5b8 00006fb3 00000001 81240052 00000000 00000000 00000000 77c2c5d8 ffffffc0
[2024/1/11 16:15:42 692] [ 2.574262] c5d8 0000000a 00000000 77c2bd48 ffffffc0 09150df0 ffffff80 77c2c349 ffffffc0
[2024/1/11 16:15:42 692] [ 2.574272] c5f8 77c2cb40 ffffffc0 00000000 00000000 00000000 00000000 243fd916 00000000
[2024/1/11 16:15:42 692] [ 2.574282] c618 00000000 00000000 77c2c700 ffffffc0 7ba34f00 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 692] [ 2.574292] c638 0a035080 ffffffc0 00006fb4 00000001 41ed0011 00000000 00000000 00000000
[2024/1/11 16:15:42 692] [ 2.574307]
[2024/1/11 16:15:42 692] [ 2.574307] X19: 0xffffffc00a29cc00:
[2024/1/11 16:15:42 693] [ 2.574308] ca00 fe000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 693] [ 2.574318] ca20 00000000 00000000 00000000 00000000 08c0aa28 ffffff80 0a29c880 ffffffc0
[2024/1/11 16:15:42 693] [ 2.574327] ca40 00000000 00000000 00000000 00000000 00000001 00000000 0a29ca58 ffffffc0
[2024/1/11 16:15:42 693] [ 2.574337] ca60 0a29ca58 ffffffc0 0005b8d8 00061a80 207f0080 0000270a 7ac80010 ffffffc0
[2024/1/11 16:15:42 693] [ 2.574347] ca80 0a189880 ffffffc0 091f2550 ffffff80 0a189a80 ffffffc0 0a18b180 ffffffc0
[2024/1/11 16:15:42 693] [ 2.574357] caa0 0a18b200 ffffffc0 0a0ba800 ffffffc0 00000100 00000002 00000000 00000000
[2024/1/11 16:15:42 704] [ 2.574367] cac0 00000000 00000000 08c07064 ffffff80 08c06f60 ffffff80 00000001 00000000
[2024/1/11 16:15:42 705] [ 2.574377] cae0 00000000 00000000 0000002a 00000008 00000200 dead0000 00000000 00000000
[2024/1/11 16:15:42 705] [ 2.574387] cb00 fffb779e 00000000 08c08214 ffffff80 1d000002 00000000 00000000 00000000
[2024/1/11 16:15:42 705] [ 2.574397] cb20 00000000 00000000 00000000 00000000 7ef1c928 ffffffc0 fffb762c 00000000
[2024/1/11 16:15:42 705] [ 2.574407] cb40 08c06b60 ffffff80 0b400002 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 705] [ 2.574416] cb60 00000000 00000000 00000000 00000000 00000000 00000000 08c06a74 ffffff80
[2024/1/11 16:15:42 705] [ 2.574426] cb80 00000001 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[2024/1/11 16:15:42 705] [ 2.574436] cba0 00000000 00000000 00000000 00000000 00000000 00000000 08c069a8 ffffff80
[2024/1/11 16:15:42 705] [ 2.574446] cbc0 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 705] [ 2.574456] cbe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 705] [ 2.574465] cc00* 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[2024/1/11 16:15:42 705] [ 2.574475] cc20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 705] [ 2.574484] cc40 0a032008 ffffffc0 0a033800 ffffffc0 0a032000 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 705] [ 2.574495] cc60 0a052100 ffffffc0 091f0ca0 ffffff80 00000001 00000040 00000000 000001c8
[2024/1/11 16:15:42 705] [ 2.574505] cc80 ffffffff 00000000 00000025 00000000 0a29cc50 ffffffc0 0a052080 ffffffc0
[2024/1/11 16:15:42 705] [ 2.574514] cca0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[2024/1/11 16:15:42 705] [ 2.574524] ccc0 00000000 00000000 00000000 00000000 00000000 00000000 77d489d8 ffffffc0
[2024/1/11 16:15:42 717] [ 2.574534] cce0 77d489d8 ffffffc0 0a29cc00 ffffffc0 77d48000 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 717] [ 2.574544] cd00 00000000 00000000 00000100 00000000 ffffffe0 0000000f 0a29cd18 ffffffc0
[2024/1/11 16:15:42 717] [ 2.574554] cd20 0a29cd18 ffffffc0 08bf50ac ffffff80 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 717] [ 2.574564] cd40 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[2024/1/11 16:15:42 717] [ 2.574574] cd60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 717] [ 2.574583] cd80 0a29cd80 ffffffc0 0a29cd80 ffffffc0 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 717] [ 2.574593] cda0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[2024/1/11 16:15:42 717] [ 2.574603] cdc0 00000000 00000000 00000000 00000000 00000000 00000000 ffffffe0 0000000f
[2024/1/11 16:15:42 717] [ 2.574612] cde0 0a29cde0 ffffffc0 0a29cde0 ffffffc0 08bf48c4 ffffff80 00000000 00000000
[2024/1/11 16:15:42 717] [ 2.574623]
[2024/1/11 16:15:42 717] [ 2.574623] X20: 0xffffffc00a032008:
[2024/1/11 16:15:42 717] [ 2.574624] 1e08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 717] [ 2.574634] 1e28 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 717] [ 2.574644] 1e48 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 717] [ 2.574654] 1e68 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 718] [ 2.574664] 1e88 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 718] [ 2.574673] 1ea8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 718] [ 2.574683] 1ec8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 730] [ 2.574693] 1ee8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 730] [ 2.574703] 1f08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 730] [ 2.574712] 1f28 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 730] [ 2.574722] 1f48 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 731] [ 2.574732] 1f68 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 731] [ 2.574742] 1f88 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 731] [ 2.574751] 1fa8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 731] [ 2.574761] 1fc8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 731] [ 2.574771] 1fe8 00000000 00000000 00000000 00000000 00000000 00000000 0a0ea000 ffffffc0
[2024/1/11 16:15:42 731] [ 2.574780] 2008* 0a0ea008 ffffffc0 0a7b3400 ffffffc0 0a18bd80 ffffffc0 7ac82028 ffffffc0
[2024/1/11 16:15:42 731] [ 2.574790] 2028 77ccc018 ffffffc0 0a0ea018 ffffffc0 7bbfe400 ffffffc0 09814f08 ffffff80
[2024/1/11 16:15:42 731] [ 2.574800] 2048 0a18aee0 ffffffc0 00000007 00000007 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 731] [ 2.574810] 2068 00000000 00000000 00000000 00000000 00000000 00000000 09869110 ffffff80
[2024/1/11 16:15:42 731] [ 2.574820] 2088 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[2024/1/11 16:15:42 731] [ 2.574830] 20a8 00000000 00000000 7b01ee40 ffffffc0 00000000 00000000 09868f18 ffffff80
[2024/1/11 16:15:42 731] [ 2.574840] 20c8 09869bf0 ffffff80 00000000 00000000 0a29cc00 ffffffc0 0a0320e0 ffffffc0
[2024/1/11 16:15:42 731] [ 2.574850] 20e8 0a0320e0 ffffffc0 0a0320f0 ffffffc0 0a0320f0 ffffffc0 0a032100 ffffffc0
[2024/1/11 16:15:42 731] [ 2.574860] 2108 0a032100 ffffffc0 0a032110 ffffffc0 0a032110 ffffffc0 00000000 00000001
[2024/1/11 16:15:42 744] [ 2.574870] 2128 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 744] [ 2.574879] 2148 00000000 00000106 00000000 00000000 00000000 dead4ead ffffffff 00000000
[2024/1/11 16:15:42 744] [ 2.574889] 2168 ffffffff ffffffff 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 744] [ 2.574899] 2188 00000000 00000000 00000000 00000000 7ac821a0 ffffffc0 77ccc190 ffffffc0
[2024/1/11 16:15:42 744] [ 2.574909] 21a8 ffffffff 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[2024/1/11 16:15:42 744] [ 2.574919] 21c8 0a0321c8 ffffffc0 0a0321c8 ffffffc0 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 744] [ 2.574929] 21e8 00000000 00000000 00000000 00000000 00000000 00000000 087f58fc ffffff80
[2024/1/11 16:15:42 744] [ 2.574940]
[2024/1/11 16:15:42 744] [ 2.574940] X23: 0xffffffc00a29cc00:
[2024/1/11 16:15:42 744] [ 2.574941] ca00 fe000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 744] [ 2.574950] ca20 00000000 00000000 00000000 00000000 08c0aa28 ffffff80 0a29c880 ffffffc0
[2024/1/11 16:15:42 744] [ 2.574960] ca40 00000000 00000000 00000000 00000000 00000001 00000000 0a29ca58 ffffffc0
[2024/1/11 16:15:42 744] [ 2.574970] ca60 0a29ca58 ffffffc0 0005b8d8 00061a80 207f0080 0000270a 7ac80010 ffffffc0
[2024/1/11 16:15:42 744] [ 2.574980] ca80 0a189880 ffffffc0 091f2550 ffffff80 0a189a80 ffffffc0 0a18b180 ffffffc0
[2024/1/11 16:15:42 744] [ 2.574990] caa0 0a18b200 ffffffc0 0a0ba800 ffffffc0 00000100 00000002 00000000 00000000
[2024/1/11 16:15:42 744] [ 2.575000] cac0 00000000 00000000 08c07064 ffffff80 08c06f60 ffffff80 00000001 00000000
[2024/1/11 16:15:42 744] [ 2.575010] cae0 00000000 00000000 0000002a 00000008 00000200 dead0000 00000000 00000000
[2024/1/11 16:15:42 745] [ 2.575020] cb00 fffb779e 00000000 08c08214 ffffff80 1d000002 00000000 00000000 00000000
[2024/1/11 16:15:42 745] [ 2.575030] cb20 00000000 00000000 00000000 00000000 7ef1c930 ffffffc0 fffb762d 00000000
[2024/1/11 16:15:42 755] [ 2.575040] cb40 08c06b60 ffffff80 0b800002 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 755] [ 2.575050] cb60 00000000 00000000 00000000 00000000 00000000 00000000 08c06a74 ffffff80
[2024/1/11 16:15:42 755] [ 2.575060] cb80 00000001 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[2024/1/11 16:15:42 755] [ 2.575070] cba0 00000000 00000000 00000000 00000000 00000000 00000000 08c069a8 ffffff80
[2024/1/11 16:15:42 755] [ 2.575079] cbc0 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 755] [ 2.575089] cbe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 755] [ 2.575099] cc00* 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[2024/1/11 16:15:42 755] [ 2.575109] cc20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 755] [ 2.575118] cc40 0a032008 ffffffc0 0a033800 ffffffc0 0a032000 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 755] [ 2.575128] cc60 0a052100 ffffffc0 091f0ca0 ffffff80 00000001 00000040 00000000 000001c8
[2024/1/11 16:15:42 756] [ 2.575139] cc80 ffffffff 00000000 00000025 00000000 0a29cc50 ffffffc0 0a052080 ffffffc0
[2024/1/11 16:15:42 756] [ 2.575149] cca0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[2024/1/11 16:15:42 756] [ 2.575158] ccc0 00000000 00000000 00000000 00000000 00000000 00000000 77d489d8 ffffffc0
[2024/1/11 16:15:42 756] [ 2.575168] cce0 77d489d8 ffffffc0 0a29cc00 ffffffc0 77d48000 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 756] [ 2.575178] cd00 00000000 00000000 00000100 00000000 ffffffe0 0000000f 0a29cd18 ffffffc0
[2024/1/11 16:15:42 767] [ 2.575188] cd20 0a29cd18 ffffffc0 08bf50ac ffffff80 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 767] [ 2.575198] cd40 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[2024/1/11 16:15:42 767] [ 2.575208] cd60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 767] [ 2.575218] cd80 0a29cd80 ffffffc0 0a29cd80 ffffffc0 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 767] [ 2.575228] cda0 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[2024/1/11 16:15:42 767] [ 2.575237] cdc0 00000000 00000000 00000000 00000000 00000000 00000000 ffffffe0 0000000f
[2024/1/11 16:15:42 767] [ 2.575247] cde0 0a29cde0 ffffffc0 0a29cde0 ffffffc0 08bf48c4 ffffff80 00000000 00000000
[2024/1/11 16:15:42 767] [ 2.575258]
[2024/1/11 16:15:42 767] [ 2.575258] X24: 0xffffffc0778b0000:
[2024/1/11 16:15:42 767] [ 2.575259] fe00 00000000 00000000 00000000 00400000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 767] [ 2.575269] fe20 00000000 00000000 00000000 00000000 00800000 00000000 00000000 00000000
[2024/1/11 16:15:42 767] [ 2.575279] fe40 00000000 00000000 00000000 00000000 01000400 00000000 00000000 00400000
[2024/1/11 16:15:42 767] [ 2.575289] fe60 00000000 00400000 00004000 20000000 00000000 00000000 00001000 20000000
[2024/1/11 16:15:42 767] [ 2.575299] fe80 00000000 00000000 00000000 00000000 00000000 00000000 00000080 00000000
[2024/1/11 16:15:42 767] [ 2.575309] fea0 00000000 00000002 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 767] [ 2.575318] fec0 00000000 00000000 00000000 00000008 00000000 00000000 00000040 00000000
[2024/1/11 16:15:42 767] [ 2.575328] fee0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 779] [ 2.575338] ff00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 779] [ 2.575348] ff20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 779] [ 2.575357] ff40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 779] [ 2.575367] ff60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 779] [ 2.575377] ff80 10000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 779] [ 2.575386] ffa0 08000000 00000000 80000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 779] [ 2.575396] ffc0 00010000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 779] [ 2.575406] ffe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00100000
[2024/1/11 16:15:42 779] [ 2.575416] 0000* 0a032008 ffffffc0 77c0ab00 ffffffc0 77c7bc80 ffffffc0 778b0818 ffffffc0
[2024/1/11 16:15:42 779] [ 2.575426] 0020 0a0d2018 ffffffc0 0a032018 ffffffc0 7bbfe400 ffffffc0 09814f08 ffffff80
[2024/1/11 16:15:42 779] [ 2.575436] 0040 77c054c8 ffffffc0 00000004 00000007 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 779] [ 2.575445] 0060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 779] [ 2.575455] 0080 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
[2024/1/11 16:15:42 779] [ 2.575465] 00a0 00000000 00000000 00000000 00000000 00000000 00000000 09869cb0 ffffff80
[2024/1/11 16:15:42 779] [ 2.575475] 00c0 00000000 00000000 00000000 00000000 778b0000 ffffffc0 778b00d8 ffffffc0
[2024/1/11 16:15:42 779] [ 2.575485] 00e0 778b00d8 ffffffc0 778b00e8 ffffffc0 778b00e8 ffffffc0 778b00f8 ffffffc0
[2024/1/11 16:15:42 788] [ 2.575495] 0100 778b00f8 ffffffc0 778b0108 ffffffc0 778b0108 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 789] [ 2.575505] 0120 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 789] [ 2.575515] 0140 00000000 00000104 00000000 00000000 00000000 dead4ead ffffffff 00000000
[2024/1/11 16:15:42 789] [ 2.575524] 0160 ffffffff ffffffff 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 789] [ 2.575534] 0180 00000000 00000000 00000000 00000000 778b0990 ffffffc0 0a0d2190 ffffffc0
[2024/1/11 16:15:42 789] [ 2.575544] 01a0 ffffffff 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[2024/1/11 16:15:42 789] [ 2.575554] 01c0 778b01c0 ffffffc0 778b01c0 ffffffc0 00000000 00000000 00000004 00000000
[2024/1/11 16:15:42 789] [ 2.575564] 01e0 00000000 00000000 00000000 00000000 00000000 00000000 087f58fc ffffff80
[2024/1/11 16:15:42 789] [ 2.575574]
[2024/1/11 16:15:42 789] [ 2.575574] X25: 0xffffffc00a03252c:
[2024/1/11 16:15:42 789] [ 2.575575] 232c ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 789] [ 2.575585] 234c 00000000 00000000 00000000 00000000 00000000 0a032360 ffffffc0 0a032360
[2024/1/11 16:15:42 789] [ 2.575595] 236c ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 789] [ 2.575605] 238c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 789] [ 2.575615] 23ac 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 00000000
[2024/1/11 16:15:42 800] [ 2.575625] 23cc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 800] [ 2.575634] 23ec 00000000 0a0323f0 ffffffc0 0a0323f0 ffffffc0 00000000 00000000 00000000
[2024/1/11 16:15:42 800] [ 2.575644] 240c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 800] [ 2.575654] 242c 00000000 08be326c ffffff80 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 800] [ 2.575664] 244c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 801] [ 2.575673] 246c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 801] [ 2.575683] 248c 00000000 00040000 00000001 00000000 00000004 00000000 00000000 00000000
[2024/1/11 16:15:42 801] [ 2.575693] 24ac 00000400 0000000a 00002000 00000000 00000000 9b010059 32503033 3200b1de
[2024/1/11 16:15:42 801] [ 2.575703] 24cc 572c7a00 d04f0132 8f5903ff ffffffef 8a400000 00000000 00000000 00000000
[2024/1/11 16:15:42 801] [ 2.575713] 24ec 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 801] [ 2.575722] 250c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000009b
[2024/1/11 16:15:42 801] [ 2.575732] 252c* 30503259 00003233 00000000 b1de572c 07e70100 00070000 08f50403 00000064
[2024/1/11 16:15:42 801] [ 2.575742] 254c 02625a00 00000000 00000002 017d7840 00000400 00000009 00000009 00200000
[2024/1/11 16:15:42 801] [ 2.575752] 256c 00000000 01550108 00010015 00003c20 00000172 00200000 00000172 000009f6
[2024/1/11 16:15:42 801] [ 2.575762] 258c 00000001 03197500 0bebc200 03a3e000 00000400 000005dc 000000f7 000000f7
[2024/1/11 16:15:42 801] [ 2.575772] 25ac 000005dc 00000000 00000000 ffffffea ffffffff ffffffea 00000400 00000101
[2024/1/11 16:15:42 815] [ 2.575782] 25cc 0000000d 00000001 00000200 00001000 00000000 01000101 00000020 00000d0c
[2024/1/11 16:15:42 815] [ 2.575791] 25ec 00000000 00800700 1f570201 00000072 05101500 55f7f701 00000005 00000000
[2024/1/11 16:15:42 815] [ 2.575802] 260c 0103a3e0 00000101 00000001 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 815] [ 2.575812] 262c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 815] [ 2.575821] 264c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 815] [ 2.575831] 266c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 815] [ 2.575841] 268c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 815] [ 2.575850] 26ac 00000000 00000000 00000013 00000000 00000000 799f4ee0 ffffffc0 00400000
[2024/1/11 16:15:42 816] [ 2.575860] 26cc 00000000 00000001 746f6f62 00000030 00000000 00000000 00000000 00000001
[2024/1/11 16:15:42 816] [ 2.575870] 26ec 00000002 00400000 00000000 00000002 746f6f62 00000031 00000000 00000000
[2024/1/11 16:15:42 816] [ 2.575879] 270c 00000000 00000001 00000002 01000000 00000000 00000003 626d7072 00000000
[2024/1/11 16:15:42 816] [ 2.575891]
[2024/1/11 16:15:42 816] [ 2.575891] X28: 0xffffffc00a032000:
[2024/1/11 16:15:42 816] [ 2.575892] 1e00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 816] [ 2.575902] 1e20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 816] [ 2.575911] 1e40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 816] [ 2.575921] 1e60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 816] [ 2.575931] 1e80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 816] [ 2.575940] 1ea0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 816] [ 2.575950] 1ec0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.575960] 1ee0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.575969] 1f00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.575979] 1f20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.575989] 1f40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.575998] 1f60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.576008] 1f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.576018] 1fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.576027] 1fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.576037] 1fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.576047] 2000* 0a0ea000 ffffffc0 0a0ea008 ffffffc0 0a7b3400 ffffffc0 0a18bd80 ffffffc0
[2024/1/11 16:15:42 836] [ 2.576057] 2020 7ac82028 ffffffc0 77ccc018 ffffffc0 0a0ea018 ffffffc0 7bbfe400 ffffffc0
[2024/1/11 16:15:42 836] [ 2.576067] 2040 09814f08 ffffff80 0a18aee0 ffffffc0 00000007 00000007 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.576077] 2060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.576086] 2080 09869110 ffffff80 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[2024/1/11 16:15:42 836] [ 2.576096] 20a0 00000000 00000000 00000000 00000000 7b01ee40 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.576106] 20c0 09868f18 ffffff80 09869bf0 ffffff80 00000000 00000000 0a29cc00 ffffffc0
[2024/1/11 16:15:42 836] [ 2.576116] 20e0 0a0320e0 ffffffc0 0a0320e0 ffffffc0 0a0320f0 ffffffc0 0a0320f0 ffffffc0
[2024/1/11 16:15:42 836] [ 2.576126] 2100 0a032100 ffffffc0 0a032100 ffffffc0 0a032110 ffffffc0 0a032110 ffffffc0
[2024/1/11 16:15:42 836] [ 2.576136] 2120 00000000 00000001 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 836] [ 2.576146] 2140 00000000 00000000 00000000 00000106 00000000 00000000 00000000 dead4ead
[2024/1/11 16:15:42 837] [ 2.576155] 2160 ffffffff 00000000 ffffffff ffffffff 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 837] [ 2.576165] 2180 00000000 00000000 00000000 00000000 00000000 00000000 7ac821a0 ffffffc0
[2024/1/11 16:15:42 837] [ 2.576175] 21a0 77ccc190 ffffffc0 ffffffff 00000000 00000000 dead4ead ffffffff 00000000
[2024/1/11 16:15:42 837] [ 2.576185] 21c0 ffffffff ffffffff 0a0321c8 ffffffc0 0a0321c8 ffffffc0 00000000 00000000
[2024/1/11 16:15:42 837] [ 2.576195] 21e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[2024/1/11 16:15:42 837] [ 2.576208] Code: d112a042 aa0203e1 f9000462 b40000e1 (f9403841)
rk3568_log.zip (33.6 KB)
