SDK包名称:rk3328_linux_release_v2.5.1_20210301_firefly_split
SDK修改内容:什么都没修改,只是参考编译 Ubuntu 固件 ( GPT ) — Firefly Wiki
Log日志:3328linux20240507.rar
[ 7.498124] rockchip-saradc ff280000.saradc: failed to get regulator, -517
[ 7.500082] #0: rockchip,rk3328
[ 7.500389] #1: rockchip,hdmi
[ 7.501909] Freeing unused kernel memory: 1216K
/dev/console is OK
NAME=Buildroot
VERSION=2018.02-rc3-g1e7d09e844
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME=“Buildroot 2018.02-rc3”
Starting logging: OK
[ 7.584675] devfreq ff300000.gpu: Couldn’t update frequency transition information.
Populating /dev using udev: [ 7.595435] udevd[184]: starting version 3.2.7
[ 7.596884] random: udevd: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
[ 7.598059] random: udevd: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
[ 7.598998] random: udevd: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
[ 7.599937] random: udevd: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
[ 7.600940] random: udevd: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
[ 7.605888] udevd[184]: specified group ‘kvm’ unknown
[ 7.618572] udevd[185]: starting eudev-3.2.7
[ 7.663699] random: udevd: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
[ 7.671486] random: udevd: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
done
Initializing random number generator… [ 7.961141] random: dd: uninitialized urandom read (512 bytes read, 2 bits of entropy available)
done.
mount: /userdata: special device /dev/block/by-name/userdata does not exist.
Starting network: cmdline=storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=feaf09f78d5750ac rockchip_jtag ro rootwait earlyprintk=uart8250-32bit,0xff130000 swiotlb=1 kpti=0 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
read console from cmdline is /dev/ttyFIQ0
Starting recovery on Thu Jan 1 00:00:07 1970
failed to read font: res=-1, fall back to the compiled-in font
cannot find/open a drm device: No such file or directory
gr_init faile
Noui upgrade
recovery filesystem table
0 (null) /tmp ramdisk (null) (null) (null)
1 /dev/root / ext2 rw,noauto 0 1
2 proc /proc proc defaults 0 0
3 devpts /dev/pts devpts defaults,gid=5,mode=620 0 0
4 tmpfs /dev/shm tmpfs mode=0777 0 0
5 tmpfs /tmp tmpfs mode=1777 0 0
6 tmpfs /run tmpfs mode=0755,nosuid,nodev 0 0
7 sysfs /sys sysfs defaults 0 0
8 debug /sys/kernel/debug debugfs defaults 0 0
9 pstore /sys/fs/pstore pstore defaults 0 0
10 /dev/block/by-name/misc /misc emmc defaults 0 0
11 /dev/block/by-name/oem /oem ext2 defaults 0 2
12 /dev/block/by-name/userdata /userdata ext4 defaults 0 2
buf = /dev/block/by-name/misc
### get mount_ponit = /dev/block/by-name/misc ###
stat /dev/block/by-name/misc try 1: No such file or directory
OK
Debug: configfs_init
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0’: No such file or directory
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0’: No such file or directory
[ 8.100907] file system registered
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0’: No such file or directory
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/rndis.gs0’: No such file or directory
[ 8.128171] Mass Storage Function, version: 2009/09/11
[ 8.128687] LUN: removable file: (no medium)
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uvc.gs6’: No such file or directory
[ 8.191841] read descriptors
[ 8.192128] read strings
stat /dev/block/by-name/misc try 2: No such file or directory
sh: write error: No such device
Starting input-event-daemon: input-event-daemon: Start parsing /etc/input-event-daemon.conf…
input-event-daemon: Adding device: /dev/input/event0…
input-event-daemon: Start listening on 1 devices…
done
/etc/init.d/rcS: line 28: alsactl: not found
[root@buildroot:/]# stat /dev/block/by-name/misc try 3: No such file or directory
stat /dev/block/by-name/misc try 4: No such file or directory
stat /dev/block/by-name/misc try 5: No such file or directory
stat /dev/block/by-name/misc try 6: No such file or directory
stat /dev/block/by-name/misc try 7: No such file or directory
stat /dev/block/by-name/misc try 8: No such file or directory
stat /dev/block/by-name/misc try 9: No such file or directory
stat /dev/block/by-name/misc try 10: No such file or directory
failed to stat /dev/block/by-name/misc
emmc_point is
sd_point is (null)
sd_point_2 is (null)
read cmdline
Boot from non-SDcard
devices is not MTD.
[root@buildroot:/]#
[root@buildroot:/]# stat /dev/block/by-name/misc try 5: No such file or directory
[root@buildroot:/]#
[root@buildroot:/]#
[root@buildroot:/]#
[root@buildroot:/]#
[root@buildroot:/]#
[root@buildroot:/]# stat /dev/block/by-name/misc try 6: No such file or directory
3328linux20240507.rar (13.2 KB)
