固件文件名称:正点原子sdk
固件下载地址:链接:百度网盘-链接不存在 提取码:7ow2
Log日志:session.log
自制底板固态无法使用
[ 0.105043] reg-fixed-voltage pcie30-avdd0v9: Looking up vin-supply from device tree
[ 0.105050] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.105104] pcie30_avdd0v9: 900 mV
[ 0.105235] reg-fixed-voltage pcie30-avdd0v9: pcie30_avdd0v9 supplying 900000uV
[ 0.105310] reg-fixed-voltage pcie30-avdd1v8: Looking up vin-supply from device tree
[ 0.105317] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.105358] pcie30_avdd1v8: 1800 mV
[ 0.105503] reg-fixed-voltage pcie30-avdd1v8: pcie30_avdd1v8 supplying 1800000uV
[ 0.105584] vcc3v3_pcie: supplied by dc_12v
[ 0.105625] vcc3v3_pcie: 3300 mV
[ 0.105769] reg-fixed-voltage gpio-regulator: vcc3v3_pcie supplying 3300000uV
[ 0.201049] rk-pcie 3c0800000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.201125] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.11
[ 0.209810] snps pcie3phy FW update! size 8192
[ 0.223662] rk-pcie 3c0800000.pcie: missing legacy IRQ resource
[ 0.223689] rk-pcie 3c0800000.pcie: Missing config reg space
[ 0.223706] rk-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[ 0.223733] rk-pcie 3c0800000.pcie: err 0xf0000000..0xf00fffff → 0xf0000000
[ 0.223752] rk-pcie 3c0800000.pcie: IO 0xf0100000..0xf01fffff → 0xf0100000
[ 0.223769] rk-pcie 3c0800000.pcie: MEM 0xf0200000..0xf1ffffff → 0xf0200000
[ 0.223780] rk-pcie 3c0800000.pcie: MEM 0x380000000..0x3bfffffff → 0x380000000
[ 1.232749] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x3
[ 2.246053] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x3
[ 3.259428] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x3
[ 4.276057] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.289361] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x3
[ 6.299328] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x3
[ 7.312665] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.326004] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x3
[ 9.339344] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x3
[ 10.352696] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x3
[ 11.366039] rk-pcie 3c0800000.pcie: PCIe Link Fail
[ 11.366072] rk-pcie 3c0800000.pcie: failed to initialize host
session.log (73 KB)
