rk3568 usb用不了,求大佬help
下面是整个日志
root@RK356X:/# dmesg | grep -i usb
[    0.108472] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree
[    0.108479] vcc5v0_usb: supplied by dc_12v
[    0.108525] vcc5v0_usb: 5000 mV
[    0.108668] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV
[    0.108850] vcc5v0_host: supplied by vcc5v0_usb
[    0.109314] vcc5v0_otg: supplied by vcc5v0_usb
[    0.116038] usbcore: registered new interface driver usbfs
[    0.116098] usbcore: registered new interface driver hub
[    0.116143] usbcore: registered new device driver usb
[    0.208705] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[    0.208773] phy phy-fe8a0000.usb2-phy.0: Linked as a consumer to regulator.5
[    0.208883] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree
[    0.208891] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply property in node /usb2-phy@fe8a0000/otg-port failed
[    0.208971] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree
[    0.209019] phy phy-fe8a0000.usb2-phy.1: Linked as a consumer to regulator.6
[    0.210284] extcon extcon1: failed to create extcon usb2-phy link
[    0.210339] phy phy-fe8b0000.usb2-phy.2: Looking up phy-supply from device tree
[    0.210382] phy phy-fe8b0000.usb2-phy.2: Linked as a consumer to regulator.5
[    0.210484] phy phy-fe8b0000.usb2-phy.3: Looking up phy-supply from device tree
[    0.210538] phy phy-fe8b0000.usb2-phy.3: Linked as a consumer to regulator.5
[    0.210619] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply from device tree
[    0.210627] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply property in node /usb2-phy@fe8b0000/otg-port failed
[    0.210645] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[    0.543807] usbcore: registered new interface driver rndis_wlan
[    0.543877] usbcore: registered new interface driver rtl8150
[    0.543925] usbcore: registered new interface driver r8152
[    0.543972] usbcore: registered new interface driver asix
[    0.544016] usbcore: registered new interface driver ax88179_178a
[    0.544062] usbcore: registered new interface driver cdc_ether
[    0.544106] usbcore: registered new interface driver rndis_host
[    0.544165] usbcore: registered new interface driver cdc_ncm
[    0.544210] usbcore: registered new interface driver cdc_mbim
[    0.555216] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.557566] ehci-platform fd800000.usb: EHCI Host Controller
[    0.557741] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[    0.557973] ehci-platform fd800000.usb: irq 12, io mem 0xfd800000
[    0.568562] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[    0.568779] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.568798] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.568818] usb usb1: Product: EHCI Host Controller
[    0.568831] usb usb1: Manufacturer: Linux 4.19.232 ehci_hcd
[    0.568843] usb usb1: SerialNumber: fd800000.usb
[    0.569240] hub 1-0:1.0: USB hub found
[    0.571808] ehci-platform fd880000.usb: EHCI Host Controller
[    0.572005] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[    0.572227] ehci-platform fd880000.usb: irq 14, io mem 0xfd880000
[    0.585232] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[    0.585423] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.585442] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.585461] usb usb2: Product: EHCI Host Controller
[    0.585474] usb usb2: Manufacturer: Linux 4.19.232 ehci_hcd
[    0.585487] usb usb2: SerialNumber: fd880000.usb
[    0.585878] hub 2-0:1.0: USB hub found
[    0.586623] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.586879] ohci-platform fd840000.usb: Generic Platform OHCI controller
[    0.587050] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[    0.587236] ohci-platform fd840000.usb: irq 13, io mem 0xfd840000
[    0.646047] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.646065] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.646074] usb usb3: Product: Generic Platform OHCI controller
[    0.646081] usb usb3: Manufacturer: Linux 4.19.232 ohci_hcd
[    0.646088] usb usb3: SerialNumber: fd840000.usb
[    0.646484] hub 3-0:1.0: USB hub found
[    0.646996] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[    0.647173] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[    0.647345] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000
[    0.706029] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.706047] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.706055] usb usb4: Product: Generic Platform OHCI controller
[    0.706062] usb usb4: Manufacturer: Linux 4.19.232 ohci_hcd
[    0.706069] usb usb4: SerialNumber: fd8c0000.usb
[    0.706455] hub 4-0:1.0: USB hub found
[    0.708103] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[    0.708828] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.708846] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.708861] usb usb5: Product: xHCI Host Controller
[    0.708874] usb usb5: Manufacturer: Linux 4.19.232 xhci-hcd
[    0.708887] usb usb5: SerialNumber: xhci-hcd.0.auto
[    0.709290] hub 5-0:1.0: USB hub found
[    0.709800] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[    0.709826] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    0.709902] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.710023] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    0.710041] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.710055] usb usb6: Product: xHCI Host Controller
[    0.710068] usb usb6: Manufacturer: Linux 4.19.232 xhci-hcd
[    0.710081] usb usb6: SerialNumber: xhci-hcd.0.auto
[    0.710469] hub 6-0:1.0: USB hub found
[    0.710961] usbcore: registered new interface driver cdc_acm
[    0.710978] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.711033] usbcore: registered new interface driver cdc_wdm
[    0.711248] usbcore: registered new interface driver uas
[    0.711370] usbcore: registered new interface driver usb-storage
[    0.711465] usbcore: registered new interface driver usbserial_generic
[    0.711500] usbserial: USB Serial support registered for generic
[    0.711552] usbcore: registered new interface driver cp210x
[    0.711583] usbserial: USB Serial support registered for cp210x
[    0.711662] usbcore: registered new interface driver ftdi_sio
[    0.711694] usbserial: USB Serial support registered for FTDI USB Serial Device
[    0.711926] usbcore: registered new interface driver keyspan
[    0.711969] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    0.711993] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    0.712016] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    0.712048] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    0.712104] usbcore: registered new interface driver option
[    0.712135] usbserial: USB Serial support registered for GSM modem (1-port)
[    0.712406] usbcore: registered new interface driver oti6858
[    0.712438] usbserial: USB Serial support registered for oti6858
[    0.712490] usbcore: registered new interface driver pl2303
[    0.712534] usbserial: USB Serial support registered for pl2303
[    0.712601] usbcore: registered new interface driver qcserial
[    0.712635] usbserial: USB Serial support registered for Qualcomm USB modem
[    0.712710] usbcore: registered new interface driver sierra
[    0.712742] usbserial: USB Serial support registered for Sierra USB modem
[    0.714108] usbcore: registered new interface driver usbtouchscreen
[    0.779834] usbcore: registered new interface driver uvcvideo
[    0.779856] USB Video Class driver (1.1.1)
[    0.785182] usbcore: registered new interface driver bfusb
[    0.785284] usbcore: registered new interface driver btusb
[    0.818612] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    0.835304] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    0.958766] usb 5-1: new full-speed USB device number 2 using xhci-hcd
[    0.967943] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[    0.968007] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    0.968038] usb 1-1: Product: USB2.0 Hub
[    0.969963] hub 1-1:1.0: USB hub found
[    0.983652] usb 2-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[    0.983672] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    0.983686] usb 2-1: Product: USB2.0 Hub
[    0.984388] hub 2-1:1.0: USB hub found
[    1.090274] usbcore: registered new interface driver usbhid
[    1.090292] usbhid: USB HID core driver
[    1.098289] usbcore: registered new interface driver snd-usb-audio
[    1.103281] usb 5-1: New USB device found, idVendor=1a86, idProduct=e5e3, bcdDevice= 2.00
[    1.103313] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.103322] usb 5-1: Product: HID Transfer
[    1.103329] usb 5-1: Manufacturer: 9LQ0172005164
[    1.139300] input: 9LQ0172005164 HID Transfer as /devices/platform/usbhost/fd000000.dwc3/xhci-hcd.0.auto/usb5/5-1/5-1:1.0/0003:1A86:E5E3.0001/input/input2
[    1.196075] hid-multitouch 0003:1A86:E5E3.0001: input,hidraw0: USB HID v1.10 Device [9LQ0172005164 HID Transfer] on usb-xhci-hcd.0.auto-1/input0
[    1.201331] hid-generic 0003:1A86:E5E3.0002: hiddev96,hidraw1: USB HID v1.10 Device [9LQ0172005164 HID Transfer] on usb-xhci-hcd.0.auto-1/input1
插入usb2.0端口没有反应
