Android7.1 应用默认播放设备
固件文件名称:firefly_rk3399_industry7.1_git_20211216
Log日志:logcat.txt
Android7.1 功放默认选择了rkhdmidpsound作为播放设备。
我使用的是第三方的功放,tinyplay播放正常,在安卓端点击APP默认声音输出是rkhdmidpsound,请问如何修改为自定义的功放设备?
固件信息:
Android7.1industry/firefly_rk3399_industry7.1_git_20211216/firefly-rk3399-Industry
commit:
commit 83168832667a152212c2394d48dc93dc0eec1426
Author: cjp <service@t-firefly.com>
Date: Wed Oct 26 17:32:39 2022 +0800
1.Optimize mipi dsi1 2.Update dongle lib 3.Fix sdio clock
部分log:
[b]
rk3399_firefly_aio_lvds:/ #
ogcat -s AudioHardwareTiny audio_hw_hdmiin alsa_route                         <
--------- beginning of main
--------- beginning of system
01-18 12:33:03.888   278   278 D AudioHardwareTiny: ALSA Audio Version: V1.1.0
01-18 12:33:03.888   278   278 D AudioHardwareTiny: adev_open: buf =  0 [awaw8266codec  ]: aw_aw8266-codec - aw,aw8266-codec
01-18 12:33:03.888   278   278 D AudioHardwareTiny: adev_open: buf =                       aw,aw8266-codec
01-18 12:33:03.888   278   278 D AudioHardwareTiny: adev_open: buf =  1 [rkhdmidpsound  ]: rk-hdmi-dp-soun - rk-hdmi-dp-sound
01-18 12:33:03.888   278   278 D AudioHardwareTiny: get_card_number: number =1,card_name =  1 [rkhdmidpsound  ]: rk-hdmi-dp-soun - rk-hdmi-dp-sound
01-18 12:33:03.944   278   278 D alsa_route: Can not get config table for sound card1 rkhdmidpsound, so get default config table.
01-18 12:33:03.944   278   278 D AudioHardwareTiny: adev_open: buf =                       rk-hdmi-dp-sound
01-18 12:33:03.944   278   278 D AudioHardwareTiny: audio hal adev_open_output_stream devices = 0x2, flags = 2, samplerate = 48000
01-18 12:33:03.944   278   278 D AudioHardwareTiny: out->config.rate = 44100, out->config.channels = 2 out->config.format = 0,out->config.flag = 0
01-18 12:33:03.961   278   278 D AudioHardwareTiny: adev_set_mode: set_mode = 0
01-18 12:33:03.969   278   347 D AudioHardwareTiny: out_set_parameters: kvpairs = routing=2
01-18 12:33:03.969   278   347 V AudioHardwareTiny: out_set_parameters: exit: status(0)
01-18 12:33:03.969   278   278 D AudioHardwareTiny: pcm_config->rate:44100,in->requested_rate:48000,in->channel_mask:2
01-18 12:33:03.971   278   278 D AudioHardwareTiny: in->mSpeexFrameSize:560
01-18 12:33:03.971   278   278 D AudioHardwareTiny: create new input stream for dev(0x00000004), rate(48000), channel(0x0000000C)
01-18 12:33:10.210   278   356 D AudioHardwareTiny: [-----]adev_set_parameters: kvpairs = orientation=undefined
01-18 12:33:10.890   278   278 D AudioHardwareTiny: [-----]adev_set_parameters: kvpairs = A2dpSuspended=false
01-18 12:33:12.045   278   347 D AudioHardwareTiny: 1212121 start_output_stream
01-18 12:33:12.045   278   347 E AudioHardwareTiny: vicent r 44100  c 2  ps 512 pc 6
01-18 12:33:12.045   278   347 D AudioHardwareTiny: start_output_stream device: 2
01-18 12:33:12.045   278   347 D AudioHardwareTiny: read_out_sound_card: buf =  0 [awaw8266codec  ]: aw_aw8266-codec - aw,aw8266-codec
01-18 12:33:12.045   278   347 D AudioHardwareTiny: read_out_sound_card: buf =                       aw,aw8266-codec
01-18 12:33:12.045   278   347 D AudioHardwareTiny: read_out_sound_card: buf =  1 [rkhdmidpsound  ]: rk-hdmi-dp-soun - rk-hdmi-dp-sound
01-18 12:33:12.045   278   347 D AudioHardwareTiny: get_card_number: number =1,card_name =  1 [rkhdmidpsound  ]: rk-hdmi-dp-soun - rk-hdmi-dp-sound
01-18 12:33:12.045   278   347 D AudioHardwareTiny: read_out_sound_card: buf =                       rk-hdmi-dp-sound
01-18 12:33:12.045   278   347 E AudioHardwareTiny: start_output_stream() >>>> PCM_CARD_HDMI:-1, PCM_CARD:-1, HdmiIn_snd_config.config:4
01-18 12:33:12.045   278   347 D alsa_route: route_info->sound_card 0, route_info->devices 0
01-18 12:33:12.046   278   347 D alsa_route: route_set_controls() set route 11
01-18 12:33:12.202   278   347 D AudioHardwareTiny: out_set_parameters: kvpairs = routing=2
01-18 12:33:12.202   278   347 V AudioHardwareTiny: out_set_parameters: exit: status(0)
01-18 12:33:12.225   278   347 D AudioHardwareTiny: out_set_parameters: kvpairs = routing=2
01-18 12:33:12.225   278   347 V AudioHardwareTiny: out_set_parameters: exit: status(0)
01-18 12:33:12.258   278   347 D AudioHardwareTiny: out_set_parameters: kvpairs = routing=2
01-18 12:33:12.258   278   347 V AudioHardwareTiny: out_set_parameters: exit: status(0)
01-18 12:33:12.281   278   347 D AudioHardwareTiny: out_set_parameters: kvpairs = routing=2
01-18 12:33:12.281   278   347 V AudioHardwareTiny: out_set_parameters: exit: status(0)
01-18 12:33:13.913   278  1015 D AudioHardwareTiny: [-----]adev_set_parameters: kvpairs = A2dpSuspended=false
01-18 12:33:15.622   278  1015 D AudioHardwareTiny: [-----]adev_set_parameters: kvpairs = orientation=portrait
01-18 12:33:16.321   278   347 D alsa_route: route_set_controls() set route 24
01-18 12:33:16.321   278   347 D AudioHardwareTiny: close device
[/b]
logcat.txt (658 KB)
意思默认要从aw8226输出,不要从HDMI输出吗?
对的,是这个意思
Android默认是接了HDMI 显示器后本体Audio就不出声了,可以自己进行修改播放路由选择
老哥有修改思路吗,是修改HAL层还是framwork层,不太熟悉Android,可否提供些思路呢
替换附件库试下
/system/vendor/lib/hw/audio.primary.rk30board.so
/system/vendor/lib64/hw/audio.primary.rk30board.so
audio.rar (162 KB)
zhangzhenzhao 发表于 2024-4-11 09:09
替换附件库试下
/system/vendor/lib64/hw/audio.prim …
现在Android7可以播放了,还请帮忙导出一份Android10的对应文件
附上Android10 的logcat日志
logcat_Android10.zip (68.4 KB)
audio.primary.rk30board_Android10.rar (186 KB)
可以用,感谢,顺便问下这个自己修改也能达到这个效果吗
