ubuntu20.04镜像chroot之后无法apt-get update
固件文件名称:Ubuntu20.04-Xfce_RK3588_v3.11-5_20240115.img
固件下载地址:百度网盘
Log日志:无法apt-get update.txt
需要再ubuntu20.04中安装gedit,file-roller,中文输入法等功能,尝试过用rsync的方法,吧所有安装好的板子上的rootfs用rsync的方法导出,但是导出后该文件系统无法自动挂载u盘,所以只能将原本的镜像mount出来之后chroot该文件系统,然后安装;但是再apt-get update的时候报错,报错信息如下:
Err:1 Index of /ubuntu-ports/ | 清华大学开源软件镜像站 | Tsinghua Open Source Mirror focal InRelease
Temporary failure resolving ‘mirrors.tuna.tsinghua.edu.cn
Err:2 Index of /ubuntu-ports/ | 清华大学开源软件镜像站 | Tsinghua Open Source Mirror focal-updates InRelease
Err:3 Index of /ubuntu-ports/ | 清华大学开源软件镜像站 | Tsinghua Open Source Mirror focal-backports InRelease
Err:4 Index of /ubuntu-ports/ | 清华大学开源软件镜像站 | Tsinghua Open Source Mirror focal-security InRelease
Reading package lists… Done
E: Sub-process returned an error code
W: Failed to fetch http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/dists/focal/InRelease Temporary failure resolving ‘mirrors.tuna.tsinghua.edu.cn
W: Failed to fetch http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/dists/focal-updates/InRelease Temporary failure resolving ‘mirrors.tuna.tsinghua.edu.cn
W: Failed to fetch http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/dists/focal-backports/InRelease Temporary failure resolving ‘mirrors.tuna.tsinghua.edu.cn
W: Failed to fetch http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports/dists/focal-security/InRelease Temporary failure resolving ‘mirrors.tuna.tsinghua.edu.cn
W: Some index files failed to download. They have been ignored, or old ones used instead.
无法apt-get update.txt (1.37 KB)
可以在板子上部署好后,导出rootfs,再重新打包
https://wiki.t-firefly.com/zh_CN/Firefly-Linux-Guide/first_use.html#dao-chu-rootfs
您好现在还有个问题就是安装完中文后终端会有乱码,软码如下:
xinput
��Virtual core pointer id=2 [master pointer (3)]
� ��Virtual core XTEST pointer id=4 [slave pointer (2)]
� ��SEM USB Keyboard Consumer Control id=8 [slave pointer (2)]
� ��E-Signal USB Gaming Mouse id=10 [slave pointer (2)]
� ��E-Signal USB Gaming Mouse Consumer Control id=13 [slave pointer (2)]
� ��goodix-ts id=15 [slave pointer (2)]
��Virtual core keyboard id=3 [master keyboard (2)]
��Virtual core XTEST keyboard id=5 [slave keyboard (3)]
��adc-keys id=6 [slave keyboard (3)]
��SEM USB Keyboard id=7 [slave keyboard (3)]
��SEM USB Keyboard System Control id=9 [slave keyboard (3)]
��E-Signal USB Gaming Mouse Keyboard id=11 [slave keyboard (3)]
��E-Signal USB Gaming Mouse System Control id=12 [slave keyboard (3)]
��rk-headset id=14 [slave keyboard (3)]
��SEM USB Keyboard Consumer Control id=16 [slave keyboard (3)]
��E-Signal USB Gaming Mouse Consumer Control id=17 [slave keyboard (3)]
按照4.1导出镜像的时候直接瞬间结束,而且在对应的路径下没有产生img文件,打印信息如下:
root@firefly:/home/firefly# cd /
root@firefly:/# ff
ff_export_rootfs ffmpeg ffprobe
ffgo ffplay ff_rotate
root@firefly:/# ff_export_rootfs /media/firefly/3CEA-6B7D/
https://www.t-firefly.com/
tysasdgda
tysasdgda
root@firefly:/# cd /home/firefly/
root@firefly:/home/firefly# ff_export_rootfs /media/firefly/3CEA-6B7D/
tysasdgda
root@firefly:/home/firefly# sync
1 要导出到外部存储设备,例如U盘
2 固件是否有改动过
zhangzhenzhao 发表于 2024-4-17 08:44
1 要导出到外部存储设备,例如U盘
2 固件是否有改动过
就是插上u盘,想导出到u盘里面;只改了rootfs,就是多安装一部分功能,gedit,中文输入法,仅此而已
我们测试过是没问题,建议烧写默认固件再验证看下
