固件文件名称:Public-All-1684-Ubuntu2004-Sdk2309LTS_SP1-Build202
固件下载地址:百度网盘
Log日志:newlog.zip
AIBOX-1684X运行ChatDoc-TPU出错(已经安装官方提供的sail sophon_arm-3.7.0-py3-none-any.whl)步骤一、git clone https://github.com/wangyifan2018/ChatDoc-TPU.git下载工程
步骤二、./run.sh --model chatglm3 --dev_id 0下载大模型
步骤三、pip3 install -r requirements.txt -i https://pypi.tuna.tsinghua.edu.cn/simple安装依赖
步骤四、./run.sh --model chatglm3 --dev_id 0 运行出错。部分log显示如下
[2024-06-25 08:56:20.527] [error] [tensor.cpp:403] bm_memset_device failed, return=4
[bmlib_memory][error] bm_alloc_gmem failed, dev_id = 0, size = 0x0
[BM_CHECK][error] BM_CHECK_RET fail /workspace/libsophon/bmlib/src/bmlib_memory.cpp: bm_malloc_device_byte_heap_mask: 705
[2024-06-25 08:56:20.565] [error] [tensor.cpp:396] bm_malloc_device_type() err=5, size=0
[bmlib_memory][error] bm_device_mem_range_valid saddr=0xfffffffff eaddr=0xfffffffff out of range
[bmlib_memory][error] memset wrong memory addr 0xfffffffff
[2024-06-25 08:56:20.565] [error] [tensor.cpp:403] bm_memset_device failed, return=4
[2024-06-25 08:56:20.603] [error] [tensor.cpp:396] bm_malloc_device_type() err=5, size=0
[2024-06-25 08:56:20.604] [error] [tensor.cpp:403] bm_memset_device failed, return=4
[2024-06-25 08:56:20.642] [error] [tensor.cpp:396] bm_malloc_device_type() err=5, size=0
[2024-06-25 08:56:20.642] [error] [tensor.cpp:403] bm_memset_device failed, return=4
2024-06-25 08:56:20,643 - INFO - chatbot init success!
2024-06-25 08:58:00.294 Uncaught app exception
File “/usr/local/lib/python3.8/dist-packages/streamlit/runtime/scriptrunner/script_runner.py”, line 552, in _run_script
exec(code, module.dict)
File “/home/linaro/ChatDoc-TPU/web_demo_st.py”, line 178, in
for result_answer, _ in chatbot_st.llm.stream_predict(user_input, his):
File “/home/linaro/ChatDoc-TPU/chat/chatglm3/chatglm3.py”, line 269, in stream_predict
token = self.forward_first(tokens)
File “/home/linaro/ChatDoc-TPU/chat/chatglm3/chatglm3.py”, line 147, in forward_first
input_ids = np.zeros(self.SEQLEN, type_convert(self.first_embed_input[“dtype”]))
File “/home/linaro/ChatDoc-TPU/chat/utils.py”, line 16, in type_convert
if sail_dtype == sail.Dtype.BM_FLOAT16:
AttributeError: type object ‘sophon.sail.Dtype’ has no attribute ‘BM_FLOAT16’
newlog.zip (15.1 KB)
