求大佬指点,RK3399刷官方ubuntu24.04不开机,串口输出卡在fan53555
DDR Version 1.26 20210628
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 MHz, current 856MHz
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 354
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68604
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x40000
GPT part: 4, name: recovery, start:0x4a000, size:0x20000
GPT part: 5, name: backup, start:0x6a000, size:0x10000
GPT part: 6, name: rootfs, start:0x7a000, size:0x4ab000
GPT part: 7, name: userdata, start:0x525000, size:0x17f9fc0
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
Trust Addr:0x6000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xe8748
RunBL31 0x40000 @ 110758 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-278-gef70f120a #zhangzj #9 Fri Sep 17 09:39:24 UTC 2021 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09(u-boot commit id: e24f0b9f2b)(sdk version: rk3399_linux_release_20230328_v2.5.1d)-ge24f0b9f2b #weicz (Mar 30 2023 - 16:11:18 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 3.8 GiB
Sysmem: init
Relocation Offset: f5bdb000, fdt: f3dcf4d8
Bootdev(atags): mmc 0
MMC0: HS400, 50Mhz
PartType: EFI
=================begin===================
104667 bytes read in 69 ms (1.4 MiB/s)
DTB(Distro): rk-kernel.dtb
boot mode: recovery (misc)
Android header version 0
I2c0 speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 1100000 uV
In: serial
Out: serial
Err: serial
Model: Firefly-RK3399 Board (Linux Opensource)
Found DTB in recovery part
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 856000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
No FDT memory address configured. Default at 0x08300000
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 23473 KiB
RAM disk load addr 0x0a200000 size 7436 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 … OK
Using Device Tree in place at 0000000008300000, end 000000000831c8da
Adding bank: 0x0a200000 - 0xf8000000 (size: 0xede00000)
Total: 2986.969 ms
[ 0.000000] Linux version 4.4.194 (weicz@tchip14) (rk3399/firefly: 2c932b990420f943afa543138f1ab2a99a33cc0c) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #267 SMP Thu Mar 30 11:31:00 CST 2023
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ecb000 s46440 r8192 d31384 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=sdhci@fe330000 recovery androidboot.slot_suffix= androidboot.serialno=e3dff3216d039f2c ro rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0xf7e83000-0xf7ec3000] (0MB)
[ 0.000000] Memory: 3924164K/4030464K available (14782K kernel code, 1840K rwdata, 5588K rodata, 1216K init, 774K bss, 106300K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009470000 - 0xffffff80095a0000 ( 1216 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008ef0000 ( 14784 KB)
[ 0.000000] .rodata : 0xffffff8008ef0000 - 0xffffff8009470000 ( 5632 KB)
[ 0.000000] .data : 0xffffff80095a0000 - 0xffffff800976c008 ( 1841 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] ITS: allocated 65536 Devices @f2d00000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000f2c90000
[ 0.000000] CPU0: using LPI pending table @0x00000000f2ca0000
[ 0.002243] Console: colour dummy device 80x25
[ 0.002686] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003675] pid_max: default: 32768 minimum: 301
[ 0.004203] Security Framework initialized
[ 0.004668] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.005308] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006756] Initializing cgroup subsys io
[ 0.007165] Initializing cgroup subsys memory
[ 0.007607] Initializing cgroup subsys devices
[ 0.008038] Initializing cgroup subsys freezer
[ 0.008480] Initializing cgroup subsys perf_event
[ 0.008936] Initializing cgroup subsys net_prio
[ 0.009374] Initializing cgroup subsys hugetlb
[ 0.009815] Initializing cgroup subsys pids
[ 0.010234] ftrace: allocating 53054 entries in 208 pages
[ 0.137391] sched-energy: Sched-energy-costs installed from DT
[ 0.137958] CPU0: update cpu_capacity 401
[ 0.138403] ASID allocator initialised with 32768 entries
[ 0.142235] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.143609] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.145910] Detected VIPT I-cache on CPU1
[ 0.145946] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.145977] CPU1: using LPI pending table @0x00000000f2f60000
[ 0.146031] CPU1: update cpu_capacity 401
[ 0.146034] CPU1: Booted secondary processor [410fd034]
[ 0.146825] Detected VIPT I-cache on CPU2
[ 0.146857] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.146888] CPU2: using LPI pending table @0x00000000f2f80000
[ 0.146938] CPU2: update cpu_capacity 401
[ 0.146942] CPU2: Booted secondary processor [410fd034]
[ 0.147739] Detected VIPT I-cache on CPU3
[ 0.147771] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.147801] CPU3: using LPI pending table @0x00000000f2fe0000
[ 0.147849] CPU3: update cpu_capacity 401
[ 0.147853] CPU3: Booted secondary processor [410fd034]
[ 0.148651] Detected PIPT I-cache on CPU4
[ 0.148676] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.148711] CPU4: using LPI pending table @0x00000000f2410000
[ 0.148746] CPU4: update cpu_capacity 1024
[ 0.148749] CPU4: Booted secondary processor [410fd082]
[ 0.149414] Detected PIPT I-cache on CPU5
[ 0.149439] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.149475] CPU5: using LPI pending table @0x00000000f2440000
[ 0.149509] CPU5: update cpu_capacity 1024
[ 0.149512] CPU5: Booted secondary processor [410fd082]
[ 0.149624] Brought up 6 CPUs
[ 0.161979] SMP: Total of 6 processors activated.
[ 0.162431] CPU features: detected feature: GIC system register CPU interface
[ 0.163120] CPU features: detected feature: 32-bit EL0 Support
[ 0.163679] CPU: All CPU(s) started at EL2
[ 0.164110] alternatives: patching kernel code
[ 0.165917] devtmpfs: initialized
[ 0.192232] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.193190] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.194158] xor: measuring software checksum speed
[ 0.204120] 8regs : 2860.000 MB/sec
[ 0.214176] 8regs_prefetch: 2564.000 MB/sec
[ 0.224230] 32regs : 3208.000 MB/sec
[ 0.234286] 32regs_prefetch: 2848.000 MB/sec
[ 0.234729] xor: using function: 32regs (3208.000 MB/sec)
[ 0.235264] pinctrl core: initialized pinctrl subsystem
[ 0.237477] Failed to find legacy iommu devices
[ 0.238289] NET: Registered protocol family 16
[ 0.242990] cpuidle: using governor ladder
[ 0.246999] cpuidle: using governor menu
[ 0.247394] Registered FIQ tty driver
[ 0.248329] vdso: 2 pages (1 code @ ffffff8008ef6000, 1 data @ ffffff80095a4000)
[ 0.249067] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.250133] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.273931] console [pstore-1] enabled
[ 0.274304] pstore: Registered ramoops as persistent store backend
[ 0.274897] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.278012] console [ttyFIQ0] enabled
[ 0.278705] bootconsole [uart0] disabled
[ 0.279640] Registered fiq debugger ttyFIQ0
[ 0.329854] raid6: int64x1 gen() 468 MB/s
[ 0.346923] raid6: int64x1 xor() 427 MB/s
[ 0.364086] raid6: int64x2 gen() 675 MB/s
[ 0.381127] raid6: int64x2 xor() 599 MB/s
[ 0.398241] raid6: int64x4 gen() 984 MB/s
[ 0.415294] raid6: int64x4 xor() 675 MB/s
[ 0.432420] raid6: int64x8 gen() 781 MB/s
[ 0.449495] raid6: int64x8 xor() 634 MB/s
[ 0.466573] raid6: neonx1 gen() 964 MB/s
[ 0.483696] raid6: neonx1 xor() 681 MB/s
[ 0.500798] raid6: neonx2 gen() 1277 MB/s
[ 0.517873] raid6: neonx2 xor() 964 MB/s
[ 0.534947] raid6: neonx4 gen() 1734 MB/s
[ 0.552055] raid6: neonx4 xor() 1177 MB/s
[ 0.569152] raid6: neonx8 gen() 1691 MB/s
[ 0.586237] raid6: neonx8 xor() 1248 MB/s
[ 0.586627] raid6: using algorithm neonx4 gen() 1734 MB/s
[ 0.587103] raid6: … xor() 1177 MB/s, rmw enabled
[ 0.587544] raid6: using intx1 recovery algorithm
[ 0.592852] iommu: Adding device ff650000.vpu_service to group 0
[ 0.593475] iommu: Adding device ff660000.rkvdec to group 1
[ 0.594078] iommu: Adding device ff8f0000.vop to group 2
[ 0.594651] iommu: Adding device ff900000.vop to group 3
[ 0.595212] iommu: Adding device ff910000.rkisp1 to group 4
[ 0.595805] iommu: Adding device ff920000.rkisp1 to group 5
[ 0.596781] rk_iommu ff650800.iommu: can’t get sclk
[ 0.597456] rk_iommu ff660480.iommu: can’t get sclk
[ 0.598097] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.598685] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.599286] rk_iommu ff914000.iommu: can’t get sclk
[ 0.599868] rk_iommu ff924000.iommu: can’t get sclk
[ 0.600677] SCSI subsystem initialized
[ 0.601363] usbcore: registered new interface driver usbfs
[ 0.601888] usbcore: registered new interface driver hub
[ 0.602456] usbcore: registered new device driver usb
[ 0.602976] media: Linux media interface: v0.10
[ 0.603425] Linux video capture interface: v2.00
[ 0.603906] pps_core: LinuxPPS API ver. 1 registered
[ 0.604349] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.605176] PTP clock support registered
[ 0.606690] Advanced Linux Sound Architecture Driver Initialized.
[ 0.607806] Bluetooth: Core ver 2.21
[ 0.608156] NET: Registered protocol family 31
[ 0.608563] Bluetooth: HCI device and connection manager initialized
[ 0.609136] Bluetooth: HCI socket layer initialized
[ 0.609581] Bluetooth: L2CAP socket layer initialized
[ 0.610053] Bluetooth: SCO socket layer initialized
[ 0.610847] NetLabel: Initializing
[ 0.611153] NetLabel: domain hash size = 128
[ 0.611537] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.612026] NetLabel: unlabeled traffic allowed by default
[ 0.612687] nfc: nfc_init: NFC Core ver 0.1
[ 0.613106] NET: Registered protocol family 39
[ 0.613611] rockchip-cpuinfo cpuinfo: Serial : e3dff3216d039f2c
[ 0.615015] clocksource: Switched to clocksource arch_sys_counter
[ 0.668361] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.669289] NET: Registered protocol family 2
[ 0.670126] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.671033] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.672547] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.673253] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.673954] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.674950] NET: Registered protocol family 1
[ 0.675631] RPC: Registered named UNIX socket transport module.
[ 0.676172] RPC: Registered udp transport module.
[ 0.676591] RPC: Registered tcp transport module.
[ 0.677019] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.678272] Trying to unpack rootfs image as initramfs…
[ 1.057815] Freeing initrd memory: 7432K
[ 1.058987] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.059812] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.061902] kvm [1]: 8-bit VMID
[ 1.062194] kvm [1]: Hyp mode initialized successfully
[ 1.062769] kvm [1]: interrupt-controller@fff20000 IRQ10
[ 1.063445] kvm [1]: timer IRQ12
[ 1.066587] audit: initializing netlink subsys (disabled)
[ 1.067109] audit: type=2000 audit(0.974:1): initialized
[ 1.067972] Initialise system trusted keyring
[ 1.068730] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.077267] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.078750] NFS: Registering the id_resolver key type
[ 1.079240] Key type id_resolver registered
[ 1.079615] Key type id_legacy registered
[ 1.079993] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.081323] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.082105] fuse init (API version 7.23)
[ 1.082794] SGI XFS with security attributes, no debug enabled
[ 1.088689] NET: Registered protocol family 38
[ 1.089123] Key type asymmetric registered
[ 1.089492] Asymmetric key parser ‘x509’ registered
[ 1.090100] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.090889] io scheduler noop registered
[ 1.091261] io scheduler deadline registered
[ 1.091681] io scheduler cfq registered (default)
[ 1.093774] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[ 1.098999] ace test_init function.
[ 1.099505] ace test_init end.ret=0
[ 1.100195] radar end.ret=0
[ 1.103334] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 1.103932] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.104540] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.105120] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 1.105729] PCI host bridge /pcie@f8000000 ranges:
[ 1.106181] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 1.106640] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 2.115038] pll lock timeout!
[ 2.115327] phy phy-pcie-phy.5: phy poweron failed → -22
[ 2.115820] rockchip-pcie f8000000.pcie: fail to power on phy, err -22
[ 2.116418] rockchip-pcie f8000000.pcie: deferred probe failed
[ 2.117171] rockchip-pcie: probe of f8000000.pcie failed with error -22
[ 2.118671] Module initialized.
[ 2.119441] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 2.120293] rk-vcodec ff650000.vpu_service: probe device
[ 2.120991] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 2.122165] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 2.122782] rk-vcodec ff650000.vpu_service: init success
[ 2.123503] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 2.124433] rk-vcodec ff660000.rkvdec: probe device
[ 2.125067] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 2.125991] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 2.126591] rk-vcodec ff660000.rkvdec: init success
[ 2.128480] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.129168] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 2.131402] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.132090] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 2.133917] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 2.135156] pwm-regulator: supplied by vcc5v0_sys
[ 2.136272] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 2.137439] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 2.138735] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 38, base_baud = 1500000) is a 16550A
[ 2.141278] [drm] Initialized drm 1.1.0 20060810
[ 2.145688] [drm] Rockchip DRM driver version: v1.0.1
[ 2.148382] mali ff9a0000.gpu: Failed to get regulator
[ 2.148838] mali ff9a0000.gpu: Power control initialization failed
[ 2.149772] Unable to detect cache hierarchy for CPU 0
[ 2.151079] brd: module loaded
[ 2.156692] loop: module loaded
[ 2.157529] zram: Added device: zram0
[ 2.158153] lkdtm: No crash points registered, enable through debugfs
[ 2.159101] Loading dl1825 driver
[ 2.161042] register firefly_spi_init spi return v = :0
[ 2.161530] register spi return v = :0
[ 2.162372] tun: Universal TUN/TAP device driver, 1.6
[ 2.162827] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.164375] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 2.165104] rk_gmac-dwmac fe300000.ethernet: Can not read property: clk_alway_enable.
[ 2.165803] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 2.166442] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 2.166946] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 2.167470] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 2.168183] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 2.168798] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 2.174359] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 2.174973] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 2.175437] Ring mode enabled
[ 2.175719] DMA HW capability register supported
[ 2.176132] Normal descriptors
[ 2.176439] RX Checksum Offload Engine supported (type 2)
[ 2.176926] Wake-Up On Lan supported
[ 2.177296] Enable RX Mitigation via HW Watchdog Timer
[ 2.245654] libphy: stmmac: probed
[ 2.245969] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 2.246554] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 2.248449] usbcore: registered new interface driver rtl8192cu
[ 2.249033] usbcore: registered new interface driver rndis_wlan
[ 2.249720] usbcore: registered new interface driver mt7601u
[ 2.250317] Rockchip WiFi SYS interface (V1.00) …
[ 2.250819] usbcore: registered new interface driver rtl8150
[ 2.251371] usbcore: registered new interface driver r8152
[ 2.251901] usbcore: registered new interface driver asix
[ 2.252422] usbcore: registered new interface driver ax88179_178a
[ 2.252998] usbcore: registered new interface driver cdc_ether
[ 2.253566] usbcore: registered new interface driver rndis_host
[ 2.254155] usbcore: registered new interface driver cdc_ncm
[ 2.254690] usbcore: registered new interface driver qmi_wwan
[ 2.255245] usbcore: registered new interface driver cdc_mbim
[ 2.257154] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 2.360766] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 2.461394] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 2.562003] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 2.662620] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 2.763253] rockchip-typec-phy ff800000.phy: wait pma ready timeout
[ 2.763817] phy phy-ff800000.phy.4: phy poweron failed → -110
[ 2.764413] dwc3 fe900000.dwc3: failed to initialize core
[ 2.764968] dwc3: probe of fe900000.dwc3 failed with error -110
[ 2.765586] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 2.767191] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.767782] ehci-pci: EHCI PCI platform driver
[ 2.768253] ehci-platform: EHCI generic platform driver
[ 2.772592] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.773261] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 2.774065] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 2.780036] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.780743] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.781364] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.782003] usb usb1: Product: EHCI Host Controller
[ 2.782446] usb usb1: Manufacturer: Linux 4.4.194 ehci_hcd
[ 2.782935] usb usb1: SerialNumber: fe3c0000.usb
[ 2.783788] hub 1-0:1.0: USB hub found
[ 2.784198] hub 1-0:1.0: 1 port detected
[ 2.785115] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.785675] ohci-platform: OHCI generic platform driver
[ 2.786614] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.787398] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 2.788188] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 2.843218] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.843825] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.844477] usb usb2: Product: Generic Platform OHCI controller
[ 2.845001] usb usb2: Manufacturer: Linux 4.4.194 ohci_hcd
[ 2.845500] usb usb2: SerialNumber: fe3e0000.usb
[ 2.846360] hub 2-0:1.0: USB hub found
[ 2.846725] hub 2-0:1.0: 1 port detected
[ 2.848030] usbcore: registered new interface driver cdc_acm
[ 2.848531] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.849284] usbcore: registered new interface driver cdc_wdm
[ 2.849822] usbcore: registered new interface driver uas
[ 2.850389] usbcore: registered new interface driver usb-storage
[ 2.850995] usbcore: registered new interface driver usbserial
[ 2.851557] usbcore: registered new interface driver usbserial_generic
[ 2.852171] usbserial: USB Serial support registered for generic
[ 2.852740] usbcore: registered new interface driver ch341
[ 2.853263] usbserial: USB Serial support registered for ch341-uart
[ 2.853856] usbcore: registered new interface driver cp210x
[ 2.854387] usbserial: USB Serial support registered for cp210x
[ 2.854957] usbcore: registered new interface driver ftdi_sio
[ 2.855501] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.856238] usbcore: registered new interface driver keyspan
[ 2.856759] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.857484] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.858166] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.858833] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.859530] usbcore: registered new interface driver option
[ 2.860065] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.860785] usbcore: registered new interface driver oti6858
[ 2.861317] usbserial: USB Serial support registered for oti6858
[ 2.861886] usbcore: registered new interface driver pl2303
[ 2.862419] usbserial: USB Serial support registered for pl2303
[ 2.862982] usbcore: registered new interface driver sierra
[ 2.863514] usbserial: USB Serial support registered for Sierra USB modem
[ 2.865309] usbcore: registered new interface driver usbtouchscreen
[ 2.865874] [HXTP] himax_hx83102_init
[ 2.866219] [HXTP] himax_hx83102_probe:Enter
[ 2.866882] .. rk pwm remotectl v1.1 init
[ 2.867491] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.868554] sensor_register_slave:mma8452,id=17
[ 2.868969] sensor_register_slave:lis3dh,id=7
[ 2.869375] sensor_register_slave:mma7660,id=18
[ 2.869789] sensor_register_slave:lsm303d,id=23
[ 2.870210] sensor_register_slave:gs_mc3230,id=24
[ 2.870630] [Gsensor] gsensor_init
[ 2.870952] sensor_register_slave:mpu6880_acc,id=25
[ 2.871396] sensor_register_slave:mpu6500_acc,id=26
[ 2.871832] sensor_register_slave:lsm330_acc,id=27
[ 2.872276] sensor_register_slave:akm8975,id=31
[ 2.872688] sensor_register_slave:akm8963,id=32
[ 2.873108] sensor_register_slave:l3g4200d,id=46
[ 2.873521] sensor_register_slave:l3g20d,id=47
[ 2.873922] sensor_register_slave:ewtsa,id=48
[ 2.874320] sensor_register_slave:lsm330_gyro,id=52
[ 2.874756] sensor_register_slave:cm3217,id=54
[ 2.875165] sensor_register_slave:cm3218,id=55
[ 2.876097] i2c /dev entries driver
[ 2.877673] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.878358] fan53555-reg: supplied by vcc5v0_sys
