固件文件名称:rk3308_linux_release_v1.5.0a_20221212
Log日志:日志.zip
请教下,我用RK3308H的芯片,更换emmc,大小同样是8G的,但是在kernel启动后提示无法挂载文件系统,但是在uboot中使用mmc info是能够看到emmc的容量等信息的。
=> mmc info
Device: dwmmc@ff490000
Manufacturer ID: 32
OEM: 101
Timing Interface: High Speed
Tran Speed: 52000000
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.3 GiB WRREL
Boot Capacity: 4 MiB ENH
RPMB Capacity: 4 MiB ENH
如上所示,是在uboot中看到的emmc的信息。
然后我的分区表设置是这样的:
FIRMWARE_VER:8.1
MACHINE_MODEL:RK3308
MACHINE_ID:007
MANUFACTURER: RK3308
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: 3308
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
TYPE: GPT
CMDLINE: mtdparts=rk29xxnand:0x00008000@0x00002000(uboot),0x00008000@0x0000A000(trust),0x00008000@0x00012000(misc),0x00010000@0x0001A000(recovery),0x00010000@0x0002A000(boot),0x000C0000@0x0003A000(rootfs),0x00040000@0x000FA000(oem),-@0x013A000(userdata:grow)
uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9
然后因为芯片用的是3308h,是自带的64M ddr,所以改了rk3308_common.h的头文件:
#define ENV_MEM_LAYOUT_SETTINGS
“scriptaddr=0x00500000\0”
“pxefile_addr_r=0x00600000\0”
“fdt_addr_r=0x01800000\0”
“kernel_addr_no_bl32_r=0x00280000\0”
“kernel_addr_r=0x00680000\0”
“kernel_addr_c=0x01a80000\0”
“ramdisk_addr_r=0x02d00000\0”
然后内核打印中,可以看到emmc初始化是成功了的,也读取到了容量信息,
[ 1.767715] =======================================================
[ 1.767925] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.768135] =======================================================
[ 1.768345] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 1.768558] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.768769] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[ 1.768982] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.769194] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.769401] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: wifi OOB pin isn’t defined.
[ 1.769774] usbcore: registered new interface driver rtl8188eu
[ 1.770190] hctosys: unable to open rtc device (rtc0)
[ 1.784300] vcc_sd: disabling
[ 1.784371] vccio_sd: disabling
[ 2.011426] mmc1: MAN_BKOPS_EN bit is not set
[ 2.012575] mmc_host mmc1: Bus speed (slot 0) = 50176000Hz (slot req 52000000Hz, actual 50176000HZ div = 0)
[ 2.014662] mmc_host mmc1: Bus speed (slot 0) = 98304000Hz (slot req 52000000Hz, actual 49152000HZ div = 1)
[ 2.014926] mmc1: new DDR MMC card at address 0001
[ 2.016233] mmcblk1: mmc1:0001 MMC8GB 7.28 GiB
[ 2.016728] mmcblk1boot0: mmc1:0001 MMC8GB partition 1 4.00 MiB
[ 2.017288] mmcblk1boot1: mmc1:0001 MMC8GB partition 2 4.00 MiB
[ 2.017781] mmcblk1rpmb: mmc1:0001 MMC8GB partition 3 4.00 MiB
[ 2.023621] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.264713] vendor storage:20160801 ret = 0
u▒ 2.791478]
[ 2.904831] ALSA device list:
[ 2.905983] #0: rockchip,rk3308b-acodec
[ 2.906798] #1: rockchip,rk3308b-i2s
[ 2.907601] #7: Loopback 1
[ 2.929761] Freeing unused kernel memory: 384K
[ 4.287990] pstore: decompression failed;returned -5
Starting logging: OK
Welcome to Rockchip Linux SDK
Populating /dev using udev: [ 5.777588] udevd[178]: starting version 3.2.5
[ 6.590761] udevd[179]: starting eudev-3.2.5
done
Initializing random number generator… done.
Will now mount all partitions in /etc/fstab
^CNote: Create /.skip_fsck to skip fsck
- The check might take a while if didn’t shutdown properly!
[ 60.054863] hwrng: no data available
Handling misc: /dev/mmcblk1p3 /misc emmc defaults 0
Unsupported file system emmc for /dev/mmcblk1p3
Handling oem: /dev/mmcblk1p7 /oem ext2 defaults 2
Checking /dev/mmcblk1p7(ext2)
e2fsck 1.43.9 (8-Feb-2018)
/dev/mmcblk1p7: clean, 34/6848 files, 17906/27296 blocks
Resizing /dev/mmcblk1p7(ext2)
[ 72.625176] EXT4-fs (mmcblk1p7): couldn’t mount as ext3 due to feature incompatibilities
[ 72.881759] EXT4-fs (mmcblk1p7): mounted filesystem without journal. Opts: (null)
resize2fs 1.43.9 (8-Feb-2018)
[ 73.197191] EXT4-fs (mmcblk1p7): resizing filesystem from 27296 to 131072 blocks
[ 75.819145] EXT4-fs (mmcblk1p7): resized filesystem to 131072
Filesystem at /dev/mmcblk1p7 is mounted on /tmp/tmp.SNCawn; on-line resizing required
old_desc_blocks = 1, new_desc_blocks = 1
The filesystem on /dev/mmcblk1p7 is now 131072 (1k) blocks long.
tune2fs 1.43.9 (8-Feb-2018)
Mounting /dev/mmcblk1p7(ext2) on /oem
[ 77.234129] EXT4-fs (mmcblk1p7): couldn’t mount as ext3 due to feature incompatibilities
[ 77.391899] EXT4-fs (mmcblk1p7): mounted filesystem without journal. Opts: (null)
Handling userdata: /dev/mmcblk1p8 /userdata ext2 defaults 2
Checking /dev/mmcblk1p8(ext2)
/dev/mmcblk1p8 was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
[ 99.761786] hrtimer: interrupt took 2577750 ns
^C[ 259.779757] hwrng: no data available
^CPass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/mmcblk1p8: 14/437248 files (0.0% non-contiguous), 115296/6991852 blocks
Resizing /dev/mmcblk1p8(ext2)
[ 325.179766] hwrng: no data available
[ 325.596791] EXT4-fs (mmcblk1p8): couldn’t mount as ext3 due to feature incompatibilities
[ 326.308928] EXT4-fs (mmcblk1p8): mounted filesystem without journal. Opts: (null)
The filesystem is already 6991852 (1k) blocks long. Nothing to do!
Mounting /dev/mmcblk1p8(ext2) on /userdata
[ 327.912833] EXT4-fs (mmcblk1p8): couldn’t mount as ext3 due to feature incompatibilities
[ 328.367280] EXT4-fs (mmcblk1p8): mounted filesystem without journal. Opts: (null)
Log saved to /tmp/mountall.log
Starting network: cmdline=storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 earlycon=uart8250,mmio32,0xff0e0000 swiotlb=1 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 rootwait=8 snd_aloop.index=7 snd_aloop.use_raw_jiffies=1 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1 rootdelay=1
read console from cmdline is /dev/ttyFIQ0
Starting recovery on Thu Jan 1 00:05:29 1970
Recovery System have UI defined.
failed to read font: res=-1, fall back to the compiled-in font
cannot find/open a drm device: No such file or directory
recovery filesystem table
0 (null) /tmp ramdisk (null) (null) (null)
1 /dev/root / ext2 rw,noauto 0 1
2 proc /proc proc defaults 0 0
3 devpts /dev/pts devpts defaults,gid=5,mode=620 0 0
4 tmpfs /dev/shm tmpfs mode=0777 0 0
5 tmpfs /tmp tmpfs mode=1777 0 0
6 tmpfs /run tmpfs mode=0755,nosuid,nodev 0 0
7 sysfs /sys sysfs defaults 0 0
8 debug /sys/kernel/debug debugfs defaults 0 0
9 pstore /sys/fs/pstore pstore defaults 0 0
10 /dev/block/by-name/misc /misc emmc defaults 0 0
11 /dev/block/by-name/oem /oem ext2 defaults 0 2
12 /dev/block/by-name/userdata /userdata ext2 defaults 0 2
[I/]RECOVERY devices is not MTD.
emmc_point is /dev/mmcblk1
sd_point is (null)
sd_point_2 is (null)
Recovery start…
read cmdline
Boot from non-SDcard
[I/]RECOVERY Boot command: boot-recovery
[I/]RECOVERY Got arguments from boot message
Command: “recovery” “–wipe_all”
firefly: umount sdcard
Formatting /userdata…
OK
format ‘/dev/block/by-name/userdata’ to ext2 filesystem
executing ‘/sbin/mke2fs’
Debug: configfs_init
[ 332.382037] file system registered
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0’: No such file or directory
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/rndis.gs0’: No such file or directory
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/acm.gs6’: No such file or directory
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/mass_storage.0’: No such file or directory
mkdir: can’t create directory ‘/sys/kernel/config/usb_gadget/rockchip/functions/uvc.gs6’: No such file or directory
[ 336.287657] read descriptors
[ 336.300895] read strings
[ 337.370112] dwc2 ff400000.usb: bound driver configfs-gadget
[ 337.491947] dwc2 ff400000.usb: new device is high-speed
[ 337.528156] dwc2 ff400000.usb: dwc2_hsotg_process_req_status: direction out?
Starting input-event-daemon: input-event-daemon: open(/dev/input/event3): No such file or directory
input-event-daemon: Exiting…
done
[root@buildroot:/]# [ 343.054995] dwc2 ff400000.usb: new device is high-speed
[ 343.158862] ------------[ cut here ]------------
[ 343.159686] WARNING: at drivers/usb/dwc2/gadget.c:2310
[ 343.159994] Modules linked in:
[ 343.160345]
[ 343.160819] CPU: 0 PID: 154 Comm: mmcqd/1 Not tainted 4.4.143 #96
[ 343.161157] Hardware name: Firefly ROC-RK3308B-CC-PLUS analog mic board (DT)
[ 343.161554] task: ffffffc00130f080 task.stack: ffffffc00396c000
[ 343.162036] PC is at dwc2_hsotg_epint+0x42c/0x654
[ 343.162440] LR is at dwc2_hsotg_irq+0x31c/0x650
[ 343.162825] pc : [] lr : [] pstate: 000001c5
[ 343.163139] sp : ffffffc003f48bb0
[ 343.163451] x29: ffffffc003f48bb0 x28: 0000000000000000
[ 343.164007] x27: 0000000000000000 x26: 0000000004000030
[ 343.164554] x25: 0000000000801000 x24: ffffffc002d000e4
[ 343.165091] x23: 0000000000000001 x22: 0000000000000000
[ 343.165626] x21: ffffffc002d00018 x20: 0000000000000008
[ 343.166160] x19: ffffffc002d58cd8 x18: 0000000000000000
[ 343.166686] x17: 0000000000000000 x16: 00000000d744fcc9
[ 343.167218] x15: 0000000000000002 x14: 0000000000000012
[ 343.167751] x13: 0000000080008000 x12: ffffffc002d00018
[ 343.168287] x11: 0000000000000004 x10: ffffff80088a830c
[ 343.168820] x9 : 0000000000000000 x8 : ffffffc0038000f0
[ 343.169359] x7 : ffffffc003800028 x6 : ffffffc003800000
[ 343.169893] x5 : 00000000fffffffa x4 : 0000000000000000
[ 343.170416] x3 : 0000000000002099 x2 : ffffff8009000908
[ 343.170949] x1 : 0000000000000000 x0 : ffffff8008ca060f
[ 343.171506]
[ 343.171506] PC: 0xffffff80085c3a5c:
[ 343.171893] 3a5c b9000041 aa1303e1 f8448c22 eb01005f 54001340 d1016042 52800003 aa1303e1
[ 343.173319] 3a7c 97fffc3b f9402e60 f9400400 97fff6f6 b9409262 79411a61 0b020021 b9009261
[ 343.174726] 3a9c 5287ffe2 6b02003f 540011c9 52800020 0a020021 39025260 b9009261 36181234
[ 343.176122] 3abc b94ae2a0 340011e0 350011d6 34001137 b00036e0 91183c00 39400801 35000081
[ 343.177516] 3adc d4210000 52800021 39000801 39423a60 3717e500 36280114 f94002a0 d0001c62
[ 343.178907] 3afc b0002781 2a1603e3 91114042 91010c21 97f97cbe 395a32a0 3607e3c0 363fe3b4
[ 343.180302] 3b1c b94ae2a0 35ffe360 aa1303e1 aa1503e0 97fff783 17ffff17 6b01001f 54ffe7e8
[ 343.181694] 3b3c 3902527f 17ffff3d b94ae2a0 34ffe8c0 39423a60 36100240 79411a60 7100041f
[ 343.183147]
[ 343.183147] LR: 0xffffff80085c4364:
[ 343.183531] 4364 2a1b03e2 2a1503e1 aa1303e0 97fff6b3 110006b5 9100239c 17ffffed f9400675
[ 343.184933] 4384 912062b5 b94002b5 d5033d9f f9400660 91207000 b9400000 d5033d9f 0a0002b5
[ 343.186330] 43a4 5280001c 53107ebb 12003eb5 395a3660 6b00039f 540002ca 350001bb 395a3660
[ 343.187725] 43c4 6b00037f 54fff46a 34fff455 360000b5 52800022 2a1b03e1 aa1303e0 97fffcb4
[ 343.189119] 43e4 1100077b 53017eb5 17fffff5 360000bb 52800002 2a1c03e1 aa1303e0 97fffcac
[ 343.190513] 4404 1100079c 53017f7b 17ffffe9 5280001b 17ffffeb 350000c5 aa1303e0 97fffad4
[ 343.191907] 4424 14000003 b946ba60 34ffff80 365000d4 f9400660 91005000 d5033e9f 52808001
[ 343.193301] 4444 b9000001 37380dd4 36300194 f9400260 90002781 91020421 97f97a96 f9400660
[ 343.194753]
[ 343.194753] SP: 0xffffffc003f48b30:
[ 343.195134] 8b30 00000000 00000000 00000001 00000000 02d000e4 ffffffc0 00801000 00000000
[ 343.196518] 8b50 04000030 00000000 00000000 00000000 00000000 00000000 03f48bb0 ffffffc0
[ 343.197891] 8b70 085c43e4 ffffff80 03f48bb0 ffffffc0 085c3adc ffffff80 000001c5 00000000
[ 343.199280] 8b90 01c69380 ffffffc0 02d58cd8 ffffffc0 00000000 00000080 02d00018 ffffffc0
[ 343.200673] 8bb0 03f48c10 ffffffc0 085c43e4 ffffff80 02d00018 ffffffc0 00040000 00000000
[ 343.202062] 8bd0 00000001 00000000 08951468 ffffff80 00000008 00000000 02d000e4 ffffffc0
[ 343.203437] 8bf0 00801000 00000000 04000030 00000000 00000000 00000000 08004010 ffffff80
[ 343.204814] 8c10 03f48c70 ffffffc0 080d87d0 ffffff80 02c18600 ffffffc0 00000000 00000000
[ 343.206286]
[ 343.206286] X0: 0xffffff8008ca058f:
[ 343.206668] 058c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.208035] 05ac 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.209394] 05cc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.210757] 05ec 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.212125] 060c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.213477] 062c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.214834] 064c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.216193] 066c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.217545] 068c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.219017]
[ 343.219017] X2: 0xffffff8009000888:
[ 343.219401] 0888 00178500 00000000 0000000f 0000002f 00000000 00010001 00000000 00000000
[ 343.220849] 08a8 00000b8f 000002c6 0c100020 00000000 00000000 00000000 00040000 00000000
[ 343.222296] 08c8 00179c00 00000000 0000000f 0000002f 00000000 00010001 00000000 00000000
[ 343.223734] 08e8 00000b8f 000002c6 0c100020 00000000 00000000 00000000 00008000 00000000
[ 343.225171] 0908 00002090 00000000 00000000 01e14c14 0000000d 01e14c14 00000400 00000000
[ 343.226615] 0928 00000080 00000000 00000000 03100050 0000000d 03100050 00000400 00000000
[ 343.228059] 0948 00000080 00000000 00000000 33b3165a 0000000d 33b3165a 00000400 00000000
[ 343.229500] 0968 00000080 00000000 00000000 d5c4c3a0 0000000d d5c4c3a0 00000400 00000000
[ 343.231101]
[ 343.231101] X6: 0xffffffc0037fff80:
[ 343.231486] ff80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.232849] ffa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.234214] ffc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.235579] ffe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.236933] 0000 00000001 0000003f 03800248 ffffffc0 00000000 00000000 03800018 ffffffc0
[ 343.238323] 0020 03800018 ffffffc0 00000000 00000000 00204600 ffffffc0 00204800 ffffffc0
[ 343.239710] 0040 00204a00 ffffffc0 00204c00 ffffffc0 00204e00 ffffffc0 03612a00 ffffffc0
[ 343.241106] 0060 03612c00 ffffffc0 03612e00 ffffffc0 03613000 ffffffc0 03613200 ffffffc0
[ 343.242590]
[ 343.242590] X7: 0xffffffc0037fffa8:
[ 343.242976] ffa8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.244338] ffc8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.245699] ffe8 00000000 00000000 00000000 00000000 00000000 00000000 00000001 0000003f
[ 343.247056] 0008 03800248 ffffffc0 00000000 00000000 03800018 ffffffc0 03800018 ffffffc0
[ 343.248454] 0028 00000000 00000000 00204600 ffffffc0 00204800 ffffffc0 00204a00 ffffffc0
[ 343.249838] 0048 00204c00 ffffffc0 00204e00 ffffffc0 03612a00 ffffffc0 03612c00 ffffffc0
[ 343.251228] 0068 03612e00 ffffffc0 03613000 ffffffc0 03613200 ffffffc0 03613400 ffffffc0
[ 343.252624] 0088 03613600 ffffffc0 03613800 ffffffc0 03613a00 ffffffc0 03613c00 ffffffc0
[ 343.254095]
[ 343.254095] X8: 0xffffffc003800070:
[ 343.254480] 0070 03613000 ffffffc0 03613200 ffffffc0 03613400 ffffffc0 03613600 ffffffc0
[ 343.255880] 0090 03613800 ffffffc0 03613a00 ffffffc0 03613c00 ffffffc0 03613e00 ffffffc0
[ 343.257273] 00b0 0367c000 ffffffc0 0367c200 ffffffc0 0367c400 ffffffc0 0367c600 ffffffc0
[ 343.258664] 00d0 0367c800 ffffffc0 0367ca00 ffffffc0 0367cc00 ffffffc0 0367ce00 ffffffc0
[ 343.260062] 00f0 0367d000 ffffffc0 0367d200 ffffffc0 0367d400 ffffffc0 0367d600 ffffffc0
[ 343.261453] 0110 0367d800 ffffffc0 0367da00 ffffffc0 0367dc00 ffffffc0 0367de00 ffffffc0
[ 343.262847] 0130 036ce200 ffffffc0 036ce400 ffffffc0 036ce600 ffffffc0 036ce800 ffffffc0
[ 343.264242] 0150 036cea00 ffffffc0 036cec00 ffffffc0 036cf000 ffffffc0 036cf200 ffffffc0
[ 343.265745]
[ 343.265745] X10: 0xffffff80088a828c:
[ 343.266134] 828c ffffff80 080bd958 ffffff80 00000000 00000000 080b6e98 ffffff80 080bda84
[ 343.267528] 82ac ffffff80 080c5fe0 ffffff80 080c4284 ffffff80 080c395c ffffff80 080c2610
[ 343.268923] 82cc ffffff80 080c1fe4 ffffff80 080c16f4 ffffff80 080c0c40 ffffff80 080c0bf8
[ 343.270313] 82ec ffffff80 080be774 ffffff80 080c23a8 ffffff80 080c1d3c ffffff80 40200800
[ 343.271704] 830c 00000080 00000000 00000000 00082040 00000000 0c284860 00000001 2b4b6270
[ 343.273083] 832c 0000010f 4c627078 0002102d 00000000 000003ea 000007be 00000b7d 00000f28
[ 343.274457] 834c 000012be 00001641 000019b0 00001d0d 00002057 0000238f 000026b5 000029ca
[ 343.275833] 836c 00002cce 00002fc2 000032a6 0000357a 0000383e 00003af3 00003d99 00004031
[ 343.277326]
[ 343.277326] X12: 0xffffffc002cfff98:
[ 343.277712] ff98 00000000 00000000 00000000 00000000 00000000 00000000 12fd28db 00000000
[ 343.279089] ffb8 00000000 00000000 02d08090 ffffffc0 00206a80 ffffffc0 00000000 00000000
[ 343.280476] ffd8 01386420 ffffffc0 41ed0011 00002e1d 00000000 00000000 00000000 00000000
[ 343.281849] fff8 00000000 00000000 02d3cf80 ffffffc0 036c2250 ffffffc0 08429218 ffffff80
[ 343.283243] 0018 036c2010 ffffffc0 09000000 ffffff80 000801b0 00100400 02240200 0007ffff
[ 343.284636] 0038 01214bff 000303cc 4f54310a 00006664 02d586d8 ffffffc0 00000003 00000003
[ 343.286018] 0058 158f000f 00000000 02883000 ffffffc0 ffffffe0 0000000f 02d00070 ffffffc0
[ 343.287406] 0078 02d00070 ffffffc0 085b6ab0 ffffff80 00000000 00000000 00000000 00000000
[ 343.289022]
[ 343.289022] X19: 0xffffffc002d58c58:
[ 343.289405] 8c58 00000000 00000000 00000001 00000000 00000000 00000000 02d58c70 ffffffc0
[ 343.290776] 8c78 02d58c70 ffffffc0 00000000 3466660c 30303030 73752e30 00000062 00000000
[ 343.292168] 8c98 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 343.293528] 8cb8 00000000 00000000 02d58d80 ffffffc0 02d5b280 ffffffc0 08429218 ffffff80
[ 343.294924] 8cd8 03ba9418 ffffffc0 02d58d6d ffffffc0 08c5a0c8 ffffff80 02d58cf0 ffffffc0
[ 343.296319] 8cf8 02d58cf0 ffffffc0 00000031 00400000 00000040 00000000 00000000 00000000
[ 343.297698] 8d18 00000000 00000000 01c693d8 ffffffc0 01c693d8 ffffffc0 02d00018 ffffffc0
[ 343.299092] 8d38 01c69380 ffffffc0 00000000 00000000 00000000 00000000 00000012 00000000
[ 343.300568]
[ 343.300568] X21: 0xffffffc002cfff98:
[ 343.300955] ff98 00000000 00000000 00000000 00000000 00000000 00000000 12fd28db 00000000
[ 343.302325] ffb8 00000000 00000000 02d08090 ffffffc0 00206a80 ffffffc0 00000000 00000000
[ 343.303709] ffd8 01386420 ffffffc0 41ed0011 00002e1d 00000000 00000000 00000000 00000000
[ 343.305090] fff8 00000000 00000000 02d3cf80 ffffffc0 036c2250 ffffffc0 08429218 ffffff80
[ 343.306481] 0018 036c2010 ffffffc0 09000000 ffffff80 000801b0 00100400 02240200 0007ffff
[ 343.307871] 0038 01214bff 000303cc 4f54310a 00006664 02d586d8 ffffffc0 00000003 00000003
[ 343.309249] 0058 158f000f 00000000 02883000 ffffffc0 ffffffe0 0000000f 02d00070 ffffffc0
[ 343.310638] 0078 02d00070 ffffffc0 085b6ab0 ffffff80 00000000 00000000 00000000 00000000
[ 343.312154]
[ 343.312154] X24: 0xffffffc002d00064:
[ 343.312539] 0064 ffffffc0 ffffffe0 0000000f 02d00070 ffffffc0 02d00070 ffffffc0 085b6ab0
[ 343.313938] 0084 ffffff80 00000000 00000000 00000000 00000000 08ab3295 ffffff80 00000000
[ 343.315315] 00a4 00000000 02c18480 ffffffc0 00000000 00000000 08ab329c ffffff80 00000000
[ 343.316693] 00c4 00000000 02c18500 ffffffc0 00000000 00000000 00000000 00000000 00000008
[ 343.318062] 00e4 002d002c 02d64c00 ffffffc0 00000019 00000000 02d5b0c0 ffffffc0 00000000
[ 343.319450] 0104 00000000 00000000 00000000 00000000 00000000 00000000 00000000 02c16a00
[ 343.320809] 0124 ffffffc0 ffffffe0 0000000f 02d00130 ffffffc0 02d00130 ffffffc0 085b94e0
[ 343.322199] 0144 ffffff80 00000000 00000000 00000000 00000000 00000000 00000000 085b75c0
[ 343.323762]
[ 343.323762] X29: 0xffffffc003f48b30:
[ 343.324146] 8b30 00000000 00000000 00000001 00000000 02d000e4 ffffffc0 00801000 00000000
[ 343.325527] 8b50 04000030 00000000 00000000 00000000 00000000 00000000 03f48bb0 ffffffc0
[ 343.326908] 8b70 085c43e4 ffffff80 03f48bb0 ffffffc0 085c3adc ffffff80 000001c5 00000000
[ 343.328298] 8b90 01c69380 ffffffc0 02d58cd8 ffffffc0 00000000 00000080 02d00018 ffffffc0
[ 343.329682] 8bb0 03f48c10 ffffffc0 085c43e4 ffffff80 02d00018 ffffffc0 00040000 00000000
[ 343.331071] 8bd0 00000001 00000000 08951468 ffffff80 00000008 00000000 02d000e4 ffffffc0
[ 343.332447] 8bf0 00801000 00000000 04000030 00000000 00000000 00000000 08004010 ffffff80
[ 343.333823] 8c10 03f48c70 ffffffc0 080d87d0 ffffff80 02c18600 ffffffc0 00000000 00000000
[ 343.335193]
[ 343.335507] —[ end trace d7623370a4f57054 ]—
[ 343.335791] Call trace:
[ 343.336213] Exception stack(0xffffffc003f489e0 to 0xffffffc003f48b10)
[ 343.336762] 89e0: ffffffc002d58cd8 0000008000000000 ffffffc003f48bb0 ffffff80085c3adc
[ 343.337296] 8a00: 0000004fe4dc5100 0000000000000001 ffffff80080f49a4 ffffff80080b9c2c
[ 343.337818] 8a20: ffffffc003f48a50 ffffffc003f48a28 ffffffc003f48a28 0000000000000000
[ 343.338348] 8a40: 0000004fe4dcae19 ffffff8008bf9580 ffffffc003f48a70 ffffff80080f4998
[ 343.338874] 8a60: ffffffc003f4aee8 ffffffc003f48d68 ffffffc003f48a80 ffffff8008674528
[ 343.339389] 8a80: ffffff8008ca060f 0000000000000000 ffffff8009000908 0000000000002099
[ 343.339911] 8aa0: 0000000000000000 00000000fffffffa ffffffc003800000 ffffffc003800028
[ 343.340423] 8ac0: ffffffc0038000f0 0000000000000000 ffffff80088a830c 0000000000000004
[ 343.340935] 8ae0: ffffffc002d00018 0000000080008000 0000000000000012 0000000000000002
[ 343.341357] 8b00: 00000000d744fcc9 0000000000000000
[ 343.341839] [] dwc2_hsotg_epint+0x42c/0x654
[ 343.342297] [] dwc2_hsotg_irq+0x31c/0x650
[ 343.342826] [] handle_irq_event_percpu+0x98/0x128
[ 343.343313] [] handle_irq_event+0x48/0x78
[ 343.343832] [] handle_fasteoi_irq+0xc0/0x128
[ 343.344310] [] generic_handle_irq+0x18/0x2c
[ 343.344787] [] __handle_domain_irq+0xa8/0xac
[ 343.345234] [] gic_handle_irq+0x7c/0xa8
[ 343.345626] Exception stack(0xffffffc003f48d90 to 0xffffffc003f48ec0)
[ 343.346079] 8d80: ffffffc003f48dc0 0000008000000000
[ 343.346605] 8da0: ffffffc003f48ef0 ffffff8008080f14 0000000040000145 0000000000000000
[ 343.347118] 8dc0: 0000000000000000 ffffff8008bc3000 0000000000000100 0000000000000020
[ 343.347639] 8de0: 00ffffffffffffff 00000001f33d4485 000000000007a990 ffffffc003f4db68
[ 343.348148] 8e00: 0000000000000005 0000000000000000 ffffff80088a830c 0000000000000004
[ 343.348663] 8e20: ffffffc002d00018 0000000080008000 0000000000000012 0000000000000002
[ 343.349176] 8e40: 00000000d744fcc9 0000000000000000 0000000000000000 ffffff8008ca6bc0
[ 343.349696] 8e60: ffffff8008bc3000 0000000000208940 ffffff8008be5000 000000000000000a
[ 343.350225] 8e80: ffffffc00130f080 ffffffc003f45060 ffffff8008be5000 0000000000000000
[ 343.350747] 8ea0: 0000000000000002 ffffffc003f48ef0 ffffff800809c72c ffffffc003f48ef0
[ 343.351203] [] el1_irq+0xb4/0x128
[ 343.351712] [] irq_exit+0x80/0xc8
[ 343.352195] [] __handle_domain_irq+0x78/0xac
[ 343.352635] [] gic_handle_irq+0x7c/0xa8
[ 343.353026] Exception stack(0xffffffc00396fa30 to 0xffffffc00396fb60)
[ 343.353478] fa20: 0000000000000000 ffffffc00130f080
[ 343.353999] fa40: 0000000000000029 0000000000000010 0000000000000780 ffffff8008cf0ec0
[ 343.354513] fa60: ffffffc0033caf08 0000000000000002 00000001ffffbfff 0000000000000001
[ 343.355011] fa80: 0000000000000750 0000000000000000 0000000000000000 0000000000000400
[ 343.355519] faa0: 0000000000000008 0000000001a116fe 00000000d744fcc9 0000000000000000
[ 343.356047] fac0: 0000000000000000 ffffffc0033caf08 ffffffc00130f080 ffffffc001d6cd00
[ 343.356575] fae0: ffffffc0033caf08 0000000000000140 ffffffc00130f080 ffffffc002d8ea10
[ 343.357100] fb00: ffffffc002d8e800 0000000000000000 ffffffc002d8eba8 ffffffc00396fb60
[ 343.357625] fb20: ffffff800817c428 ffffffc00396fb60 ffffff800817c44c 0000000080000145
[ 343.358158] fb40: ffffffc00396fb60 ffffff800817c368 ffffffffffffffff ffffff8008340d84
[ 343.358611] [] el1_irq+0xb4/0x128
[ 343.359129] [] end_buffer_async_write+0x1ac/0x1b0
[ 343.359626] [] end_bio_bh_io_sync+0x40/0x54
[ 343.360129] [] bio_endio+0x94/0x9c
[ 343.360586] [] blk_update_request+0x154/0x2b0
[ 343.361040] [] blk_update_bidi_request+0x20/0x7c
[ 343.361488] [] blk_end_bidi_request+0x20/0x68
[ 343.361924] [] blk_end_request+0x10/0x18
[ 343.362416] [] mmc_blk_issue_rw_rq+0x464/0x85c
[ 343.362887] [] mmc_blk_issue_rq+0x390/0x3b0
[ 343.363360] [] mmc_queue_thread+0xbc/0x164
[ 343.363801] [] kthread+0xd4/0xe4
[ 343.364248] [] ret_from_fork+0x10/0x50
[ 348.688093] dwc2 ff400000.usb: new device is high-speed
[ 354.315870] dwc2 ff400000.usb: new device is high-speed
executed ‘/sbin/mke2fs’ done
executed ‘/sbin/mke2fs’ return 0
executing ‘/sbin/e2fsck’
到这里,是提示文件系统挂载失败,或者有些分区的文件系统不兼容,请问下大佬们,这是emmc芯片没正常工作起来吗,还是哪里的参数设置的不对?
日志.zip (10.2 KB)
