SDK包名称:Firefly-RK3308_Linux_SDK_git_20190924.7z
SDK修改内容:无如何修改
Log日志:log_error.txt
murphy@ubuntu:~/work$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.2 LTS
Release: 16.04
Codename: xenial
murphy@ubuntu:~/work/buildroot/output/firefly_rk3308_release$ make
umask 0022 && make -C /home/murphy/work/buildroot O=/home/murphy/work/buildroot/output/firefly_rk3308_release/.
rkwifibt 1.0.0 Building
/home/murphy/work/buildroot/output/firefly_rk3308_release/host/bin/aarch64-rockchip-linux-gnu-gcc -o /home/murphy/work/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/b
/home/murphy/work/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/brcm_tools/brcm_patchram_plus1.c:182:3: warning: initialization discards ‘const’ qualifier from pointe
{(const char *) NULL, NULL}
/home/murphy/work/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/brcm_tools/brcm_patchram_plus1.c: In function ‘proc_read_local_name’:
/home/murphy/work/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/brcm_tools/brcm_patchram_plus1.c:778:17: warning: implicit declaration of function ‘toupper’ [-Wimplic
(p_name+i) = toupper((p_name+i));
/home/murphy/work/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/brcm_tools/brcm_patchram_plus1.c: In function ‘proc_open_patchram’:
/home/murphy/work/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/brcm_tools/brcm_patchram_plus1.c:807:13: warning: implicit declaration of function ‘tolower’ [-Wimplic
(p+i) = tolower((p+i));
/home/murphy/work/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/brcm_tools/dhd_priv.c: In function ‘main’:
/home/murphy/work/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/brcm_tools/dhd_priv.c:81:15: warning: assignment from incompatible pointer type [-Wincompatible-pointe
ifr.ifr_data = &priv_cmd;
/home/murphy/work/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/brcm_tools/dhd_priv.c:89:2: warning: implicit declaration of function ‘close’ [-Wimplicit-function-dec
close(ioctl_sock);
mkdir -p /home/murphy/work/buildroot/output/firefly_rk3308_release/target/system/lib/modules/
/home/murphy/work/buildroot/../build.sh modules
============Start build kernel modules============
TARGET_ARCH =arm64
TARGET_KERNEL_CONFIG =firefly-rk3308b_linux_defconfig
CHK scripts/mod/devicetable-offsets.h
CHK include/generated/timeconst.h
CHK include/generated/bounds.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
make[3]: ‘include/generated/vdso-offsets.h’ is up to date.
Building modules, stage 2.
MODPOST 2 modules
ERROR: “nf_hooks_needed” [net/bridge/br_netfilter.ko] undefined!
ERROR: “nf_hook_slow” [net/bridge/br_netfilter.ko] undefined!
ERROR: “br_dev_queue_push_xmit” [net/bridge/br_netfilter.ko] undefined!
ERROR: “nf_unregister_hooks” [net/bridge/br_netfilter.ko] undefined!
ERROR: “br_forward_finish” [net/bridge/br_netfilter.ko] undefined!
ERROR: “nf_ipv6_ops” [net/bridge/br_netfilter.ko] undefined!
ERROR: “nf_br_ops” [net/bridge/br_netfilter.ko] undefined!
ERROR: “nf_register_hooks” [net/bridge/br_netfilter.ko] undefined!
ERROR: “br_handle_frame_finish” [net/bridge/br_netfilter.ko] undefined!
ERROR: “v4l2_event_unsubscribe” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “video_device_release_empty” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_device_unregister” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_ctrl_handler_free” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_ctrl_g_ctrl” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “__video_register_device” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_device_register” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_device_disconnect” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “video_unregister_device” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_ctrl_subscribe_event” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_fh_release” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “__v4l2_ctrl_s_ctrl” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “video_devdata” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_ctrl_handler_setup” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_fh_open” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_device_put” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_get_timestamp” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “video_ioctl2” [drivers/media/usb/gspca/gspca_main.ko] undefined!
ERROR: “v4l2_ctrl_poll” [drivers/media/usb/gspca/gspca_main.ko] undefined!
scripts/Makefile.modpost:91: recipe for target ‘__modpost’ failed
make[3]: *** [__modpost] Error 1
Makefile:1185: recipe for target ‘modules’ failed
make[2]: *** [modules] Error 2
====Build kernel failed!====
package/pkg-generic.mk:247: recipe for target ‘/home/murphy/work/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/.stamp_built’ failed
make[1]: *** [/home/murphy/work/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/.stamp_built] Error 1
Makefile:16: recipe for target ‘_all’ failed
make: *** [_all] Error 2
murphy@ubuntu:~/work/buildroot/output/firefly_rk3308_release$ make menuconfig
umask 0022 && make -C /home/murphy/work/buildroot O=/home/murphy/work/buildroot/output/firefly_rk3308_release/. menuconfig
GEN /home/murphy/work/buildroot/output/firefly_rk3308_release/Makefile
log_error.txt (18.9 KB)
