运行SOPHON-DEMO的Qwen出现内存报错
固件文件名称:Public-All-1684-Ubuntu2004-Sdk2309LTS_SP1-Build202
固件下载地址:百度网盘
Log日志:qwen_run.log
步骤1、git clone https://github.com/sophgo/sophon-demo工程步骤2、cd Qwen目录
步骤3、先执行./scripts/download.sh下载模型
步骤4、pip3 install -r python/requirements.txt 和安装sophon_arm_pcie-3.7.0-py3-none-any.whl依赖
步骤5、streamlit run python/web_demo.py
错误显示-cmd终端显示:
[2024-06-17 10:28:10.560] [error] [tensor.cpp:403] bm_memset_device failed, return=4
[bmlib_memory][error] bm_alloc_gmem failed, dev_id = 0, size = 0x0
[BM_CHECK][error] BM_CHECK_RET fail /workspace/libsophon/bmlib/src/bmlib_memory.cpp: bm_malloc_device_byte_heap_mask: 705
[2024-06-17 10:28:10.597] [error] [tensor.cpp:396] bm_malloc_device_type() err=5, size=0
[bmlib_memory][error] bm_device_mem_range_valid saddr=0xfffffffff eaddr=0xfffffffff out of range
[bmlib_memory][error] memset wrong memory addr 0xfffffffff
[2024-06-17 10:28:10.597] [error] [tensor.cpp:403] bm_memset_device failed, return=4
[2024-06-17 10:28:10.635] [error] [tensor.cpp:396] bm_malloc_device_type() err=5, size=0
[2024-06-17 10:28:10.635] [error] [tensor.cpp:403] bm_memset_device failed, return=4
[2024-06-17 10:28:10.672] [error] [tensor.cpp:396] bm_malloc_device_type() err=5, size=0
[2024-06-17 10:28:10.672] [error] [tensor.cpp:403] bm_memset_device failed, return=4
[2024-06-17 10:28:10.710] [error] [tensor.cpp:396] bm_malloc_device_type() err=5, size=0
[2024-06-17 10:28:10.710] [error] [tensor.cpp:403] bm_memset_device failed, return=4
[2024-06-17 10:28:10.747] [error] [tensor.cpp:396] bm_malloc_device_type() err=5, size=0
[2024-06-17 10:28:10.747] [error] [tensor.cpp:403] bm_memset_device failed, return=4
错误显示-串口终端显示:
[ 3690.300620][4] ion_alloc failed(-22): len 0 heap_id_mask 4 flags 0
[ 3690.306888][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.313185][4] ion_alloc failed(-22): len 0 heap_id_mask 1 flags 0
[ 3690.319452][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.325633][4] ion_alloc failed(-22): len 0 heap_id_mask 2 flags 0
[ 3690.331897][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.338074][4] ion_alloc failed(-22): len 0 heap_id_mask 4 flags 0
[ 3690.344337][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.350833][4] ion_alloc failed(-22): len 0 heap_id_mask 1 flags 0
[ 3690.357103][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.363282][4] ion_alloc failed(-22): len 0 heap_id_mask 2 flags 0
[ 3690.369548][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.375725][4] ion_alloc failed(-22): len 0 heap_id_mask 4 flags 0
[ 3690.381988][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.388292][4] ion_alloc failed(-22): len 0 heap_id_mask 1 flags 0
[ 3690.394554][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.400743][4] ion_alloc failed(-22): len 0 heap_id_mask 2 flags 0
[ 3690.407011][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.413193][4] ion_alloc failed(-22): len 0 heap_id_mask 4 flags 0
[ 3690.419463][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.425752][4] ion_alloc failed(-22): len 0 heap_id_mask 1 flags 0
[ 3690.432020][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.438205][4] ion_alloc failed(-22): len 0 heap_id_mask 2 flags 0
[ 3690.444486][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
[ 3690.450671][4] ion_alloc failed(-22): len 0 heap_id_mask 4 flags 0
[ 3690.456941][4] ion_ioctl ion alloc failed, fd=-22, from streamlit
qwen_run.log (86.2 KB)
可能是 FireflyChat 占用了内存导致的,执行 sudo systemctl stop FireflyChat 命令关闭 FireflyChat 后再继续尝试运行 demo
Multius 发表于 2024-6-17 15:11
可能是 FireflyChat 占用了内存导致的,执行 sudo systemctl stop FireflyChat 命令关闭 FireflyChat 后 …
试过还是不行
bing20138 发表于 2024-6-17 15:33
试过还是不行
使用的具体是 Qwen 的哪一个模型?模型最终编译出来的 bmodel 文件有多大体积?
也试过./memory_edit.sh -c -npu 7615 -vpu 3072 -vpp 3072修改TPU内存也是不行的
qwen-7b_int4_1dev.bmodel 4.78GB
难道是因为这个原因?
bing20138 发表于 2024-6-17 16:06
难道是因为这个原因?
这里的说明是对于编译模型的机器的要求,与模型运行无关
这个尺寸的 int4 的量化模型应该是足够在 1684x 上面运行的,但由于 Qwen 第一代模型的适配工作也有些时日了,具体原因难以排查。
建议使用 Qwen1.5 或者 Qwen2 进行部署验证。
Firefly | 让科技更简单,让生活更智能 (t-firefly.com),我们在这里提供了 Qwen1.5 编译好的 bmodel 文件,可直接使用。
换QWEN1.5会报AttributeError: module ‘sophon.sail’ has no attribute ‘EngineLLM’
这样改还是会内存报错
bing20138 发表于 2024-6-17 16:52
这样改还是会内存报错
现在模型是用firefly官方的模型文件
才注意到仓库的差异,关于大模型的部署,我们优先推荐参考LLM-TPU这个仓库,目前我们的模型部署代码均以此仓库作为参考标准
我现在LLM-TPU工程,执行./run.sh --model qwen1.5-1.8b --arch soc会报cp: cannot stat ‘chat.cpython-310-x86_64-linux-gnu.so’: No such file or directory错误
bing20138 发表于 2024-6-17 18:02
我现在LLM-TPU工程,执行./run.sh --model qwen1.5-1.8b --arch soc会报cp: cannot stat 'chat.cpython-310 …
这个./run.sh 脚本有问题,在机器上编译是生成不了x86的.so文件的,这里需要修改这个脚本或者参考./run.sh脚本最后一段手动运行
Multius 发表于 2024-6-18 09:23
这个./run.sh 脚本有问题,在机器上编译是生成不了x86的.so文件的,这里需要修改这个脚本或者参考./run.s …
好的,已解决,3Q3Q 就是run_demo.sh脚本问题
