SDK包名称:rk3308h-s-linux
SDK修改内容:buildroot中把busybox版本号改为1.36.1。
kernel中更改dts
Log日志:开机LOG.zip
自己设计的rk3308电路,系统启动到某个地方卡死了,急需大牛们给解决一下。以下是打印的信息。
DDR Version V2.06 20211109
CHIP ID = 0x00003308
REG2C: 0x00000032, 0x00000032
451MHz
DDR2
Col=10 Bank=2 Row=13 Size=64MB
OUT: sdram_init finish.
Boot1 Release Time: Mar 24 2022 08:28:57, version: 1.36
ROM VER:0x56323030, 19
chip_id:330800,0
ChipType = 0x13, 508
DPLL = 1300 MHz
…nandc_flash_init enter…
No.1 FLASH ID:ff ff ff ff ff ff
DPLL = 1300 MHz
sfc nor id: ff ff ff
DPLL = 1300 MHz
sfc_nand id: ff ff ff
NeedKHz=200KHz,clock=12000KHz
mmc2:cmd5,20
DPLL = 1300 MHz
NeedKHz=24000KHz,clock=650000KHz
DPLL = 1300 MHz
NeedKHz=40000KHz,clock=650000KHz
SdmmcInit=2 0
BootCapSize=0
UserCapSize=480MB
FwPartOffset=2000 , 0
SdmmcInit=0 NOT PRESENT
StorageInit ok = 14547
SecureMode = 0
Secure read PBA: 0x4
Secure read PBA: 0x404
Secure read PBA: 0x804
Secure read PBA: 0xc04
Secure read PBA: 0x1004
atags_set_bootdev: ret:(0)
GPT part: 0, name: uboot, start:0x2000, size:0x800
GPT part: 1, name: trust, start:0x2800, size:0x800
GPT part: 2, name: boot, start:0x3000, size:0x3000
GPT part: 3, name: rootfs, start:0x6000, size:0x2d000
GPT part: 4, name: userdata, start:0x33000, size:0xbcfdf
find part:uboot OK. first_lba:0x2000.
find part:trust OK. first_lba:0x2800.
LoadTrust Addr:0x2800
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x600000, size=0x733d8
RunBL31 0x10000 @ 85368 us
INFO: Preloader serial: 4
INFO: Next images boot on AArch32 mode
NOTICE: BL31: v1.3(release):e75c67d15
NOTICE: BL31: Built : 10:23:16, Dec 21 2021
INFO: Lastlog: last=0x2c000, realtime=0x2e000, size=0x2000
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe b
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: Entry point address = 0x600000
INFO: SPSR = 0x1d3
U-Boot 2017.09 (Apr 08 2024 - 16:41:38 +0800)
Model: Rockchip RK3308 EVB
CPU: AArch32
PreSerial: 4
DRAM: 63 MiB
Sysmem: init
Sysmem Error: Enter alloc: “U-Boot” 0x01451350 - 0x04000000
Sysmem Error: Enter alloc: “STACK” 0x01251350 - 0x01451350
Sysmem Error: Has allcated: U-Boot, 0x0354a360 - 0x04000000
Relocation Offset is: 00000000
dwmmc@ff490000: 0
Bootdev(atags): mmc 0
MMC0: Legacy, 50Mhz
PartType: EFI
jams boot mode: fastboot!!!
Found DTB in boot part
DTB: rk-kernel.dtb
Sysmem Error: Enter alloc: “FDT” 0x03200000 - 0x03216400
Sysmem Error: Has allcated: STACK, 0x01251350 - 0x01451350
vdd_core init 1015000 uV
DVFS: cpu: low=0.0’c, high=55.0’c, Vmax=1325000uV, tz_temp=55.0’c, h_repeat=0, l_repeat=0
DVFS: 6669.308’c
DVFS: cpu: target rate=408000000, readback rate=816000000 !
DVFS: cpu(high): 816000000->408000000 Hz, 1015000->950000 uV
Model: Rockchip RK3308bs evb amic v11 board (AArch32)
enter fastboot!
CLK: (uboot. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 816000 KHz
dpll 1300000 KHz
vpll0 1177823 KHz
vpll1 901583 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
aclk_peri 185714 KHz
hclk_peri 100000 KHz
pclk_peri 100000 KHz
hclk_audio 98151 KHz
pclk_audio 98151 KHz
Net: Net Initialization Skipped
No ethernet found.
Could not find misc partition
Sysmem Error: Enter alloc: “KERNEL” 0x02007800 - 0x022cac00
Sysmem Error: Has allcated: FDT, 0x03200000 - 0x03216404
Fdt Ramdisk skip relocation
Booting ZIMAGE kernel at 0x2008000(Uncompress to 0x00058000) with fdt at 0x3200000…
Sysmem Error: Enter alloc: “UNCOMPRESS-KERNEL” 0x00100000 - 0x00722800
## Booting Android Image at 0x02007800 …
Kernel load addr 0x02008000 size 2827 KiB
## Flattened Device Tree blob at 03200000
Booting using the fdt blob at 0x3200000
XIP Kernel Image … OK
Using Device Tree in place at 03200000, end 03216352
Adding bank: 0x00100000 - 0x04000000 (size: 0x03f00000)
Total: 411.111 ms
[ 0.000000] Linux version 4.4.143 (wjh@ubuntu) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #118 SMP PREEMPT Fri Aug 30 03:02:15 PDT 2024
[ 0.000000] CPU: ARMv7 Processor [410fd042] revision 2 (ARMv7), cr=50c5383d
[ 0.000000] Machine model: Rockchip RK3308bs evb amic v11 board (AArch32)
[ 0.000000] earlycon: Early serial console at MMIO32 0xff0e0000 (options ‘’)
[ 0.000000] Reserved memory: failed to reserve memory for node ‘drm-logo@00000000’: base 0x00000000, size 0 MiB
[ 0.000000] PERCPU: Embedded 12 pages/cpu @c3f13000 s16400 r8192 d24560 u49152
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16002
[ 0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 rw rootwait earlycon=uart8250,mmio32,0xff0e0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext2 snd_aloop.index=7 snd_aloop.use_raw_jiffies=1
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 59580K/64512K available (2501K kernel code, 222K rwdata, 1248K rodata, 184K init, 220K bss, 4932K reserved, 0K cma-reserved)
[ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
[ 0.000000] modules : 0xbf800000 - 0xc0000000 ( 8 MB)
[ 0.000000] .text : 0xc0058000 - 0xc02c9974 (2503 kB)
[ 0.000000] .init : 0xc0426000 - 0xc0454000 ( 184 kB)
[ 0.000000] .data : 0xc0454000 - 0xc048ba90 ( 223 kB)
[ 0.000000] .bss : 0xc048d000 - 0xc04c4190 ( 221 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (virt).
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000746] Switching to timer-based delay loop, resolution 41ns
[ 0.002362] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003319] pid_max: default: 4096 minimum: 301
[ 0.003872] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.004493] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.005660] CPU: Testing write buffer coherency: ok
[ 0.006348] Setting up static identity map for 0x58240 - 0x5828c
[ 0.022437] Brought up 4 CPUs
[ 0.022723] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.023314] CPU: All CPU(s) started in SVC mode.
[ 0.024158] devtmpfs: initialized
[ 0.047127] VFP support v0.3: implementor 41 architecture 3 part 40 variant 4 rev 2
[ 0.048269] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.049189] futex hash table entries: 16 (order: -2, 1024 bytes)
[ 0.050068] pinctrl core: initialized pinctrl subsystem
[ 0.051890] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.055628] cpuidle: using governor menu
[ 0.056011] Registered FIQ tty driver
[ 0.059477] console [pstore-1] enabled
[ 0.059840] pstore: Registered ramoops as persistent store backend
[ 0.060411] ramoops: attached 0x20000@0x30000, ecc: 0/0
[ 0.081395] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.082138] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.083372] fiq debugger fiq mode enabled
[[ 0.084099] console [ttyFIQ0] enabled
[ 0.084762] bootconsole [uart0] disabled
[ 0.085387] Registered fiq debugger ttyFIQ0
WARNING: suspend_mode_handler: Not support call: 0x4
[ 0.116503] vcc_1v8: regulator get failed, ret=-517
[ 0.116894] vcc_1v8_codec: regulator get failed, ret=-517
[ 0.117672] vcc_1v8: supplied by vcc_io
[ 0.117751] vcc_1v8_codec: supplied by vcc_io
[ 0.117914] vccio_flash: supplied by vcc_io
[ 0.119900] SCSI subsystem initialized
[ 0.120067] usbcore: registered new interface driver usbfs
[ 0.120140] usbcore: registered new interface driver hub
[ 0.120245] usbcore: registered new device driver usb
[ 0.121327] pps_core: LinuxPPS API ver. 1 registered
[ 0.121344] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.122461] Advanced Linux Sound Architecture Driver Initialized.
[ 0.122769] rockchip-cpuinfo cpuinfo: Serial : 7f19991b2fc3e895
[ 0.123527] clocksource: Switched to clocksource arch_sys_counter
[ 0.126002] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.131263] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.131361] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.134965] io scheduler noop registered (default)
[ 0.136415] phy phy-ff008000.syscon:usb2-phy@100.0: Failed to get VBUS supply regulator
[ 0.140566] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.140600] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.143254] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.143281] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.143613] rockchip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 0.143740] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 0.145280] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.147437] ff0a0000.serial: ttyS0 at MMIO 0xff0a0000 (irq = 28, base_baud = 5078125) is a 16550A
[ 0.149239] [drm] Initialized drm 1.1.0 20060810
[ 0.149437] random: nonblocking pool is initialized
[ 0.153587] zram: Added device: zram0
[ 0.153818] SCSI Media Changer driver v0.25
[ 0.154870] ff400000.usb supply vusb_d not found, using dummy regulator
[ 0.154944] ff400000.usb supply vusb_a not found, using dummy regulator
[ 0.157156] dwc2 ff400000.usb: Configuration mismatch. dr_mode forced to device
[ 0.157192] dwc2 ff400000.usb: 128 invalid for host_nperio_tx_fifo_size. Check HW configuration.
[ 0.157208] dwc2 ff400000.usb: 256 invalid for host_perio_tx_fifo_size. Check HW configuration.
[ 0.157252] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 0.380985] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_SDP_CHARGER
[ 0.381244] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.381265] ehci-platform: EHCI generic platform driver
[ 0.385017] ehci-platform ff440000.usb: EHCI Host Controller
[ 0.385059] ehci-platform ff440000.usb: new USB bus registered, assigned bus number 1
[ 0.385188] ehci-platform ff440000.usb: irq 40, io mem 0xff440000
[ 0.390556] ehci-platform ff440000.usb: USB 2.0 started, EHCI 1.00
[ 0.391439] hub 1-0:1.0: USB hub found
[ 0.391482] hub 1-0:1.0: 1 port detected
[ 0.392146] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.392185] ohci-platform: OHCI generic platform driver
[ 0.392556] ohci-platform ff450000.usb: Generic Platform OHCI controller
[ 0.392597] ohci-platform ff450000.usb: new USB bus registered, assigned bus number 2
[ 0.392723] ohci-platform ff450000.usb: irq 41, io mem 0xff450000
[ 0.448392] hub 2-0:1.0: USB hub found
[ 0.448441] hub 2-0:1.0: 1 port detected
[ 0.449584] usbcore: registered new interface driver usb-storage
[ 0.449613] usb20_otg: version 3.10a 21-DEC-2012
[ 0.449949] usb20_host: version 3.10a 21-DEC-2012
[ 0.450864] i2c /dev entries driver
[ 0.451744] rk3x-i2c ff050000.i2c: Initialized RK3xxx I2C bus at c48d6000
[ 0.515052] rtc-hym8563 3-0051: could not init device, -6
[ 0.515118] rk3x-i2c ff070000.i2c: Initialized RK3xxx I2C bus at c48d8000
[ 0.516365] rockchip-iodomain ff000000.grf:io-domains: vccio0 supplied by 3300000 uV
[ 0.516499] rockchip-iodomain ff000000.grf:io-domains: vccio1 supplied by 3300000 uV
[ 0.516621] rockchip-iodomain ff000000.grf:io-domains: vccio2 supplied by 3300000 uV
[ 0.516714] rockchip-iodomain ff000000.grf:io-domains: vccio3 supplied by 3300000 uV
[ 0.516798] rockchip-iodomain ff000000.grf:io-domains: vccio4 supplied by 3300000 uV
[ 0.516877] rockchip-iodomain ff000000.grf:io-domains: vccio5 supplied by 3300000 uV
[ 0.518474] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 0.518713] rockchip-thermal ff1f0000.tsadc: tsadc is probed successfully!
[ 0.519575] cpu cpu0: leakage=13
[ 0.519773] cpu cpu0: Failed to get pvtm
[ 0.520872] cpu cpu0: l=0 h=55000 hyst=5000 l_limit=1200000000 h_limit=1008000000
[ 0.521854] cpuidle: enable-method property ‘psci’ found operations
[ 0.521979] cpuidle: enable-method property ‘psci’ found operations
[ 0.522085] cpuidle: enable-method property ‘psci’ found operations
[ 0.522197] cpuidle: enable-method property ‘psci’ found operations
[ 0.522359] Synopsys Designware Multimedia Card Interface Driver
[ 0.523453] dwmmc_rockchip ff480000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 0.523629] dwmmc_rockchip ff480000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.523676] dwmmc_rockchip ff480000.dwmmc: Using internal DMA controller.
[ 0.523700] dwmmc_rockchip ff480000.dwmmc: Version ID is 270a
[ 0.523770] dwmmc_rockchip ff480000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
[ 0.523842] dwmmc_rockchip ff480000.dwmmc: No vmmc regulator found
[ 0.523857] dwmmc_rockchip ff480000.dwmmc: No vqmmc regulator found
[ 0.524190] dwmmc_rockchip ff480000.dwmmc: allocated mmc-pwrseq
[ 0.534620] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.545706] dwmmc_rockchip ff480000.dwmmc: 1 slots initialized
[ 0.546363] dwmmc_rockchip ff490000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.546407] dwmmc_rockchip ff490000.dwmmc: Using internal DMA controller.
[ 0.546431] dwmmc_rockchip ff490000.dwmmc: Version ID is 270a
[ 0.546492] dwmmc_rockchip ff490000.dwmmc: DW MMC controller at irq 43,32 bit host data width,256 deep fifo
[ 0.546571] dwmmc_rockchip ff490000.dwmmc: No vmmc regulator found
[ 0.546587] dwmmc_rockchip ff490000.dwmmc: No vqmmc regulator found
[ 0.557616] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.568660] dwmmc_rockchip ff490000.dwmmc: 1 slots initialized
[ 0.569268] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.569674] usbcore: registered new interface driver usbhid
[ 0.569689] usbhid: USB HID core driver
[ 0.569817] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[ 0.570081] rockchip-dmc dmc: Failed to get leakage
[ 0.570166] rockchip-dmc dmc: Failed to get pvtm
[ 0.570417] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 0.570436] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 0.570451] rockchip-dmc dmc: don’t add devfreq feature
[ 0.570470] rockchip-dmc dmc: Cannot set voltage 975000 uV
[ 0.570647] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 0.570781] rockchip-dmc: probe of dmc failed with error -22
[ 0.572850] rknandc_base v1.1 2017-01-11
[ 0.573177] rknandc ff4b0000.nandc: rknandc_probe clk rate = 147456000
[ 0.573234] rkflash_dev_init enter
[ 0.573248] …nandc_flash_init enter…
[ 0.573270] rkflash[0] is invalid
[ 0.573405] rksfc_base v1.1 2016-01-08
[ 0.573721] rksfc ff4c0000.sfc: rksfc_probe clk rate = 100000000
[ 0.573769] rkflash_dev_init enter
[ 0.573789] sfc nor id: ff ff ff
[ 0.573799] rkflash[1] is invalid
[ 0.573807] rkflash_dev_init enter
[ 0.573826] sfc_nand id: ff ff ff
[ 0.573836] rkflash[2] is invalid
[ 0.574216] rockchip-pinctrl pinctrl: pin gpio0-10 already requested by ff1f0000.tsadc; cannot claim for rp_power
[ 0.574240] rockchip-pinctrl pinctrl: pin-10 (rp_power) status -22
[ 0.574259] rockchip-pinctrl pinctrl: could not request pin 10 (gpio0-10) from group rp-power-pins on device rockchip-pinctrl
[ 0.574274] rp_power rp_power: Error applying setting, reverse things back
[ 0.574321] rp_gpio prepare build 1 gpio
[ 0.574377] rp_gpio request vcc_5v
[ 0.574420] success request gpio138 out
[ 0.574741] input: gpio_event as /devices/platform/rp_power/input/input0
[ 0.575716] rp_gpio prepare build 3 gpio
[ 0.575784] rp_gpio request gpio0b0
[ 0.575817] success request gpio8 out
[ 0.575858] rp_gpio request gpio0b1
[ 0.575881] success request gpio9 out
[ 0.575921] rp_gpio request gpio0b6
[ 0.575946] success request gpio14 out
[ 0.579977] dummy_codec dummy-codec: Unable to get mclk
[ 0.580499] rk3308-acodec ff560000.acodec: Don’t need hp-ctl gpio
[ 0.580626] rk3308-acodec ff560000.acodec: Don’t need hp-det gpio
[ 0.580725] rk3308-acodec ff560000.acodec: Don’t need spk-ctl gpio
[ 0.580822] rk3308-acodec ff560000.acodec: Don’t need pa-drv gpio
[ 0.580838] rk3308-acodec ff560000.acodec: De-pop as much as possible
[ 0.580950] The acodec version is: b
[ 0.581086] gpiod_direction_input: invalid GPIO
[ 0.581107] rk3308-acodec ff560000.acodec: Failed to request IRQ: -22
[ 0.581275] rk3308-acodec: probe of ff560000.acodec failed with error -22
[ 0.587858] rk-multicodecs vad-sound_8: vad ↔ i2s-8ch-0-dais mapping ok
[ 0.588663] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 0.589063] flash vendor_init_thread!
[ 0.589166] flash vendor storage:20170308 ret = -1
[ 0.589507] Registering SWP/SWPB emulation handler
[ 0.591039] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 0.593151] asoc-simple-card i2s_2ch: dummy_codec ↔ ff350000.i2s mapping ok
[ 0.594426] hctosys: unable to open rtc device (rtc0)
[ 0.604387] ALSA device list:
[ 0.604413] #0: rockchip,rk3308-vad
[ 0.604421] #1: i2s_2ch
[ 0.604428] #7: Loopback 1
[ 0.604661] Waiting for root device PARTUUID=614e0000-0000…
[ 0.609611] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 0.619630] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 0.650643] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 0.650866] mmc_host mmc0: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 3.594694] vendor storage:20160801 ret = -1
开机LOG.zip (7.36 KB)
