SDK包名称:rv1126_rv1109_linux_ai_camera_release_20210306
SDK修改内容:无修改
Log日志:err_log.txt
sdk版本:rv1126_rv1109_linux_ai_camera_release_20210306/.repo/manifests/rv1126_rv1109/rv1126_rv1109_linux_release_20240117_v2.2.5f.xml
source envsetup.sh 选择 9. firefly_rv1126_rv1109_rkmedia_uvcc (选择firefly_rv1126_rv110_uvcc 也是同样错误)
./build.sh external/rkmedia
然后报错
processing option: external/rkmedia
Found BR2_PACKAGE_RKMEDIA in buildroot/output/firefly_rv1126_rv1109_uvcc/.config
make: Entering directory ‘/home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc’
umask 0022 && make -C /home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot O=/home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/. rkmedia-dirclean
grep: /home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/../kernel/.config: No such file or directory
rm -Rf /home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/build/rkmedia
make: Leaving directory ‘/home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc’
umask 0022 && make -C /home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot O=/home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/. rkmedia-rebuild
rm -f /home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/build/rkmedia/.stamp_rsynced
rm -f /home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/build/rkmedia/.stamp_staging_installed
rm -f /home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/build/rkmedia/.stamp_target_installed
rm -f /home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/build/rkmedia/.stamp_images_installed
rm -f /home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/build/rkmedia/.stamp_host_installed
touch /home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/build/rkmedia/.stamp_built || true
touch: cannot touch ‘/home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/build/rkmedia/.stamp_built’: No such file or directory
rm -f /home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/build/rkmedia/.stamp_built
toolchain-external-custom Configuring
Cannot execute cross-compiler ‘/home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/../prebuilts/gcc/linux-x86/arm/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc’
package/pkg-generic.mk:218: recipe for target ‘/home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/build/toolchain-external-custom/.stamp_configured’ failed
make[1]: *** [/home/lcx/rv1126_rv1109_linux_ai_camera_release_20210306/buildroot/output/firefly_rv1126_rv1109_uvcc/build/toolchain-external-custom/.stamp_configured] Error 1
Makefile:16: recipe for target ‘_all’ failed
make: *** [_all] Error 2
ERROR: Running build_pkg failed!
ERROR: exit code 2 from line 451:
make -C buildroot/output/$pkg_cfg ${pkg_final_target}-rebuild O=buildroot/output/$pkg_cfg
err_log.txt (3.41 KB)
