固件文件名称:FIREFLY-RK3288-UBUNTU16.04-GPT-20200326-1507.img\F
Log日志:16-2.zip
不是官方的板子,是广告机上的
DDR Version 1.06 20171020
Channel a: DDR3 400MHz
Channel b: DDR3 400MHz
Memory OK
Memory OK
Boot1 Release Time: Apr 11 2018 10:32:58, version: 2.36
ChipType = 0x8, 224
mmc2:cmd19,256
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7457MB
FwPartOffset=2000 , 2000
mmc0:cmd8,1024
mmc0:cmd8,1024
mmc0:cmd8,1024
SdmmcInit=0 1
StorageInit ok = 35545
LOADER Check OK! 0x200000, 66356
TOS Check OK! 0x8400000, 101833
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:377: Initializing (1.1.0-371-gca9b9a06 #56 Wed Dec 5 06:27:16 UTC 2018 arm)
INF [0x0] TEE-CORE:init_primary_helper:378: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:379: Next entry point address: 0x200000
U-Boot 2017.09-03676-g0cbcc01 (Mar 26 2020 - 14:06:50 +0800)
Model: Firefly-RK3288
DRAM: 2 GiB
Sysmem: init
Relocation Offset is: 00000000
dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
MMC: no card present
mmc_init: -123, time 0
switch to partitions #0, OK
Bootdev: mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
rockchip_get_boot_mode: Could not found misc partition
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c0 speed: 400000Hz
vdd_log -5 uV
*** Warning - bad CRC, using default environment
In: serial@ff690000
Out: serial@ff690000
Err: serial@ff690000
Model: Firefly-RK3288 Board (Linux Opensource)
CLK: (uboot. arm: enter 1000000 KHz, init 1000000 KHz, kernel 0N/A)
apll 1000000 KHz
dpll 396000 KHz
cpll 384000 KHz
gpll 594000 KHz
npll 24000 KHz
aclk_bus 297000 KHz
Net: No ethernet found.
Hit key to stop autoboot('CTRL+C'): 3 2 1 0
Could not find misc partition
ANDROID: reboot reason: "(none)"
Booting ZIMAGE kernel at 0x02008000(Uncompress to 0) with fdt at 0x8300000...
## Booting Android Image at 0x02007800 ...
Kernel load addr 0x02008000 size 7999 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image ... OK
'reserved-memory' dma-unusable@fe000000: addr=fe000000 size=1000000
'reserved-memory' ramoops@00000000: addr=8000000 size=f0000
Loading Device Tree to 0ffe9000, end 0ffffdc0 ... OK
Can't find file:logo_kernel.bmp
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x09200000 - 0x80000000 (size: 0x76e00000)
Total: 3548.248 ms
Starting kernel ...
[ 0.000000] Linux version 4.4.194 (llq@llq-H310M-DS2V) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #249 SMP Thu Mar 26 14:42:33 CST 2020
[ 0.000000] Machine model: Firefly-RK3288 Board (Linux Opensource)
[ 0.000000] cma: Reserved 16 MiB at 0x7f000000
[ 0.000000] psci: PSCIv65535.65535 detected in firmware.
[ 0.000000] PERCPU: Embedded 14 pages/cpu @eef77000 s24728 r8192 d24424 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519168
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= earlyprintk rw rootwait console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 systemd.gpt_auto=0
[ 0.000000] Memory: 2027056K/2082816K available (12288K kernel code, 1004K rwdata, 3468K rodata, 1024K init, 632K bss, 39376K reserved, 16384K cma-reserved, 1293716K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0d00000 (13280 kB)
[ 0.000000] .init : 0xc1200000 - 0xc1300000 (1024 kB)
[ 0.000000] .data : 0xc1300000 - 0xc13fb06c (1005 kB)
[ 0.000000] .bss : 0xc13fd000 - 0xc149b210 ( 633 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000030] Switching to timer-based delay loop, resolution 41ns
[ 0.003901] Console: colour dummy device 80x30
[ 0.003945] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.003970] pid_max: default: 32768 minimum: 301
[ 0.004095] Security Framework initialized
[ 0.004113] Yama: becoming mindful.
[ 0.004204] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004228] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.005373] Initializing cgroup subsys devices
[ 0.005405] Initializing cgroup subsys freezer
[ 0.005453] CPU: Testing write buffer coherency: ok
[ 0.005508] ftrace: allocating 44356 entries in 131 pages
[ 0.131634] CPU0: update cpu_capacity 430
[ 0.131654] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.131759] Setting up static identity map for 0x100000 - 0x100058
[ 0.135086] CPU1: update cpu_capacity 430
[ 0.135096] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.136308] CPU2: update cpu_capacity 430
[ 0.136318] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.137549] CPU3: update cpu_capacity 430
[ 0.137559] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.137720] Brought up 4 CPUs
[ 0.137762] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.137772] CPU: All CPU(s) started in SVC mode.
[ 0.139812] devtmpfs: initialized
[ 0.171896] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.172471] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.172511] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.173968] pinctrl core: initialized pinctrl subsystem
[ 0.175559] NET: Registered protocol family 16
[ 0.178103] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.201467] cpuidle: using governor ladder
[ 0.231517] cpuidle: using governor menu
[ 0.231587] Registered FIQ tty driver
[ 0.284654] console [pstore-1] enabled
[ 0.284668] pstore: Registered ramoops as persistent store backend
[ 0.284684] ramoops: attached 0xf0000@0x8000000, ecc: 0/0
[ 0.286015] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.286036] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.287170] fiq debugger fiq mode enabled
[ 0.758802] console [ttyFIQ0] enabled
[ 0.762843] Registered fiq debugger ttyFIQ0
[ 0.843452] vcc_flash: regulator get failed, ret=-517
[ 0.849269] vcc_sd: regulator get failed, ret=-517
[ 0.854784] vcc28_dvp: regulator get failed, ret=-517
[ 0.860577] dovdd_1v8: regulator get failed, ret=-517
[ 0.865918] rockchip-pinctrl pinctrl: pin gpio0-11 already requested by vcc28-dvp-regulator; cannot claim for vcc-mipi
[ 0.876661] rockchip-pinctrl pinctrl: pin-11 (vcc-mipi) status -22
[ 0.882852] rockchip-pinctrl pinctrl: could not request pin 11 (gpio0-11) from group mipi-pwr on device rockchip-pinctrl
[ 0.893836] reg-fixed-voltage vcc-mipi: Error applying setting, reverse things back
[ 0.904015] iommu: Adding device ff910000.rkisp1 to group 0
[ 0.909748] iommu: Adding device ff930000.vop to group 1
[ 0.915248] iommu: Adding device ff940000.vop to group 2
[ 0.920720] iommu: Adding device ff9a0000.vpu-service to group 3
[ 0.926930] iommu: Adding device ff9c0000.hevc-service to group 4
[ 0.933901] rk_iommu ff914000.iommu: can't get sclk
[ 0.939464] rk_iommu ff930300.iommu: can't get sclk
[ 0.944786] rk_iommu ff940300.iommu: can't get sclk
[ 0.950163] rk_iommu ff9a0800.iommu: can't get sclk
[ 0.955554] rk_iommu ff9c0440.iommu: can't get sclk
[ 0.961374] SCSI subsystem initialized
[ 0.965519] usbcore: registered new interface driver usbfs
[ 0.971159] usbcore: registered new interface driver hub
[ 0.976654] usbcore: registered new device driver usb
[ 0.981986] media: Linux media interface: v0.10
[ 0.986608] Linux video capture interface: v2.00
[ 0.991384] pps_core: LinuxPPS API ver. 1 registered
[ 0.996389] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.005556] PTP clock support registered
[ 1.012006] Advanced Linux Sound Architecture Driver Initialized.
[ 1.019100] Bluetooth: Core ver 2.21
[ 1.022787] NET: Registered protocol family 31
[ 1.027239] Bluetooth: HCI device and connection manager initialized
[ 1.033643] Bluetooth: HCI socket layer initialized
[ 1.038536] Bluetooth: L2CAP socket layer initialized
[ 1.043672] Bluetooth: SCO socket layer initialized
[ 1.050230] rockchip-cpuinfo cpuinfo: Serial : 805e91ee6a522501
[ 1.057750] clocksource: Switched to clocksource arch_sys_counter
[ 1.147442] NET: Registered protocol family 2
[ 1.152760] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.159966] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 1.166749] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.173234] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 1.179252] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 1.185959] NET: Registered protocol family 1
[ 1.190957] RPC: Registered named UNIX socket transport module.
[ 1.196890] RPC: Registered udp transport module.
[ 1.201654] RPC: Registered tcp transport module.
[ 1.206368] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.214557] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 1.226285] Initialise system trusted keyring
[ 1.246155] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.255286] NFS: Registering the id_resolver key type
[ 1.260447] Key type id_resolver registered
[ 1.264645] Key type id_legacy registered
[ 1.268726] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.276425] fuse init (API version 7.23)
[ 1.289426] NET: Registered protocol family 38
[ 1.293913] Key type asymmetric registered
[ 1.298136] Asymmetric key parser 'x509' registered
[ 1.303148] bounce: pool size: 64 pages
[ 1.307315] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.314844] io scheduler noop registered
[ 1.318887] io scheduler deadline registered
[ 1.323229] io scheduler cfq registered (default)
[ 1.337009] rk-vcodec ff9a0000.vpu-service: no regulator for vcodec
[ 1.343788] rk-vcodec ff9a0000.vpu-service: probe device
[ 1.349658] rk-vcodec ff9a0000.vpu-service: drm allocator with mmu enabled
[ 1.357789] rk-vcodec ff9a0000.vpu-service: could not find power_model node
[ 1.364762] rk-vcodec ff9a0000.vpu-service: init success
[ 1.370646] rk-vcodec ff9c0000.hevc-service: no regulator for vcodec
[ 1.377514] rk-vcodec ff9c0000.hevc-service: probe device
[ 1.383387] rk-vcodec ff9c0000.hevc-service: drm allocator with mmu enabled
[ 1.391276] rk-vcodec ff9c0000.hevc-service: could not find power_model node
[ 1.398392] rk-vcodec ff9c0000.hevc-service: init success
[ 1.407466] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.415108] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.425749] dma-pl330 ff600000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.433387] dma-pl330 ff600000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.444519] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.453320] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.460829] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 1.470783] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.482205] [drm] Initialized drm 1.1.0 20060810
[ 1.494079] [drm] Rockchip DRM driver version: v1.0.1
[ 1.499705] rockchip-drm display-subsystem: devfreq is not set
[ 1.507098] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0d66538)
[ 1.515586] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0d66538)
[ 1.523362] i2c i2c-6: of_i2c: modalias failure on /hdmi@ff980000/ports
[ 1.530044] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.537970] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.01a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.549502] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0d5d460)
[ 1.556909] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.563591] [drm] No driver support for vblank timestamp query.
[ 1.569957] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
[ 1.577921] rockchip-drm display-subsystem: can't not find any loader display
[ 1.585102] rockchip-drm display-subsystem: failed to show loader logo
[ 1.591924] Freeing drm_logo memory: 616K
[ 1.595969] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 1.604023] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.620343] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.650555] usbcore: registered new interface driver udl
[ 1.661825] mali ffa30000.gpu: Failed to get regulator
[ 1.666982] mali ffa30000.gpu: Power control initialization failed
[ 1.675237] brd: module loaded
[ 1.689222] loop: module loaded
[ 1.693577] zram: Added device: zram0
[ 1.697297] lkdtm: No crash points registered, enable through debugfs
[ 1.705132] rockchip-spi ff110000.spi: no high_speed pinctrl state
[ 1.712944] register spi return v = :0
[ 1.716794] tun: Universal TUN/TAP device driver, 1.6
[ 1.721906] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.730636] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.737296] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 1.748104] PPP generic driver version 2.4.2
[ 1.752848] usbcore: registered new interface driver rndis_wlan
[ 1.759204] usbcore: registered new interface driver rt2800usb
[ 1.765164] Rockchip WiFi SYS interface (V1.00) ...
[ 1.770262] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.777809] usbcore: registered new interface driver pegasus
[ 1.783571] usbcore: registered new interface driver rtl8150
[ 1.789370] usbcore: registered new interface driver r8152
[ 1.794964] usbcore: registered new interface driver asix
[ 1.800511] usbcore: registered new interface driver ax88179_178a
[ 1.806696] usbcore: registered new interface driver cdc_ether
[ 1.812673] usbcore: registered new interface driver dm9601
[ 1.818405] usbcore: registered new interface driver smsc75xx
[ 1.824272] usbcore: registered new interface driver smsc95xx
[ 1.830159] usbcore: registered new interface driver net1080
[ 1.835926] usbcore: registered new interface driver rndis_host
[ 1.841996] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.849576] usbcore: registered new interface driver cdc_ncm
[ 1.855333] usbcore: registered new interface driver qmi_wwan
[ 1.861220] usbcore: registered new interface driver cdc_mbim
[ 1.867589] ff540000.usb supply vusb_d not found, using dummy regulator
[ 1.874376] ff540000.usb supply vusb_a not found, using dummy regulator
[ 1.998468] dwc2 ff540000.usb: DWC OTG Controller
[ 2.003229] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 2.010387] dwc2 ff540000.usb: irq 44, io mem 0xff540000
[ 2.016103] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.022951] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.030214] usb usb1: Product: DWC OTG Controller
[ 2.034930] usb usb1: Manufacturer: Linux 4.4.194 dwc2_hsotg
[ 2.040620] usb usb1: SerialNumber: ff540000.usb
[ 2.046277] hub 1-0:1.0: USB hub found
[ 2.050151] hub 1-0:1.0: 1 port detected
[ 2.055052] ff580000.usb supply vusb_d not found, using dummy regulator
[ 2.061818] ff580000.usb supply vusb_a not found, using dummy regulator
[ 2.187845] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 2.195780] dwc2 ff580000.usb: DWC OTG Controller
[ 2.200602] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 2.207696] dwc2 ff580000.usb: irq 45, io mem 0xff580000
[ 2.213351] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.220199] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.227431] usb usb2: Product: DWC OTG Controller
[ 2.232176] usb usb2: Manufacturer: Linux 4.4.194 dwc2_hsotg
[ 2.237867] usb usb2: SerialNumber: ff580000.usb
[ 2.243490] hub 2-0:1.0: USB hub found
[ 2.247319] hub 2-0:1.0: 1 port detected
[ 2.254024] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.260631] ehci-platform: EHCI generic platform driver
[ 2.266318] ehci-platform ff500000.usb: EHCI Host Controller
[ 2.272413] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 3
[ 2.280555] ehci-platform ff500000.usb: irq 42, io mem 0xff500000
[ 2.427822] usb 1-1: new high-speed USB device number 2 using dwc2
[ 2.447821] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
[ 2.454349] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.461206] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.468470] usb usb3: Product: EHCI Host Controller
[ 2.473356] usb usb3: Manufacturer: Linux 4.4.194 ehci_hcd
[ 2.478879] usb usb3: SerialNumber: ff500000.usb
[ 2.484562] hub 3-0:1.0: USB hub found
[ 2.488436] hub 3-0:1.0: 1 port detected
[ 2.493512] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.499844] ohci-platform: OHCI generic platform driver
[ 2.505475] ohci-platform ff520000.usb: Generic Platform OHCI controller
[ 2.512744] ohci-platform ff520000.usb: new USB bus registered, assigned bus number 4
[ 2.520863] ohci-platform ff520000.usb: irq 43, io mem 0xff520000
[ 2.582106] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.588976] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.596210] usb usb4: Product: Generic Platform OHCI controller
[ 2.602179] usb usb4: Manufacturer: Linux 4.4.194 ohci_hcd
[ 2.607677] usb usb4: SerialNumber: ff520000.usb
[ 2.613689] hub 4-0:1.0: USB hub found
[ 2.617520] hub 4-0:1.0: 1 port detected
[ 2.622645] usbcore: registered new interface driver cdc_acm
[ 2.628379] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.636602] usbcore: registered new interface driver cdc_wdm
[ 2.642529] usbcore: registered new interface driver usb-storage
[ 2.648834] usbcore: registered new interface driver usbserial
[ 2.654756] usbcore: registered new interface driver usbserial_generic
[ 2.661401] usbserial: USB Serial support registered for generic
[ 2.667521] usbcore: registered new interface driver ch341
[ 2.673287] usbserial: USB Serial support registered for ch341-uart
[ 2.679886] usbcore: registered new interface driver cp210x
[ 2.685615] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 2.692384] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.692451] usbserial: USB Serial support registered for cp210x
[ 2.692623] usbcore: registered new interface driver ftdi_sio
[ 2.692680] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.692961] usbcore: registered new interface driver keyspan
[ 2.693016] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.693066] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.693116] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.693164] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.693270] usbcore: registered new interface driver option
[ 2.693322] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.693686] usbcore: registered new interface driver oti6858
[ 2.693739] usbserial: USB Serial support registered for oti6858
[ 2.693851] usbcore: registered new interface driver pl2303
[ 2.693906] usbserial: USB Serial support registered for pl2303
[ 2.694018] usbcore: registered new interface driver qcserial
[ 2.694070] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.694196] usbcore: registered new interface driver sierra
[ 2.694249] usbserial: USB Serial support registered for Sierra USB modem
[ 2.696111] usbcore: registered new interface driver iforce
[ 2.696264] usbcore: registered new interface driver xpad
[ 2.696427] ==gsl_ts_init==
[ 2.696476] ret=0
[ 2.696957] usbcore: registered new interface driver usbtouchscreen
[ 2.697315] .. rk pwm remotectl v1.1 init
[ 2.697827] input: ff680000.pwm as /devices/platform/ff680000.pwm/input/input0
[ 2.698637] sensor_register_slave:mma8452,id=17
[ 2.698656] sensor_register_slave:lis3dh,id=7
[ 2.698672] sensor_register_slave:mma7660,id=18
[ 2.698688] sensor_register_slave:lsm303d,id=22
[ 2.698703] sensor_register_slave:gs_mc3230,id=23
[ 2.698707] [Gsensor] gsensor_init
[ 2.698723] sensor_register_slave:mpu6880_acc,id=24
[ 2.698739] sensor_register_slave:mpu6500_acc,id=25
[ 2.698754] sensor_register_slave:lsm330_acc,id=26
[ 2.698770] sensor_register_slave:akm8975,id=30
[ 2.698785] sensor_register_slave:akm8963,id=31
[ 2.698801] sensor_register_slave:l3g4200d,id=45
[ 2.698816] sensor_register_slave:l3g20d,id=46
[ 2.698830] sensor_register_slave:ewtsa,id=47
[ 2.698845] sensor_register_slave:lsm330_gyro,id=51
[ 2.698861] sensor_register_slave:cm3217,id=53
[ 2.698876] sensor_register_slave:cm3218,id=54
[ 2.700118] i2c /dev entries driver
[ 2.702011] fan53555-regulator 0-0040: Failed to get chip ID!
[ 2.702669] fan53555-regulator 0-0041: Failed to get chip ID!
[ 2.703499] rtc-hym8563 0-0051: could not init device, -6
[ 2.704641] REG1: supplied by vcc_sys
[ 2.704897] vcc_ddr: failed to get the current voltage(-6)
[ 2.704912] act8865 0-005a: failed to register REG1
[ 2.705096] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f09fe000
[ 2.706265] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at f0d22000
[ 2.707325] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f0d24000
[ 2.708710] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0d26000
[ 2.712452] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 2.712497] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 2.716052] usbcore: registered new interface driver uvcvideo
[ 2.716056] USB Video Class driver (1.1.1)
[ 2.718969] Boot mode: coldboot
[ 2.719678] clk: couldn't get clock 0 for /tsadc@ff280000
[ 2.721552] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.721870] Bluetooth: Virtual HCI driver ver 1.5
[ 2.722119] Bluetooth: HCI UART driver ver 2.3
[ 2.722127] Bluetooth: HCI UART protocol H4 registered
[ 2.722132] Bluetooth: HCI UART protocol LL registered
[ 2.722137] Bluetooth: HCI UART protocol ATH3K registered
[ 2.722264] usbcore: registered new interface driver bfusb
[ 2.722397] usbcore: registered new interface driver btusb
[ 2.723011] cpu cpu0: bin=1
[ 2.723201] cpu cpu0: leakage=16
[ 2.723260] cpu cpu0: Failed to get reg
[ 2.723288] cpu cpu0: bin-scale=25
[ 2.723804] sdhci: Secure Digital Host Controller Interface driver
[ 2.723807] sdhci: Copyright(c) Pierre Ossman
[ 2.723818] Synopsys Designware Multimedia Card Interface Driver
[ 2.725306] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.725405] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[ 2.725423] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[ 2.725508] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[ 2.725548] dwmmc_rockchip ff0c0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.726656] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.726744] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 2.726761] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 2.726831] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 2.726861] dwmmc_rockchip ff0d0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.726907] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[ 2.726916] dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found
[ 2.728250] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.728338] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[ 2.728356] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[ 2.728440] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[ 2.728471] dwmmc_rockchip ff0f0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.728518] dwmmc_rockchip ff0f0000.dwmmc: No vmmc regulator found
[ 2.728526] dwmmc_rockchip ff0f0000.dwmmc: No vqmmc regulator found
[ 2.741470] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.754179] dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
[ 2.754623] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.756207] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.757972] usbcore: registered new interface driver usbhid
[ 2.757976] usbhid: USB HID core driver
[ 2.758622] ashmem: initialized
[ 2.760042] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 2.763290] rknandbase v1.2 2018-05-08
[ 2.764840] usbcore: registered new interface driver snd-usb-audio
[ 2.766604] ES8323 2-0010: Can not read property spk_ctl_gpio
[ 2.767125] ES8323 2-0010: Can not read property aux_det_gpio
[ 2.774584] u32 classifier
[ 2.774615] Netfilter messages via NETLINK v0.30.
[ 2.774770] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.775320] ctnetlink v0.93: registering with nfnetlink.
[ 2.775542] ip_set: protocol 6
[ 2.775562] IPVS: Registered protocols ()
[ 2.775626] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 2.775794] IPVS: Creating netns size=1104 id=0
[ 2.775844] IPVS: ipvs loaded.
[ 2.776662] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.776950] Initializing XFRM netlink socket
[ 2.778543] NET: Registered protocol family 10
[ 2.779879] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.780232] sit: IPv6 over IPv4 tunneling driver
[ 2.781439] NET: Registered protocol family 17
[ 2.781491] NET: Registered protocol family 15
[ 2.781563] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.781628] Bridge firewalling registered
[ 2.781824] Bluetooth: RFCOMM socket layer initialized
[ 2.781886] Bluetooth: RFCOMM ver 1.11
[ 2.781934] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.781954] Bluetooth: HIDP socket layer initialized
[ 2.782051] 8021q: 802.1Q VLAN Support v1.8
[ 2.782093] lib80211: common routines for IEEE802.11 drivers
[ 2.782159] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.782622] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.782658] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212
[ 2.782664] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.782670] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.782751] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 150, flags = 0.
[ 2.782762] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 2.782767] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.782776] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.782955] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.783644] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139.
[ 2.783706] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149.
[ 2.783748] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146.
[ 2.783788] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151.
[ 2.783799] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 2.783916] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.784005] [BT_RFKILL]: ** disable irq
[ 2.784359] [BT_RFKILL]: bt_default device registered.
[ 2.784564] Key type dns_resolver registered
[ 2.784776] sensor_register_slave:mpu6880_gyro,id=50
[ 2.784931] ov13850 3-0010: driver version: 00.01.03
[ 2.785561] ov13850 3-0010: could not get default pinstate
[ 2.785570] ov13850 3-0010: could not get sleep pinstate
[ 2.807594] mmc_host mmc0: Bus speed (slot 0) = 99000000Hz (slot req 100000000Hz, actual 99000000HZ div = 0)
[ 2.809033] dwmmc_rockchip ff0f0000.dwmmc: All phases bad!
[ 2.809041] mmc0: tuning execution failed
[ 2.809056] mmc0: error -5 whilst initialising MMC card
[ 3.582071] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 3.587842] hub 1-1:1.0: USB hub found
[ 3.591750] hub 1-1:1.0: 7 ports detected
[ 3.777787] rk3x-i2c ff150000.i2c: timeout, ipd: 0x00, state: 1
[ 3.783738] ov13850 3-0010: Unexpected sensor id(000000), ret(-5)
[ 3.791385] ThumbEE CPU extension supported.
[ 3.795694] Registering SWP/SWPB emulation handler
[ 3.801804] Loading compiled-in X.509 certificates
[ 3.807822] mali ffa30000.gpu: Failed to get regulator
[ 3.812981] mali ffa30000.gpu: Power control initialization failed
[ 3.821270] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 3.827990] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 3.838068] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 3.846471] clk: couldn't get clock 0 for /tsadc@ff280000
[ 3.853672] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.861046] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[ 3.867895] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[ 3.873692] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[ 3.883496] dwmmc_rockchip ff0c0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 3.893200] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.900559] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 3.907367] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 3.913195] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 3.923001] dwmmc_rockchip ff0d0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 3.931167] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[ 3.937353] dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found
[ 3.944995] rockchip-dmc dmc: Cannot get the regulator "center"
[ 4.075620] asoc-simple-card sound: ES8323 HiFi <-> ff890000.i2s mapping ok
[ 4.083945] asoc-simple-card sound: i2s-hifi <-> ff890000.i2s mapping ok
[ 4.090728] asoc-simple-card sound: ASoC: no sink widget found for MIC1
[ 4.097350] asoc-simple-card sound: ASoC: Failed to add route Microphone Jack -> direct -> MIC1
[ 4.106083] asoc-simple-card sound: ASoC: no sink widget found for MIC2
[ 4.112730] asoc-simple-card sound: ASoC: Failed to add route Microphone Jack -> direct -> MIC2
[ 4.121457] asoc-simple-card sound: ASoC: no source widget found for micbias1
[ 4.128627] asoc-simple-card sound: ASoC: Failed to add route micbias1 -> direct -> Microphone Jack
[ 4.137675] asoc-simple-card sound: ASoC: no source widget found for HPOL
[ 4.144514] asoc-simple-card sound: ASoC: Failed to add route HPOL -> direct -> Headphone Jack
[ 4.153168] asoc-simple-card sound: ASoC: no source widget found for HPOR
[ 4.159997] asoc-simple-card sound: ASoC: Failed to add route HPOR -> direct -> Headphone Jack
[ 4.172616] input: rockchip,firefly-codec Headphone Jack as /devices/platform/sound/sound/card0/input2
[ 4.185244] asoc-simple-card spdif-sound: dit-hifi <-> ff8b0000.sound mapping ok
[ 4.194502] mali ffa30000.gpu: Failed to get regulator
[ 4.199706] mali ffa30000.gpu: Power control initialization failed
[ 4.208025] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 4.214683] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 4.225499] clk: couldn't get clock 0 for /tsadc@ff280000
[ 4.232646] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.240020] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[ 4.246833] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[ 4.252714] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[ 4.262544] dwmmc_rockchip ff0c0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 4.272250] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.279627] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 4.286436] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 4.292251] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 4.302061] dwmmc_rockchip ff0d0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 4.310295] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[ 4.316483] dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found
[ 4.324033] rockchip-dmc dmc: Cannot get the regulator "center"
[ 4.330532] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 4.330536]
[ 4.330548] =======================================================
[ 4.330551] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 4.330554] =======================================================
[ 4.330559] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 4.330565] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 4.330571] [WLAN_RFKILL]: wifi turn on power. -1
[ 4.330574] RTW: module init start
[ 4.330578] RTW: rtl8188eu v5.2.2.3_24783.20171030
[ 4.330583] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 4.330787] usbcore: registered new interface driver rtl8188eu
[ 4.330793] RTW: module init ret=0
[ 4.331880] input: gpio-keys as /devices/platform/gpio-keys/input/input3
[ 4.338500] hctosys: unable to open rtc device (rtc0)
[ 4.338826] mali ffa30000.gpu: Failed to get regulator
[ 4.338836] mali ffa30000.gpu: Power control initialization failed
[ 4.340971] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 4.340972] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 4.342728] clk: couldn't get clock 0 for /tsadc@ff280000
[ 4.344462] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.344583] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[ 4.344600] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[ 4.344644] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[ 4.344675] dwmmc_rockchip ff0c0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 4.346306] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.346421] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 4.346439] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 4.346479] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 4.346509] dwmmc_rockchip ff0d0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 4.346555] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[ 4.346563] dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found
[ 4.347841] rockchip-dmc dmc: Cannot get the regulator "center"
[ 4.359848] vcc_sd: disabling
[ 4.359858] vcc_mipi: disabling
[ 4.359864] dvdd_1v2: disabling
[ 4.360142] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '14:46:42', on 'Mar 25 2020'.
[ 4.360744] Mali: Mali device driver loaded
[ 4.360780] rkisp1 ff910000.rkisp1: clear unready subdev num: 1
[ 4.361462] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.361468] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 4.361473] rkisp1: update sensor failed
[ 4.361981] ALSA device list:
[ 4.361987] #0: rockchip,firefly-codec
[ 4.361991] #1: ROCKCHIP,SPDIF
[ 4.603751] ======== dhd_wlan_init_plat_data ========
[ 4.604046] Waiting for root device PARTUUID=614e0000-0000...
[ 4.614603] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 4.620212] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=232, oob_irq_flags=0x414
[ 4.627691] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 4.631988] dhd_wifi_platform_load: Enter
[ 4.636029] Power-up adapter 'DHD generic adapter'
[ 4.640916] wifi_platform_set_power = 1
[ 4.644764] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 4.649935] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 4.654648] [WLAN_RFKILL]: wifi turn on power. -1
[ 4.967796] wifi_platform_bus_enumerate device present 1
[ 4.973113] ======== Card detection to detect SDIO card! ========
[ 4.979248] sdio: host isn't initialization successfully.
[ 5.837790] vendor storage:20190527 ret = -1
[ 6.977803] failed to power up DHD generic adapter, 1 retry left
[ 6.999912] wifi_platform_set_power = 0
[ 7.003762] ======== PULL WL_REG_ON(-1) LOW! ========
[ 7.008867] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 7.013581] [WLAN_RFKILL]: wifi shut off power.
[ 7.018139] wifi_platform_bus_enumerate device present 0
[ 7.023450] ======== Card detection to remove SDIO card! ========
[ 7.029569] sdio: host isn't initialization successfully.
[ 7.035124] wifi_platform_set_power = 1
[ 7.039005] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 7.044151] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 7.048887] [WLAN_RFKILL]: wifi turn on power. -1
[ 7.357805] wifi_platform_bus_enumerate device present 1
[ 7.363123] ======== Card detection to detect SDIO card! ========
[ 7.369252] sdio: host isn't initialization successfully.
[ 9.367801] failed to power up DHD generic adapter, 0 retry left
[ 9.389913] wifi_platform_set_power = 0
[ 9.393763] ======== PULL WL_REG_ON(-1) LOW! ========
[ 9.398857] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 9.403570] [WLAN_RFKILL]: wifi shut off power.
[ 9.408132] wifi_platform_bus_enumerate device present 0
[ 9.413444] ======== Card detection to remove SDIO card! ========
[ 9.419561] sdio: host isn't initialization successfully.
[ 9.425054] failed to power up DHD generic adapter, max retry reached**
[ 9.431809] unregister wifi platform drivers
[ 9.436092] wifi_platform_bus_enumerate device present 0
[ 9.441447] ======== Card detection to remove SDIO card! ========
[ 9.447543] sdio: host isn't initialization successfully.
[ 9.453068] ======== dhd_wlan_deinit_plat_data ========
[ 9.458327] dhd_module_init: Failed to load the driver, try cnt 0
[ 9.464484] dhd_module_init: Failed to load driver max retry reached**
[ 9.471046] dhd_module_init: Exit err=-19
16-2.zip (23.5 KB)
