我用官方提供的rk3288_ubuntu_18.04编译Ubuntu后烧录出错
这个板子是2+8g的但是这个上边usage只显示2g
然后就是一直弹这个错误
Channel a: DDR3 400MHz
Channel b: DDR3 400MHz
Memory OK
Memory OK
Boot1 Release Time: Jul 22 2021 09:08:57, version: 2.63
ChipType = 0x8, 235
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7457MB
FwPartOffset=2000 , 2000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=29820MB
FwPartOffset=0 , 0
StorageInit ok = 48634
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part:  0, name:            uboot, start:0x4000, size:0x2000
GPT part:  1, name:            trust, start:0x6000, size:0x2000
GPT part:  2, name:             misc, start:0x8000, size:0x2000
GPT part:  3, name:             boot, start:0xa000, size:0x10000
GPT part:  4, name:         recovery, start:0x1a000, size:0x10000
GPT part:  5, name:           backup, start:0x2a000, size:0x10000
GPT part:  6, name:           rootfs, start:0x5a000, size:0x3fe800
GPT part:  7, name:         userdata, start:0x458800, size:0xa3865f
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LOADER Check OK! 0x4000, 167807
TOS    Check OK! 0x6000, 199824
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:385: Core0 Initializing (1.1.0-449-g24f5da14f #hisping.lin #3 Mon Aug 14 03:49:32 UTC 2023 arm)
INF [0x0] TEE-CORE:init_primary_helper:386: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:387: Next entry point address: 0x200000
U-Boot 2017.09(u-boot commit id: e4da79f87a88e70b076e97de82fc8ece3b6d6ea9)(sdk version: rk3288_linux_release_20220304_v2.5.0a.xml)-ge4da79f #mkyx (Aug 17 2024 - 02:35:23 -0700)
Model: Evb-RK3288
PreSerial: 2, raw, 0xff690000
DRAM:  2 GiB
Sysmem: init
Relocation Offset: 00000000
Relocation fdt: 7bdd3950 - 7bdd4de5
CR: M/C/I
Hotkey: ctrl+`
dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: None
Found DTB in boot part
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 400000Hz
PMIC:  RK808
vdd_arm 1100000 uV
vdd_gpu 1100000 uV
vcc_log 1100000 uV
hdmi@ff980000 disconnected
AUX CH command reply failed!
AUX CH error happens: 2
failed to get edid
CLK: (sync kernel. arm: enter 1000000 KHz, init 1000000 KHz, kernel 0N/A)
  apll 1000000 KHz
  dpll 396000 KHz
  cpll 24000 KHz
  gpll 594000 KHz
  npll 24000 KHz
  aclk_bus 198000 KHz
Net:   Net Initialization Skipped
No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
ANDROID: reboot reason: "(none)"
optee api revision: 2.0
Not AVB images, AVB skip
Booting ZIMAGE kernel at 0x02008000(Uncompress to 0) with fdt at 0x08300000...
Fdt Ramdisk skip relocation
## Booting Android Image at 0x02007800 ...
Kernel load addr 0x02008000 size 8329 KiB
## Flattened Device Tree blob at 0x08300000
   Booting using the fdt blob at 0x08300000
   XIP Kernel Image from 0x02008000 to 0x02008000 ... OK
  'reserved-memory' dma-unusable@fe000000: addr=fe000000 size=1000000
  'reserved-memory' ramoops@8000000: addr=8000000 size=f0000
   Using Device Tree in place at 08300000, end 08312c6f
failed to reserve drm-cubic-lut memory
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x09310000 - 0x80000000 (size: 0x76cf0000)
Total: 786.996 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x500
[    0.000000] Linux version 5.10.198+ (mkyx@ubuntu) (arm-linux-gnueabihf-gcc (Linaro GCC 6.3-2017.05) 6.3.1 20170404, GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #1 SMP Fri Aug 16 22:03:01 PDT 2024
[    0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: rockchip,rk3288w
[    0.000000] earlycon: uart8250 at MMIO32 0xff690000 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 16 MiB at 0x7f000000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000000000000-0x00000000207fffff]
[    0.000000]   HighMem  [mem 0x0000000020800000-0x000000007fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x00000000083fffff]
[    0.000000]   node   0: [mem 0x0000000009310000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] On node 0, zone Normal: 784 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 20 pages/cpu s50392 r8192 d23336 u81920
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 519392
[    0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal  androidboot.verifiedbootstate=orange androidboot.slot_suffix=  rw rootwait earlycon=uart8250,mmio32,0xff690000 console=ttyFIQ0 vmalloc=496M root=PARTUUID=614e0000-0000 rootfstype=ext4
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 2025536K/2081728K available (13312K kernel code, 1877K rwdata, 3908K rodata, 1024K init, 516K bss, 39808K reserved, 16384K cma-reserved, 1547552K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 50900 entries in 150 pages
[    0.000000] ftrace: allocated 150 pages with 4 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008803] Switching to timer-based delay loop, resolution 41ns
[    0.017870] Console: colour dummy device 80x30
[    0.022801] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.034210] CPU: Testing write buffer coherency: ok
[    0.039635] CPU0: Spectre v2: using BPIALL workaround
[    0.045210] pid_max: default: 32768 minimum: 301
[    0.050433] LSM: Security Framework initializing
[    0.055554] Yama: becoming mindful.
[    0.059490] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.067559] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.077892] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[    0.085979] Setting up static identity map for 0x100000 - 0x100060
[    0.093151] rcu: Hierarchical SRCU implementation.
[    0.099604] smp: Bringing up secondary CPUs ...
[    0.106413] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[    0.106428] CPU1: Spectre v2: using BPIALL workaround
[    0.120262] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[    0.120279] CPU2: Spectre v2: using BPIALL workaround
[    0.134078] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[    0.134094] CPU3: Spectre v2: using BPIALL workaround
[    0.146206] smp: Brought up 1 node, 4 CPUs
[    0.150714] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.157655] CPU: All CPU(s) started in SVC mode.
[    0.164055] devtmpfs: initialized
[    0.195003] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[    0.203949] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.214819] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.223734] pinctrl core: initialized pinctrl subsystem
[    0.231981] NET: Registered protocol family 16
[    0.240858] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.251179] Registered FIQ tty driver
[    0.255957] thermal_sys: Registered thermal governor 'step_wise'
[    0.256989] cpuidle: using governor menu
[    0.269169] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.278002] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.345362] rockchip-gpio ff750000.gpio0: probed /pinctrl/gpio0@ff750000
[    0.354069] rockchip-gpio ff780000.gpio1: probed /pinctrl/gpio1@ff780000
[    0.362858] rockchip-gpio ff790000.gpio2: probed /pinctrl/gpio2@ff790000
[    0.371515] rockchip-gpio ff7a0000.gpio3: probed /pinctrl/gpio3@ff7a0000
[    0.380287] rockchip-gpio ff7b0000.gpio4: probed /pinctrl/gpio4@ff7b0000
[    0.388974] rockchip-gpio ff7c0000.gpio5: probed /pinctrl/gpio5@ff7c0000
[    0.397607] rockchip-gpio ff7d0000.gpio6: probed /pinctrl/gpio6@ff7d0000
[    0.406459] rockchip-gpio ff7e0000.gpio7: probed /pinctrl/gpio7@ff7e0000
[    0.415268] rockchip-gpio ff7f0000.gpio8: probed /pinctrl/gpio8@ff7f0000
[    0.422795] rockchip-pinctrl pinctrl: probed pinctrl
[    0.482773] fiq_debugger fiq_debugger.0: IRQ fiq not found
[    0.488960] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[    0.495282] fiq_debugger_probe: could not install nmi irq handler
[    0.502161] printk: console [ttyFIQ0] enabled
[    0.511298] printk: bootconsole [uart8250] disabled
[    0.521995] Registered fiq debugger ttyFIQ0
[    0.530486] iommu: Default domain type: Translated
[    0.541144] SCSI subsystem initialized
[    0.545304] usbcore: registered new interface driver usbfs
[    0.550956] usbcore: registered new interface driver hub
[    0.556352] usbcore: registered new device driver usb
[    0.561652] mc: Linux media interface: v0.10
[    0.565999] videodev: Linux video capture interface: v2.00
[    0.571728] pps_core: LinuxPPS API ver. 1 registered
[    0.576700] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.585899] PTP clock support registered
[    0.592565] Advanced Linux Sound Architecture Driver Initialized.
[    0.599792] Bluetooth: Core ver 2.22
[    0.603455] NET: Registered protocol family 31
[    0.607908] Bluetooth: HCI device and connection manager initialized
[    0.614337] Bluetooth: HCI socket layer initialized
[    0.619233] Bluetooth: L2CAP socket layer initialized
[    0.624359] Bluetooth: SCO socket layer initialized
[    0.631139] clocksource: Switched to clocksource arch_sys_counter
[    1.790889] NET: Registered protocol family 2
[    1.795669] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.804618] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 6144 bytes, linear)
[    1.813195] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    1.821021] TCP bind hash table entries: 4096 (order: 4, 81920 bytes, linear)
[    1.828357] TCP: Hash tables configured (established 4096 bind 4096)
[    1.834970] UDP hash table entries: 256 (order: 1, 12288 bytes, linear)
[    1.841686] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes, linear)
[    1.849119] NET: Registered protocol family 1
[    1.854778] RPC: Registered named UNIX socket transport module.
[    1.860715] RPC: Registered udp transport module.
[    1.865499] RPC: Registered tcp transport module.
[    1.870216] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.880505] rockchip-thermal ff280000.tsadc: tsadc is probed successfully!
[    1.889842] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[    1.901378] Initialise system trusted keyrings
[    1.906251] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[    1.923673] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.932588] NFS: Registering the id_resolver key type
[    1.937704] Key type id_resolver registered
[    1.941971] Key type id_legacy registered
[    1.946021] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.953716] fuse: init (API version 7.32)
[    2.065689] NET: Registered protocol family 38
[    2.070159] Key type asymmetric registered
[    2.074318] Asymmetric key parser 'x509' registered
[    2.079317] bounce: pool size: 64 pages
[    2.083265] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    2.090668] io scheduler mq-deadline registered
[    2.095256] io scheduler kyber registered
[    2.099526] io scheduler bfq registered
[    2.107422] rockchip-mipi-dphy-rx ff770000.syscon:mipi-phy-rx0: invalid resource
[    2.123480] pwm-backlight backlight: supply power not found, using dummy regulator
[    2.132171] iep ff900000.iep: Adding to iommu group 0
[    2.137407] iep: failed to find iep power down clock source.
[    2.144042] iep: IEP Power ON
[    2.147081] iep: IEP Power OFF
[    2.150195] iep: IEP Driver loaded succesfully
[    2.155143] iep: Module initialized.
[    2.158989] mpp_service mpp-srv: 04a62e7 author: liji 2024-02-16 first commit
[    2.166184] mpp_service mpp-srv: probe start
[    2.172000] mpp_rkvdec ff9c0000.hevc_service: Adding to iommu group 5
[    2.178848] mpp_rkvdec ff9c0000.hevc_service: probing start
[    2.185091] rkvdec_init:1242: failed on clk_get clk_hevc_cabac
[    2.190945] mpp_rkvdec ff9c0000.hevc_service: shared_video_a is not found!
[    2.197881] rkvdec_init:1255: No aclk reset resource define
[    2.203515] mpp_rkvdec ff9c0000.hevc_service: shared_video_h is not found!
[    2.210396] rkvdec_init:1258: No hclk reset resource define
[    2.216013] mpp_rkvdec ff9c0000.hevc_service: shared_niu_a is not found!
[    2.222755] rkvdec_init:1261: No niu aclk reset resource define
[    2.228690] mpp_rkvdec ff9c0000.hevc_service: shared_niu_h is not found!
[    2.235449] rkvdec_init:1264: No niu hclk reset resource define
[    2.241439] mpp_rkvdec ff9c0000.hevc_service: shared_video_cabac is not found!
[    2.248669] rkvdec_init:1270: No cabac reset resource define
[    2.254377] mpp_rkvdec ff9c0000.hevc_service: shared_video_hevc_cabac is not found!
[    2.262071] rkvdec_init:1273: No hevc cabac reset resource define
[    2.268763] mpp_rkvdec ff9c0000.hevc_service: probing finish
[    2.275648] mpp_vdpu1 ff9a0400.vdpu: Adding to iommu group 4
[    2.281923] mpp_vdpu1 ff9a0400.vdpu: probe device
[    2.287190] mpp_vdpu1 ff9a0400.vdpu: reset_group->rw_sem_on=0
[    2.293035] mpp_vdpu1 ff9a0400.vdpu: reset_group->rw_sem_on=0
[    2.299400] mpp_vdpu1 ff9a0400.vdpu: probing finish
[    2.305160] mpp_vepu1 ff9a0000.vepu: Adding to iommu group 4
[    2.311262] mpp_vepu1 ff9a0000.vepu: probe device
[    2.316468] mpp_vepu1 ff9a0000.vepu: reset_group->rw_sem_on=0
[    2.322289] mpp_vepu1 ff9a0000.vepu: reset_group->rw_sem_on=0
[    2.328609] mpp_vepu1 ff9a0000.vepu: probing finish
[    2.334523] mpp_service mpp-srv: probe success
[    2.346630] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.354294] dma-pl330 ff250000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.365228] dma-pl330 ff600000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.372871] dma-pl330 ff600000.dma-controller:       DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[    2.382513] rockchip-pvtm ff770000.syscon:pvtm: pvtm@0 probed
[    2.388329] rockchip-pvtm ff770000.syscon:pvtm: pvtm@1 probed
[    2.394887] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    2.403517] vcc_log: supplied by regulator-dummy
[    2.409410] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    2.416960] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 46, base_baud = 1500000) is a 16550A
[    2.429178] rockchip-vop ff930000.vop: Adding to iommu group 2
[    2.435619] rockchip-vop ff940000.vop: Adding to iommu group 3
[    2.456077] no ATF memory for init
[    2.466463] panel-simple panel: supply power not found, using dummy regulator
[    2.478532] brd: module loaded
[    2.495633] loop: module loaded
[    2.499833] zram: Added device: zram0
[    2.507204] tun: Universal TUN/TAP device driver, 1.6
[    2.514331] clk: failed to reparent mac_clk to npll: -22
[    2.519776] rk_gmac-dwmac ff290000.ethernet: IRQ eth_lpi not found
[    2.526226] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
[    2.532629] rk_gmac-dwmac ff290000.ethernet: clock input or output? (output).
[    2.539778] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
[    2.545490] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
[    2.551200] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
[    2.557467] rk_gmac-dwmac ff290000.ethernet: cannot get clock clk_mac_speed
[    2.564733] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[    2.570739] rk_gmac-dwmac ff290000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    2.577954] rk_gmac-dwmac ff290000.ethernet:         DWMAC1000
[    2.583231] rk_gmac-dwmac ff290000.ethernet: DMA HW capability register supported
[    2.590716] rk_gmac-dwmac ff290000.ethernet: RX Checksum Offload Engine supported
[    2.598237] rk_gmac-dwmac ff290000.ethernet: COE Type 2
[    2.603500] rk_gmac-dwmac ff290000.ethernet: TX Checksum insertion supported
[    2.610551] rk_gmac-dwmac ff290000.ethernet: Wake-Up On Lan supported
[    2.617169] rk_gmac-dwmac ff290000.ethernet: Normal descriptors
[    2.623147] rk_gmac-dwmac ff290000.ethernet: Ring mode enabled
[    2.628994] rk_gmac-dwmac ff290000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.722661] mdio_bus stmmac-0:00: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    3.732210] mdio_bus stmmac-0:01: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    3.744915] PPP generic driver version 2.4.2
[    3.750025] usbcore: registered new interface driver rt2800usb
[    3.756083] usbcore: registered new interface driver rndis_wlan
[    3.762067] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    3.769558] usbcore: registered new interface driver pegasus
[    3.775346] usbcore: registered new interface driver rtl8150
[    3.781140] usbcore: registered new interface driver r8152
[    3.786724] usbcore: registered new interface driver asix
[    3.792244] usbcore: registered new interface driver ax88179_178a
[    3.798417] usbcore: registered new interface driver cdc_ether
[    3.804395] usbcore: registered new interface driver dm9601
[    3.810066] usbcore: registered new interface driver smsc75xx
[    3.815964] usbcore: registered new interface driver smsc95xx
[    3.821837] usbcore: registered new interface driver net1080
[    3.827578] usbcore: registered new interface driver rndis_host
[    3.833654] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    3.841244] usbcore: registered new interface driver cdc_ncm
[    3.846991] usbcore: registered new interface driver cdc_mbim
[    3.853437] dwc2 ff540000.usb: supply vusb_d not found, using dummy regulator
[    3.860833] dwc2 ff540000.usb: supply vusb_a not found, using dummy regulator
[    4.301364] dwc2 ff540000.usb: Waiting for Host Mode timed out
[    4.307240] dwc2 ff540000.usb: dwc2_check_params: Invalid parameter lpm_clock_gating=1
[    4.315227] dwc2 ff540000.usb: dwc2_check_params: Invalid parameter besl=1
[    4.322150] dwc2 ff540000.usb: dwc2_check_params: Invalid parameter hird_threshold_en=1
[    4.330854] dwc2 ff540000.usb: DWC OTG Controller
[    4.335683] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[    4.342834] dwc2 ff540000.usb: irq 52, io mem 0xff540000
[    4.348636] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    4.356962] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.364229] usb usb1: Product: DWC OTG Controller
[    4.368945] usb usb1: Manufacturer: Linux 5.10.198+ dwc2_hsotg
[    4.374828] usb usb1: SerialNumber: ff540000.usb
[    4.380549] hub 1-0:1.0: USB hub found
[    4.384462] hub 1-0:1.0: 1 port detected
[    4.389831] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[    4.397326] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[    4.541242] dwc2 ff580000.usb: dwc2_check_params: Invalid parameter lpm_clock_gating=1
[    4.549171] dwc2 ff580000.usb: dwc2_check_params: Invalid parameter besl=1
[    4.556110] dwc2 ff580000.usb: dwc2_check_params: Invalid parameter hird_threshold_en=1
[    4.564191] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[    4.572101] dwc2 ff580000.usb: DWC OTG Controller
[    4.576861] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[    4.584176] dwc2 ff580000.usb: irq 53, io mem 0xff580000
[    4.589942] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    4.598267] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.605534] usb usb2: Product: DWC OTG Controller
[    4.610249] usb usb2: Manufacturer: Linux 5.10.198+ dwc2_hsotg
[    4.616131] usb usb2: SerialNumber: ff580000.usb
[    4.621852] hub 2-0:1.0: USB hub found
[    4.625709] hub 2-0:1.0: 1 port detected
[    4.633451] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.639992] ehci-platform: EHCI generic platform driver
[    4.646188] ehci-platform ff500000.usb: EHCI Host Controller
[    4.652363] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 3
[    4.660846] ehci-platform ff500000.usb: irq 50, io mem 0xff500000
[    4.731230] usb 1-1: new high-speed USB device number 2 using dwc2
[    4.761217] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
[    4.767888] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    4.776223] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.783499] usb usb3: Product: EHCI Host Controller
[    4.788384] usb usb3: Manufacturer: Linux 5.10.198+ ehci_hcd
[    4.794083] usb usb3: SerialNumber: ff500000.usb
[    4.799854] hub 3-0:1.0: USB hub found
[    4.803769] hub 3-0:1.0: 1 port detected
[    4.809060] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.815335] ohci-platform: OHCI generic platform driver
[    4.821095] ohci-platform ff520000.usb: Generic Platform OHCI controller
[    4.828261] ohci-platform ff520000.usb: new USB bus registered, assigned bus number 4
[    4.837588] ohci-platform ff520000.usb: irq 51, io mem 0xff520000
[    4.915815] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[    4.924159] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.931431] usb usb4: Product: Generic Platform OHCI controller
[    4.937361] usb usb4: Manufacturer: Linux 5.10.198+ ohci_hcd
[    4.943057] usb usb4: SerialNumber: ff520000.usb
[    4.948764] hub 4-0:1.0: USB hub found
[    4.952679] hub 4-0:1.0: 1 port detected
[    4.958019] usbcore: registered new interface driver cdc_acm
[    4.963741] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.972220] usbcore: registered new interface driver cdc_wdm
[    4.978084] usbcore: registered new interface driver usb-storage
[    4.984519] usbcore: registered new interface driver usbserial_generic
[    4.991235] usbserial: USB Serial support registered for generic
[    4.997360] usbcore: registered new interface driver cp210x
[    5.003041] usbserial: USB Serial support registered for cp210x
[    5.009108] usbcore: registered new interface driver ftdi_sio
[    5.015069] usbserial: USB Serial support registered for FTDI USB Serial Device
[    5.022967] usbcore: registered new interface driver keyspan
[    5.028906] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    5.036879] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201, bcdDevice= 1.00
[    5.045120] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    5.045225] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    5.052295] usb 1-1: Product: USB 2.0 Hub [MTT]
[    5.053439] hub 1-1:1.0: USB hub found
[    5.059669] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    5.064370] hub 1-1:1.0: 7 ports detected
[    5.067991] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    5.086870] usbcore: registered new interface driver option
[    5.092556] usbserial: USB Serial support registered for GSM modem (1-port)
[    5.099974] usbcore: registered new interface driver oti6858
[    5.105759] usbserial: USB Serial support registered for oti6858
[    5.111923] usbcore: registered new interface driver pl2303
[    5.117551] usbserial: USB Serial support registered for pl2303
[    5.123647] usbcore: registered new interface driver qcserial
[    5.129443] usbserial: USB Serial support registered for Qualcomm USB modem
[    5.136594] usbcore: registered new interface driver sierra
[    5.142273] usbserial: USB Serial support registered for Sierra USB modem
[    5.150555] usbcore: registered new interface driver iforce
[    5.156339] usbcore: registered new interface driver xpad
[    5.162116] usbcore: registered new interface driver usbtouchscreen
[    5.170277] i2c /dev entries driver
[    5.178013] rk808 0-001b: chip id: 0x0
[    5.187867] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    5.194173] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    5.201009] vdd_arm: supplied by vcc_sys
[    5.206455] vdd_gpu: supplied by vcc_sys
[    5.211176] vcc_ddr: supplied by vcc_sys
[    5.216317] vcc_io: supplied by vcc_sys
[    5.221414] vcc_tp: supplied by vcc_sys
[    5.227240] vcca_codec: supplied by vcc_sys
[    5.233349] vdd_10: supplied by regulator-dummy
[    5.239426] vcc_wl: supplied by vcc_io
[    5.244866] vccio_sd: supplied by vcc_io
[    5.250490] vdd10_lcd: supplied by regulator-dummy
[    5.257237] vcc_18: supplied by regulator-dummy
[    5.263565] vcc18_lcd: supplied by regulator-dummy
[    5.269807] vcc_sd: supplied by vcc_io
[    5.274500] vcc_lcd: supplied by vcc_io
[    5.283786] rk808-rtc rk808-rtc: registered as rtc0
[    5.289384] rk808-rtc rk808-rtc: setting system clock to 2013-01-18T08:50:27 UTC (1358499027)
[    5.308411] input: gsl3673 as /devices/platform/ff160000.i2c/i2c-4/4-0040/input/input0
[    5.451299] gsl3673 4-0040: GSL3673 test_i2c error!
[    5.456192] gsl3673 4-0040: gsl_probe: init_chip failed
[    5.462272] gsl3673: probe of 4-0040 failed with error -2
[    5.473459] rkisp1 ff910000.rkisp1: Adding to iommu group 1
[    5.479364] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[    5.485829] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[    5.492488] rkisp1 ff910000.rkisp1: Entity type for entity rkisp1-isp-subdev was not initialized!
[    5.503978] usbcore: registered new interface driver uvcvideo
[    5.509732] USB Video Class driver (1.1.1)
[    5.515830] device-mapper: ioctl: 4.44.0-ioctl (2021-02-01) initialised: dm-devel@redhat.com
[    5.525229] Bluetooth: HCI UART driver ver 2.3
[    5.529688] Bluetooth: HCI UART protocol H4 registered
[    5.534889] Bluetooth: HCI UART protocol ATH3K registered
[    5.540425] usbcore: registered new interface driver bfusb
[    5.546112] usbcore: registered new interface driver btusb
[    5.552236] cpu cpu0: bin=1
[    5.555193] cpu cpu0: leakage=16
[    5.570828] cpu cpu0: temp=33636, pvtm=17329 (17293 + 36)
[    5.576974] rockchip_cpuclk_pre_rate_change: Invalid rate : 500000000 for cpuclk
[    5.584903] cpu cpu0: pvtm-volt-sel=3
[    5.588604] cpu cpu0: bin-scale=25
[    5.595580] cpu cpu0: avs=0
[    5.598783] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    5.608948] sdhci: Secure Digital Host Controller Interface driver
[    5.615259] sdhci: Copyright(c) Pierre Ossman
[    5.619634] Synopsys Designware Multimedia Card Interface Driver
[    5.626998] sdhci-pltfm: SDHCI platform and OF driver helper
[    5.627281] dwmmc_rockchip ff0c0000.mmc: No normal pinctrl state
[    5.633779] dwmmc_rockchip ff0d0000.mmc: No normal pinctrl state
[    5.638700] dwmmc_rockchip ff0c0000.mmc: No idle pinctrl state
[    5.644724] dwmmc_rockchip ff0d0000.mmc: No idle pinctrl state
[    5.644896] cryptodev: driver 1.12 loaded.
[    5.644947] hid: raw HID events driver (C) Jiri Kosina
[    5.645564] dwmmc_rockchip ff0f0000.mmc: No normal pinctrl state
[    5.645569] dwmmc_rockchip ff0f0000.mmc: No idle pinctrl state
[    5.645686] dwmmc_rockchip ff0f0000.mmc: IDMAC supports 32-bit address mode.
[    5.645754] usbcore: registered new interface driver usbhid
[    5.645758] usbhid: USB HID core driver
[    5.646052] ashmem: initialized
[    5.648155] optee: probing for conduit method.
[    5.648170] optee: revision 1.1
[    5.648567] optee: initialized driver
[    5.648748] rknandbase v1.2 2021-01-07
[    5.649421] usbcore: registered new interface driver snd-usb-audio
[    5.650696] dwmmc_rockchip ff0c0000.mmc: IDMAC supports 32-bit address mode.
[    5.656496] rt5640 2-001c: Device with ID register 0xc06dcccc is not rt5640/39
[    5.656563] dwmmc_rockchip ff0d0000.mmc: IDMAC supports 32-bit address mode.
[    5.660622] dwmmc_rockchip ff0f0000.mmc: Using internal DMA controller.
[    5.660650] dwmmc_rockchip ff0d0000.mmc: Using internal DMA controller.
[    5.660660] dwmmc_rockchip ff0d0000.mmc: Version ID is 270a
[    5.660714] dwmmc_rockchip ff0d0000.mmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
[    5.660950] dwmmc_rockchip ff0d0000.mmc: allocated mmc-pwrseq
[    5.660959] mmc_host mmc0: card is non-removable.
[    5.665780] dwmmc_rockchip ff0c0000.mmc: Using internal DMA controller.
[    5.671751] dwmmc_rockchip ff0f0000.mmc: Version ID is 270a
[    5.677584] dwmmc_rockchip ff0c0000.mmc: Version ID is 270a
[    5.684710] dwmmc_rockchip ff0f0000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
[    5.686422] u32 classifier
[    5.686425]     input device check on
[    5.686904] IPVS: Registered protocols ()
[    5.686944] IPVS: Connection hash table configured (size=4096, memory=16Kbytes)
[    5.687070] IPVS: ipvs loaded.
[    5.687370] Initializing XFRM netlink socket
[    5.687734] NET: Registered protocol family 10
[    5.688501] Segment Routing with IPv6
[    5.688686] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    5.689125] NET: Registered protocol family 17
[    5.689149] NET: Registered protocol family 15
[    5.689193] Bridge firewalling registered
[    5.689308] Bluetooth: RFCOMM socket layer initialized
[    5.689330] Bluetooth: RFCOMM ver 1.11
[    5.689342] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.689350] Bluetooth: HIDP socket layer initialized
[    5.689388] 8021q: 802.1Q VLAN Support v1.8
[    5.689405] lib80211: common routines for IEEE802.11 drivers
[    5.689424] [BT_RFKILL]: Enter rfkill_rk_init
[    5.689426] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    5.689627] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    5.689662] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6335
[    5.689666] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    5.689669] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    5.689738] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 150, flags = 0.
[    5.689745] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    5.689748] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    5.689753] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[    5.689756] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    5.690094] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139.
[    5.690115] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149.
[    5.690127] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146.
[    5.690138] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151.
[    5.690201] [BT_RFKILL]: Request irq for bt wakeup host
[    5.690240] dwmmc_rockchip ff0c0000.mmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[    5.694175] mmc_host mmc2: card is non-removable.
[    5.697285] [BT_RFKILL]: ** disable irq
[    5.697446] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    5.701668] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[    5.703297] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    5.704930] [BT_RFKILL]: bt_default device registered.
[    5.714343] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    5.718555] Key type dns_resolver registered
[    5.741016] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    5.746515] ov13850 3-0010: driver version: 00.01.05
[    5.784006] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    5.785274] ov13850 3-0010: supply avdd not found, using dummy regulator
[    5.788033] mmc_host mmc2: Bus speed (slot 0) = 49500000Hz (slot req 52000000Hz, actual 49500000HZ div = 0)
[    5.790215] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[    5.791240] dwmmc_rockchip ff0c0000.mmc: All phases bad!
[    5.792296] mmc2: new high speed MMC card at address 0001
[    5.792754] mmcblk2: mmc2:0001 DG4008 7.28 GiB
[    5.792983] mmcblk2boot0: mmc2:0001 DG4008 partition 1 4.00 MiB
[    5.793251] mmcblk2boot1: mmc2:0001 DG4008 partition 2 4.00 MiB
[    5.796431] mmcblk2rpmb: mmc2:0001 DG4008 partition 3 4.00 MiB, chardev (240:0)
[    5.796510] ov13850 3-0010: supply dovdd not found, using dummy regulator
[    5.796550] ov13850 3-0010: supply dvdd not found, using dummy regulator
[    5.796646] ov13850 3-0010: could not get sleep pinstate
[    5.805885] mmc1: tuning execution failed: -5
[    5.805895] mmc1: error -5 whilst initialising SD card
[    5.821193] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    5.838547]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8
[    5.842392] mmc_host mmc0: Bus speed (slot 0) = 187500Hz (slot req 100000Hz, actual 93750HZ div = 1)
[    5.900472] mmc_host mmc1: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0)
[    6.011124] rk3x-i2c ff150000.i2c: timeout, ipd: 0x00, state: 1
[    6.018255] mmc1: new high speed SDHC card at address b36a
[    6.022715] ov13850 3-0010: Unexpected sensor id(000000), ret(-5)
[    6.032469] mmcblk1: mmc1:b36a SDABC 29.1 GiB
[    6.037525] gc8034 3-0037: driver version: 00.01.09
[    6.060650]  mmcblk1: p1
[    6.064903] gc8034 3-0037: supply dovdd not found, using dummy regulator
[    6.231542] iep: iep dpi mode inactivity
[    6.231658] gc8034 3-0037: supply dvdd not found, using dummy regulator
[    6.242112] gc8034 3-0037: supply avdd not found, using dummy regulator
[    6.248754] gc8034 3-0037: lane_num(4)  pixel_rate(319887360)
[    6.254579] gc8034 3-0037: could not get sleep pinstate
[    6.481496] rk3x-i2c ff150000.i2c: timeout, ipd: 0x00, state: 1
[    6.487530] gc8034 3-0037: gc8034 read reg:0xf0 failed !
[    6.701498] rk3x-i2c ff150000.i2c: timeout, ipd: 0x00, state: 1
[    6.707521] gc8034 3-0037: gc8034 read reg:0xf1 failed !
[    6.713074] gc8034 3-0037: Unexpected sensor id(000000), ret(-110)
[    6.723617] ThumbEE CPU extension supported.
[    6.727900] Registering SWP/SWPB emulation handler
[    6.732965] Loading compiled-in X.509 certificates
[    6.738507] rga: rga2, irq = 59, match scheduler
[    6.743617] rga: rga2 hardware loaded successfully, hw_version:3.0.16445.
[    6.750413] rga: rga2 probe successfully
[    6.754579] rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[    6.761883] rga: Module initialized. v1.3.1
[    6.784579] vcc18_dvp: supplied by vcc_io
[    6.789130] rockchip-iodomain ff770000.syscon:io-domains: lcdc(3300000 uV) supplied by vcc_lcd
[    6.797892] rockchip-iodomain ff770000.syscon:io-domains: dvp(1800000 uV) supplied by vcc18_dvp
[    6.807172] rockchip-iodomain ff770000.syscon:io-domains: flash0(1800000 uV) supplied by vcc_18
[    6.815983] rockchip-iodomain ff770000.syscon:io-domains: flash1(3300000 uV) supplied by vcc_io
[    6.824780] rockchip-iodomain ff770000.syscon:io-domains: wifi(1800000 uV) supplied by vcc_wl
[    6.833802] rockchip-iodomain ff770000.syscon:io-domains: bb(3300000 uV) supplied by vcc_io
[    6.842210] rockchip-iodomain ff770000.syscon:io-domains: audio(3300000 uV) supplied by vcc_io
[    6.850899] rockchip-iodomain ff770000.syscon:io-domains: sdcard(3300000 uV) supplied by vccio_sd
[    6.859829] rockchip-iodomain ff770000.syscon:io-domains: gpio30(3300000 uV) supplied by vcc_io
[    6.869024] rockchip-dmc dmc: bin=0
[    6.872540] rockchip-dmc dmc: Failed to get ddr_leakage
[    6.878000] rockchip-dmc dmc: avs=0
[    6.884290] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[    6.890730] rockchip-dmc dmc: failed to get vop pn to msch rl
[    6.896655] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    6.906651] rockchip-dmc dmc: could not find power_model node
[    6.913647] rockchip-dp ff970000.dp: no DP phy configured
[    6.919613] rockchip-vop ff930000.vop: missing rockchip,grf property
[    6.926170] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0e70e08)
[    6.933522] rockchip-vop ff940000.vop: missing rockchip,grf property
[    6.940030] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0e70e08)
[    6.947713] rockchip-drm display-subsystem: bound ff970000.dp (ops 0xc0e73dc4)
[    6.955102] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.01a with HDCP (DWC HDMI 2.0 TX PHY)
[    6.965451] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[    6.973499] dwhdmi-rockchip ff980000.hdmi: IRQ index 1 not found
[    6.979960] input: hdmi_cec_key as /devices/platform/ff980000.hdmi/dw-hdmi-cec.3.auto/input/input1
[    6.989480] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0e74b94)
[    6.997152] [drm:rockchip_drm_show_logo] *ERROR* Reserved logo memory should be aligned as:0x1000, cureent is:start[0x7df00000] size[0x000b7388]
[    7.010196] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
[    7.065707] rockchip-dp ff970000.dp: failed to read downspread -110
[    7.072067] rockchip-drm display-subsystem: connector[eDP-1] loader protect failed
[    7.079646] rockchip-drm display-subsystem: can't not find any logo display
[    7.086661] rockchip-drm display-subsystem: failed to show kernel logo
[    7.116841] rockchip-dp ff970000.dp: failed to read max link rate
[    7.123053] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    7.133060] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[    7.142715] midgard ffa30000.gpu: bin=0
[    7.146573] midgard ffa30000.gpu: Failed to get gpu_leakage
[    7.152254] midgard ffa30000.gpu: bin-scale=55
[    7.157998] midgard ffa30000.gpu: avs=0
[    7.161935] W : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_config_rk.c; [Line] : 114; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[    7.177294] midgard ffa30000.gpu: GPU identified as 0x0750 r1p0 status 0
[    7.178223] rockchip-dp ff970000.dp: failed to read max link rate
[    7.184137] midgard ffa30000.gpu: Protected mode not available
[    7.190138] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    7.196207] midgard ffa30000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    7.212235] midgard ffa30000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[    7.223593] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 427; [Func] : midgard_kbase_devfreq_init(); success initing power_model_simple.
[    7.224241] devfreq ffa30000.gpu: Couldn't update frequency transition information.
[    7.246660] midgard ffa30000.gpu: Probed as mali0
[    7.251769] input: adc-keys as /devices/platform/adc-keys/input/input2
[    7.259802] input: gpio-keys as /devices/platform/gpio-keys/input/input3
[    7.267483] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.278101] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.285151] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    7.291892] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 410; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '22:08:38', on 'Aug 16 2024'.
[    7.293785] cfg80211: failed to load regulatory.db
[    7.314227] Mali:
[    7.318713] Mali device driver loaded
[    7.324430] rkisp1 ff910000.rkisp1: clear unready subdev num: 2
[    7.330608] rockchip-mipi-dphy-rx: No link between dphy and sensor
[    7.336824] rkisp1: update sensor failed
[    7.340752] ALSA device list:
[    7.343735]   No soundcards found.
[    7.364625] EXT4-fs (mmcblk2p7): recovery complete
[    7.369431] EXT4-fs (mmcblk2p7): mounted filesystem with ordered data mode. Opts: (null)
[    7.377565] ext4 filesystem being mounted at /root supports timestamps until 2038 (0x7fffffff)
[    7.386222] VFS: Mounted root (ext4 filesystem) on device 179:7.
[    7.398942] devtmpfs: mounted
[    7.406349] Freeing unused kernel memory: 1024K
[    7.411357] Run /sbin/init as init process
[    7.826495] systemd[1]: System time before build time, advancing clock.
[    7.855306] systemd[1]: Failed to insert module 'autofs4': No such file or directory
[    7.887357] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    7.909732] systemd[1]: Detected architecture arm.
Welcome to Ubuntu 18.04.4 LTS!
[    7.924631] systemd[1]: Set hostname to <firefly>.
[    8.153044] systemd[1]: File /lib/systemd/system/systemd-udevd.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    8.170330] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    8.375125] random: systemd: uninitialized urandom read (16 bytes read)
[    8.382897] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[    8.388431] random: systemd: uninitialized urandom read (16 bytes read)
[    8.399418] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    8.405360] random: systemd: uninitialized urandom read (16 bytes read)
[    8.417099] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    8.425292] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.433904] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Reached target User and Group Name Lookups.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Listening on Syslog Socket.
         Starting Journal Service...
[  OK  ] Listening on udev Kernel Socket.
         Starting udev Coldplug all Devices...
         Starting Load Kernel Modules...
         Mounting Kernel Debug File System...
[  OK  ] Reached target Swap.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[  OK  ] Reached target Remote File Systems.
         Starting Set the console keyboard layout...
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Load Kernel Modules.
         Starting Apply Kernel Variables...
         Mounting Kernel Configuration File System...
         Mounting FUSE Control File System...
         Starting Load/Save Random Seed...
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Journal Service.
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Set the console keyboard layout.
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
         Starting Set console font and keymap...
         Starting Tell Plymouth To Write Out Runtime Data...
[  OK  ] Started Tell Plymouth To Write Out Runtime Data.
[  OK  ] Started Set console font and keymap.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
         Starting Network Name Resolution...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Created slice system-systemd\x2dbacklight.slice.
         Starting Load/Save Screen Backlight…ightness of backlight:backlight...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Reached target Paths.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started Regular background program processing daemon.
         Starting rkisp 3A engine...
         Starting Dispatcher daemon for systemd-networkd...
         Starting LSB: automatic crash report generation...
         Starting Disk Manager...
         Starting Modem Manager...
[  OK  ] Started D-Bus System Message Bus.
         Starting Network Manager...
         Starting Accounts Service...
         Starting Adbd for linux...
         Starting System Logging Service...
         Starting Restore /etc/resolv.conf i…fore the ppp link was shut down...
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Started Set the CPU Frequency Scaling governor.
         Starting WPA supplicant...
         Starting Login Service...
[  OK  ] Started Discard unused blocks once a week.
[  OK  ] Reached target Timers.
[  OK  ] Started Network Name Resolution.
[  OK  ] Started Restore /etc/resolv.conf if…before the ppp link was shut down.
[  OK  ] Started rkisp 3A engine.
[  OK  ] Started System Logging Service.
[  OK  ] Found device /dev/ttyFIQ0.
[    9.941166] rk_gmac-dwmac ff290000.ethernet: Failed to reset the dma
[    9.947541] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[    9.947546] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_open: Hw setup failed
[  OK  ] Started LSB: automatic crash report generation.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Login Service.
[  OK  ] Started WPA supplicant.
         Starting Authorization Manager...
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Started Authorization Manager.
[  OK  ] Started Accounts Service.
         Starting Hostname Service...
[  OK  ] Started Modem Manager.
[  OK  ] Started Hostname Service.
         Starting Network Manager Script Dispatcher Service...
[  OK  ] Started Disk Manager.
[  OK  ] Started Dispatcher daemon for systemd-networkd.
[  OK  ] Started Network Manager Script Dispatcher Service.
[   10.772575] rk_gmac-dwmac ff290000.ethernet: Failed to reset the dma
[   10.779037] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[   10.788397] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_open: Hw setup failed
[  OK  ] Started Network Manager.
[  OK  ] Reached target Network.
         Starting Permit User Sessions...
         Starting /etc/rc.local Compatibility...
         Starting OpenBSD Secure Shell server...
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Started Permit User Sessions.
         Starting Hold until boot process finishes up...
         Starting Light Display Manager...
[  OK  ] Started Hold until boot process finishes up.
         Starting Set console scheme...
[  OK  ] Started Serial Getty on ttyFIQ0.
[  OK  ] Started Adbd for linux.
[  OK  ] Started Set console scheme.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
[   11.091165] rk_gmac-dwmac ff290000.ethernet: Failed to reset the dma
[   11.097531] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[   11.106632] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_open: Hw setup failed
[  OK  ] Started Light Display Manager.
[   11.361196] rk_gmac-dwmac ff290000.ethernet: Failed to reset the dma
[   11.367623] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[   11.376801] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_open: Hw setup failed
[  OK  ] Started OpenBSD Secure Shell server.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
Ubuntu 18.04.4 LTS firefly ttyFIQ0
firefly login: root (automatic login)
[   11.544078] rockchip-dp ff970000.dp: failed to read max link rate
Last login: Sun Jan 28 23:58:22 CST 2018 on ttyFIQ0
[   11.575528] rockchip-dp ff970000.dp: failed to read max link rate
[   11.631202] rk_gmac-dwmac ff290000.ethernet: Failed to reset the dma
[   11.637590] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[   11.646792] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_open: Hw setup failed
 _____ _           __ _
|  ___(_)_ __ ___ / _| |_   _
| |_  | | '__/ _ \ |_| | | | |
|  _| | | | |  __/  _| | |_| |
|_|   |_|_|  \___|_| |_|\__, |[   11.891148] rk_gmac-dwmac ff290000.ethernet: Failed to reset the dma
[   11.909118] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
                        |___/ [   11.918288] rk_gmac-dwmac ff290000.ethernet eth0: stmmac_open: Hw setup failed
Welcome to Ubuntu 18.04.4 LTS (GNU/Linux 5.10.198+ armv7l)
 * Documentation:  http://wiki.t-firefly.com
 * Management:     http://www.t-firefly.com
System information as of Sun Jan 28 23:58:20 CST 2018
System load:   0.71 0.15 0.05   Up time:       0 min
Memory usage:  3 % of 1995MB    IP:
Usage of /:    100% of 2.0G
root@firefly:~# [   13.629077] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   13.629086] rga_mm: failed to get buffer from handle
[   13.640891] rga_job: rga_job_commit: failed to map job info
[   13.646653] rga_job: request[1] task[0] job_commit failed.
[   13.652183] rga_job: rga request[1] commit failed!
[   13.656974] rga: request[1] submit failed!
[   15.041440] rockchip-dp ff970000.dp: failed to read max link rate
[   15.071904] rockchip-dp ff970000.dp: failed to read max link rate
[   16.051801] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   16.051809] rga_mm: failed to get buffer from handle
[   16.063597] rga_job: rga_job_commit: failed to map job info
[   16.069209] rga_job: request[2] task[0] job_commit failed.
[   16.074753] rga_job: rga request[2] commit failed!
[   16.079555] rga: request[2] submit failed!
[   19.703267] rockchip-dp ff970000.dp: failed to read max link rate
[   19.734087] rockchip-dp ff970000.dp: failed to read max link rate
re[   20.689352] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   20.689361] rga_mm: failed to get buffer from handle
[   20.701209] rga_job: rga_job_commit: failed to map job info
[   20.706822] rga_job: request[3] task[0] job_commit failed.
[   20.712345] rga_job: rga request[3] commit failed!
[   20.717143] rga: request[3] submit failed!
s[   21.976671] rockchip-dp ff970000.dp: failed to read max link rate
[   22.007265] rockchip-dp ff970000.dp: failed to read max link rate
[   22.903398] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   22.903406] rga_mm: failed to get buffer from handle
[   22.915204] rga_job: rga_job_commit: failed to map job info
[   22.920811] rga_job: request[4] task[0] job_commit failed.
[   22.926357] rga_job: rga request[4] commit failed!
[   22.931167] rga: request[4] submit failed!
[   24.488382] rockchip-dp ff970000.dp: failed to read max link rate
[   24.519293] rockchip-dp ff970000.dp: failed to read max link rate
[   25.471913] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   25.471921] rga_mm: failed to get buffer from handle
[   25.483702] rga_job: rga_job_commit: failed to map job info
[   25.489309] rga_job: request[5] task[0] job_commit failed.
[   25.494842] rga_job: rga request[5] commit failed!
[   25.499627] rga: request[5] submit failed!
[   26.658750] rockchip-dp ff970000.dp: failed to read max link rate
[   26.689257] rockchip-dp ff970000.dp: failed to read max link rate
[   27.651059] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   27.651068] rga_mm: failed to get buffer from handle
[   27.662911] rga_job: rga_job_commit: failed to map job info
[   27.668623] rga_job: request[6] task[0] job_commit failed.
[   27.674156] rga_job: rga request[6] commit failed!
[   27.678952] rga: request[6] submit failed!
[   29.201460] rockchip-dp ff970000.dp: failed to read max link rate
[   29.232301] rockchip-dp ff970000.dp: failed to read max link rate
[   30.219038] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   30.219046] rga_mm: failed to get buffer from handle
[   30.230867] rga_job: rga_job_commit: failed to map job info
[   30.236498] rga_job: request[7] task[0] job_commit failed.
[   30.242007] rga_job: rga request[7] commit failed!
[   30.246801] rga: request[7] submit failed!
[   31.457922] rockchip-dp ff970000.dp: failed to read max link rate
[   31.488820] rockchip-dp ff970000.dp: failed to read max link rate
[   32.441584] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   32.441592] rga_mm: failed to get buffer from handle
[   32.453383] rga_job: rga_job_commit: failed to map job info
[   32.458980] rga_job: request[8] task[0] job_commit failed.
[   32.464507] rga_job: rga request[8] commit failed!
[   32.469314] rga: request[8] submit failed!
[   33.993878] rockchip-dp ff970000.dp: failed to read max link rate
[   34.024454] rockchip-dp ff970000.dp: failed to read max link rate
[   34.978958] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   34.978967] rga_mm: failed to get buffer from handle
[   34.990883] rga_job: rga_job_commit: failed to map job info
[   34.996592] rga_job: request[9] task[0] job_commit failed.
[   35.002109] rga_job: rga request[9] commit failed!
[   35.006894] rga: request[9] submit failed!
[   36.083051] rockchip-dp ff970000.dp: failed to read max link rate
[   36.113456] rockchip-dp ff970000.dp: failed to read max link rate
[   37.072803] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   37.072811] rga_mm: failed to get buffer from handle
[   37.084598] rga_job: rga_job_commit: failed to map job info
[   37.090208] rga_job: request[10] task[0] job_commit failed.
[   37.095826] rga_job: rga request[10] commit failed!
[   37.100704] rga: request[10] submit failed!
[   38.710783] rockchip-dp ff970000.dp: failed to read max link rate
[   38.742108] rockchip-dp ff970000.dp: failed to read max link rate
[   39.729733] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   39.729742] rga_mm: failed to get buffer from handle
[   39.741610] rga_job: rga_job_commit: failed to map job info
[   39.747321] rga_job: request[11] task[0] job_commit failed.
[   39.752939] rga_job: rga request[11] commit failed!
[   39.757826] rga: request[11] submit failed!
[   40.985099] rockchip-dp ff970000.dp: failed to read max link rate
[   41.016456] rockchip-dp ff970000.dp: failed to read max link rate
[   41.971655] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   41.971662] rga_mm: failed to get buffer from handle
[   41.983477] rga_job: rga_job_commit: failed to map job info
[   41.989090] rga_job: request[12] task[0] job_commit failed.
[   41.994710] rga_job: rga request[12] commit failed!
[   41.999598] rga: request[12] submit failed!
[   43.438633] rockchip-dp ff970000.dp: failed to read max link rate
[   43.469493] rockchip-dp ff970000.dp: failed to read max link rate
[   44.428190] rga_mm: render_mode[0x2] dst channel handle[0] must is valid!
[   44.428198] rga_mm: failed to get buffer from handle
[   44.439988] rga_job: rga_job_commit: failed to map job info
[   44.445688] rga_job: request[13] task[0] job_commit failed.
[   44.451309] rga_job: rga request[13] commit failed!
大佬们帮忙看一下,不胜感激
看一下这个 确定一下dts是不是正确的,我刚编译的没有问题。
https://github.com/whsgzcy/rk3288_debug_kengs?tab=readme-ov-file
