官方下载的代码编译时报错,错误信息中有乱码
SDK包名称:firefly_rk3288_rk3128_android5.1_git_20211216
SDK修改内容:没有修改
Log日志:build_all.log
使用下面的命令编译的时候
./FFTools/make.sh -d firefly-rk3288 -j8 -l rk3288_box-userdebug
报错如日志所示:
/home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: 1: /home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: ELF: not found
/home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: 2: /home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: @8: not found
/home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: 3: /home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: �: not found
/home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: 4: /home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: �: not found
/home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: 5: /home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: �j�j�xZ: not found
/home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: 6: /home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: 8�j8�j��TT@T@: not found
/home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: 8: /home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: Syntax error: “(” unexpected
dirname: missing operand
Try ‘dirname --help’ for more information.
/home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: 3: /home/allwin/android/u-boot/../prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc: �: not foundmake[2]: *** [include/autoconf.mk.dep] Error 1
make[2]: *** Waiting for unfinished jobs…
make[2]: *** [include/autoconf.mk] Error 1
make[1]: *** [silentoldconfig] Error 1
make: *** No rule to make target include/config/auto.conf', needed by include/config/uboot.release’. Stop.
build_all.log (5.99 KB)
1 git reset --hard
2 git pull gitlab Firefly-RK3288:Firefly-RK3288
3 环境依赖
sudo apt-get install -y openjdk-7-jdk git-core gnupg flex bison gperf libsdl1.2-dev
libesd0-dev libwxgtk2.8-dev squashfs-tools build-essential zip curl
libncurses5-dev zlib1g-dev pngcrush schedtool libxml2 libxml2-utils
xsltproc lzop libc6-dev schedtool g+±multilib lib32z1-dev lib32ncurses5-dev
lib32readline-gplv2-dev gcc-multilib libswitch-perl
libssl1.0.0 libssl-dev bc
检查一下,以上3步是否都操作了。
我这边也有用这个SDK,测试正常使用。所以可能是你那边的编译准备/环境问题。
