下载 RK3308B Linux SDK 后,得到 Firefly-RK3308_Linux_SDK_git_20190924.7z 压缩包,
解压后,就一个 .git 目录
如何拉取代码,并编译得到烧写固件
- 看维基教程 https://wiki.t-firefly.com/zh_CN … /linux_compile.html
- SDK已采用repo来管理了
- SDK已采用repo来管理了
执行repo后出现如下错误,请问如何修复?
repo init --no-clone-bundle --repo-url https://gitlab.com/firefly-linux/git-repo.git -u https://gitlab.com/firefly-linux/manifests.git -b master -m rk3308_linux_release.xml
Downloading Repo source from https://gitlab.com/firefly-linux/git-repo.git
remote: Enumerating objects: 4481, done.
remote: Counting objects: 100% (3/3), done.
remote: Compressing objects: 100% (3/3), done.
remote: Total 4481 (delta 0), reused 0 (delta 0), pack-reused 4478
warning: ‘refs/heads/stable’ is not signed; falling back to signed release ‘v1.12.37’
/home/user/work/rk3308/RK3308-ROC-CC/.repo/repo/main.py:19: DeprecationWarning: the imp module is deprecated in favour of importlib and slated for removal in Python 3.12; see the module’s documentation for alternative uses
import imp
File “/home/user/work/rk3308/RK3308-ROC-CC/.repo/repo/main.py”, line 46, in
from subcmds.version import Version
File “/home/user/work/rk3308/RK3308-ROC-CC/.repo/repo/subcmds/init.py”, line 33, in
mod = import(name,
File “/home/user/work/rk3308/RK3308-ROC-CC/.repo/repo/subcmds/help.py”, line 19, in
from formatter import AbstractFormatter, DumbWriter
ModuleNotFoundError: No module named ‘formatter’
user@userVM:~/work/rk3308/RK3308-ROC-CC$
按照您的方法,在进行编译 buildroot 时,一直停留在 :linux-headers 4.4.118 Downloading
log 如下:
Mike@MikeVM:~/work/rk3308/rk3308_linux_release_v1.5.0a_20221212$ ./build.sh buildroot
processing option: buildroot
==========Start building buildroot==========
TARGET_BUILDROOT_CONFIG=firefly_rk3308_release
Top of tree: /home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212
#TARGET_BOARD=rk3308
#OUTPUT_DIR=output/firefly_rk3308_release
#CONFIG=firefly_rk3308_release_defconfig
make: Entering directory ‘/home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot’
GEN /home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/output/firefly_rk3308_release/Makefile
/home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/build/defconfig_hook.py -m /home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/configs/firefly_rk3308_release_defconfig /home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/output/firefly_rk3308_release/.rockchipconfig
BR2_DEFCONFIG=‘’ KCONFIG_AUTOCONFIG=/home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/output/firefly_rk3308_release/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/output/firefly_rk3308_release/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/output/firefly_rk3308_release/build/buildroot-config/tristate.config BR2_CONFIG=/home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/output/firefly_rk3308_release/.config HOST_GCC_VERSION=“9” BUILD_DIR=/home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/output/firefly_rk3308_release/build SKIP_LEGACY= BR2_DEFCONFIG=/home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/configs/firefly_rk3308_release_defconfig /home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/output/firefly_rk3308_release/build/buildroot-config/conf --defconfig=/home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/output/firefly_rk3308_release/.rockchipconfig Config.in
# configuration written to /home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot/output/firefly_rk3308_release/.config
make: Leaving directory ‘/home/Mike/work/rk3308/rk3308_linux_release_v1.5.0a_20221212/buildroot’
2024-03-19T14:55:10 >>> linux-headers 4.4.118 Downloading
要么先手动下载包或者检查网络多试几次或者科学上网
我这里遇到一个编译问题,编译到recovery的时候,出错
2024-04-11T17:18:11 >>> busybox 1.27.2 Extracting
2024-04-11T17:18:11 >>> busybox 1.27.2 Patching
2024-04-11T17:18:23 >>> busybox 1.27.2 Configuring
2024-04-11T17:18:23 >>> busybox 1.27.2 Building
Done in 16min 27s (error code: 2)
Command exited with non-zero status 2
you take 16:28.83 to build recovery
ERROR: Running build_recovery failed!
ERROR: exit code 2 from line 1080:
/usr/bin/time -f “you take %E to build recovery” $COMMON_DIR/mk-ramdisk.sh recovery.img $RK_CFG_RECOVERY
我用的是rk3308_linux_release_v1.5.0a_20221212
./build.sh 编译一直是这个样子的报错 还有救么
#TARGET_BOARD=rk3308b
#BUILD_TYPE=64
#OUTPUT_DIR=output//home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/rk3308/
#CONFIG=/home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/rk3308/_defconfig
make: Entering directory ‘/home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/buildroot’
make[1]: *** No rule to make target ‘/home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/rk3308/_defconfig’. Stop.
Makefile:83: recipe for target ‘_all’ failed
make: *** [_all] Error 2
make: Leaving directory ‘/home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/buildroot’
Making /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/rockdev/oem.img from /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/rk3308/ (auto sized)
Making /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/rockdev/oem.img from /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/rk3308/ with size(195M)
0+0 records in
0+0 records out
0 bytes copied, 2.464e-05 s, 0.0 kB/s
mke2fs 1.44.1 (24-Mar-2018)
Discarding device blocks: done
Creating filesystem with 199680 1k blocks and 50000 inodes
Filesystem UUID: 9fc2a286-4d74-479e-a63e-d374cdd47bd4
Superblock backups stored on blocks:
8193, 24577, 40961, 57345, 73729
Allocating group tables: done
Writing inode tables: done
Writing superblocks and filesystem accounting information: done
Copying /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/rk3308/ into /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/rockdev/oem.img (root permission required)
cp: error writing ‘/tmp/tmp.b8qNU5I1pp/smart_voice/talking_droid’: No space left on device
cp: cannot create directory ‘/tmp/tmp.b8qNU5I1pp/yocto/build/conf’: No space left on device
Retring with increased size…(1/10)
Making /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/rockdev/oem.img from /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/rk3308/ with size(199M)
0+0 records in
0+0 records out
0 bytes copied, 2.518e-05 s, 0.0 kB/s
/home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/rockdev/oem.img contains a ext2 file system
last mounted on /tmp/tmp.b8qNU5I1pp on Mon Jan 6 21:30:30 2025
Proceed anyway? (y,N) y
Creating filesystem with 203776 1k blocks and 51000 inodes
Filesystem UUID: 20ae7906-9761-4a79-8415-cf9baae8064a
tune2fs 1.44.1 (24-Mar-2018)
Setting maximal mount count to -1
Setting interval between checks to 0 seconds
done.
create userdata.img…Top of tree: /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308
You’re building on Linux
Lunch menu…pick a combo:
- firefly_rk3308_release
- firefly_rk3308_recovery
- firefly_rk3308_pcba
- firefly_rk3308_qt_release
Which would you like? [1] /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/userdata/
#BUILD_TYPE=64
#OUTPUT_DIR=output//home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/userdata/
#CONFIG=/home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/userdata/_defconfig
make[1]: *** No rule to make target ‘/home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/userdata/_defconfig’. Stop.
Making /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/rockdev/userdata.img from /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/userdata/ (auto sized)
Making /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/rockdev/userdata.img from /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/userdata/ with size(15M)
0+0 records in
0+0 records out
0 bytes copied, 2.4929e-05 s, 0.0 kB/s
Creating filesystem with 15360 1k blocks and 3840 inodes
Filesystem UUID: ffed593a-26f0-48e8-b63e-3d55bf2e75fb
8193
Copying /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/device/rockchip/userdata/ into /home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/rockdev/userdata.img (root permission required)
done.
create uboot.img…done.
create trust.img…done.
create loader…done.
create boot.img…done.
Image: image in rockdev is ready
Make image ok!
Make update.img
start to make update.img…
Android Firmware Package Tool v1.65
------ PACKAGE ------
Add file: ./package-file
Add file: ./Image/MiniLoaderAll.bin
Add file: ./Image/parameter.txt
Add file: ./Image/trust.img
Add file: ./Image/uboot.img
Add file: ./Image/boot.img
Add file: ./Image/rootfs.img
Add file: ./Image/recovery.img
Error: open file failed,err=2!
------ FAILED ------
Press any key to quit:
mv: cannot stat ‘/home/yuhang/project/roc_rk3308b_cc_plus/Firefly-RK3308/tools/linux/Linux_Pack_Firmware/rockdev/update.img’: No such file or directory
Make update image failed!
