用教程方法打开rk3288的uart3失败,跪求解答
1.按照教程将sdk包中的是dts中加入下面的代码:
&uart_gps {
status = “okay”;
dma-names = “!tx”, “!rx”;
pinctrl-0 = <&uart3_xfer &uart3_cts>;
2.返回kernel目录执行 make命令
3.将生成的kernel resource写入板子中,启动设备
4.将做好的串口转usb线连接两个设备,出现问题:
     @  如果接入调试串口,串口转usb电路板上提示灯正常闪烁
      @接入打开的uart3串口,串口转usb提示灯一直显示,没有闪烁??这是为什么啊
     @用ls 查看dev/ttys*,结果显示没有ttys3,但我用echo  向设备输入后,再用ls显示设备,此时能正常显示
    @如何操作,设备一打开时就能用ls显示出ttys3设备
1|shell@rk3288:/ $ ls /dev/ttyS*
/dev/ttyS0
/dev/ttyS2
shell@rk3288:/ $ ls /dev/ttyS* //执行过echo 111 >/dev/ttyS3后
/dev/ttyS0
/dev/ttyS2
/dev/ttyS3
shell@rk3288:/ $ ls /dev/ttyS* 执行过echo 111 >/dev/ttyS1后
/dev/ttyS0
/dev/ttyS1
/dev/ttyS2
/dev/ttyS3
/dts-v1/;
#include “rk3288.dtsi”
#include “lcd-box.dtsi”
fiq-debugger {
status = “okay”;
hsic-usb-hub{
	compatible = "hub_reset";
	reset,pin =<&gpio7 GPIO_A6 GPIO_ACTIVE_HIGH>;	// hub reset pin
	status = "disabled";
wireless-wlan {
    compatible = "wlan-platdata";
/* wifi_chip_type - wifi chip define
* bcmwifi ==> like ap6xxx, rk90x;
* rtkwifi ==> like rtl8188xx, rtl8723xx,rtl8812auv;
* esp8089 ==> esp8089;
* other   ==> for other wifi;
wifi_chip_type = "bcmwifi";
    sdio_vref = <1800>; //1800mv or 3300mv
//keep_wifi_power_on;
    //power_ctrl_by_pmu;
    power_pmu_regulator = "act_ldo3";
    power_pmu_enable_level = <1>; //1->HIGH, 0->LOW
    //vref_ctrl_enable;
    //vref_ctrl_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
    vref_pmu_regulator = "act_ldo3";
    vref_pmu_enable_level = <1>; //1->HIGH, 0->LOW
    WIFI,poweren_gpio = <&gpio4 GPIO_D4 GPIO_ACTIVE_HIGH>;
    WIFI,host_wake_irq = <&gpio4 GPIO_D6 GPIO_ACTIVE_HIGH>;
    //WIFI,reset_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_LOW>;
    status = "okay";
wireless-bluetooth {
    compatible = "bluetooth-platdata";
    //wifi-bt-power-toggle;
    uart_rts_gpios = <&gpio4 GPIO_C3 GPIO_ACTIVE_LOW>;
    pinctrl-names = "default","rts_gpio";
    pinctrl-0 = <&uart0_rts>;
    pinctrl-1 = <&uart0_rts_gpio>;
    BT,power_gpio = <&gpio4 GPIO_D3 GPIO_ACTIVE_HIGH>;
    BT,reset_gpio = <&gpio4 GPIO_D5 GPIO_ACTIVE_HIGH>;
    BT,wake_gpio = <&gpio4 GPIO_D2 GPIO_ACTIVE_HIGH>;
    BT,wake_host_irq = <&gpio4 GPIO_D7 GPIO_ACTIVE_LOW>;
    status = "okay";
pwm_regulator {
	compatible = "rockchip_pwm_regulator";
	pwms = <&pwm1 0 2000>;
	rockchip,pwm_id= <1>;
	rockchip,pwm_voltage_map= <925000 950000 975000 1000000 1025000 1050000 1075000 1100000 1125000 1150000 1175000 1200000 1225000 1250000 1275000 1300000 1325000 1350000 1375000 1400000>;
	rockchip,pwm_voltage= <1100000>;
	rockchip,pwm_min_voltage= <925000>;
	rockchip,pwm_max_voltage= <1400000>;
	rockchip,pwm_suspend_voltage= <950000>;
	rockchip,pwm_coefficient= <475>;
	regulators {
		#address-cells = <1>;
		#size-cells = <0>;
		pwm_reg0: regulator@0 {
			regulator-compatible = "pwm_dcdc1";
			regulator-name= "vdd_logic";
			regulator-min-microvolt = <925000>;
			regulator-max-microvolt = <1400000>;
			regulator-always-on;
			regulator-boot-on;
codec_hdmi_i2s: codec-hdmi-i2s {
	compatible = "hdmi-i2s";
codec_hdmi_spdif: codec-hdmi-spdif {
	compatible = "hdmi-spdif";
rockchip-hdmi-i2s {
	compatible = "rockchip-hdmi-i2s";
	dais {
		dai0 {
			audio-codec = <&codec_hdmi_i2s>;
			i2s-controller = <&i2s>;
			format = "i2s";
			//continuous-clock;
			//bitclock-inversion;
			//frame-inversion;
			//bitclock-master;
			//frame-master;
rockchip-hdmi-spdif {
	compatible = "rockchip-hdmi-spdif";
	dais {
		dai0 {
			audio-codec = <&codec_hdmi_spdif>;
			i2s-controller = <&spdif>;
rockchip-rk1000 {
	compatible = "rockchip-rk1000";
	dais {
		dai0 {
			audio-codec = <&rk1000_codec>;
			format = "i2s";
			//continuous-clock;
			//frame-inversion;
			//bitclock-master;
			//frame-master;
rockchip-es8323 {
	compatible = "rockchip-es8323";
	dais {
		dai0 {
			audio-codec = <&es8323>;
			format = "i2s";
			//continuous-clock;
			//frame-inversion;
			//bitclock-master;
			//frame-master;
rkxx-remotectl{
	compatible = "rockchip,remotectl";
            module-gpios = <&gpio7 GPIO_A0 GPIO_ACTIVE_LOW>;
    led-power = <&gpio8 GPIO_A1 GPIO_ACTIVE_LOW>;
firefly-led{
	compatible = "firefly,led";
	led-work = <&gpio8 GPIO_A2 GPIO_ACTIVE_LOW>;
	status = "okay";
leds {
   compatible = "gpio-leds";
   power {
       label = "firefly:blue:power";
       linux,default-trigger = "ir-power-click";
       default-state = "on";
       gpios = <&gpio8 GPIO_A1 GPIO_ACTIVE_LOW>;
    user {
       label = "firefly:yellow:user";
       linux,default-trigger = "ir-user-click";
       default-state = "off";
       gpios = <&gpio8 GPIO_A2 GPIO_ACTIVE_LOW>;
atx8_unsetup{
compatible = “firefly,noatx8”;
atx8-rst = <&gpio7 GPIO_C5 GPIO_ACTIVE_HIGH>;
status = “okay”;
usb_control {
compatible = “rockchip,rk3288-usb-control”;
	host_drv_gpio = <&gpio0 GPIO_B6 GPIO_ACTIVE_LOW>;
	otg_drv_gpio = <&gpio0 GPIO_B4 GPIO_ACTIVE_LOW>;
	rockchip,remote_wakeup;
	rockchip,usb_irq_wakeup;
&gmac {
// pmu_regulator = “act_ldo5”;
// pmu_enable_level = <1>; //1->HIGH, 0->LOW
// power-gpio = <&gpio0 GPIO_A6 GPIO_ACTIVE_HIGH>;
reset-gpio = <&gpio4 GPIO_B0 GPIO_ACTIVE_LOW>;
phy-mode = “rgmii”;
clock_in_out = “input”;
tx_delay = <0x30>;
rx_delay = <0x10>;
&pinctrl {
//used for init some gpio
init-gpios = <&gpio8 GPIO_A0 GPIO_ACTIVE_HIGH
	&gpio7 GPIO_B1 GPIO_ACTIVE_HIGH
	&gpio4 GPIO_B0 GPIO_ACTIVE_HIGH>;
gpio0_gpio {
		gpio0_c2: gpio0-c2 {
			rockchip,pins = <GPIO0_C2>;
			rockchip,pull = <VALUE_PULL_DOWN>;
		//to add
gpio7_gpio {
		gpio7_b7: gpio7-b7 {
			rockchip,pins = <GPIO7_B7>;
			rockchip,pull = <VALUE_PULL_UP>;
		//to add
//could add other pinctrl definition such as gpio
// gmac drive strength
gpio4_gmac {
	mac_clk: mac-clk {
		rockchip,drive = <VALUE_DRV_12MA>;
	mac_txpins: mac-txpins {
	mac_rxpins: mac-rxpins {
	mac_crs: mac-crs {
	mac_mdpins: mac-mdpins {
&nandc0 {
status = “okay”; // used nand set “okay” ,used emmc set “disabled”
&nandc1 {
status = “disabled”; // used nand set “okay” ,used emmc set “disabled”
&nandc0reg {
&emmc {
clock-frequency = <100000000>;
clock-freq-min-max = <400000 100000000>;
    supports-highspeed;
supports-emmc;
    bootpart-no-access;
//supports-tSD;//only tsd-sdcard mode
supports-DDR_MODE;
caps2-mmc-hs200;
    ignore-pm-notify;
	keep-power-in-suspend;
	//poll-hw-reset
	status = "okay";
&sdmmc {
clock-frequency = <50000000>;
lock-freq-min-max = <400000 50000000>;
supports-highspeed;
supports-sd;
broken-cd;
card-detect-delay = <200>;
	ignore-pm-notify;
    	vmmc-supply = <&ldo1_reg>;
	status = "okay";
&sdio {
clock-freq-min-max = <200000 50000000>;
supports-highspeed;
supports-sdio;
ignore-pm-notify;
//cap-sdio-irq;
status = “okay”;
&spi0 {
max-freq = <48000000>;
spi_test@00 {
compatible = “rockchip,spi_test_bus0_cs0”;
reg = <0>;
spi-max-frequency = <24000000>;
//spi-cpha;
//spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
spi_test@01 {
        compatible = "rockchip,spi_test_bus0_cs1";
        reg = <1>;
        spi-cpha;
	spi-cpol;
        poll_mode = <0>;
        type = <0>;
	enable_dma = <0>;
&spi1 {
spi_test@10 {
compatible = “rockchip,spi_test_bus1_cs0”;
reg = <0>;
//spi-cpha;
//spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
//dtv: connect to dtv demodulator for control signal
tstv-ctrl@00 {
	compatible = "rockchip,dtv_spi_ctrl";
	gpio-powerup = <&gpio0 GPIO_D7 GPIO_ACTIVE_HIGH>;
	gpio-powerdown = <&gpio2 GPIO_B6 GPIO_ACTIVE_HIGH>;
	gpio-reset = <&gpio2 GPIO_B7 GPIO_ACTIVE_HIGH>;
        gpio-nreset = <&gpio2 GPIO_B4 GPIO_ACTIVE_HIGH>;
	spi-max-frequency = <12000000>;
	reg = <0>;
            poll_mode = <0>;
        type = <0>;
	enable_dma = <0>;
&spi2 {
spi_test@20 {
compatible = “rockchip,spi_test_bus2_cs0”;
reg = <0>;
//spi-cpha;
//spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
spi_test@21 {
        compatible = "rockchip,spi_test_bus2_cs1";
        reg = <1>;
        //spi-cpha;
	//spi-cpol;
        poll_mode = <0>;
        type = <0>;
	enable_dma = <0>;
&hsadc {
&uart_bt {
status = “okay”;
pinctrl-0 = <&uart0_xfer &uart0_cts>;
&uart_gps {
status = “okay”;
&uart_bb {
status = “okay”;
pinctrl-0 = <&uart1_xfer &uart1_cts>;
&i2c0 {
status = “okay”;
rk808: rk808@1b {
reg = <0x1b>;
status = “okay”;
syr827: syr827@40 {
compatible = “silergy,syr82x”;
reg = <0x40>;
status = “okay”;
regulators {
#size-cells = <0>;
syr827_dc1: regulator@0 {
reg = <0>;
regulator-compatible = “syr82x_dcdc1”;
regulator-name = “vdd_arm”;
regulator-min-microvolt = <712500>;
regulator-max-microvolt = <1500000>;
regulator-boot-on;
regulator-initial-mode = <0x2>;
regulator-initial-state = <3>;
regulator-state-mem {
regulator-state-mode = <0x2>;
regulator-state-enabled;
regulator-state-uv = <900000>;
syr828: syr828@41 {
reg = <0x41>;
status = “okay”;
regulators {
#size-cells = <0>;
syr828_dc1: regulator@0 {
reg = <0>;
regulator-name = “vdd_gpu”;
regulator-boot-on;
regulator-state-disabled;
act8846: act8846@5a {
reg = <0x5a>;
status = “okay”;
rtc@51 {
	compatible = "rtc,hym8563";
	reg = <0x51>;
	irq_gpio = <&gpio7 GPIO_A4 IRQ_TYPE_EDGE_FALLING>;
&i2c1 {
status = “okay”;
rtc@51 {
compatible = “nxp,pcf8563”;
reg = <0x51>;
&i2c2 {
status = “okay”;
es8323: es8323@10 {
compatible = “es8323”;
reg = <0x10>;
spk-con-gpio = <&gpio0 GPIO_B2 GPIO_ACTIVE_HIGH>;
hp-det-gpio = <&gpio7 GPIO_B7 GPIO_ACTIVE_HIGH>;
hp-mic-only = <1>;
clocks = <&clk_i2s>, <&clk_i2s_out>;
clock-names = “i2s_clk”,“i2s_mclk”;
pinctrl-names = “default”;
pinctrl-0 = <&i2s_mclk>;
&i2c3 {
status = “okay”;
&i2c4 {
status = “okay”;
rk1000_control@40 {
compatible = “rockchip,rk1000_control”;
reg = <0x40>;
gpio-reset = <&gpio7 GPIO_C5 GPIO_ACTIVE_LOW>;
//pinctrl-names = “default”;
//pinctrl-0 = <&i2s_mclk>;
rk1000_tve@42 {
compatible = “rockchip,rk1000_tve”;
reg = <0x42>;
// gpio-switch = <&gpio3 GPIO_D4 GPIO_ACTIVE_LOW>;
rockchip,source = <0>; //0: LCDC0; 1: LCDC1
rockchip,prop = ;//
rk1000_codec: rk1000_codec@60 {
compatible = “rockchip,rk1000_codec”;
reg = <0x60>;
spk_ctl_io = <&gpio7 GPIO_A5 GPIO_ACTIVE_LOW>;
boot_depop = <1>;
pa_enable_time = <5000>;
vga_ddc@50 {
compatible = “firefly,vga_ddc”;
reg = <0x50>;
gpio-pwn = <&gpio0 GPIO_C1 GPIO_ACTIVE_HIGH>;
rockchip,prop = ;//
status = “okay”;
&i2c5 {
/$rbox$modify$_begin_huangzhibao for rk1000/
//&i2s{
// pinctrl-names = “default”, “sleep”;
// pinctrl-0 = <&i2s_sclk &i2s_lrckrx &i2s_lrcktx &i2s_sdi &i2s_sdo0 &i2s_sdo1 &i2s_sdo2 &i2s_sdo3>;
// pinctrl-1 = <&i2s_gpio>;
/$rbox$modify$_end/
&fb {
rockchip,disp-mode = ;
&rk_screen {
display-timings = <&disp_timings>;
/lcdc0 as PRMRY(HDMI),lcdc1 as EXTEND(RK1000)/
&lcdc0 {
status = “okay”;
rockchip,prop = ;
&lcdc1 {
rockchip,prop = ;
&hdmi {
status = “okay”;
rockchips,hdmi_audio_source = <0>;
hdmi_cec = <0>;
&adc {
status = “okay”;
key {
	compatible = "rockchip,key";
	io-channels = <&adc 1>;
	vol-up-key {
		linux,code = <115>;
		label = "volume up";
		rockchip,adc_value = <1>;
	vol-down-key {
		linux,code = <114>;
		label = "volume down";
		rockchip,adc_value = <170>;
	power-key {
		gpios = <&gpio0 GPIO_A5 GPIO_ACTIVE_LOW>;
		linux,code = <116>;
		label = "power";
		gpio-key,wakeup;
	recovery-key {
		linux,code = <113>;
		label = "recovery";
		rockchip,adc_value = <4>;
	menu-key {
		linux,code = <59>;
		label = "menu";
		rockchip,adc_value = <355>;
	home-key {
		linux,code = <102>;
		label = "home";
		rockchip,adc_value = <746>;
	back-key {
		linux,code = <158>;
		label = "back";
		rockchip,adc_value = <560>;
	camera-key {
		linux,code = <212>;
		label = "camera";
		rockchip,adc_value = <450>;
&pwm0 {
interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>;
status = “okay”;
&pwm1 {
&clk_core_dvfs_table {
support-pvtm = <1>;
pvtm-operating-points = <
/* KHz uV pvtm margin*/
126000 900000 25000
216000 900000 25000
312000 900000 25000
408000 900000 25000
600000 950000 50000
696000 950000 25000
816000 1000000 25000
1008000 1050000 25000
1200000 1100000 25000
1416000 1200000 25000
1512000 1300000 25000
1608000 1350000 25000
1704000 1350000 25000
1800000 1350000 25000
status=“okay”;
&clk_gpu_dvfs_table {
/* KHz uV */
// 100000 900000
200000 900000
300000 950000
420000 1100000
500000 1150000
// 600000 1250000
status=“okay”;
&clk_ddr_dvfs_table {
/* KHz uV */
200000 1075000
300000 1075000
456000 1125000
533000 1150000
freq-table = <
	/*status		freq(KHz)*/
	SYS_STATUS_NORMAL	456000
	SYS_STATUS_SUSPEND	200000
	//SYS_STATUS_VIDEO_1080P  240000
	SYS_STATUS_VIDEO_4K     456000
	SYS_STATUS_PERFORMANCE  533000
	//SYS_STATUS_BOOST	324000
	//SYS_STATUS_ISP		400000
auto-freq-table = <
	240000
	324000
	456000
	528000
auto-freq=<0>;
status="okay";
/include/ “act8846.dtsi”
&act8846 {
gpios =<&gpio7 GPIO_B6 GPIO_ACTIVE_LOW>,<&gpio0 GPIO_A1 GPIO_ACTIVE_HIGH>;
cpu_det_gpio =<&gpio7 GPIO_B2 GPIO_ACTIVE_LOW>;
usb_hub_reset_gpio =<&gpio8 GPIO_A3 GPIO_ACTIVE_LOW>;
act8846,system-power-controller;
regulators {
	dcdc1_reg: regulator@0{
		regulator-name= "act_dcdc1";
		regulator-min-microvolt = <1200000>;
		regulator-max-microvolt = <1200000>;
		regulator-boot-on;
	dcdc2_reg: regulator@1 {
		regulator-name= "vccio";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
			regulator-state-uv = <3300000>;
	dcdc3_reg: regulator@2 {
		regulator-min-microvolt = <700000>;
			regulator-state-uv = <1200000>;
	dcdc4_reg: regulator@3 {
		regulator-name= "act_dcdc4";
		regulator-min-microvolt = <2000000>;
		regulator-max-microvolt = <2000000>;
			regulator-state-uv = <2000000>;
	ldo1_reg: regulator@4 {
		regulator-name= "vccio_sd";
		regulator-min-microvolt = <1800000>;
	ldo2_reg: regulator@5 {
		regulator-name= "act_ldo2";
		regulator-min-microvolt = <1050000>;
		regulator-max-microvolt = <1050000>;
	ldo3_reg: regulator@6 {
		regulator-name= "act_ldo3";
		regulator-max-microvolt = <1800000>;
	ldo4_reg:regulator@7 {
		regulator-name= "act_ldo4";
	ldo5_reg: regulator@8 {
		regulator-name= "act_ldo5";
	ldo6_reg: regulator@9 {
		regulator-name= "act_ldo6";
		regulator-min-microvolt = <1100000>;
		regulator-max-microvolt = <1100000>;
	ldo7_reg: regulator@10 {
		regulator-name= "vcc_18";
	ldo8_reg: regulator@11 {
		regulator-name= "act_ldo8";
		regulator-min-microvolt = <1850000>;
		regulator-max-microvolt = <1850000>;
/include/ “rk808.dtsi”
&rk808 {
gpios =<&gpio0 GPIO_A4 GPIO_ACTIVE_HIGH>,<&gpio0 GPIO_B3 GPIO_ACTIVE_LOW>;
rk808,system-power-controller;
regulators {
	rk808_dcdc1_reg: regulator@0{
		regulator-name= "vdd_arm";
		regulator-boot-on;
	rk808_dcdc2_reg: regulator@1 {
		regulator-name= "vdd_gpu";
		regulator-boot-on;
	rk808_dcdc3_reg: regulator@2 {
		regulator-name= "rk_dcdc3";
		regulator-boot-on;
	rk808_dcdc4_reg: regulator@3 {
		regulator-boot-on;
/* NO USED, 3.3V*/
	rk808_ldo1_reg: regulator@4 {
		regulator-name= "rk_ldo1";
		regulator-boot-on;
/* BOX:RK1000s, 3.3V  */
	rk808_ldo2_reg: regulator@5 {
		regulator-name= "rk_ldo2";
		regulator-boot-on;
/* RK3288 PLL,USB PHY, 1.0V */
	rk808_ldo3_reg: regulator@6 {
		regulator-name= "rk_ldo3";
		regulator-min-microvolt = <1000000>;
		regulator-max-microvolt = <1000000>;
		regulator-boot-on;
/* BOX:RK1000S CORE, 1.8V  */
	rk808_ldo4_reg:regulator@7 {
		regulator-name= "rk_ldo4";
		regulator-boot-on;
/* SDMMC IO, 3.3V*/
	rk808_ldo5_reg: regulator@8 {
		regulator-name= "rk_ldo5";
		regulator-boot-on;
/* CAMERA, 1.8V  box modify*/
	rk808_ldo6_reg: regulator@9 {
		regulator-name= "rk_ldo6";
		regulator-boot-on;
/* RK3288 USB PHY, SAR-ADC, WIFI IO, 1.8V */
	rk808_ldo7_reg: regulator@10 {
		regulator-name= "rk_ldo7";
		regulator-boot-on;
/* DTV, 3.3V  box modify*/
	rk808_ldo8_reg: regulator@11 {
		regulator-name= "rk_ldo8";
		regulator-boot-on;
	rk808_ldo9_reg: regulator@12 {
		regulator-name= "rk_ldo9";
		regulator-boot-on;
	rk808_ldo10_reg: regulator@13 {
		regulator-name= "rk_ldo10";
		regulator-boot-on;
&lcdc_vdd_domain {
regulator-name = “vcc30_lcd”;
&dpio_vdd_domain{
regulator-name = “vcc18_cif”;
&flash0_vdd_domain{
regulator-name = “vcc_flash”;
&flash1_vdd_domain{
&apio3_vdd_domain{
regulator-name = “vccio_wl”;
&apio5_vdd_domain{
regulator-name = “vccio”;
&apio4_vdd_domain{
&apio1_vdd_domain{
&apio2_vdd_domain{
&sdmmc0_vdd_domain{
regulator-name = “vcc_sd”;
用哪个SDK?
gowhere 发表于 2015-12-8 14:46
/dts-v1/;
用这种方法打开出现的问题跟2楼相同,并且万能表测电压,为0
我的dts文件
firefly-rk3288.dts.tar.gz (4.62 KB)
zhansb 发表于 2015-12-8 14:48
用哪个SDK?
原来的板子是双系统的。我在你们网站上下载了一个android4。4的,刷入开发板,同时下载的sdk是你们网站上的4。4版本sdk。
我先整个编译,然后安装教程更改dts,编译,刷入开发板
在默认版最新更新下根据wiki步骤试过有ttyS3设备,收发也没问题:
diff --git a/kernel/arch/arm/boot/dts/firefly-rk3288.dts b/kernel/arch/arm/boot/dts/firefly-rk3288.dts
index 8181797..bc46f0b 100755
— a/kernel/arch/arm/boot/dts/firefly-rk3288.dts
+++ b/kernel/arch/arm/boot/dts/firefly-rk3288.dts
@@ -408,6 +408,12 @@
status = “okay”;
+&uart_gps {
  •   status = "okay";
  •   dma-names = "!tx", "!rx";
  •   pinctrl-0 = <&uart3_xfer &uart3_cts>;
diff --git a/kernel/arch/arm/boot/dts …
我没有更新,就是用的下载的sdk源码整个编译,然后部分编译,这个有影响吗
更新后,修改uart3后完整烧录试试
楼主,我按照官方教程执行到你说的的第三步总是有问题,就是要将kernel.img和resource.img共同烧录到RK3288上时,提示没有找到kernel分区偏移
wandyqian 发表于 2015-12-14 09:32
楼主,我按照官方教程执行到你说的的第三步总是有问题,就是要将kernel.img和resource.img共同烧录到RK3288 …
使用 linux upgrade_tool 烧写 ,参考wiki的步骤
