固件文件名称:RK356X/RK3588 RKNN SDK
Log日志:228启动.txt
拉12路流,板子会不定期异常重启,并且重启后会挂死,串口网口均无法连接,麻烦大佬帮忙看看是啥原因了
[ 51.648319] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2637 session 2637:2 count 1 cur_task 00000000a3d3d693 id 3333
[ 156.438411] rkvdec2_ccu_link_timeout_work:1566: task timeout
PANIC at PC : 0x00000000000602a8DDR V1.09 a930779e06 typ 22/11/21-17:50:56 -------异常重启(都有rkvdec2_ccu_link_timeout_work打印)
LPDDR4, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
Manufacturer ID:0xff
CH0 RX Vref:28.7%, TX Vref:12.2%,0.0%
CH1 RX Vref:28.7%, TX Vref:12.2%,0.0%
CH2 RX Vref:28.7%, TX Vref:12.2%,0.0%
CH3 RX Vref:28.7%, TX Vref:12.2%,0.0%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-gc060f28d70-220414 #zyf (Apr 18 2022 - 18:13:34)
Failed to set cpub01
Failed to set cpub23
unknown raw ID phN
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 2
spl: mmc init failed with error: -123
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(bb1bbbc832…) + OK
## Checking uboot 0x00200000 … sha256(17637c0a6e…) + OK
## Checking fdt 0x0035d928 … sha256(c07f4a4d71…) + OK
## Checking atf-2 0x000f0000 … sha256(30812190d0…) + OK
## Checking atf-3 0xff100000 … sha256(cb7bdbec2b…) + OK
## Checking optee 0x08400000 … sha256(fde0860845…) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 181.97 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-499-ge63a16361:derrick.huang
NOTICE: BL31: Built : 10:58:38, Jan 10 2023
INFO: spec: 0x1
INFO: ext 32k is not valid
INFO: ddr: stride-en 4CH
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing BL32
INFO: hdmirx_handler: dma not on, ret
I/TC:
I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022年 09月 20日 星期二 09:41:09 CST aarch64
INFO: SPSR = 0x3c9
U-Boot 2017.09(u-boot commit id: f2154d648)(sdk version: .xml) (Dec 11 2023 - 16:58:52 +0800)
Model: Rockchip RK3588 Evaluation Board
PreSerial: 2, raw, 0xfeb50000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: eda19000
Relocation fdt: eb9fa5f8 - eb9fecd0
CR: M/C/I
Hotkey: ctrl+m
mmc@fe2c0000: 1, mmc@fe2e0000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
DM: v2
boot mode: None
=================begin===================
163234 bytes read in 15 ms (10.4 MiB/s)
DTB(Distro): rk-kernel.dtb
I2c0 speed: 100000Hz
vsel-gpios- not found!
en-gpios- not found!
vdd_cpu_big0_s0 1000000 uV
vdd_cpu_big1_s0 1000000 uV
I2c1 speed: 100000Hz
vdd_npu_s0 812500 uV
spi2: RK806: 2
ON=0x00, OFF=0x00
vdd_gpu_s0 750000 uV
vdd_cpu_lit_s0 750000 uV
vdd_log_s0 750000 uV
vdd_vdenc_s0 init 750000 uV
vdd_ddr_s0 850000 uV
Firefly fixed_regulator_set_enable: dev=‘vcc-hub-reset-regulator’, enable=1, delay=0, has_gpio=0
Firefly fixed_regulator_set_enable: dev=‘vbus-typec0-pwr-en-regulator’, enable=1, delay=0, has_gpio=0
Firefly fixed_regulator_set_enable: dev=‘vbus-typec1-pwr-en-regulator’, enable=1, delay=0, has_gpio=0
Firefly fixed_regulator_set_enable: dev=‘vcc-sdcard-pwr-en-regulator’, enable=1, delay=0, has_gpio=0
get vp0 plane mask:0x5, primary id:2, cursor_plane:-1, from dts
get vp1 plane mask:0xa, primary id:3, cursor_plane:-1, from dts
get vp2 plane mask:0x140, primary id:8, cursor_plane:-1, from dts
get vp3 plane mask:0x280, primary id:9, cursor_plane:-1, from dts
Model: Firefly AIO-3588Q MIPI101(Linux)
No resource partition
No file: logo.bmp
512 bytes read in 6 ms (83 KiB/s)
logo(Distro): logo.bmp
6220854 bytes read in 42 ms (141.3 MiB/s)
vp0 have layer nr:2[0 2 ], primary plane: 2
vp1 have layer nr:2[1 3 ], primary plane: 3
vp2 have layer nr:2[6 8 ], primary plane: 8
vp3 have layer nr:2[7 9 ], primary plane: 9
hdmi@fde80000 disconnected
CLK: (uboot. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 24000 KHz
b1pll 24000 KHz
lpll 24000 KHz
v0pll 24000 KHz
aupll 786431 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 850000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 594000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Net: eth0: ethernet@fe1b0000, eth1: ethernet@fe1c0000
optee api revision: 2.0
Not AVB images, AVB skip
No valid android hdr
Android image load failed
## Booting FIT Image FIT: No fit blob
FIT: No FIT image
Unknown command ‘bootrkp’ - try ‘help’
switch to partitions #0, OK
Scanning mmc 0:3…
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
104 bytes read in 8 ms (12.7 KiB/s)
FIREFLY: use /rk-kernel.dtb
1: rk-kernel.dtb linux-5.10.110
Retrieving file: /initrd-5.10.110
9233322 bytes read in 58 ms (151.8 MiB/s)
Retrieving file: /Image-5.10.110
44507648 bytes read in 306 ms (138.7 MiB/s)
Retrieving file: /rk-kernel.dtb
163234 bytes read in 14 ms (11.1 MiB/s)
Fdt Ramdisk skip relocation
bidram_dump_all:
memory.rgn[0].addr = 0x00000000 - 0xf0000000 (size: 0xf0000000)
memory.total = 0xf0000000 (3840 MiB. 0 KiB)
reserved.rgn[0].name = "ATF"
.addr = 0x00000000 - 0x00100000 (size: 0x00100000)
reserved.rgn[1].name = "SHM"
.addr = 0x00100000 - 0x00200000 (size: 0x00100000)
reserved.rgn[2].name = "OPTEE"
.addr = 0x08400000 - 0x09400000 (size: 0x01000000)
reserved.total = 0x01200000 (18 MiB. 0 KiB)
LMB.reserved[0].addr = 0x00000000 - 0x00200000 (size: 0x00200000)
LMB.reserved[1].addr = 0x08400000 - 0x09400000 (size: 0x01000000)
reserved.core.total = 0x01200000 (18 MiB. 0 KiB)
sysmem_dump_all:
memory.rgn[0].addr = 0x00200000 - 0x08400000 (size: 0x08200000)
memory.rgn[1].addr = 0x09400000 - 0xf0000000 (size: 0xe6c00000)
memory.total = 0xeee00000 (3822 MiB. 0 KiB)
allocated.rgn[0].name = "UBOOT"
.addr = 0xeb9fa5e0 - 0xf0000000 (size: 0x04605a20)
allocated.rgn[1].name = "STACK"
.addr = 0xeb7fa5e0 - 0xeb9fa5e0 (size: 0x00200000)
allocated.rgn[2].name = "FDT"
.addr = 0x08300000 - 0x0832ae04 (size: 0x0002ae04)
kmem-resv.rgn[0].name = "cma"
.addr = 0x10000000 - 0x20000000 (size: 0x10000000)
kmem-resv.rgn[1].name = "ramoops@110000"
.addr = 0x00110000 - 0x00200000 (size: 0x000f0000)
framework malloc_r = 32 MiB
framework malloc_f = 512 KiB
allocated.total = 0x14920824 (329 MiB. 130 KiB)
LMB.allocated[0].addr = 0x08300000 - 0x0832ae04 (size: 0x0002ae04)
LMB.allocated[1].addr = 0xeb7fa5e0 - 0xf0000000 (size: 0x04805a20)
reserved.core.total = 0x04830824 (72 MiB. 194 KiB)
## Flattened Device Tree blob at 0x08300000
Booting using the fdt blob at 0x08300000
‘reserved-memory’ cma: addr=10000000 size=10000000
Using Device Tree in place at 0000000008300000, end 000000000832ada1
No file: logo_kernel.bmp
512 bytes read in 7 ms (71.3 KiB/s)
logo(Distro): logo_kernel.bmp
Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000)
Total: 4371.252 ms
[ 5.066995] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 5.067020] Linux version 5.10.110 (zhut@indgw) (kernel commit id: f2154d648) (sdk version: .xml) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #3 SMP Mon Dec 11 17:04:52 CST 2023
[ 5.074686] Machine model: Firefly AIO-3588Q MIPI101(Linux)
[ 5.074769] earlycon: uart8250 at MMIO32 0x00000000feb50000 (options ‘’)
[ 5.124422] printk: bootconsole [uart8250] enabled
[ 5.131000] efi: UEFI not found.
[ 5.138351] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 5.150530] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB
[ 5.158674] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[ 5.233990] Zone ranges:
[ 5.236545] DMA [mem 0x0000000000200000-0x00000000ffffffff]
[ 5.242761] DMA32 empty
[ 5.245671] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 5.251884] Movable zone start for each node
[ 5.256291] Early memory node ranges
[ 5.259877] node 0: [mem 0x0000000000200000-0x00000000083fffff]
[ 5.266132] node 0: [mem 0x0000000009400000-0x00000000efffffff]
[ 5.272466] node 0: [mem 0x00000001f0000000-0x00000001ffffffff]
[ 5.278765] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[ 5.310545] psci: probing for conduit method from DT.
[ 5.315654] psci: PSCIv1.1 detected in firmware.
[ 5.320417] psci: Using standard PSCI v0.2 function IDs
[ 5.325729] psci: Trusted OS migration not required
[ 5.330694] psci: SMC Calling Convention v1.2
[ 5.335546] percpu: Embedded 32 pages/cpu s93352 r8192 d29528 u131072
[ 5.342304] Detected VIPT I-cache on CPU0
[ 5.346417] CPU features: detected: GIC system register CPU interface
[ 5.352951] CPU features: detected: Virtualization Host Extensions
[ 5.359331] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 5.366357] alternatives: patching kernel code
[ 5.373116] Built 1 zonelists, mobility grouping on. Total pages: 1027656
[ 5.380027] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=/mmc@fe2e0000 androidboot.verifiedbootstate=orange ro rootwait earlycon=uart8250,mmio32,0xfeb50000 console=ttyFIQ0 irqchip.gicv3_pseudo_nmi=0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 5.418647] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 5.426972] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 5.434840] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 5.447667] software IO TLB: mapped [mem 0x00000000e9f00000-0x00000000edf00000] (64MB)
[ 5.490086] Memory: 3688444K/4175872K available (22848K kernel code, 3848K rwdata, 8916K rodata, 7744K init, 678K bss, 225284K reserved, 262144K cma-reserved)
[ 5.504421] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 5.511050] ftrace: allocating 69291 entries in 271 pages
[ 5.618881] ftrace: allocated 271 pages with 5 groups
[ 5.624394] rcu: Hierarchical RCU implementation.
[ 5.629204] rcu: RCU event tracing is enabled.
[ 5.633811] Rude variant of Tasks RCU enabled.
[ 5.638340] Tracing variant of Tasks RCU enabled.
[ 5.643233] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 5.656256] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 5.663796] GICv3: GIC: Using split EOI/Deactivate mode
[ 5.669021] GICv3: 480 SPIs implemented
[ 5.672901] GICv3: 0 Extended SPIs implemented
[ 5.677454] GICv3: Distributor has no Range Selector support
[ 5.683116] GICv3: 16 PPIs implemented
[ 5.686948] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000
[ 5.694040] ITS [mem 0xfe640000-0xfe65ffff]
[ 5.698440] ITS@0x00000000fe640000: allocated 8192 Devices @1f0220000 (indirect, esz 8, psz 64K, shr 0)
[ 5.708103] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @1f0230000 (flat, esz 2, psz 64K, shr 0)
[ 5.718573] ITS: using cache flushing for cmd queue
[ 5.723582] ITS [mem 0xfe660000-0xfe67ffff]
[ 5.727924] ITS@0x00000000fe660000: allocated 8192 Devices @1f0250000 (indirect, esz 8, psz 64K, shr 0)
[ 5.737568] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @1f0260000 (flat, esz 2, psz 64K, shr 0)
[ 5.748186] ITS: using cache flushing for cmd queue
[ 5.753193] GICv3: using LPI property table @0x00000001f0270000
[ 5.759282] GIC: using cache flushing for LPI property table
[ 5.765003] GICv3: CPU0: using allocated LPI pending table @0x00000001f0280000
[ 5.772627] random: get_random_bytes called from start_kernel+0x3f0/0x65c with crng_init=0
[ 5.884656] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 5.900096] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 5.911686] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 5.921182] Console: colour dummy device 80x25
[ 5.926020] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 5.937080] pid_max: default: 32768 minimum: 301
[ 5.942125] LSM: Security Framework initializing
[ 5.947136] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 5.955115] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 5.965104] rcu: Hierarchical SRCU implementation.
[ 5.971234] Platform MSI: msi-controller@fe640000 domain created
[ 5.977739] Platform MSI: msi-controller@fe660000 domain created
[ 5.984487] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created
[ 5.993369] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created
[ 6.002326] EFI services will not be available.
[ 6.007513] smp: Bringing up secondary CPUs …
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
[ 6.020601] Detected VIPT I-cache on CPU1
[ 6.020627] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000
[ 6.020642] GICv3: CPU1: using allocated LPI pending table @0x00000001f0290000
[ 6.020684] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 6.028997] Detected VIPT I-cache on CPU2
[ 6.029019] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000
[ 6.029034] GICv3: CPU2: using allocated LPI pending table @0x00000001f02a0000
[ 6.029072] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 6.037352] Detected VIPT I-cache on CPU3
[ 6.037372] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000
[ 6.037385] GICv3: CPU3: using allocated LPI pending table @0x00000001f02b0000
[ 6.037422] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 6.045689] CPU features: detected: Spectre-v4
[ 6.045691] CPU features: detected: Spectre-BHB
[ 6.045693] Detected PIPT I-cache on CPU4
[ 6.045703] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000
[ 6.045710] GICv3: CPU4: using allocated LPI pending table @0x00000001f02c0000
[ 6.045732] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0]
[ 6.053958] Detected PIPT I-cache on CPU5
[ 6.053969] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000
[ 6.053976] GICv3: CPU5: using allocated LPI pending table @0x00000001f02d0000
[ 6.053998] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0]
[ 6.062222] Detected PIPT I-cache on CPU6
[ 6.062233] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000
[ 6.062240] GICv3: CPU6: using allocated LPI pending table @0x00000001f02e0000
[ 6.062261] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0]
[ 6.070488] Detected PIPT I-cache on CPU7
[ 6.070499] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000
[ 6.070506] GICv3: CPU7: using allocated LPI pending table @0x00000001f02f0000
[ 6.070528] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0]
[ 6.070584] smp: Brought up 1 node, 8 CPUs
[ 6.270719] SMP: Total of 8 processors activated.
[ 6.275801] CPU features: detected: Privileged Access Never
[ 6.281731] CPU features: detected: User Access Override
[ 6.287444] CPU features: detected: 32-bit EL0 Support
[ 6.293010] CPU features: detected: Common not Private translations
[ 6.299755] CPU features: detected: RAS Extension Support
[ 6.305512] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 6.314736] CPU features: detected: CRC32 instructions
[ 6.320240] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 6.327724] CPU features: detected: RCpc load-acquire (LDAPR)
[ 6.333958] CPU: All CPU(s) started at EL2
[ 6.339386] devtmpfs: initialized
[ 6.349266] Registered cp15_barrier emulation handler
[ 6.354591] Registered setend emulation handler
[ 6.359468] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 6.369687] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 6.377126] pinctrl core: initialized pinctrl subsystem
[ 6.382820] DMI not present or invalid.
[ 6.386983] NET: Registered protocol family 16
[ 6.392363] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 6.399985] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 6.408261] audit: initializing netlink subsys (disabled)
[ 6.414075] audit: type=2000 audit(0.316:1): state=initialized audit_enabled=0 res=1
[ 6.414425] thermal_sys: Registered thermal governor ‘fair_share’
[ 6.422307] thermal_sys: Registered thermal governor ‘step_wise’
[ 6.428777] thermal_sys: Registered thermal governor ‘user_space’
[ 6.435152] thermal_sys: Registered thermal governor ‘power_allocator’
[ 6.441729] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 6.457044] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 6.465473] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
[ 6.474015] thermal thermal_zone4: power_allocator: sustainable_power will be estimated
[ 6.482487] thermal thermal_zone5: power_allocator: sustainable_power will be estimated
[ 6.491043] thermal thermal_zone6: power_allocator: sustainable_power will be estimated
[ 6.499502] cpuidle: using governor menu
[ 6.503653] Registered FIQ tty driver
[ 6.507614] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 6.514838] ASID allocator initialised with 65536 entries
[ 6.521418] ramoops: dmesg-0 0x20000@0x0000000000110000
[ 6.526893] ramoops: console 0x80000@0x0000000000130000
[ 6.532388] ramoops: pmsg 0x50000@0x00000000001b0000
[ 6.537819] printk: console [ramoops-1] enabled
[ 6.542572] pstore: Registered ramoops as persistent store backend
[ 6.549145] ramoops: using 0xf0000@0x110000, ecc: 0
[ 6.580353] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000
[ 6.587450] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000
[ 6.594447] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000
[ 6.601512] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000
[ 6.608597] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000
[ 6.615519] rockchip-pinctrl pinctrl: probed pinctrl
[ 6.626519] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 6.633620] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 6.640757] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 6.647816] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 6.712131] raid6: neonx8 gen() 6884 MB/s
[ 6.772194] raid6: neonx8 xor() 5397 MB/s
[ 6.832260] raid6: neonx4 gen() 6759 MB/s
[ 6.892322] raid6: neonx4 xor() 5703 MB/s
[ 6.952387] raid6: neonx2 gen() 6443 MB/s
[ 7.012450] raid6: neonx2 xor() 5096 MB/s
[ 7.072517] raid6: neonx1 gen() 5271 MB/s
[ 7.132579] raid6: neonx1 xor() 4487 MB/s
[ 7.192650] raid6: int64x8 gen() 3210 MB/s
[ 7.252711] raid6: int64x8 xor() 1900 MB/s
[ 7.312774] raid6: int64x4 gen() 3676 MB/s
[ 7.372840] raid6: int64x4 xor() 1906 MB/s
[ 7.432895] raid6: int64x2 gen() 3063 MB/s
[ 7.492957] raid6: int64x2 xor() 1653 MB/s
[ 7.553017] raid6: int64x1 gen() 2514 MB/s
[ 7.613083] raid6: int64x1 xor() 1319 MB/s
[ 7.617577] raid6: using algorithm neonx8 gen() 6884 MB/s
[ 7.623284] raid6: … xor() 5397 MB/s, rmw enabled
[ 7.628514] raid6: using neon recovery algorithm
[ 7.633893] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 7.639635] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 7.645664] fiq_debugger_probe: could not install nmi irq handler
[[ 7.652142] printk: console [ttyFIQ0] enabled
[ 7.661058] printk: bootconsole [uart8250] disabled
[ 7.666264] Registered fiq debugger ttyFIQ0
[ 7.666520] vcc5v0_sys: supplied by vcc12v_dcin
[ 7.666596] vcc5v0_usbdcin: supplied by vcc12v_dcin
[ 7.666663] vcc5v0_usb: supplied by vcc12v_dcin
[ 7.666732] vcc_1v1_nldo_s3: supplied by vcc5v0_sys
[ 7.666809] vcc5v0_host: supplied by vcc5v0_usb
[ 7.667065] vcc5v0_host3: supplied by vcc5v0_usb
[ 7.667142] vcc_sata_pwr_en: supplied by vcc12v_dcin
[ 7.676360] vcc3v3_pcie30: supplied by vcc12v_dcin
[ 7.676581] iommu: Default domain type: Passthrough
[ 7.676633] rk_iommu fdab9000.iommu: version = 2
[ 7.676885] rk_iommu fdb50800.iommu: version = 2
[ 7.677069] rk_iommu fdb60f00.iommu: version = 2
[ 7.677199] rk_iommu fdb70f00.iommu: version = 2
[ 7.677316] rk_iommu fdb90480.iommu: version = 2
[ 7.677456] rk_iommu fdba0800.iommu: version = 2
[ 7.677592] rk_iommu fdba4800.iommu: version = 2
[ 7.677732] rk_iommu fdba8800.iommu: version = 2
[ 7.677872] rk_iommu fdbac800.iommu: version = 2
[ 7.678010] rk_iommu fdbb0800.iommu: version = 2
[ 7.678149] rk_iommu fdbdf000.iommu: version = 2
[ 7.678347] rk_iommu fdbef000.iommu: version = 2
[ 7.678561] rk_iommu fdc38700.iommu: version = 2
[ 7.678781] rk_iommu fdc48700.iommu: version = 2
[ 7.678881] rk_iommu fdd97e00.iommu: version = 2
[ 7.679096] usbcore: registered new interface driver usbfs
[ 7.679107] usbcore: registered new interface driver hub
[ 7.679118] usbcore: registered new device driver usb
[ 7.679144] mc: Linux media interface: v0.10
[ 7.679152] videodev: Linux video capture interface: v2.00
[ 7.679169] pps_core: LinuxPPS API ver. 1 registered
[ 7.679172] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 7.679177] PTP clock support registered
[ 7.679359] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 7.679387] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 7.680091] Advanced Linux Sound Architecture Driver Initialized.
[ 7.680233] Bluetooth: Core ver 2.22
[ 7.680242] NET: Registered protocol family 31
[ 7.680245] Bluetooth: HCI device and connection manager initialized
[ 7.680249] Bluetooth: HCI socket layer initialized
[ 7.680253] Bluetooth: L2CAP socket layer initialized
[ 7.680258] Bluetooth: SCO socket layer initialized
[ 7.681507] rockchip-cpuinfo cpuinfo: SoC : 35881000
[ 7.681512] rockchip-cpuinfo cpuinfo: Serial : e9e5db0d91301df3
[ 7.681722] clocksource: Switched to clocksource arch_sys_counter
[ 7.893122] NET: Registered protocol family 2
[ 7.893194] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 7.894068] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes, linear)
[ 7.894107] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 7.894257] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 7.894579] TCP: Hash tables configured (established 32768 bind 32768)
[ 7.894619] UDP hash table entries: 2048 (order: 5, 196608 bytes, linear)
[ 7.894685] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes, linear)
[ 7.894789] NET: Registered protocol family 1
[ 7.895045] RPC: Registered named UNIX socket transport module.
[ 7.895054] RPC: Registered udp transport module.
[ 7.895056] RPC: Registered tcp transport module.
[ 7.895058] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 7.895368] PCI: CLS 0 bytes, default 64
[ 7.895587] Trying to unpack rootfs image as initramfs…
[ 8.069826] Freeing initrd memory: 9016K
[ 8.070390] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 8.070814] kvm [1]: IPA Size Limit: 40 bits
[ 8.070826] kvm [1]: GICv3: no GICV resource entry
[ 8.070829] kvm [1]: disabling GICv2 emulation
[ 8.070831] kvm [1]: GIC system register CPU interface enabled
[ 8.070937] kvm [1]: vgic interrupt IRQ9
[ 8.071073] kvm [1]: VHE mode initialized successfully
[ 8.073570] Initialise system trusted keyrings
[ 8.073648] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 8.075175] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 8.075387] NFS: Registering the id_resolver key type
[ 8.075395] Key type id_resolver registered
[ 8.075397] Key type id_legacy registered
[ 8.075403] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 8.075948] Key type cifs.spnego registered
[ 8.075953] Key type cifs.idmap registered
[ 8.075957] ntfs: driver 2.1.32 [Flags: R/O].
[ 8.075997] jffs2: version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
[ 8.076066] fuse: init (API version 7.32)
[ 8.076191] SGI XFS with security attributes, no debug enabled
[ 8.093252] NET: Registered protocol family 38
[ 8.093258] xor: measuring software checksum speed
[ 8.094414] 8regs : 8550 MB/sec
[ 8.095377] 32regs : 10260 MB/sec
[ 8.096094] arm64_neon : 13852 MB/sec
[ 8.096096] xor: using function: arm64_neon (13852 MB/sec)
[ 8.096101] Key type asymmetric registered
[ 8.096103] Asymmetric key parser ‘x509’ registered
[ 8.096116] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 8.096194] io scheduler mq-deadline registered
[ 8.096199] io scheduler kyber registered
[ 8.102219] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success
[ 8.103216] Firefly gpio driver init!
[ 8.103285] Firefly gpio driver register return : 0
[ 8.104023] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node
[ 8.104148] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node
[ 8.104177] rk-pcie fe170000.pcie: no vpcie3v3 regulator found
[ 8.104319] iep: Module initialized.
[ 8.104360] mpp_service mpp-srv: 789d8d341
[ 8.104364] mpp_service mpp-srv: probe start
[ 8.104420] rk-pcie fe190000.pcie: missing legacy IRQ resource
[ 8.104441] rk-pcie fe190000.pcie: IRQ msi not found
[ 8.104449] rk-pcie fe190000.pcie: use outband MSI support
[ 8.104458] rk-pcie fe190000.pcie: Missing config reg space
[ 8.104475] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges:
[ 8.104484] rk-pcie fe170000.pcie: missing legacy IRQ resource
[ 8.104500] rk-pcie fe190000.pcie: err 0x00f4000000..0x00f40fffff → 0x00f4000000
[ 8.104505] rk-pcie fe170000.pcie: IRQ msi not found
[ 8.104509] rk-pcie fe170000.pcie: use outband MSI support
[ 8.104514] rk-pcie fe170000.pcie: Missing config reg space
[ 8.104524] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges:
[ 8.104536] rk-pcie fe190000.pcie: IO 0x00f4100000..0x00f41fffff → 0x00f4100000
[ 8.104547] rk-pcie fe170000.pcie: err 0x00f2000000..0x00f20fffff → 0x00f2000000
[ 8.104557] rk-pcie fe190000.pcie: MEM 0x00f4200000..0x00f4ffffff → 0x00f4200000
[ 8.104565] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff → 0x00f2100000
[ 8.104581] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff → 0x00f2200000
[ 8.104585] rk-pcie fe190000.pcie: MEM 0x0a00000000..0x0a3fffffff → 0x0a00000000
[ 8.104604] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff → 0x0980000000
[ 8.104612] rk-pcie fe190000.pcie: Missing config reg space
[ 8.104634] rk-pcie fe170000.pcie: Missing config reg space
[ 8.104643] rk-pcie fe190000.pcie: invalid resource
[ 8.104664] rk-pcie fe170000.pcie: invalid resource
[ 8.105644] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1
[ 8.105662] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.105820] mpp_vdpu2 fdb50400.vdpu: probe device
[ 8.105896] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 8.105901] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 8.105999] mpp_vdpu2 fdb50400.vdpu: probing finish
[ 8.106145] mpp_vepu2 jpege-ccu: probing start
[ 8.106148] mpp_vepu2 jpege-ccu: probing finish
[ 8.106228] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5
[ 8.106237] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.106351] mpp_vepu2 fdba0000.jpege-core: probing start
[ 8.106425] mpp_vepu2 fdba0000.jpege-core: attach ccu success
[ 8.106516] mpp_vepu2 fdba0000.jpege-core: probing finish
[ 8.106584] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6
[ 8.106594] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.106706] mpp_vepu2 fdba4000.jpege-core: probing start
[ 8.106778] mpp_vepu2 fdba4000.jpege-core: attach ccu success
[ 8.106871] mpp_vepu2 fdba4000.jpege-core: probing finish
[ 8.106938] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7
[ 8.106946] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.107072] mpp_vepu2 fdba8000.jpege-core: probing start
[ 8.107137] mpp_vepu2 fdba8000.jpege-core: attach ccu success
[ 8.107228] mpp_vepu2 fdba8000.jpege-core: probing finish
[ 8.107303] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8
[ 8.107312] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.107423] mpp_vepu2 fdbac000.jpege-core: probing start
[ 8.107487] mpp_vepu2 fdbac000.jpege-core: attach ccu success
[ 8.107574] mpp_vepu2 fdbac000.jpege-core: probing finish
[ 8.107770] mpp-iep2 fdbb0000.iep: Adding to iommu group 9
[ 8.107779] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.107889] mpp-iep2 fdbb0000.iep: probe device
[ 8.107972] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 8.108058] mpp-iep2 fdbb0000.iep: probing finish
[ 8.108213] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4
[ 8.108221] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.108376] mpp_jpgdec fdb90000.jpegd: probe device
[ 8.108553] mpp_jpgdec fdb90000.jpegd: probing finish
[ 8.108807] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start
[ 8.108845] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish
[ 8.108897] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12
[ 8.108905] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.109094] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start
[ 8.109171] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
[ 8.109174] rkvdec2_init:1010: No niu aclk reset resource define
[ 8.109178] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
[ 8.109180] rkvdec2_init:1013: No niu hclk reset resource define
[ 8.109194] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled
[ 8.109237] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001
[ 8.109240] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0
[ 8.109362] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000
[ 8.109365] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000
[ 8.109368] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520
[ 8.109371] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576
[ 8.109374] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512
[ 8.109393] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish
[ 8.109447] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13
[ 8.109455] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.109630] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start
[ 8.109704] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
[ 8.109707] rkvdec2_init:1010: No niu aclk reset resource define
[ 8.109711] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
[ 8.109713] rkvdec2_init:1013: No niu hclk reset resource define
[ 8.109726] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled
[ 8.109756] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002
[ 8.109771] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1
[ 8.109916] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000
[ 8.109919] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000
[ 8.109922] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424
[ 8.109925] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576
[ 8.109928] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512
[ 8.109946] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish
[ 8.110070] mpp_rkvenc2 rkvenc-ccu: probing start
[ 8.110075] mpp_rkvenc2 rkvenc-ccu: probing finish
[ 8.110153] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10
[ 8.110161] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.110300] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start
[ 8.110313] mpp_rkvenc2 fdbd0000.rkvenc-core: link mode task capacity 8
[ 8.110413] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0
[ 8.110509] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish
[ 8.110547] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11
[ 8.110555] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.110742] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start
[ 8.110754] mpp_rkvenc2 fdbe0000.rkvenc-core: link mode task capacity 8
[ 8.110873] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1
[ 8.110969] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish
[ 8.111337] mpp_av1dec: Adding child /av1d@fdc70000
[ 8.111385] mpp_av1dec: register device av1d-master
[ 8.111404] mpp_av1dec av1d-master: av1_iommu_of_xlate,784
[ 8.111417] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu
[ 8.111440] mpp_av1dec av1d-master: Adding to iommu group 15
[ 8.111448] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.111618] mpp_av1dec av1d-master: probing start
[ 8.111815] mpp_av1dec av1d-master: probing finish
[ 8.111850] mpp_service mpp-srv: probe success
[ 8.116295] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 8.116301] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 8.116872] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 8.116878] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 8.117431] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 8.117436] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 8.117694] rockchip-pvtm fda40000.pvtm: pvtm@0 probed
[ 8.117733] rockchip-pvtm fda50000.pvtm: pvtm@1 probed
[ 8.117767] rockchip-pvtm fda60000.pvtm: pvtm@2 probed
[ 8.117801] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed
[ 8.117832] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed
[ 8.118182] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 8.118511] firefly-gpio: -2 is invalid
[ 8.119069] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 8.119321] fd890000.serial: ttyS0 at MMIO 0xfd890000 (irq = 28, base_baud = 1500000) is a 16550A
[ 8.119613] feb40000.serial: ttyS1 at MMIO 0xfeb40000 (irq = 92, base_baud = 1500000) is a 16550A
[ 8.119822] feb80000.serial: ttyS5 at MMIO 0xfeb80000 (irq = 93, base_baud = 1500000) is a 16550A
[ 8.120023] feb90000.serial: ttyS6 at MMIO 0xfeb90000 (irq = 94, base_baud = 1500000) is a 16550A
[ 8.120931] random: fast init done
[ 8.121019] random: crng init done
[ 8.121486] rockchip-vop2 fdd90000.vop: Adding to iommu group 14
[ 8.121500] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.125757] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 2
[ 8.125767] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 3
[ 8.125778] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 8
[ 8.125784] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 9
[ 8.125839] rockchip-drm display-subsystem: failed to get hdmi1_phy_pll: -517
[ 8.125992] [drm] failed to init overlay plane Cluster0-win1
[ 8.126015] [drm] failed to init overlay plane Cluster1-win1
[ 8.126036] [drm] failed to init overlay plane Cluster2-win1
[ 8.126057] [drm] failed to init overlay plane Cluster3-win1
[ 8.132404] rockchip-drm display-subsystem: bound fdd90000.vop (ops vop2_component_ops)
[ 8.133022] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver
[ 8.133141] rockchip-drm display-subsystem: bound fde80000.hdmi (ops dw_hdmi_rockchip_ops)
[ 8.133633] rockchip-drm display-subsystem: route-hdmi0: failed to get logo,offset
[ 8.133639] rockchip-drm display-subsystem: can’t not find any logo display
[ 8.133644] rockchip-drm display-subsystem: failed to show kernel logo
[ 8.133679] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 8.133716] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 8.134053] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[ 8.138610] brd: module loaded
[ 8.140949] loop: module loaded
[ 8.141112] zram: Added device: zram0
[ 8.141219] lkdtm: No crash points registered, enable through debugfs
[ 8.141553] system_heap: orders[0] = 6
[ 8.141556] system_heap: orders[1] = 4
[ 8.141559] system_heap: orders[2] = 0
[ 8.142849] rockchip-spi feb10000.spi: no high_speed pinctrl state
[ 8.143269] rockchip-spi feb20000.spi: no high_speed pinctrl state
[ 8.144098] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1
[ 8.144221] rk806 spi2.0: ON: 0x40 OFF:0x0
[ 8.145652] vdd_gpu_s0: supplied by vcc5v0_sys
[ 8.146638] vdd_cpu_lit_s0: supplied by vcc5v0_sys
[ 8.147173] vdd_log_s0: supplied by vcc5v0_sys
[ 8.147694] vdd_vdenc_s0: supplied by vcc5v0_sys
[ 8.148265] vdd_ddr_s0: supplied by vcc5v0_sys
[ 8.148604] vdd2_ddr_s3: supplied by vcc5v0_sys
[ 8.149115] vdd_2v0_pldo_s3: supplied by vcc5v0_sys
[ 8.149578] vcc_3v3_s3: supplied by vcc5v0_sys
[ 8.150027] vddq_ddr_s0: supplied by vcc5v0_sys
[ 8.150718] vcc_1v8_s3: supplied by vcc5v0_sys
[ 8.151183] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3
[ 8.151687] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3
[ 8.152141] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3
[ 8.152583] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3
[ 8.153033] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3
[ 8.153571] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 8.154132] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 8.154634] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3
[ 8.155130] vcc_3v3_s0: supplied by vcc5v0_sys
[ 8.155568] vccio_sd_s0: supplied by vcc5v0_sys
[ 8.156012] pldo6_s3: supplied by vcc5v0_sys
[ 8.156413] rk806 spi2.0: no sleep-setting state
[ 8.156417] rk806 spi2.0: no reset-setting pinctrl state
[ 8.156421] rk806 spi2.0: no dvs-setting pinctrl state
[ 8.157952] register firefly_spi_init spi return v = :0
[ 8.158178] wireguard: allowedips self-tests: pass
[ 8.161777] wireguard: nonce counter self-tests: pass
[ 8.309539] rk-pcie fe190000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.335080] rk-pcie fe190000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.361746] rk-pcie fe190000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.361752] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.388417] rk-pcie fe190000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.388432] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.415084] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.415108] rk-pcie fe190000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.441750] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.442277] wireguard: ratelimiter self-tests: pass
[ 8.442346] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 8.442350] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[ 8.442468] (null): ------- begin register mdio bus, phy_mask[0]---------
[ 8.445883] mdio_bus fixed-0: Fixed MDIO Bus already probed
[ 8.446234] ------ rtk_gsw_probe ------
[ 8.446238] ------ can not find mdiobus stmmac-1 ------
[ 8.446258] tun: Universal TUN/TAP device driver, 1.6
[ 8.446379] CAN device driver interface
[ 8.447097] rk_gmac-dwmac fe1b0000.ethernet: IRQ eth_lpi not found
[ 8.447220] rk_gmac-dwmac fe1b0000.ethernet: no regulator found
[ 8.447225] rk_gmac-dwmac fe1b0000.ethernet: clock input or output? (output).
[ 8.447230] rk_gmac-dwmac fe1b0000.ethernet: TX delay(0x47).
[ 8.447234] rk_gmac-dwmac fe1b0000.ethernet: Can not read property: rx_delay.
[ 8.447237] rk_gmac-dwmac fe1b0000.ethernet: set rx_delay to 0xffffffff
[ 8.447248] rk_gmac-dwmac fe1b0000.ethernet: integrated PHY? (no).
[ 8.447253] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_rx
[ 8.447257] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_tx
[ 8.447266] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock clk_mac_speed
[ 8.447481] rk_gmac-dwmac fe1b0000.ethernet: init for RGMII_RXID
[ 8.447608] rk_gmac-dwmac fe1b0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 8.447613] rk_gmac-dwmac fe1b0000.ethernet: DWMAC4/5
[ 8.447618] rk_gmac-dwmac fe1b0000.ethernet: DMA HW capability register supported
[ 8.447621] rk_gmac-dwmac fe1b0000.ethernet: RX Checksum Offload Engine supported
[ 8.447625] rk_gmac-dwmac fe1b0000.ethernet: TX Checksum insertion supported
[ 8.447629] rk_gmac-dwmac fe1b0000.ethernet: Wake-Up On Lan supported
[ 8.447656] rk_gmac-dwmac fe1b0000.ethernet: TSO supported
[ 8.447659] rk_gmac-dwmac fe1b0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 8.447664] rk_gmac-dwmac fe1b0000.ethernet: Enabled Flow TC (entries=2)
[ 8.447667] rk_gmac-dwmac fe1b0000.ethernet: TSO feature enabled
[ 8.447671] rk_gmac-dwmac fe1b0000.ethernet: Using 32 bits DMA width
[ 8.447692] (null): ------- begin register mdio bus, phy_mask[ffffffff]---------
[ 8.468421] rk-pcie fe190000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.578390] mdio_bus stmmac-0: stmmac already probed
[ 8.578395] mdio_bus stmmac-0: find addr 1 from dts
[ 8.581553] mdio_bus stmmac-0: registered phy at address 1
[ 8.582065] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found
[ 8.582154] rk_gmac-dwmac fe1c0000.ethernet: no regulator found
[ 8.582158] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output).
[ 8.582162] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x10).
[ 8.582166] rk_gmac-dwmac fe1c0000.ethernet: RX delay(0x5).
[ 8.582172] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no).
[ 8.582178] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx
[ 8.582182] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx
[ 8.582193] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed
[ 8.582406] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII
[ 8.582510] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 8.582514] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5
[ 8.582519] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported
[ 8.582522] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported
[ 8.582525] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported
[ 8.582528] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported
[ 8.582551] rk_gmac-dwmac fe1c0000.ethernet: TSO supported
[ 8.582554] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 8.582558] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2)
[ 8.582561] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled
[ 8.582565] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width
[ 8.582573] (null): ------- begin register mdio bus, phy_mask[ffffffff]---------
[ 8.655057] mdio_bus stmmac-1: stmmac already probed
[ 8.655061] mdio_bus stmmac-1: find addr 0 from dts
[ 8.658194] mdio_bus stmmac-1: registered phy at address 0
[ 8.658897] PPP generic driver version 2.4.2
[ 8.658990] PPP BSD Compression module registered
[ 8.658994] PPP Deflate Compression module registered
[ 8.659007] PPP MPPE Compression module registered
[ 8.659011] NET: Registered protocol family 24
[ 8.659038] usbcore: registered new interface driver asix
[ 8.659062] usbcore: registered new interface driver ax88179_178a
[ 8.659073] usbcore: registered new interface driver cdc_ether
[ 8.659083] usbcore: registered new interface driver net1080
[ 8.659093] usbcore: registered new interface driver cdc_subset
[ 8.659104] usbcore: registered new interface driver zaurus
[ 8.659118] usbcore: registered new interface driver cdc_ncm
[ 8.659130] usbcore: registered new interface driver qmi_wwan_q
[ 8.659141] usbcore: registered new interface driver qmi_wwan
[ 8.672283] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 8.672310] ehci-pci: EHCI PCI platform driver
[ 8.672377] ehci-platform: EHCI generic platform driver
[ 8.674816] ehci-platform fc800000.usb: EHCI Host Controller
[ 8.674990] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1
[ 8.675137] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000
[ 8.688414] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00
[ 8.688623] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.688636] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.688648] usb usb1: Product: EHCI Host Controller
[ 8.688658] usb usb1: Manufacturer: Linux 5.10.110 ehci_hcd
[ 8.688668] usb usb1: SerialNumber: fc800000.usb
[ 8.689124] hub 1-0:1.0: USB hub found
[ 8.689165] hub 1-0:1.0: 1 port detected
[ 8.692091] ehci-platform fc880000.usb: EHCI Host Controller
[ 8.692253] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2
[ 8.692359] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000
[ 8.705089] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00
[ 8.705279] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.705293] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.705304] usb usb2: Product: EHCI Host Controller
[ 8.705314] usb usb2: Manufacturer: Linux 5.10.110 ehci_hcd
[ 8.705324] usb usb2: SerialNumber: fc880000.usb
[ 8.705741] hub 2-0:1.0: USB hub found
[ 8.705781] hub 2-0:1.0: 1 port detected
[ 8.706848] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 8.706872] ohci-platform: OHCI generic platform driver
[ 8.707215] ohci-platform fc840000.usb: Generic Platform OHCI controller
[ 8.707388] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3
[ 8.707490] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000
[ 8.765813] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 8.765818] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.765822] usb usb3: Product: Generic Platform OHCI controller
[ 8.765826] usb usb3: Manufacturer: Linux 5.10.110 ohci_hcd
[ 8.765829] usb usb3: SerialNumber: fc840000.usb
[ 8.766010] hub 3-0:1.0: USB hub found
[ 8.766023] hub 3-0:1.0: 1 port detected
[ 8.766255] ohci-platform fc8c0000.usb: Generic Platform OHCI controller
[ 8.766327] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4
[ 8.766362] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000
[ 8.825781] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 8.825785] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.825789] usb usb4: Product: Generic Platform OHCI controller
[ 8.825792] usb usb4: Manufacturer: Linux 5.10.110 ohci_hcd
[ 8.825796] usb usb4: SerialNumber: fc8c0000.usb
[ 8.825962] hub 4-0:1.0: USB hub found
[ 8.825974] hub 4-0:1.0: 1 port detected
[ 8.826398] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 8.826475] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 5
[ 8.826555] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000082002010010
[ 8.826572] xhci-hcd xhci-hcd.5.auto: irq 120, io mem 0xfc000000
[ 8.826670] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.826674] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.826678] usb usb5: Product: xHCI Host Controller
[ 8.826682] usb usb5: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.826685] usb usb5: SerialNumber: xhci-hcd.5.auto
[ 8.826846] hub 5-0:1.0: USB hub found
[ 8.826857] hub 5-0:1.0: 1 port detected
[ 8.826940] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 8.827006] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 6
[ 8.827012] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[ 8.827032] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 8.827063] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.827067] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.827070] usb usb6: Product: xHCI Host Controller
[ 8.827074] usb usb6: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.827077] usb usb6: SerialNumber: xhci-hcd.5.auto
[ 8.827230] hub 6-0:1.0: USB hub found
[ 8.827240] hub 6-0:1.0: 1 port detected
[ 8.827374] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 8.827440] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 7
[ 8.827501] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000080002010010
[ 8.827517] xhci-hcd xhci-hcd.6.auto: irq 121, io mem 0xfcd00000
[ 8.827604] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.827608] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.827612] usb usb7: Product: xHCI Host Controller
[ 8.827616] usb usb7: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.827619] usb usb7: SerialNumber: xhci-hcd.6.auto
[ 8.827786] hub 7-0:1.0: USB hub found
[ 8.827797] hub 7-0:1.0: 1 port detected
[ 8.827879] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 8.827941] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 8
[ 8.827947] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
[ 8.827965] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 8.827996] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.827999] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.828003] usb usb8: Product: xHCI Host Controller
[ 8.828007] usb usb8: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.828010] usb usb8: SerialNumber: xhci-hcd.6.auto
[ 8.828165] hub 8-0:1.0: USB hub found
[ 8.828174] hub 8-0:1.0: 1 port detected
[ 8.828313] phy phy-fd5d4000.syscon:usb2-phy@4000.3: illegal mode
[ 8.828319] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 8.828391] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 9
[ 8.828467] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000080002010010
[ 8.828485] xhci-hcd xhci-hcd.7.auto: irq 122, io mem 0xfc400000
[ 8.828579] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.828583] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.828587] usb usb9: Product: xHCI Host Controller
[ 8.828590] usb usb9: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.828593] usb usb9: SerialNumber: xhci-hcd.7.auto
[ 8.828749] hub 9-0:1.0: USB hub found
[ 8.828760] hub 9-0:1.0: 1 port detected
[ 8.828841] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 8.828923] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 10
[ 8.828929] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed
[ 8.828953] usb usb10: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 8.828984] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.828988] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.828991] usb usb10: Product: xHCI Host Controller
[ 8.828994] usb usb10: Manufacturer: Linux 5.10.110 xhci-hcd
[ 8.828997] usb usb10: SerialNumber: xhci-hcd.7.auto
[ 8.829151] hub 10-0:1.0: USB hub found
[ 8.829160] hub 10-0:1.0: 1 port detected
[ 8.829290] usbcore: registered new interface driver cdc_acm
[ 8.829293] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 8.829307] usbcore: registered new interface driver cdc_wdm
[ 8.829335] usbcore: registered new interface driver usbserial_generic
[ 8.829345] usbserial: USB Serial support registered for generic
[ 8.829360] usbcore: registered new interface driver ch341
[ 8.829367] usbserial: USB Serial support registered for ch341-uart
[ 8.829383] usbcore: registered new interface driver cp210x
8.829390]Loading, please wait…
usbserial: USB Serial support registered for cp210x
[ 8.829423] usbc/dev/console is Ok
ore: registered new interface driver usb_ch9344
[ 8.829426] ch9344: USB serial driver for ch9344/ch348.
[ 8.829429] ch9344: V2.1Beta On 2023.11
[ 8.829440] usbcore: registered new interface driver ftdi_sio
[ 8.829448] usstarting version 237
bserial: USB Serial support registered for FTDI USB Serial Device
[ 8.829522] usbcore: registered new interface driver keyspan
[ 8.829529] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 8.829536] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 8.829543] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 8.829551] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 8.829567] usbcore: registered new interface driver option
[ 8.829574] usbserial: USB Serial support registered for GSM modem (1-port)
[ 8.829676] usbcore: registered new interface driver oti6858
[ 8.829683] usbserial: USB Serial support registered for oti6858
[ 8.829699] usbcore: registered new interface driver pl2303
[ 8.829706] usbserial: USB Serial support registered for pl2303
[ 8.829727] usbcore: registered new interface driver qcserial
[ 8.829733] usbserial: USB Serial support registered for Qualcomm USB modem
[ 8.829759] usbcore: registered new interface driver sierra
[ 8.829766] usbserial: USB Serial support registered for Sierra USB modem
[ 8.830098] [HXTP] himax_hx83102_init
[ 8.830102] [HXTP] himax_hx83102_probe:Enter
[ 8.830105] [HXTP] Himax common touch panel driver init
[ 8.830147] usbcore: registered new interface driver usbtouchscreen
[ 8.831133] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.3.auto/input/input0
[ 8.831354] i2c /dev entries driver
[ 8.834063] vdd_cpu_big0_s0: supplied by vcc5v0_sys
[ 8.841842] vdd_cpu_big1_s0: supplied by vcc5v0_sys
[ 8.850002] vdd_npu_s0: supplied by vcc5v0_sys
[ 8.856029] pca953x 6-0023: supply vcc not found, using dummy regulator
[ 8.856065] pca953x 6-0023: using no AI
[ 8.858187] rtc-rx8010 6-0032: registered as rtc0
[ 8.858576] rtc-rx8010 6-0032: setting system clock to 2024-01-29T01:56:36 UTC (1706493396)
[ 8.858956] pca953x 7-0027: supply vcc not found, using dummy regulator
[ 8.858997] pca953x 7-0027: using no AI
[ 8.861103] usbcore: registered new interface driver uvcvideo
[ 8.861107] USB Video Class driver (1.1.1)
[ 8.861640] lm75 6-0049: supply vs not found, using dummy regulator
[ 8.861900] hwmon hwmon0: temp1_input not attached to any thermal zone
[ 8.861905] lm75 6-0049: hwmon0: sensor ‘lm75’
[ 8.862780] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property
[ 8.863175] rockchip-thermal fec00000.tsadc: tsadc is probed successfully!
[ 8.863668] device-mapper: ioctl: 4.44.0-ioctl (2021-02-01) initialised: dm-devel@redhat.com
[ 8.863830] Bluetooth: HCI UART driver ver 2.3
[ 8.863834] Bluetooth: HCI UART protocol H4 registered
[ 8.863837] Bluetooth: HCI UART protocol ATH3K registered
[ 8.863860] usbcore: registered new interface driver bfusb
[ 8.864491] cpu cpu0: bin=0
[ 8.864662] cpu cpu0: leakage=9
[ 8.866062] cpu cpu0: pvtm=1416
[ 8.866120] cpu cpu0: pvtm-volt-sel=1
[ 8.867971] cpu cpu4: bin=0
[ 8.868139] cpu cpu4: leakage=7
[ 8.874665] cpu cpu4: pvtm=1641
[ 8.878667] cpu cpu4: pvtm-volt-sel=3
[ 8.881258] cpu cpu6: bin=0
[ 8.881426] cpu cpu6: leakage=8
[ 8.887966] cpu cpu6: pvtm=1779
[ 8.891969] cpu cpu6: pvtm-volt-sel=7
[ 8.893369] cpu cpu0: avs=0
[ 8.893864] cpu cpu4: avs=0
[ 8.894345] cpu cpu6: avs=0
[ 8.894513] cpu cpu0: EM: created perf domain
[ 8.894541] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0
[ 8.895091] cpu cpu4: EM: created perf domain
[ 8.895112] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
[ 8.903514] cpu cpu6: EM: created perf domain
[ 8.904001] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
[ 8.919378] sdhci: Secure Digital Host Controller Interface driver
[ 8.919392] sdhci: Copyright(c) Pierre Ossman
[ 8.919400] Synopsys Designware Multimedia Card Interface Driver
[ 8.919812] sdhci-pltfm: SDHCI platform and OF driver helper
[ 8.924917] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 8.924985] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping …
[ 8.925905] cryptodev: driver 1.12 loaded.
[ 8.925986] hid: raw HID events driver (C) Jiri Kosina
[ 8.926352] usbcore: registered new interface driver usbhid
[ 8.926362] usbhid: USB HID core driver
[ 8.926732] ashmem: initialized
[ 8.931425] Firefly adc init
[ 8.931432] Firefly adc–>FIREFLY_ADC_SAMPLE_JIFFIES: 16
[ 8.931436] Firefly adc–>MSEC_PER_SEC: 1000
[ 8.931441] Firefly adc–>HZ: 300
[ 8.931627] Firefly adc–>ret: 0
[ 8.931829] optee: probing for conduit method.
[ 8.931848] optee: revision 3.13 (4542e1ef)
[ 8.932201] optee: initialized driver
[ 8.932750] usbcore: registered new interface driver snd-usb-audio
[ 8.938457] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 8.950986] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA
[ 8.984350] mmc0: Host Software Queue enabled
[ 8.984362] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.984687] mmcblk0: mmc0:0001 Y2P032 29.1 GiB
[ 8.984827] mmcblk0boot0: mmc0:0001 Y2P032 partition 1 4.00 MiB
[ 8.984964] mmcblk0boot1: mmc0:0001 Y2P032 partition 2 4.00 MiB
[ 8.985046] mmcblk0rpmb: mmc0:0001 Y2P032 partition 3 16.0 MiB, chardev (234:0)
[ 8.987224] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 9.035160] rk3x-i2c feab0000.i2c: timeout, ipd: 0x90, state: 3
[ 9.035177] ES8323 3-0011: i2c recv Failed
[ 9.035286] ES8323: probe of 3-0011 failed with error -110
[ 9.043731] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card0/input1
[ 9.045905] Initializing XFRM netlink socket
[ 9.046174] NET: Registered protocol family 10
[ 9.047280] Segment Routing with IPv6
[ 9.047566] NET: Registered protocol family 17
[ 9.047640] NET: Registered protocol family 15
[ 9.047694] Bridge firewalling registered
[ 9.047702] can: controller area network core
[ 9.047747] NET: Registered protocol family 29
[ 9.047755] can: raw protocol
[ 9.047763] can: broadcast manager protocol
[ 9.047771] can: netlink gateway - max_hops=1
[ 9.047925] Bluetooth: RFCOMM TTY layer initialized
[ 9.047935] Bluetooth: RFCOMM socket layer initialized
[ 9.047956] Bluetooth: RFCOMM ver 1.11
[ 9.047965] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.047970] Bluetooth: BNEP filters: protocol multicast
[ 9.047977] Bluetooth: BNEP socket layer initialized
[ 9.047982] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 9.047989] Bluetooth: HIDP socket layer initialized
[ 9.048021] 8021q: 802.1Q VLAN Support v1.8
[ 9.048034] [BT_RFKILL]: Enter rfkill_rk_init
[ 9.048040] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 9.048360] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 9.048398] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 9.048406] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275p
[ 9.048412] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 9.048418] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 9.048437] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 20 flags = 0.
[ 9.048458] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 10, flags = 0.
[ 9.048466] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 9.048472] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 9.048478] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 9.048484] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 9.048885] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 34.
[ 9.048904] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 22.
[ 9.048915] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 21.
[ 9.048926] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 0.
[ 9.048934] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 9.048968] [BT_RFKILL]: Request irq for bt wakeup host
[ 9.049017] [BT_RFKILL]: ** disable irq
[ 9.049100] [BT_RFKILL]: bt_default device registered.
[ 9.049165] Key type dns_resolver registered
[ 9.050373] registered taskstats version 1
[ 9.050384] Loading compiled-in X.509 certificates
[ 9.051597] Btrfs loaded, crc32c=crc32c-generic
[ 9.051743] pstore: Using crash dump compression: deflate
[ 9.052452] rga3_core0 fdb60000.rga: Adding to iommu group 2
[ 9.052470] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 9.052629] rga: rga3_core0, irq = 34, match scheduler
[ 9.052972] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831.
[ 9.053022] rga: rga3_core0 probe successfully
[ 9.053339] rga3_core1 fdb70000.rga: Adding to iommu group 3
[ 9.053357] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 9.053511] rga: rga3_core1, irq = 35, match scheduler
[ 9.053702] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831.
[ 9.053744] rga: rga3_core1 probe successfully
[ 9.054049] rga: rga2, irq = 36, match scheduler
[ 9.054256] rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
[ 9.054266] rga: rga2 probe successfully
[ 9.054453] rga_iommu: IOMMU binding successfully, default mapping core[0x1]
[ 9.054613] rga: Module initialized. v1.2.23
[ 9.054624]
[ 9.054629] ********************************************************************
[ 9.054633] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 9.054637] ** **
[ 9.054641] ** WRITEABLE clk DebugFS SUPPORT HAS BEEN ENABLED IN THIS KERNEL **
[ 9.054645] ** **
[ 9.054649] ** This means that this kernel is built to expose clk operations **
[ 9.054653] ** such as parent or rate setting, enabling, disabling, etc. **
[ 9.054656] ** to userspace, which may compromise security on your system. **
[ 9.054660] ** **
[ 9.054664] ** If you see this message and you are not debugging the **
[ 9.054668] ** kernel, report this immediately to your vendor! **
[ 9.054672] ** **
[ 9.054676] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 9.054679] ********************************************************************
[ 9.073509] vendor storage:20190527 ret = 0
[ 9.081743] usb 9-1: new high-speed USB device number 2 using xhci-hcd
[ 9.087057] mali fb000000.gpu: Kernel DDK version g15p0-01eac0
[ 9.087434] pcie30_avdd1v8: supplied by avcc_1v8_s0
[ 9.087703] mali fb000000.gpu: bin=0
[ 9.087865] pcie30_avdd0v75: supplied by avdd_0v75_s0
[ 9.087884] mali fb000000.gpu: leakage=13
[ 9.087919] debugfs: Directory ‘fb000000.gpu-mali’ with parent ‘vdd_gpu_s0’ already present!
[ 9.089501] mali fb000000.gpu: pvtm=868
[ 9.089537] mali fb000000.gpu: pvtm-volt-sel=3
[ 9.090219] mali fb000000.gpu: avs=0
[ 9.090290] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 136; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 9.090589] rockchip-dmc dmc: leakage=33
[ 9.090602] rockchip-dmc dmc: leakage-volt-sel=1
[ 9.090944] rockchip-dmc dmc: avs=0
[ 9.090958] rockchip-dmc dmc: current ATF version 0x100
[ 9.091039] rockchip-dmc dmc: normal_rate = 1560000000
[ 9.091047] rockchip-dmc dmc: reboot_rate = 2112000000
[ 9.091054] rockchip-dmc dmc: suspend_rate = 528000000
[ 9.091060] rockchip-dmc dmc: video_4k_rate = 1560000000
[ 9.091067] rockchip-dmc dmc: video_4k_10b_rate = 1560000000
[ 9.091074] rockchip-dmc dmc: video_svep_rate = 1560000000
[ 9.091080] rockchip-dmc dmc: boost_rate = 2112000000
[ 9.091086] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000
[ 9.091093] rockchip-dmc dmc: performance_rate = 2112000000
[ 9.091099] rockchip-dmc dmc: hdmirx_rate = 2112000000
[ 9.091109] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 9.091115] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 9.091236] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 9.091279] rockchip-dmc dmc: could not find power_model node
[ 9.091640] mali fb000000.gpu: GPU hardware issue table may need updating:
[ 9.091640] r0p0 status 5 is unknown; treating as r0p0 status 0
[ 9.091651] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0
[ 9.091761] mali fb000000.gpu: No priority control manager is configured
[ 9.092018] mali fb000000.gpu: No memory group manager is configured
[ 9.092055] mali fb000000.gpu: Protected memory allocator not available
[ 9.092461] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT
[ 9.093195] mali fb000000.gpu: Couldn’t find power_model DT node matching ‘arm,mali-simple-power-model’
[ 9.093207] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0]
[ 9.093382] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0]
[ 9.093525] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0]
[ 9.093671] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = ‘’
[ 9.094817] ------ rtk_gsw_probe ------
[ 9.094832] ------ rtl8367 init ------
[ 9.095729] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model
[ 9.095870] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
[ 9.096729] mali fb000000.gpu: Probed as mali0
[ 9.099068] usb 1-1: New USB device found, idVendor=3763, idProduct=3c93, bcdDevice= 3.18
[ 9.099087] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.099099] usb 1-1: Product: Android
[ 9.099109] usb 1-1: Manufacturer: Android
[ 9.099119] usb 1-1: SerialNumber: c241f84
[ 9.100744] option 1-1:1.0: GSM modem (1-port) converter detected
[ 9.100998] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 9.101295] option 1-1:1.1: GSM modem (1-port) converter detected
[ 9.101494] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 9.101812] option 1-1:1.2: GSM modem (1-port) converter detected
[ 9.101988] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 9.107102] cdc_ether 1-1:1.3 usb0: regBegin: Loading essential drivers … ister ‘cdc_ether’ at usb-fc800000.usb-1, CDC Ethernet Device, 86:56:c7:a3:84:10
[ 9.109826] option 1-1:1.5: GSM modem (1-port) converter detected
[ 9.110060] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
[ 9.669056] usb 9-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 9.669071] usb 9-1: New USB device strings: Mfr=0, Product=0, Sdone.
Begin: Running /scripts/init-premount … erialNumber=0
[ 9.725231] hub 9-1:1.0: USB hub found
[ 9.725409] hub 9-1:1.0: 4 ports detectdone.
Begin: Mounting root file system … ed
[ 10.594008] input: adc-keys as /devices/platform/adc-keys/Begin: Runniing /scripts/locnal-top … put/input2
[ 10.604250] input: gpio-keys as /devices/platform/gpio/input/input3
[ 10.604668] irq: type mismatch, failed to map hwirq-27 for gpio@fd8a0000!
[ 10.605279] typec_fusb302 6-0022: failed to request gpio_int_n
done.
[ 10.605584]Begin: Running /scripts/local-pre mount ..p. c9202: sw2001_read(0x1) return 0x1
[ 10.605591] status=0x1
[ 10.605597] ====== i2c detect success watchdog init ======
[ 10.605725] pc9202_wdt_probe(): wd_en_gpio: -2 idone.
s invalid
[ 10.606764] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[ 10.606787] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[ 10.606798] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[ 10.606840] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 79,32 bit host data width,256 deep fifo
[ 10.607324] RKNPU fdab0000.npu: Adding to iommu group 0
[ 10.607351] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 10.607491] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 10.610863] typec_fusb302: probe of 6-0022 failed with error -2
[ 10.613979] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdab0000-0xfdabffff]
[ 10.613997] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdac0000-0xfdacffff]
[ 10.614010] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdad0000-0xfdadffff]
[ 10.614273] [drm] Initialized rknpu 0.8.2 20220829 for fdab0000.npu on minor 1
[ 10.631037] RKNPU fdab0000.npu: bin=0
[ 10.631234] RKNPU fdab0000.npu: leakage=8
[ 10.631293] debugfs: Directory ‘fdab0000.npu-rknpu’ with parent ‘vdd_npu_s0’ already present!
[ 10.636402] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 10.642343] RKNPU fdab0000.npu: pvtm=864
[ 10.647432] RKNPU fdab0000.npu: pvtm-volt-sel=3
[ 10.648772] RKNPU fdab0000.npu: avs=0
[ 10.649027] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
[ 10.669175] RKNPU fdab0000.npu: failed to find power_model node
[ 10.669187] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 10.669194] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
[ 10.674970] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 10.680417] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 10.681263] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 10.681272] cfg80211: failed to load regulatory.db
[ 10.681602] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 10.682451] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 405; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘10:50:42’, on Begin: Will now check root file system … ‘Oct 26 2023’.
[ 10.682771] Mali:
[ fsck from util-linux 2.36.1-4309-dirty
10.682774] Mali device driver loaded
[ 10.688729] ret 1024 0
[ 10.688843] ALSA device list:
[ 10.6888[/sbin/fsck.ext4 (1) – /dev/mmcblk0p6] fsck.ext4 -a -C0 /dev/mmcblk0p6
5/dev/mmcblk0p6: clean, 79406/1916608 files, 643534/786432 blocks
] #0do:ne.
rockchip-hdmi0 m] F[inished Load Kernel Modules. all Devices…
1]: Conditi[ OK ] Finished [0;1n;39mRemount Ro ot and Kernel File Systems.
ch[ OK ] Started Journal Service.ue File System.
eck resulted in Arbitrary Executable F Mouinting FUSE Control File System…
le Formats Fil Mountine Sg Kernel Conyfiguration File Systesm…
tem Automount Point being skipped.list of st… nodes for the current kernel.
[ 13 Starting Flush Journal to Persistent .Storage…t.
52642] systemd[ Starting P1latf]orm Persistent Storage Archiv:al..R.: failed to initialize host
eached target Use Startirng Load/Save Random Seed…ost
and Group Name Lo o k Starting Apply Kernel Variables…ered data mode. Opts: (null)
ups.65[ OK ] Finished Load Kernel Module pstore_zone.er=overlay mode=device opts=‘dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ per kernel cmdline
[ 13.659185] sy Starting Crseate System Users…d
temd[1]: Reached t[-;32m OK ] Mounted FUSE Contrrol File System.
get[ OK ] Mounted Kernel Co nfigRuration File System.with ordered data mode. Opts: (null)
emote File Sy[ OK ] Finished Plattform Persistent Storage Archival.data,fstype=ext4,mkfs=1’ using overlay per kernel cmdline
ems.ing: Something odd, no /lib/modules/5.10.110 in initramfs.
[ 13.[ OK ] Finished Load/S6ave Random Seed.
[5251] syste[[0;32m OK ] Findished Apply Kernel Variables.
[1]: Reached t[ OK ] Finished Create System Usersa.r with ordered data mode. Opts: (null)
get Slices.74] ext4 filesystem being mounted at /root/boot supports timestamps until 2038 (0x7fffffff)
[ 13.6702 Starting Create Static Device Nodes in /dev…
05] systemd[1]: Reached target Swap.45.4-4ubuntu4.13 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR
[ 13.675191] systemd[1]: Listening on Syslog Socket.
[ 13.680406] systemd[1]: Listening on initctl Compatibil[ OK ] Finished udev Coldplug all Devices[0m.t
y Named Pipe.T +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 13.687626] Starting Helper to sy nchrsonizy boost upt fore ifupdownm…
d[1]: Listening on Journal Audit Socket.to .
[ 13.693438] systemd[1]: [ OK ] Finished Create Static Device Nodes in /dev. marked executable. Please remove executable permission bits. Proceeding anyway.
Li[[0;3t2m eOK ]n Reaiched target Local File Systems (Pre).stem/5G_server_njhy.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ OK ] Reached target ;39mgLoca Filoe Systems ./systemd/system/5G_server_njhy.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
Journal Socket (/d Starting Set console font and keymap… ] Created slice [0;1;39msystem-modprobe.slice.
ev/log).
[ 1 Star3ting Tell Plymouth T.o Wr6ite 998Out Run7time Data…
0;1;39mSockets.iste Starting udev Kernel Device Manager… m.
o[[0;3e2m OK s_psto[1] syste Starting rkisp 3A engine…ore_zone…
md[1]: Finished Re Stamrting System oLoggingu Service…s to Console Directory Watch.
nt Root and Kern e Starting [0;1;39mLSB: Agent daemon for S File Systepice guests[0m…
s.arting Load Kernel Module pstore_zone…nel File Systems…
[ 13.882982] systemd[1]: Started Starting Login Service…hutdown.
Journal Service. check resulted in Load Kernel Module ramoops being skipped.
[ 13.921040] systemd-journald[524]: Received client request to flush runtime journal. being skipped.
[ 13.929282] systemd-journald[524]: File /var/lo[m OK ] Started /[0;1;39mSwitch uart modes.
journal/b8eb10c Starting n39mDisk Manager..d.Kernel File Systems…
9354b5a840e8049d S4tarting [0;1639mWPA supplicant…s…
8498/system.journal corrupted or uncleanly shut down, renaming[ a OK ] Started LnSB: GNOME Display Mandager.
replacing.54] systemd[1]: Mounted PO[ OK ]S StaIrted 1;39mNetwork Time Synchronization.
[ OK ] Finished Restore /etc/reso…re the ppp link was shut down.
[ OK ] Started rkisp 3A engine. Scyheduler.
[ OK ] Started System Logging Service.ary Directories.
[ OK ] Started enable ASYNC for Debian Display.nning repeated jobs.
[ OK ] Found device /dev/ttyFIQ0.
[ OK ] Started LSB: Agent daemon for Spice guests.
[ OK ] Started LSB: automatic crash report generation.
[ OK ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
[ OK ] Started Avahi mDNS/DNS-SD Stack. download activities.
[ OK ] Started WPA supplicant.rade and clean activities.m
[ OK ] Started Login Service.c ext4 Onli…ata Check for All Filesystems:.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting Save/Restore Sound Card State…
[ OK ] Started ifup for eth1. regeneration.
Starting Load/Save RF Kill Switch Status…
[ OK ] Finished Save/Restore Sound Card State.NS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Sound Card.SCUPSy Schsteduler.
[ OK ] Started Load/Save RF Kill Switch Status.
Starting Authorization Manager…e Bus Socket0m.
[ OK ] Started Authorization Manager.Docker Socket for the 1API
[ OK ] Started Accounts Service. : Moun[ OK ] Startted Network Name Resoluteion[0m.
[ OK ] Finished Helper to synchronize boot up for ifupdown.
Starting Raise network interfaces…
Starting Hostname Service…reate list of static device nodes for the current kernel.
[ OK ] Found device /sys/subsystem/net/devices/eth1.1.oard layout.
[ OK ] Started ifup for eth1.1. ] Remached targeto Host and Network Name Lookups
[ OK ] Started Disk Manager.
[ OK ] Started Hostname Service.
Starting Network Manager Script Dispatcher Service…
[ OK ] Started Network Manager Script Dispatcher Service.
[ OK ] Started Network Manager.
[ OK ] Found device /sys/subsystem/net/devices/eth1.2.
[ OK ] Started ifup for eth1.2.
[ OK ] Found device /sys/subsystem/net/devices/eth1.3.
[ OK ] Started ifup for eth1.3.
[ OK ] Finished Raise network interfaces.
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
Starting containerd container runtime…
Starting Net-Smp-Affinity…
Starting OpenVPN service…
Starting /etc/rc.local Compatibility…
Starting OpenBSD Secure Shell server…
[ 9.336572] rc.local[1517]: run rc.local
Starting Permit User Sessions…
[ 9.342433] rc.local[1520]: Adding user hyst to group docker
Starting Ubuntu FAN network setup…
[ OK ] Started Net-Smp-Affinity.
[ OK ] Finished OpenVPN service.
[ OK ] Finished Permit User Sessions.
[ OK ] Finished Ubuntu FAN network setup.
[ OK ] Started OpenBSD Secure Shell server.
[FAILED] Failed to start Adbd for linux.
See ‘systemctl status adbd.service’ for details.
[ OK ] Started Setup rockchip platform environment.
[ OK ] Started containerd container runtime.
Starting Docker Application Container Engine…
[ 12.143857] rc.local[2053]: RS485-1 alreday exist: lrwxrwxrwx 1 root root 18 Aug 22 10:26 /opt/hanyuan/RS485-1 → /dev/ttyCH9344USB0
[ 12.150778] rc.local[2053]: RS485-2 alreday exist: lrwxrwxrwx 1 root root 18 Aug 22 10:26 /opt/hanyuan/RS485-2 → /dev/ttyCH9344USB1
[ 12.162718] rc.local[2053]: RS485-3 alreday exist: lrwxrwxrwx 1 root root 18 Aug 22 10:26 /opt/hanyuan/RS485-3 → /dev/ttyCH9344USB2
[ 12.174469] rc.local[2053]: RS485-4 alreday exist: lrwxrwxrwx 1 root root 18 Aug 22 10:26 /opt/hanyuan/RS485-4 → /dev/ttyCH9344USB3
[ OK ] Started /etc/rc.local Compatibility.
[ 12.186255] rc.local[2053]: /dev/ttyCH9344USB8 is not exist !
[ 12.198209] rc.local[2053]: /dev/ttyCH9344USB9 is not exist !
[ OK ] Started 4G2 Server.
[ 12.203733] rc.local[2053]: /dev/ttyCH9344USB10 is not exist !
[ OK ] Started 4G1 Server.
[ 12.214260] rc.local[2053]: /dev/ttyCH9344USB11 is not exist !
[ OK ] Started 5G Server.
[ 12.224884] rc.local[2053]: LORA alreday exist: lrwxrwxrwx 1 root root 10 Aug 22 10:26 /opt/hanyuan/LORA → /dev/ttyS0
Starting Hold until boot process finishes up…
[ 12.241247] rc.local[2053]: BLE alreday exist: lrwxrwxrwx 1 root root 10 Aug 22 10:26 /opt/hanyuan/BLE → /dev/ttyS1
Starting Terminate Plymouth Boot Screen…
[ 12.256820] rc.local[2053]: EC-BLE alreday exist: lrwxrwxrwx 1 root root 10 Aug 22 10:26 /opt/hanyuan/EC-BLE → /dev/ttyS5
[ OK ] Finished Hold until boot process finishes up.
[ 12.273590] rc.local[2053]: Create uart interface end.
[ OK ] Finished Terminate Plymouth Boot Screen.
[ OK ] Started Serial Getty on ttyFIQ0.
Starting Set console scheme…
[ OK ] Finished Set console scheme.
[ OK ] Created slice system-getty.slice.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started Docker Application Container Engine.
[ OK ] Started connection-control-hyst service.
[ OK ] Started console-display-hyst service.
[ OK ] Started rule-engine service.
[ OK ] Started video ai service.
Starting video ai service…
[ 19.296541] of_dma_request_slave_channel: dma-names property of node ‘/serial@fd890000’ missing or empty
[ 19.304274] of_dma_request_slave_channel: dma-names property of node ‘/serial@feb40000’ missing or empty
[ OK ] Stopped connection-control-hyst service.
[ OK ] Stopped console-display-hyst service.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Finished Update UTMP about System Runlevel Changes.
Ubuntu 20.04.6 LTS HYG330 ttyFIQ0
HYG330 login: [ 54.195268] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2634 session 2634:5 count 3 cur_task 000000000319129c id 4036
[ 54.195283] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2634 session 2634:3 count 1 cur_task 00000000539f9f7c id 4035
[ 54.195387] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2634 session 2634:2 count 2 cur_task 00000000bd6afb64 id 4033
[ 54.196709] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2634 session 2634:7 count 2 cur_task 000000006c5f390e id 4037
[ 54.198444] rk_vcodec: mpp_wait_result_default:920: timeout, pid 2634 session 2634:4 count 2 cur_task 00000000eedb9a92 id 4031
[ 110.457917] rkvdec2_ccu_link_timeout_work:1566: task timeout
[ 110.457[ 110.458090] rkvdec2_soft_ccu_reset:1747: soft reset fail, int 00000020 -----------挂死前基本都有这个打印,但后面的异常栈不相同
[ 110.458098] rkvdec2_soft_ccu_reset:1753: bus busy
[ 110.503464] Unable to handle kernel paging request at virtual address 0000017a00000171
[ 110.522545] Mem abort info:
[ 110.525338] ESR = 0x96000004
[ 110.528387] EC = 0x25: DABT (current EL), IL = 32 bits
[ 110.533692] SET = 0, FnV = 0
[ 110.536740] EA = 0, S1PTW = 0
[ 110.539881] Data abort info:
[ 110.542756] ISV = 0, ISS = 0x00000004
[ 110.546586] CM = 0, WnR = 0
[ 110.549554] [0000017a00000171] address between user and kernel address ranges
[ 110.556680] Internal error: Oops: 96000004 [#2] SMP
[ 110.561557] Modules linked in: spi_sc1187y ahci_platform libahci_platform libahci libata scsi_mod
[ 110.570429] CPU: 6 PID: 3292 Comm: stream-service Tainted: G D 5.10.110 #3
[ 110.578592] Hardware name: Firefly AIO-3588Q MIPI101(Linux) (DT)
[ 110.584587] pstate: 20400089 (nzCv daIf +PAN -UAO -TCO BTYPE=–)
[ 110.590590] pc : get_page_from_freelist+0x1c0/0xd90
[ 110.595466] lr : get_page_from_freelist+0x168/0xd90
[ 110.600340] sp : ffffffc01676b8e0
[ 110.603648] x29: ffffffc01676b8e0 x28: ffffffc01676baa0
[ 110.608956] x27: 0000000000000001 x26: 0000000000000801
[ 110.614262] x25: 0000000000000000 x24: 0000000000000000
[ 110.619568] x23: ffffffc0120bfb60 x22: ffffff81ff70cb60
[ 110.624876] x21: ffffffc0129b7d90 x20: ffffff81ff70cb70
[ 110.630183] x19: ffffffc0129b6480 x18: 0000000000000000
[ 110.635491] x17: 0000000000000000 x16: 0000000000000000
[ 110.640798] x15: 0000007f476ab868 x14: 0000000000000000
[ 110.646106] x13: 0000000000000000 x12: 0000000000000000
[ 110.651414] x11: 0000000000000000 x10: 0000000000000000
[ 110.656721] x9 : ffffffc01029af58 x8 : ffffffc1ed64d000
[ 110.662027] x7 : 0000017a00000169 x6 : 0000000000000000
[ 110.667336] x5 : ffffff81ff70cb60 x4 : 00000000000000c0
[ 110.672643] x3 : dead000000000122 x2 : 00000000000000a0
[ 110.677950] x1 : 0000017a00000171 x0 : 0000017a00000171
[ 110.683257] Call trace:
[ 110.685703] get_page_from_freelist+0x1c0/0xd90
[ 110.690231] __alloc_pages_nodemask+0x188/0xda0
[ 110.694759] get_zeroed_page+0x30/0x70
[ 110.698509] rga_job_commit+0x30/0x480
[ 110.702256] rga_request_commit+0x48/0xe0
[ 110.706259] rga_request_submit+0x100/0x430
[ 110.710441] rga_ioctl_blit+0xcc/0x220
[ 110.714188] rga_ioctl+0x35c/0x8d0
[ 110.717589] __arm64_sys_ioctl+0xb4/0x100
[ 110.721597] el0_svc_common.constprop.0+0xa4/0x2a0
[ 110.726381] do_el0_svc+0x78/0xa0
[ 110.729692] el0_svc+0x20/0x30
[ 110.732741] el0_sync_handler+0xe8/0xf0
[ 110.736570] el0_sync+0x1a0/0x1c0
[ 110.739877]
[ 110.739877] PC: 0xffffffc01029a070:
[ 110.744834] 9e70 14000006 f860db01 f9402a84 8b040024 39814481 8b010273 aa1903e1 9418b7dd
[ 110.753002] 9e90 b9400341 6b01001f 54fffee3 f100027f 9a9fa265 a9446bf9 17ffffdd d503201f
[ 110.761170] 9eb0 aa1e03e9 d503201f d503233f a9b17bfd 52800d04 910003fd a90153f3 2a0103f4
[ 110.769337] 9ed0 d2801805 b9007be0 d5384101 9ba47e86 a9025bf5 9b241684 910400c0 a90363f7
[ 110.777503] 9ef0 a9046bf9 2a1403f9 2a0203fa a90573fb aa0303fc f9004be0 52800020 a90993e6
[ 110.785672] 9f10 1ad42017 2a1703fb f942a022 f90077e2 d2800002 d000f040 91002000 f90037ff
[ 110.793840] 9f30 f9005fe0 f90063e0 f9400b95 f94002b8 b4000e58 aa1803f3 b0014140 91282000
[ 110.802007] 9f50 f90033e0 d503201f f94033e0 b9400000 7100001f 54003aec 39408380 34000100
[ 110.810175] 9f70 f9402660 f94037e1 eb01001f 54000b20 97febc70 72001c1f 54002f20 92400740
[ 110.818342] 9f90 b9401f98 f942e265 12000757 f8607a62 f10000bf f9400e60 9a9fa0b6 8b000042
[ 110.826508] 9fb0 35001019 721d075f 540039e1 f9401260 12190354 373800ba f9430e61 f100003f
[ 110.834675] 9fd0 9a9fa021 8b000020 8b38ce61 cb0002c0 f9401421 8b010041 eb00003f 54000123
[ 110.842841] 9ff0 aa1603e5 2a1a03e4 2a1803e3 aa1303e0 52800001 97ffff0b 72001c1f 54004260
[ 110.851007] a010 b9401b98 97ffed03 d53cd048 aa0003e6 f9402a77 8b0802e5 7100071f 54000041
[ 110.859174] a030 35003574 93407f16 910006d4 8b1610b6 8b1410b4 f9400ac0 eb00029f 540008c0
[ 110.867340] a050 b4000ad4 f9400ac0 eb14001f 54000a60 f9400281 d2802443 f2fbd5a3 f1002027
[ 110.875505] a070* a9400022 f9000440 f9000002 d2802000 f2fbd5a0 a9000c20 b8686ae0 51000400
[ 110.883672] a090 b8286ae0 54000160 f85f8021 9000f0e0 9117c000 d53cd042 d37efc21 91001021
[ 110.891838] a0b0 8b010c01 f8626820 91000400 f8226820 d51b4226 f0014260 b9481800 7100001f
[ 110.900004] a0d0 5400316c f9429e60 370001e0 b5005987 f9400782 910042a0 b9401f81 b50023a2
[ 110.908171] a0f0 b9401aa3 aa0003f5 6b03003f 54002323 f94002b3 b5fff2b3 3640549a 12177b5a
[ 110.916337] a110 17ffff8a 9114e263 d2800020 f9003be7 f9800071 c85f7c61 8a200021 c8027c61
[ 110.924505] a130 35ffffa2 f9402663 528b8524 72b851e4 aa1303e0 cb030263 52800002 52800001
[ 110.932671] a150 9346fc63 1b047c63 97ff0256 f9403be7 17ffffdf b98008a1 2a1803e3 2a1a03e4
[ 110.940838] a170 aa1403e2 aa1303e0 f9003be6 f90043e8 97fff868 f94043e8 f9403be6 b8686ae1
[ 110.949005] a190 0b000021 b8286ae1 f9400ac0 eb00029f 54fff581 d503201f d2800007 17ffffc5
[ 110.957173] a1b0 aa1603e5 2a1803e3 2a1a03e4 2a1903e1 aa1303e0 97fffe9b 72001c1f 54000041
[ 110.965339] a1d0 3617f89a f9403fe0 b9401b94 f271001f 7a411b24 540045a1 91150260 f90057e0
[ 110.973506] a1f0 944e8248 937c7e96 f9404fe1 f90047e0 93407e98 121c0357 91030021 8b160021
[ 110.981673] a210 8b010260 f90043e0 f9404be0 8b000260 f9003be0 f94053e0 8b000260 f9005be0
[ 110.989841] a230 35000d97 d503201f 7100069f 540019e0 71002b3f 54004a48 f94043e3 2a1903e1
[ 110.998009] a250 d37cef04 2a0103e2 8b214440 8b000840 8b000c80 8b000260 f9406000 eb03001f
[ 111.006178]
[ 111.006178] LR: 0xffffffc01029a018:
[ 111.011134] 9e18 540001a8 2a1703e3 aa1603e2 2a1503e1 aa1403e0 52800004 97ffff80 a94153f3
[ 111.019300] 9e38 a9425bf5 a94363f7 a8c57bfd d50323bf d65f03c0 a9046bf9 b0012158 b0012159
[ 111.027467] 9e58 b001215a 91046339 910b835a 912d6318 12800000 f942e293 14000006 f860db01
[ 111.035633] 9e78 f9402a84 8b040024 39814481 8b010273 aa1903e1 9418b7dd b9400341 6b01001f
[ 111.043800] 9e98 54fffee3 f100027f 9a9fa265 a9446bf9 17ffffdd d503201f aa1e03e9 d503201f
[ 111.051966] 9eb8 d503233f a9b17bfd 52800d04 910003fd a90153f3 2a0103f4 d2801805 b9007be0
[ 111.060132] 9ed8 d5384101 9ba47e86 a9025bf5 9b241684 910400c0 a90363f7 a9046bf9 2a1403f9
[ 111.068297] 9ef8 2a0203fa a90573fb aa0303fc f9004be0 52800020 a90993e6 1ad42017 2a1703fb
[ 111.076463] 9f18 f942a022 f90077e2 d2800002 d000f040 91002000 f90037ff f9005fe0 f90063e0
[ 111.084629] 9f38 f9400b95 f94002b8 b4000e58 aa1803f3 b0014140 91282000 f90033e0 d503201f
[ 111.092795] 9f58 f94033e0 b9400000 7100001f 54003aec 39408380 34000100 f9402660 f94037e1
[ 111.100962] 9f78 eb01001f 54000b20 97febc70 72001c1f 54002f20 92400740 b9401f98 f942e265
[ 111.109128] 9f98 12000757 f8607a62 f10000bf f9400e60 9a9fa0b6 8b000042 35001019 721d075f
[ 111.117296] 9fb8 540039e1 f9401260 12190354 373800ba f9430e61 f100003f 9a9fa021 8b000020
[ 111.125462] 9fd8 8b38ce61 cb0002c0 f9401421 8b010041 eb00003f 54000123 aa1603e5 2a1a03e4
[ 111.133629] 9ff8 2a1803e3 aa1303e0 52800001 97ffff0b 72001c1f 54004260 b9401b98 97ffed03
[ 111.141796] a018* d53cd048 aa0003e6 f9402a77 8b0802e5 7100071f 54000041 35003574 93407f16
[ 111.149964] a038 910006d4 8b1610b6 8b1410b4 f9400ac0 eb00029f 540008c0 b4000ad4 f9400ac0
[ 111.158131] a058 eb14001f 54000a60 f9400281 d2802443 f2fbd5a3 f1002027 a9400022 f9000440
[ 111.166298] a078 f9000002 d2802000 f2fbd5a0 a9000c20 b8686ae0 51000400 b8286ae0 54000160
[ 111.174466] a098 f85f8021 9000f0e0 9117c000 d53cd042 d37efc21 91001021 8b010c01 f8626820
[ 111.182634] a0b8 91000400 f8226820 d51b4226 f0014260 b9481800 7100001f 5400316c f9429e60
[ 111.190801] a0d8 370001e0 b5005987 f9400782 910042a0 b9401f81 b50023a2 b9401aa3 aa0003f5
[ 111.198967] a0f8 6b03003f 54002323 f94002b3 b5fff2b3 3640549a 12177b5a 17ffff8a 9114e263
[ 111.207133] a118 d2800020 f9003be7 f9800071 c85f7c61 8a200021 c8027c61 35ffffa2 f9402663
[ 111.215300] a138 528b8524 72b851e4 aa1303e0 cb030263 52800002 52800001 9346fc63 1b047c63
[ 111.223466] a158 97ff0256 f9403be7 17ffffdf b98008a1 2a1803e3 2a1a03e4 aa1403e2 aa1303e0
[ 111.231633] a178 f9003be6 f90043e8 97fff868 f94043e8 f9403be6 b8686ae1 0b000021 b8286ae1
[ 111.239799] a198 f9400ac0 eb00029f 54fff581 d503201f d2800007 17ffffc5 aa1603e5 2a1803e3
[ 111.247966] a1b8 2a1a03e4 2a1903e1 aa1303e0 97fffe9b 72001c1f 54000041 3617f89a f9403fe0
[ 111.256132] a1d8 b9401b94 f271001f 7a411b24 540045a1 91150260 f90057e0 944e8248 937c7e96
[ 111.264298] a1f8 f9404fe1 f90047e0 93407e98 121c0357 91030021 8b160021 8b010260 f90043e0
[ 111.272464]
[ 111.272464] SP: 0xffffffc01676b8e0:
[ 111.277421] b6e0 00000171 0000017a 1166a060 ffffffc0 1676b710 ffffffc0 1003a180 ffffffc0
[ 111.285587] b700 96000004 00000000 1676b790 ffffffc0 1676b750 ffffffc0 11630b70 ffffffc0
[ 111.293754] b720 1676b790 ffffffc0 96000004 00000000 12a78000 ffffffc0 00000171 0000017a
[ 111.301921] b740 1676b790 ffffffc0 00000000 00000000 1676b780 ffffffc0 116312ac ffffffc0
[ 111.310087] b760 129b6480 ffffffc0 ffffffff 0000007f 1676b8e0 ffffffc0 1029a070 ffffffc0
[ 111.318254] b780 1676b8c0 ffffffc0 10012408 ffffffc0 00000171 0000017a 00000171 0000017a
[ 111.326422] b7a0 000000a0 00000000 00000122 dead0000 000000c0 00000000 ff70cb60 ffffff81
[ 111.334590] b7c0 00000000 00000000 00000169 0000017a ed64d000 ffffffc1 1029af58 ffffffc0
[ 111.342756] b7e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 111.350924] b800 00000000 00000000 476ab868 0000007f 00000000 00000000 00000000 00000000
[ 111.359091] b820 00000000 00000000 129b6480 ffffffc0 ff70cb70 ffffff81 129b7d90 ffffffc0
[ 111.367259] b840 ff70cb60 ffffff81 120bfb60 ffffffc0 00000000 00000000 00000000 00000000
[ 111.375425] b860 00000801 00000000 00000001 00000000 1676baa0 ffffffc0 1676b8e0 ffffffc0
[ 111.383593] b880 1029a018 ffffffc0 1676b8e0 ffffffc0 1029a070 ffffffc0 20400089 00000000
[ 111.391759] b8a0 ff706aa8 ffffff81 00000040 00000000 ffffffff 0000007f 1001059c ffffffc0
[ 111.399926] b8c0 1676b8e0 ffffffc0 1029a070 ffffffc0 00000003 00000000 00000000 00000000
[ 111.408093] b8e0* 1676b9d0 ffffffc0 1029af58 ffffffc0 00000000 00000000 00000001 00000000
[ 111.416259] b900 126c2be8 ffffffc0 000001f8 00000000 f468bc00 ffffff81 301e2100 ffffff80
[ 111.424425] b920 00000000 00000000 00000000 00000000 00000dc4 00000000 69a83b00 ffffff80
[ 111.432592] b940 12ac2a08 ffffffc0 00000000 00000000 1676ba00 ffffffc0 00100dc4 ffffffc0
[ 111.440758] b960 00000000 00000000 f26a9ae0 ffffff81 00000100 00000000 00000000 00000000
[ 111.448924] b980 000000c0 00000000 00000000 00000000 1676b9b0 ffffffc0 120a3008 ffffffc0
[ 111.457089] b9a0 120a3008 ffffffc0 2bc9f200 ffffff80 1676b9d0 ffffffc0 1029afb0 ffffffc0
[ 111.465255] b9c0 00000000 00000000 df21d700 2ad28d16 1676bb20 ffffffc0 1029bdc0 ffffffc0
[ 111.473421] b9e0 00000000 00000000 66613300 ffffff80 301efa00 ffffff80 000001f8 00000000
[ 111.481589] ba00 00000013 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 111.489755] ba20 00000000 00000000 69a83b00 ffffff80 1676ba90 ffffffc0 11336828 ffffffc0
[ 111.497923] ba40 126c2be8 ffffffc0 00100dc4 00000400 1676ba90 ffffffc0 108d3790 ffffffc0
[ 111.506090] ba60 785dcff8 ffffff80 00000013 00000000 00000800 00000000 1676bb28 ffffffc0
[ 111.514256] ba80 785dd0b8 ffffff80 df21d700 2ad28d16 1676baf0 ffffffc0 108cd364 ffffffc0
[ 111.522423] baa0 129b7d80 ffffffc0 69a84398 ffffff80 129b7d90 ffffffc0 00000000 00000001
[ 111.530588] bac0 00000000 00000000 66613300 ffffff80 00000000 00000000 00000cc0 00000000
[ 111.538756]
[ 111.538756] X5: 0xffffff81ff70cb60:
[ 111.543704] c960 00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 111.551872] c980 00000000 00000000 ff70c988 ffffff81 ff70c988 ffffff81 ff70c998 ffffff81
[ 111.560041] c9a0 ff70c998 ffffff81 00000000 00000000 00000000 00000000 00000000 00000000
[ 111.568208] c9c0 00000000 00000000 ff70c9c8 ffffff81 ff70c9c8 ffffff81 ff70c9d8 ffffff81
[ 111.576375] c9e0 ff70c9d8 ffffff81 ff70c9e8 ffffff81 ff70c9e8 ffffff81 00000000 00000000
[ 111.584543] ca00 00000000 00000000 00000000 00000000 00000000 00000001 00000000 00000000
[ 111.592711] ca20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 111.600877] ca40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 111.609045] ca60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 111.617212] ca80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 111.625379] caa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 111.633545] cac0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 111.641712] cae0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 111.649877] cb00 000000ff 00000000 00000000 00000000 00000000 00000000 00000000 00000001
[ 111.658044] cb20 00000002 00000000 ff70cb20 ffffff81 00000000 00000000 00000000 00000000
[ 111.666211] cb40 397cfcb0 00000000 000000b6 00000000 00000000 00000000 00000000 00000000
[ 111.674378] cb60* 00000000 00000000 00000000 00000000 00000171 0000017a 0000003f 00000000
[ 111.682545] cb80 01cf3308 ffffffff 01c97408 ffffffff ff70cb90 ffffff81 ff70cb90 ffffff81
[ 111.690713] cba0 ff70cba0 ffffff81 ff70cba0 ffffff81 00df2a30 00000000 00000100 00000000
[ 111.698879] cbc0 00000000 0000002a 00000007 00000000 ff70cbd0 ffffff81 ff70cbd0 ffffff81
[ 111.707046] cbe0 ff70cbe0 ffffff81 ff70cbe0 ffffff81 ff70cbf0 ffffff81 ff70cbf0 ffffff81
[ 111.715213] cc00 ff70cc00 ffffff81 ff70cc00 ffffff81 00001010 00000000 00000000 00000000
[ 111.723379] cc20 0000df30 02000000 00000000 00000000 00df0000 00000000 00000000 00000000
[ 111.731548] cc40 00000000 00000000 00000000 00000000 77d5af00 ffffff80 000089f0 00000000
[ 111.739715] cc60 01bf5680 ffffffff 01b59d80 ffffffff 039c8150 ffffff80 0000290b 00000000
[ 111.747883] cc80 ffee7200 fffffffe 07acd700 ffffffff 2f4b82c0 ffffff80 000053f0 00000000
[ 111.756050] cca0 009d2e00 ffffffff 007edc40 ffffffff 00000000 00000000 000001bb 00000000
[ 111.764217] ccc0 07b98400 ffffffff 00058e00 ffffffff 2f41d500 ffffff80 0000017c 00000000
[ 111.772384] cce0 009d0600 ffffffff 07bdda00 ffffffff f111e1c0 ffffff81 00000163 00000000
[ 111.780550] cd00 07a44600 ffffffff 07b10a00 ffffffff f654c000 ffffff81 00000109 00000000
[ 111.788716] cd20 07b95300 ffffffff 00000000 00000000 30084280 ffffff80 000002f7 00000000
[ 111.796883] cd40 00a02100 ffffffff fffd77c0 fffffffe f652e400 ffffff81 000001db 00000000
[ 111.805049]
[ 111.805049] X8: 0xffffffc1ed64d000:
[ 111.810005] ce00 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.818174] ce20 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.826340] ce40 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.834507] ce60 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.842673] ce80 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.850840] cea0 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.859007] cec0 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.867174] cee0 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.875341] cf00 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.883509] cf20 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.891676] cf40 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.899843] cf60 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.908010] cf80 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.916178] cfa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.924346] cfc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.932515] cfe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.940683] d000* ******** ******** ******** ******** ******** ******** ******** ********
[ 111.948850] d020 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.957017] d040 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.965184] d060 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.973351] d080 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.981519] d0a0 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.989686] d0c0 ******** ******** ******** ******** ******** ******** ******** ********
[ 111.997853] d0e0 ******** ******** ******** ******** ******** ******** ******** ********
[ 112.006021] d100 ******** ******** ******** ******** ******** ******** ******** ********
[ 112.014187] d120 ******** ******** ******** ******** ******** ******** ******** ********
[ 112.022354] d140 ******** ******** ******** ******** ******** ******** ******** ********
[ 112.030520] d160 ******** ******** ******** ******** ******** ******** ******** ********
[ 112.038688] d180 ******** ******** ******** ******** ******** ******** ******** ********
[ 112.046855] d1a0 ******** ******** ******** ******** ******** ******** ******** ********
[ 112.055024] d1c0 ******** ******** ******** ******** ******** ******** ******** ********
[ 112.063192] d1e0 ******** ******** ******** ******** ******** ******** ******** ********
[ 112.071359]
[ 112.071359] X9: 0xffffffc01029af58:
[ 112.076317] ad58 944d7b95 b9403fe0 120d0001 37980220 f943b2c2 f941dc42 b4000202 d5384102
[ 112.084483] ad78 b9401042 72183c5f 54000220 2a1503e0 aa1403e1 944d7b96 a9425bf5 17ffffbc
[ 112.092651] ad98 a9425bf5 17ffffba a9025bf5 944e5d63 52800021 17fffff2 b9402ec2 52810081
[ 112.100819] adb8 6a01005f 1a9f17e1 17ffffed 72160015 1a8102b5 17ffffee d503245f aa1e03e9
[ 112.108985] add8 d503201f d503233f a9ab7bfd d5384102 910003fd a9046bf9 2a0103fa f942a041
[ 112.117153] adf8 f900a7e1 d2800001 a90d7fff a90e7fff f9007bff 71002b5f 54000da8 90012141
[ 112.125320] ae18 a9025bf5 912fa035 a90153f3 aa0303f3 52800034 a90573fb b94016a1 f9003bf5
[ 112.133488] ae38 0a01001b 2a1b03e0 97ff2048 b9007bfb b9401aa2 90014143 d3431361 7100005f
[ 112.141653] ae58 b94a0863 1a9f0021 b00138e2 91360042 a90d4fe2 291d03e1 7100007f 54000aec
[ 112.149819] ae78 12160360 b9007fe0 3750097b 2a1a03e1 2a1b03e0 97ffe941 72001c1f 54000200
[ 112.157986] ae98 a94153f3 a9425bf5 a94573fb f90037ff d5384100 f940a7e1 f942a002 eb020021
[ 112.166152] aeb8 d2800002 54006481 a9446bf9 f94037e0 a8d57bfd d50323bf d65f03c0 f9403be1
[ 112.174318] aed8 d5384100 b9402c00 b9401821 12040000 2a010000 35000080 d3431360 7100041f
[ 112.182484] aef8 540005e0 a94d0be0 d34c3361 3903c3e1 b940efe1 aa0003e3 b5000782 b9400804
[ 112.190650] af18 6b04003f 54000723 f90073e3 12150362 f9400060 b40000c0 f9402403 32180041
[ 112.198817] af38 cb030000 f132001f 1a820022 b9407be0 2a140042 910343e3 2a1a03e1 97fffbd7
[ 112.206983] af58* f90037e0 b4000580 d00141a0 b9470000 7100001f 540000ed 36b000db f94037e0
[ 112.215150] af78 2a1b03e1 2a1a03e2 9400c858 35004f40 d0013980 91140000 b9400801 7100003f
[ 112.223316] af98 540010cc a94153f3 a9425bf5 a94573fb 17ffffc0 944e680d 17ffffb5 f267037f
[ 112.231483] afb8 32190280 1a941014 17ffffcf 376ff700 d4210000 17ffffb6 d5384100 b9401001
[ 112.239650] afd8 320c0362 b9007be2 52800834 72183c3f fa400a60 54fff461 91226000 52800034
[ 112.247818] aff8 f9006fe0 17ffff9f 97ff1fe4 aa0003e3 17ffffc6 a90363f7 d5384100 b9402c00
[ 112.255985] b018 b9007bfb 720e041f 540055c1 b9407be1 f9006ff3 12170420 3903c3ff 7118001f
[ 112.264152] b038 54005460 2a0103fc 12170020 b900b3e0 52810400 0a000380 321a0002 720d0383
[ 112.272318] b058 52800a01 2a010000 1a801041 291883e2 529f7fe0 12197821 72bffde0 0a000380
[ 112.280485] b078 320c0000 b9008fe3 b9009fe0 f0014120 91280000 b900a3fb b900b7e1 d3431381
[ 112.288652] b098 f90057e1 f9005fe0 f9405fe0 b900a7ff b9400000 7100001f 54004f6c 29566fe0
[ 112.296819] b0b8 340043e0 f9403be1 d5384100 b9402c00 b9401821 12040000 2a010000 35000080
[ 112.304986] b0d8 b940abe0 7100041f 54004500 a94d0be0 b940efe1 aa0003e3 b5004b02 b9400804
[ 112.313154] b0f8 6b04003f 54004aa3 f90073e3 f9400060 b4004aa0 12150373 375847db 910343e3
[ 112.321320] b118 2a1b03e2 2a1a03e1 2a1c03e0 97fffb63 b5003ec0 b9407fe0 34000740 71000f5f
[ 112.329486] b138 54004148 340006fa b940ebe0 7100041f 54000680 b9408fe0 35000640 3788063c
[ 112.337652]
[ 112.337652] X19: 0xffffffc0129b6480:
[ 112.342691] 6280 127ed938 ffffffc0 00000000 00000000 f00dc0f0 ffffff81 f00dc0c0 ffffff81
[ 112.350859] 62a0 101bc4c0 ffffffc0 11698038 ffffffc0 1026d3d0 ffffffc0 1026dcc0 ffffffc0
[ 112.359026] 62c0 101bc4f0 ffffffc0 127ed998 ffffffc0 00000000 00000000 f00dc090 ffffff81
[ 112.367192] 62e0 f00dbf90 ffffff81 101bc4c0 ffffffc0 11698038 ffffffc0 1026d2e4 ffffffc0
[ 112.375358] 6300 1026db94 ffffffc0 101bc4f0 ffffffc0 127eda78 ffffffc0 00000000 00000000
[ 112.383524] 6320 f00dbf60 ffffff81 f00dbea0 ffffff81 101bc4c0 ffffffc0 11698040 ffffffc0
[ 112.391691] 6340 1026f060 ffffffc0 1026f284 ffffffc0 101bc4f0 ffffffc0 127ee4a8 ffffffc0
[ 112.399857] 6360 00000000 00000000 f00dbe70 ffffff81 f00dbde0 ffffff81 101bc4c0 ffffffc0
[ 112.408023] 6380 11698710 ffffffc0 10276000 ffffffc0 10276840 ffffffc0 101bc4f0 ffffffc0
[ 112.416191] 63a0 127ee7b0 ffffffc0 00000000 00000000 f00dbdb0 ffffff81 f00dbd20 ffffff81
[ 112.424357] 63c0 101bc4c0 ffffffc0 11698878 ffffffc0 102817e0 ffffffc0 10282090 ffffffc0
[ 112.432525] 63e0 101bc4f0 ffffffc0 127eedf8 ffffffc0 00000000 00000000 f00dbcf0 ffffff81
[ 112.440692] 6400 f00dbba0 ffffff81 101bc4c0 ffffffc0 00000000 00000000 00000000 00000000
[ 112.448859] 6420 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.457026] 6440 127ef610 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.465192] 6460 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.473359] 6480* 00000722 00000000 00000a8f 00000000 00000dfc 00000000 00000000 00000000
[ 112.481526] 64a0 00000000 00000000 00000000 00000000 00000000 00000000 000000af 00000000
[ 112.489692] 64c0 000000af 00000000 129b6480 ffffffc0 120bfb60 ffffffc0 00000200 00000000
[ 112.497859] 64e0 000d728c 00000000 000ffe00 00000000 000eee00 00000000 00000000 00000000
[ 112.506026] 6500 11d58ee0 ffffffc0 00000000 00000000 00000001 00000000 00000000 00000000
[ 112.514193] 6520 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.522359] 6540 0155e208 ffffffff 01c0ce08 ffffffff 01c75fc8 ffffffff 01c96148 ffffffff
[ 112.530525] 6560 01c19248 ffffffff 01c18288 ffffffff 129b6570 ffffffc0 129b6570 ffffffc0
[ 112.538692] 6580 129b6580 ffffffc0 129b6580 ffffffc0 129b6590 ffffffc0 129b6590 ffffffc0
[ 112.546858] 65a0 0000012f 00000000 01c0cf08 ffffffff 01c0ec88 ffffffff 00fb6708 ffffffff
[ 112.555024] 65c0 01c73908 ffffffff 01229408 ffffffff 01c19288 ffffffff 129b65d8 ffffffc0
[ 112.563191] 65e0 129b65d8 ffffffc0 129b65e8 ffffffc0 129b65e8 ffffffc0 129b65f8 ffffffc0
[ 112.571356] 6600 129b65f8 ffffffc0 00000127 00000000 01a9bb08 ffffffff 01c35a08 ffffffff
[ 112.579523] 6620 00fb6608 ffffffff 01bcb508 ffffffff 129b6630 ffffffc0 129b6630 ffffffc0
[ 112.587689] 6640 129b6640 ffffffc0 129b6640 ffffffc0 129b6650 ffffffc0 129b6650 ffffffc0
[ 112.595855] 6660 129b6660 ffffffc0 129b6660 ffffffc0 00000119 00000000 01c3c808 ffffffff
[ 112.604021]
[ 112.604021] X20: 0xffffff81ff70cb70:
[ 112.609060] c970 ffffffff 00000000 ffffffff ffffffff 00000000 00000000 ff70c988 ffffff81
[ 112.617227] c990 ff70c988 ffffff81 ff70c998 ffffff81 ff70c998 ffffff81 00000000 00000000
[ 112.625394] c9b0 00000000 00000000 00000000 00000000 00000000 00000000 ff70c9c8 ffffff81
[ 112.633561] c9d0 ff70c9c8 ffffff81 ff70c9d8 ffffff81 ff70c9d8 ffffff81 ff70c9e8 ffffff81
[ 112.641728] c9f0 ff70c9e8 ffffff81 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.649896] ca10 00000000 00000001 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.658062] ca30 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.666229] ca50 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.674396] ca70 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.682563] ca90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.690730] cab0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.698898] cad0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.707064] caf0 00000000 00000000 00000000 00000000 000000ff 00000000 00000000 00000000
[ 112.715230] cb10 00000000 00000000 00000000 00000001 00000002 00000000 ff70cb20 ffffff81
[ 112.723396] cb30 00000000 00000000 00000000 00000000 397cfcb0 00000000 000000b6 00000000
[ 112.731563] cb50 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.739729] cb70* 00000171 0000017a 0000003f 00000000 01cf3308 ffffffff 01c97408 ffffffff
[ 112.747896] cb90 ff70cb90 ffffff81 ff70cb90 ffffff81 ff70cba0 ffffff81 ff70cba0 ffffff81
[ 112.756063] cbb0 00df2a30 00000000 00000100 00000000 00000000 0000002a 00000007 00000000
[ 112.764228] cbd0 ff70cbd0 ffffff81 ff70cbd0 ffffff81 ff70cbe0 ffffff81 ff70cbe0 ffffff81
[ 112.772395] cbf0 ff70cbf0 ffffff81 ff70cbf0 ffffff81 ff70cc00 ffffff81 ff70cc00 ffffff81
[ 112.780561] cc10 00001010 00000000 00000000 00000000 0000df30 02000000 00000000 00000000
[ 112.788726] cc30 00df0000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.796893] cc50 77d5af00 ffffff80 000089f0 00000000 01bf5680 ffffffff 01b59d80 ffffffff
[ 112.805060] cc70 039c8150 ffffff80 0000290b 00000000 ffee7200 fffffffe 07acd700 ffffffff
[ 112.813228] cc90 2f4b82c0 ffffff80 000053f0 00000000 009d2e00 ffffffff 007edc40 ffffffff
[ 112.821395] ccb0 00000000 00000000 000001bb 00000000 07b98400 ffffffff 00058e00 ffffffff
[ 112.829561] ccd0 2f41d500 ffffff80 0000017c 00000000 009d0600 ffffffff 07bdda00 ffffffff
[ 112.837728] ccf0 f111e1c0 ffffff81 00000163 00000000 07a44600 ffffffff 07b10a00 ffffffff
[ 112.845896] cd10 f654c000 ffffff81 00000109 00000000 07b95300 ffffffff 00000000 00000000
[ 112.854062] cd30 30084280 ffffff80 000002f7 00000000 00a02100 ffffffff fffd77c0 fffffffe
[ 112.862229] cd50 f652e400 ffffff81 000001db 00000000 07b94a00 ffffffff 00000000 00000000
[ 112.870397]
[ 112.870397] X21: 0xffffffc0129b7d90:
[ 112.875437] 7b90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.883603] 7bb0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.891770] 7bd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.899936] 7bf0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.908103] 7c10 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.916270] 7c30 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.924436] 7c50 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.932601] 7c70 00000000 00000000 00000000 00000000 00000000 dead4ead ffffffff 00000000
[ 112.940768] 7c90 ffffffff ffffffff 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.948934] 7cb0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.957100] 7cd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.965267] 7cf0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.973432] 7d10 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.981599] 7d30 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.989765] 7d50 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 112.997932] 7d70 00000000 00000000 00000000 00000000 129b7100 ffffffc0 00000002 00000000
[ 113.006098] 7d90* 129b6480 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.014265] 7db0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.022431] 7dd0 00000003 00000000 00000200 00000000 000fee00 00000000 001ffe00 00000000
[ 113.030598] 7df0 00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 113.038764] 7e10 13633e38 ffffffc0 13633e38 ffffffc0 00000000 dead4ead ffffffff 00000000
[ 113.046931] 7e30 ffffffff ffffffff 129b7e38 ffffffc0 129b7e38 ffffffc0 f222bb00 ffffff81
[ 113.055098] 7e50 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.063264] 7e70 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.071431] 7e90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.079596] 7eb0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.087763] 7ed0 00000000 00000004 00000000 00000000 00000f62 00000000 00000000 00000000
[ 113.095929] 7ef0 00000000 00000000 00000000 00000000 00000000 dead4ead ffffffff 00000000
[ 113.104095] 7f10 ffffffff ffffffff 129b7f18 ffffffc0 129b7f18 ffffffc0 129b7f28 ffffffc0
[ 113.112262] 7f30 129b7f28 ffffffc0 129b7f38 ffffffc0 129b7f38 ffffffc0 129b7f48 ffffffc0
[ 113.120427] 7f50 129b7f48 ffffffc0 129b7f58 ffffffc0 129b7f58 ffffffc0 00000000 00000000
[ 113.128593] 7f70 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.136760]
[ 113.136760] X22: 0xffffff81ff70cb60:
[ 113.141798] c960 00000000 00000000 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff
[ 113.149954] c980 00000000 00000000 ff70c988 ffffff81 ff70c988 ffffff81 ff70c998 ffffff81
[ 113.158121] c9a0 ff70c998 ffffff81 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.166287] c9c0 00000000 00000000 ff70c9c8 ffffff81 ff70c9c8 ffffff81 ff70c9d8 ffffff81
[ 113.174454] c9e0 ff70c9d8 ffffff81 ff70c9e8 ffffff81 ff70c9e8 ffffff81 00000000 00000000
[ 113.182621] ca00 00000000 00000000 00000000 00000000 00000000 00000001 00000000 00000000
[ 113.190788] ca20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.198954] ca40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.207120] ca60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.215287] ca80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.223453] caa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.231620] cac0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.239786] cae0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.247953] cb00 000000ff 00000000 00000000 00000000 00000000 00000000 00000000 00000001
[ 113.256120] cb20 00000002 00000000 ff70cb20 ffffff81 00000000 00000000 00000000 00000000
[ 113.264286] cb40 397cfcb0 00000000 000000b6 00000000 00000000 00000000 00000000 00000000
[ 113.272452] cb60* 00000000 00000000 00000000 00000000 00000171 0000017a 0000003f 00000000
[ 113.280619] cb80 01cf3308 ffffffff 01c97408 ffffffff ff70cb90 ffffff81 ff70cb90 ffffff81
[ 113.288785] cba0 ff70cba0 ffffff81 ff70cba0 ffffff81 00df2a30 00000000 00000100 00000000
[ 113.296953] cbc0 00000000 0000002a 00000007 00000000 ff70cbd0 ffffff81 ff70cbd0 ffffff81
[ 113.305118] cbe0 ff70cbe0 ffffff81 ff70cbe0 ffffff81 ff70cbf0 ffffff81 ff70cbf0 ffffff81
[ 113.313284] cc00 ff70cc00 ffffff81 ff70cc00 ffffff81 00001010 00000000 00000000 00000000
[ 113.321452] cc20 0000df30 02000000 00000000 00000000 00df0000 00000000 00000000 00000000
[ 113.329618] cc40 00000000 00000000 00000000 00000000 77d5af00 ffffff80 000089f0 00000000
[ 113.337785] cc60 01bf5680 ffffffff 01b59d80 ffffffff 039c8150 ffffff80 0000290b 00000000
[ 113.345952] cc80 ffee7200 fffffffe 07acd700 ffffffff 2f4b82c0 ffffff80 000053f0 00000000
[ 113.354117] cca0 009d2e00 ffffffff 007edc40 ffffffff 00000000 00000000 000001bb 00000000
[ 113.362284] ccc0 07b98400 ffffffff 00058e00 ffffffff 2f41d500 ffffff80 0000017c 00000000
[ 113.370450] cce0 009d0600 ffffffff 07bdda00 ffffffff f111e1c0 ffffff81 00000163 00000000
[ 113.378617] cd00 07a44600 ffffffff 07b10a00 ffffffff f654c000 ffffff81 00000109 00000000
[ 113.386783] cd20 07b95300 ffffffff 00000000 00000000 30084280 ffffff80 000002f7 00000000
[ 113.394949] cd40 00a02100 ffffffff fffd77c0 fffffffe f652e400 ffffff81 000001db 00000000
[ 113.403115]
[ 113.403115] X23: 0xffffffc0120bfb60:
[ 113.408154] f960 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.416322] f980 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.424489] f9a0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.432656] f9c0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.440822] f9e0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.448990] fa00 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.457158] fa20 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.465325] fa40 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.473493] fa60 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.481660] fa80 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.489827] faa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.497995] fac0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.506162] fae0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.514329] fb00 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.522497] fb20 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.530664] fb40 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.538831] fb60* ******** ******** ******** ******** ******** ******** ******** ********
[ 113.546999] fb80 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.555167] fba0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.563335] fbc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.571501] fbe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.579669] fc00 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.587837] fc20 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.596004] fc40 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.604172] fc60 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.612339] fc80 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.620506] fca0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.628672] fcc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.636839] fce0 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.645006] fd00 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.653174] fd20 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.661341] fd40 ******** ******** ******** ******** ******** ******** ******** ********
[ 113.669509]
[ 113.669509] X28: 0xffffffc01676baa0:
[ 113.674548] b8a0 ff706aa8 ffffff81 00000040 00000000 ffffffff 0000007f 1001059c ffffffc0
[ 113.682714] b8c0 1676b8e0 ffffffc0 1029a070 ffffffc0 00000003 00000000 00000000 00000000
[ 113.690881] b8e0 1676b9d0 ffffffc0 1029af58 ffffffc0 00000000 00000000 00000001 00000000
[ 113.699047] b900 126c2be8 ffffffc0 000001f8 00000000 f468bc00 ffffff81 301e2100 ffffff80
[ 113.707214] b920 00000000 00000000 00000000 00000000 00000dc4 00000000 69a83b00 ffffff80
[ 113.715381] b940 12ac2a08 ffffffc0 00000000 00000000 1676ba00 ffffffc0 00100dc4 ffffffc0
[ 113.723547] b960 00000000 00000000 f26a9ae0 ffffff81 00000100 00000000 00000000 00000000
[ 113.731714] b980 000000c0 00000000 00000000 00000000 1676b9b0 ffffffc0 120a3008 ffffffc0
[ 113.739881] b9a0 120a3008 ffffffc0 2bc9f200 ffffff80 1676b9d0 ffffffc0 1029afb0 ffffffc0
[ 113.748047] b9c0 00000000 00000000 df21d700 2ad28d16 1676bb20 ffffffc0 1029bdc0 ffffffc0
[ 113.756214] b9e0 00000000 00000000 66613300 ffffff80 301efa00 ffffff80 000001f8 00000000
[ 113.764381] ba00 00000013 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.772547] ba20 00000000 00000000 69a83b00 ffffff80 1676ba90 ffffffc0 11336828 ffffffc0
[ 113.780714] ba40 126c2be8 ffffffc0 00100dc4 00000400 1676ba90 ffffffc0 108d3790 ffffffc0
[ 113.788881] ba60 785dcff8 ffffff80 00000013 00000000 00000800 00000000 1676bb28 ffffffc0
[ 113.797047] ba80 785dd0b8 ffffff80 df21d700 2ad28d16 1676baf0 ffffffc0 108cd364 ffffffc0
[ 113.805214] baa0* 129b7d80 ffffffc0 69a84398 ffffff80 129b7d90 ffffffc0 00000000 00000001
[ 113.813380] bac0 00000000 00000000 66613300 ffffff80 00000000 00000000 00000cc0 00000000
[ 113.821546] bae0 1676bb00 ffffffc0 1163500c ffffffc0 1676bb50 ffffffc0 108cd4d8 ffffffc0
[ 113.829714] bb00 1676bb20 ffffffc0 102bd39c ffffffc0 f0003c00 ffffff81 df21d700 2ad28d16
[ 113.837881] bb20 1676bb30 ffffffc0 10978a50 ffffffc0 1676bb70 ffffffc0 10978ee8 ffffffc0
[ 113.846048] bb40 00000000 00000000 66613300 ffffff80 66613300 ffffff80 000001f8 00000000
[ 113.854214] bb60 1676bb80 ffffffc0 1163aba8 ffffffc0 1676bba0 ffffffc0 10979270 ffffffc0
[ 113.862381] bb80 66613388 ffffff80 66613300 ffffff80 301efa00 ffffff80 476ab868 0000007f
[ 113.870547] bba0 1676bbe0 ffffffc0 10971d2c ffffffc0 00000000 00000000 66613300 ffffff80
[ 113.878714] bbc0 301efa00 ffffff80 476ab868 0000007f 00000000 00000000 10971cf0 ffffffc0
[ 113.886881] bbe0 1676bcc0 ffffffc0 10972b7c ffffffc0 00005017 00000000 476ab868 0000007f
[ 113.895047] bc00 f6494140 ffffff81 12ae9000 ffffffc0 00000000 00000000 116345e8 ffffffc0
[ 113.903214] bc20 476ab868 0000007f 00000001 000004fc 00005017 00000000 00000000 00000000
[ 113.911381] bc40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.919547] bc60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.927714] bc80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 113.935880]
[ 113.935880] X29: 0xffffffc01676b8e0:
[ 113.940919] b6e0 00000171 0000017a 1166a060 ffffffc0 1676b710 ffffffc0 1003a180 ffffffc0
[ 113.949087] b700 96000004 00000000 1676b790 ffffffc0 1676b750 ffffffc0 11630b70 ffffffc0
[ 113.957254] b720 1676b790 ffffffc0 96000004 00000000 12a78000 ffffffc0 00000171 0000017a
[ 113.965422] b740 1676b790 ffffffc0 00000000 00000000 1676b780 ffffffc0 116312ac ffffffc0
[ 113.973589] b760 129b6480 ffffffc0 ffffffff 0000007f 1676b8e0 ffffffc0 1029a070 ffffffc0
[ 113.981755] b780 1676b8c0 ffffffc0 10012408 ffffffc0 00000171 0000017a 00000171 0000017a
[ 113.989922] b7a0 000000a0 00000000 00000122 dead0000 000000c0 00000000 ff70cb60 ffffff81
[ 113.998089] b7c0 00000000 00000000 00000169 0000017a ed64d000 ffffffc1 1029af58 ffffffc0
[ 114.006255] b7e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 114.014421] b800 00000000 00000000 476ab868 0000007f 00000000 00000000 00000000 00000000
[ 114.022588] b820 00000000 00000000 129b6480 ffffffc0 ff70cb70 ffffff81 129b7d90 ffffffc0
[ 114.030755] b840 ff70cb60 ffffff81 120bfb60 ffffffc0 00000000 00000000 00000000 00000000
[ 114.038922] b860 00000801 00000000 00000001 00000000 1676baa0 ffffffc0 1676b8e0 ffffffc0
[ 114.047089] b880 1029a018 ffffffc0 1676b8e0 ffffffc0 1029a070 ffffffc0 20400089 00000000
[ 114.055256] b8a0 ff706aa8 ffffff81 00000040 00000000 ffffffff 0000007f 1001059c ffffffc0
[ 114.063422] b8c0 1676b8e0 ffffffc0 1029a070 ffffffc0 00000003 00000000 00000000 00000000
[ 114.071589] b8e0* 1676b9d0 ffffffc0 1029af58 ffffffc0 00000000 00000000 00000001 00000000
[ 114.079756] b900 126c2be8 ffffffc0 000001f8 00000000 f468bc00 ffffff81 301e2100 ffffff80
[ 114.087923] b920 00000000 00000000 00000000 00000000 00000dc4 00000000 69a83b00 ffffff80
[ 114.096089] b940 12ac2a08 ffffffc0 00000000 00000000 1676ba00 ffffffc0 00100dc4 ffffffc0
[ 114.104256] b960 00000000 00000000 f26a9ae0 ffffff81 00000100 00000000 00000000 00000000
[ 114.112423] b980 000000c0 00000000 00000000 00000000 1676b9b0 ffffffc0 120a3008 ffffffc0
[ 114.120590] b9a0 120a3008 ffffffc0 2bc9f200 ffffff80 1676b9d0 ffffffc0 1029afb0 ffffffc0
[ 114.128756] b9c0 00000000 00000000 df21d700 2ad28d16 1676bb20 ffffffc0 1029bdc0 ffffffc0
[ 114.136922] b9e0 00000000 00000000 66613300 ffffff80 301efa00 ffffff80 000001f8 00000000
[ 114.145089] ba00 00000013 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 114.153255] ba20 00000000 00000000 69a83b00 ffffff80 1676ba90 ffffffc0 11336828 ffffffc0
[ 114.161422] ba40 126c2be8 ffffffc0 00100dc4 00000400 1676ba90 ffffffc0 108d3790 ffffffc0
[ 114.169590] ba60 785dcff8 ffffff80 00000013 00000000 00000800 00000000 1676bb28 ffffffc0
[ 114.177756] ba80 785dd0b8 ffffff80 df21d700 2ad28d16 1676baf0 ffffffc0 108cd364 ffffffc0
[ 114.185922] baa0 129b7d80 ffffffc0 69a84398 ffffff80 129b7d90 ffffffc0 00000000 00000001
[ 114.194088] bac0 00000000 00000000 66613300 ffffff80 00000000 00000000 00000cc0 00000000
[ 114.202255] Code: f9400281 d2802443 f2fbd5a3 f1002027 (a9400022)
[ 114.208342] —[ end trace 71cc07c902b8b795 ]—
228启动.txt (392 KB)
0[?6cm] Reached target Basicr System.t Storagke.
e.service: Succeeded.et User and Group Name Lookups.
[ 13.846 Starting Accou5nts Service…map.
85] systemd[1]: Finished L Starting Adbd foad Kernel Moduleor linux… chromeos_pstore.
[ istening on ude Starting Create Volatile Files and Directovries C..
13.853608] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 13.854027] syst[ OK [0m] Started Run anacron jobs.et.
md[1]: Finished StartingL LSB: automaotic crasha report generation…
d Kernel Module Starting enable ASYNC for Debian Display…
pstore_blk.8] systemd[1]: Mounting Kernel Debug File System…
[ 13. Starting Avahi mDNS/DNS-SD Stack…le System…
861075] systemd[1]: modprobe@pstore_zone.ser[ OK ] Started Regular background program processing daemon.
vice: Succeede[ OK ] Started D-Bus System Message Bus[0m.d layout…
. 13.750194] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 13.861447] systemd[1]: Finishe Starting Network Manager…
d Load Kernel M[ OK ] Started Save initial kernel messages after boot.e drm being skipped.
odule pstore_zone. Cre ate Volatile Files and Directories .
[ Starting Remove Stale Onli…t4 Metadata Check Snapshots…me Resolution…
Starting LSB: GNOME Display Manager…k Starting Networippek Time Synchronization…
13.868612] systemd[1]: Finis[ OK ] Started hSet the CPU Frequency eScaling governor.
d Load Kernel Modul Startieng Restore /etc/reso… the ppp link was ssh.ystem Boot/Shu tdown…
[ ut down…rnel Module pstor0m] Started udev Kerneel Device Manager.
13.875662 ↩︎
