固件文件名称:AIO-3568J_Ubuntu20.04-r3108_v1.3.2g_240111
Log日志:info.txt
使用RK3568J开发板安装官方ubuntu固件后无法运行ffmedia的demo,固件安装后系统信息如下:
OS: Ubuntu 20.04.6 LTS
MODEL: AIO-3568J HDMI (Linux)
FIREFLY: v3.10-8-gdbbe44f6
DATE: 20240111
KERNEL: Linux version 4.19.232 (lanzj@tchip14) (rk356x/firefly: 50ce91e4819b9979ae6371d22f2edd59e09bce5c) (sdk version: rk356x_linux_release_20240109_v1.3.2g.xml) (gcc version 10.3.1 20210621 (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)), GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #2 SMP Wed Jan 10 11:40:40 CST 2024
ffmedia是克隆https://gitlab.com/firefly-linux/ffmedia_release.git后编译的。
现在问题是使用demo进行播放 demo /usr/local/test.mp4 -o 1280x720 -x 0执行时显示信息如下:
Firefly FFMedia: v2.2.4
INFO: ff_media: start_instance:
INFO: ff_media: start_instance: enable file reader
INFO: 16ModuleFileReader: init: Get Video Resolution( 1920 x 1080 )
rga_api version 1.3.0_[0] (RGA is compiling with meson base: $PRODUCT_BASE)
Input Source: /usr/local/test.mp4
Input format: 1920x1080 H264
Output format: 1280x720 NV12
Encode type: H264
Decoder: enable
Rga: enable
Encoder: disable
RtspClient: disable
File writer: disable
File: disable
Rtsp push: disable
==================Pipe===================
arm_release_ver of this libmali is ‘g2p0-01eac0’, rk_so_ver is ‘4’.
ModuleFileReader (H264 1920x1080)
|—>ModuleMppDec (NV12 1920x1080)
|—>ModuleRga (NV12 1280x720)
|—>ModuleRendererVideo (NV12 1280x720)
INFO: 10MppDecoder: getTimeoutSample: 0x55990634e0 frame info changed 1 error 0 discard 0
INFO: 16ModuleFileReader: work: Produce EOS
并且会产生一个绿屏并保持,请问是什么原因呢?
还有我运行它的拉流解码demo_simple时报错:
./demo_simple
INFO: ff_media: connectToServer: connected to server 192.168.188.79:554
INFO: ff_media: RTPSource: RTPSock current buffer size is(425984)
INFO: 16ModuleRtspClient: init: rtsp para w h: 1920 1080, ws hs: 1920 1080, format: H265
INFO: 15DrmDisplayPlane: setupDisplayDevice: 0 0
INFO: 15DrmDisplayPlane: setupDisplayDevice: conn_id = 150 enc_id = 149 crtc_id = 71
INFO: 15DrmDisplayPlane: setup: plane_id = -1
ERROR: 15DrmDisplayPlane: setup: drmModeSetPlane failed, ret -2
ERROR: ff_media: main: drm display init failed
使用的流地址我使用ffplay测试过是正常的,为什么会出现这个问题?求解答。
info.txt (1.59 KB)
