rk3588L 打开pcie 插上pcie卡无反应
SDK包名称:/home/walker/proj/rk3588_sdk/.repo/manifests/rk358
SDK修改内容://pcie@fe150000
&pcie3x4 {
reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>;
vpcie3v3-supply = <&vcc3v3_pcie30>;
//status = "disabled";
status = "okay";
&vcc3v3_pcie30{
gpios = <&gpio1 RK_PB3 GPIO_ACTIVE_HIGH>;
startup-delay-us = <5000>;
status = "okay";
Log日志:pcie.txt
oot@firefly:/# dmesg | grep pcie
[ 2.976892] vcc3v3_pcie30: supplied by vcc12v_dcin
[ 2.983550] vcc3v3_pcie20_wifi: supplied by vcc12v_dcin
[ 3.491420] rk-pcie fe150000.pcie: invalid prsnt-gpios property in node
[ 3.491516] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node
[ 3.502933] rk-pcie fe150000.pcie: IRQ msi not found
[ 3.502948] rk-pcie fe150000.pcie: use outband MSI support
[ 3.502957] rk-pcie fe150000.pcie: Missing config reg space
[ 3.502973] rk-pcie fe150000.pcie: host bridge /pcie@fe150000 ranges:
[ 3.503013] rk-pcie fe150000.pcie: err 0x00f0000000..0x00f00fffff → 0x00f0000000
[ 3.503037] rk-pcie fe150000.pcie: IO 0x00f0100000..0x00f01fffff → 0x00f0100000
[ 3.503060] rk-pcie fe150000.pcie: MEM 0x00f0200000..0x00f0ffffff → 0x00f0200000
[ 3.503073] rk-pcie fe150000.pcie: MEM 0x0900000000..0x093fffffff → 0x0900000000
[ 3.503100] rk-pcie fe150000.pcie: Missing config reg space
[ 3.503106] rk-pcie fe170000.pcie: IRQ msi not found
[ 3.503110] rk-pcie fe170000.pcie: use outband MSI support
[ 3.503115] rk-pcie fe170000.pcie: Missing config reg space
[ 3.503130] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges:
[ 3.503142] rk-pcie fe150000.pcie: invalid resource
[ 3.503173] rk-pcie fe170000.pcie: err 0x00f2000000..0x00f20fffff → 0x00f2000000
[ 3.503197] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff → 0x00f2100000
[ 3.503222] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff → 0x00f2200000
[ 3.503245] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff → 0x0980000000
[ 3.503271] rk-pcie fe170000.pcie: Missing config reg space
[ 3.503302] rk-pcie fe170000.pcie: invalid resource
[ 3.710976] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x3
[ 3.736516] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.763179] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0xa
[ 3.789847] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.816527] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.843185] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.869853] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.896518] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x1
[ 3.923177] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.949826] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0xa
[ 4.347014] pcie30_avdd1v8: supplied by avcc_1v8_s0
[ 4.347673] pcie30_avdd0v75: supplied by avdd_0v75_s0
[ 6.383213] rk-pcie fe150000.pcie: PCIe Link Fail, LTSSM is 0x0, hw_retries=0
[ 6.383240] rk-pcie fe150000.pcie: failed to initialize host
[ 6.699969] rk-pcie fe170000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=0
[ 8.713285] rk_pcie_establish_link: 207 callbacks suppressed
[ 8.713295] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.739847] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.766585] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.793208] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.819920] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.846849] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.873249] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.899865] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.926532] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.953261] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 10.963298] rk-pcie fe170000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=1
[ 11.988431] rk-pcie fe170000.pcie: failed to initialize host
pcie.txt (3.62 KB)
