ROC-RK3308B-CC-PLUS 录音没有声音
固件文件名称:ROC-RK3308B-CC-PLUS-NoUi-20200417
Log日志:log.rar
我在电路板上的MIC3 引出一个座子,接到耳机的mic
录音命令:
arecord -D hw:0,0 -c 8 -r 16000 -f S16_LE --period-size=1024 --buffer-size=4096 111.wav
arecord -D hw:0,0 -c 2 -r 16000 -f S16_LE --period-size=1024 --buffer-size=4096 222.wav
arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: rockchiprk3308b [rockchip,rk3308b-acodec], device 0: dailink-multicodecs multicodec-0
Subdevices: 1/1
Subdevice #0: subdevice #0
card 7: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 8/8
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 7: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 7/8
# tinymix contents
Number of controls: 40
ctl type num name value
0 INT 1 ADC MIC Group 0 Left Volume 3 (range 0->3)
1 INT 1 ADC MIC Group 0 Right Volume 3 (range 0->3)
2 INT 1 ADC MIC Group 1 Left Volume 3 (range 0->3)
3 INT 1 ADC MIC Group 1 Right Volume 3 (range 0->3)
4 INT 1 ADC MIC Group 2 Left Volume 3 (range 0->3)
5 INT 1 ADC MIC Group 2 Right Volume 3 (range 0->3)
6 INT 1 ADC MIC Group 3 Left Volume 3 (range 0->3)
7 INT 1 ADC MIC Group 3 Right Volume 3 (range 0->3)
8 ENUM 1 ADC MICBIAS Voltage VREFx0_5VREFx0_55VREFx0_6VREFx0_65VREFx0_7VREFx0_75VREFx0_8, VREFx0_85
9 ENUM 1 ADC Main MICBIAS Off, On
10 BOOL 1 ADC MICBIAS1 On
11 BOOL 1 ADC MICBIAS2 On
12 ENUM 1 ADC MIC Group 0 Left Switch Work, Mute
13 ENUM 1 ADC MIC Group 0 Right Switch Work, Mute
14 ENUM 1 ADC MIC Group 1 Left Switch , WorkMute
15 ENUM 1 ADC MIC Group 1 Right Switch , WorkMute
16 ENUM 1 ADC MIC Group 2 Left Switch Work, Mute
17 ENUM 1 ADC MIC Group 2 Right Switch Work, Mute
18 ENUM 1 ADC MIC Group 3 Left Switch Work, Mute
19 ENUM 1 ADC MIC Group 3 Right Switch Work, Mute
20 INT 1 ADC ALC Group 0 Left Volume 12 (range 0->31)
21 INT 1 ADC ALC Group 0 Right Volume 12 (range 0->31)
22 INT 1 ADC ALC Group 1 Left Volume 20 (range 0->31)
23 INT 1 ADC ALC Group 1 Right Volume 20 (range 0->31)
24 INT 1 ADC ALC Group 2 Left Volume 12 (range 0->31)
25 INT 1 ADC ALC Group 2 Right Volume 12 (range 0->31)
26 INT 1 ADC ALC Group 3 Left Volume 20 (range 0->31)
27 INT 1 ADC ALC Group 3 Right Volume 20 (range 0->31)
28 ENUM 1 ADC Group 0 HPF Cut-off , OffOn
29 ENUM 1 ADC Group 1 HPF Cut-off , OffOn
30 ENUM 1 ADC Group 2 HPF Cut-off , OffOn
31 ENUM 1 ADC Group 3 HPF Cut-off , OffOn
32 INT 1 DAC LINEOUT Left Volume 3 (range 0->3)
33 INT 1 DAC LINEOUT Right Volume 3 (range 0->3)
34 INT 1 DAC HPOUT Left Volume 30 (range 0->30)
35 INT 1 DAC HPOUT Right Volume 30 (range 0->30)
36 INT 1 DAC HPMIX Left Volume 1 (range 0->1)
37 INT 1 DAC HPMIX Right Volume 1 (range 0->1)
38 BOOL 1 vad switch Off
39 INT 2 Master Playback Volume 99, 99 (range 0->99)
log.rar (789 Bytes)
硬件参考电路
