自己设计的板子,使用的firefly 3588的 SDK,根据硬件修改内核设备树,编译出来的固件烧录到板子中,加载到内核就失败了。是哪里需要修改适配,还是sdk 不支持自己设计的板子? 有人遇到过吗?
[BEGIN] 2024/9/24 14:02:06
DDR Version V1.07 20220412
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-gc060f28d70-220414 #zyf (Apr 18 2022 - 18:13:34)
Failed to set cpub01
Failed to set cpub23
unknown raw ID phN
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(5ae6932916…) + OK
## Checking uboot 0x00200000 … sha256(598e5a01f9…) + OK
## Checking fdt 0x00347150 … sha256(c07f4a4d71…) + OK
## Checking atf-2 0x000f0000 … sha256(c00c7fd75b…) + OK
## Checking atf-3 0xff100000 … sha256(71c3a5841b…) + OK
## Checking atf-4 0xff001000 … sha256(2301cf73be…) + OK
## Checking optee 0x08400000 … sha256(4ed9cd20b5…) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 117.857 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-384-g45c8fcb44:derrick.huang
NOTICE: BL31: Built : 15:14:04, Jun 18 2022
INFO: ext 32k is not valid
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing BL32
INFO: hdmirx_handler: dma not on, ret
I/TC:
Architecture 10.2-2020.11 (arm-10.16))) #1 Tue Jun 14 10:44:31 CST 2022 aarch64
INFO: SPSR = 0x3c9
#zyp (Aug 31 2023 - 10:02:45 +0800)
Model: Rockchip RK3588 Evaluation Board
PreSerial: 2, raw, 0xfeb50000
DRAM: 15.7 GiB
Sysmem: init
Relocation Offset: edb30000
Relocation fdt: eb9f9e28 - eb9fecd8
CR: M/C/I
Hotkey: ctrl+`
mmc@fe2c0000: 1, mmc@fe2e0000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
DM: v2
boot mode: recovery (misc)
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 100000Hz
vsel-gpios- not found!
en-gpios- not found!
vdd_cpu_big0_s0 800000 uV
vdd_cpu_big1_s0 800000 uV
spi2: RK806: 2
ON=0x00, OFF=0x00
vdd_gpu_s0 750000 uV
vdd_cpu_lit_s0 750000 uV
vdd_log_s0 750000 uV
vdd_vdenc_s0 init 750000 uV
vdd_ddr_s0 850000 uV
get vp0 plane mask:0x5, primary id:2, cursor_plane:-1, from dts
get vp1 plane mask:0xa, primary id:3, cursor_plane:-1, from dts
get vp2 plane mask:0x140, primary id:8, cursor_plane:-1, from dts
get vp3 plane mask:0x280, primary id:9, cursor_plane:-1, from dts
Model: Firefly ITX-3588J HDMI(Linux)
vp0 have layer nr:2[0 2 ], primary plane: 2
vp1 have layer nr:2[1 3 ], primary plane: 3
vp2 have layer nr:2[6 8 ], primary plane: 8
vp3 have layer nr:2[7 9 ], primary plane: 9
Monitor has basic audio support
can’t find to match
color_format:0
hdmi_select_link_config use tmds mode
mode:1920x1080 bus_format:0x100a
hdmi@fdea0000: detailed mode clock 148500 kHz, flags[5]
H: 1920 2008 2052 2200
V: 1080 1084 1089 1125
bus_format: 100a
VOP update mode to: 1920x1080p0, type: HDMI1 for VP1
dclk:148500,if_pixclk_div;2,if_dclk_div:4
rockchip_vop2_init: Failed to get hdmi0_phy_pll ret=-19
hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000
hdptx phy pll locked!
VOP VP1 enable Esmart1[500x501->500x501@710x289] fmt[2] addr[0xedf20000]
CEA mode used vic=17
mtmdsclock:1485000
bus_width:0x16a8c8,bit_rate:1485000
hdptx phy lane locked!
dw_hdmi_setup HDMI mode
don’t use dsc mode
dw hdmi qp use tmds mode
CLK: (uboot. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 24000 KHz
b1pll 24000 KHz
lpll 24000 KHz
v0pll 24000 KHz
aupll 786431 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 850000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 594000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Net: eth1: ethernet@fe1c0000
optee api revision: 2.0
Not AVB images, AVB skip
No valid android hdr
Android image load failed
## Booting FIT Image at 0xe7271c00 with size 0x04587200
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at e7271c00 …
Using ‘conf’ configuration
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0xe7299e00
Data Size: 35807744 Bytes = 34.1 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00400000
Entry Point: 0x00400000
Hash algo: sha256
Hash value: a39e175f138c1b765606adc3359150e3fdeef8496360c43c962132c93a63ad8e
Verifying Hash Integrity … sha256+ OK
## Loading ramdisk from FIT Image at e7271c00 …
Trying ‘ramdisk’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0xe94c0000
Data Size: 36932945 Bytes = 35.2 MiB
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 993174280a559715c65c49c171ee705cba9c0043aa3dcea430d4bae4a474bb1e
Loading ramdisk from 0xe94c0000 to 0x0a200000
## Loading fdt from FIT Image at e7271c00 …
Trying ‘fdt’ fdt subimage
Type: Flat Device Tree
Data Start: 0xe7272400
Data Size: 162171 Bytes = 158.4 KiB
Load Address: 0x0a100000
Hash algo: sha256
Hash value: 18f950e5da45b9ad739ecc8648482bf2a6c43c17bab6294bb50b3fa16603e504
Loading fdt from 0x0a100000 to 0x0a100000
Loading Kernel Image from 0xe7299e00 to 0x00400000 … OK
kernel loaded at 0x00400000, end = 0x02626200
‘reserved-memory’ cma: addr=10000000 size=10000000
Using Device Tree in place at 000000000a100000, end 000000000a12a97a
Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000)
Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000)
Total: 1390.784 ms
[ 1.507369] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
.36.1.20210621) #11 SMP Tue Apr 11 16:44:57 CST 2023
[ 1.518704] Machine model: Firefly ITX-3588J HDMI(Linux)
[ 1.518790] earlycon: uart8250 at MMIO32 0x00000000feb50000 (options ‘’)
[ 1.523544] printk: bootconsole [uart8250] enabled
[ 1.526547] efi: UEFI not found.
000000000, size 0 MiB
[ 1.533931] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB
[ 1.534660] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[ 1.795833] Zone ranges:
[ 1.796069] DMA [mem 0x0000000000200000-0x00000000ffffffff]
[ 1.796631] DMA32 empty
[ 1.796897] Normal [mem 0x0000000100000000-0x00000003ffefffff]
[ 1.797458] Movable zone start for each node
[ 1.797845] Early memory node ranges
[ 1.798169] node 0: [mem 0x0000000000200000-0x00000000083fffff]
[ 1.798736] node 0: [mem 0x0000000009400000-0x00000000efffffff]
[ 1.799304] node 0: [mem 0x0000000100000000-0x00000003fbffffff]
[ 1.799876] node 0: [mem 0x00000003fc500000-0x00000003ffefffff]
[ 1.800441] Initmem setup node 0 [mem 0x0000000000200000-0x00000003ffefffff]
[ 1.894275] On node 0, zone Normal: 256 pages in unavailable ranges
[ 1.894431] psci: probing for conduit method from DT.
[ 1.895456] psci: PSCIv1.1 detected in firmware.
[ 1.895871] psci: Using standard PSCI v0.2 function IDs
[ 1.896348] psci: Trusted OS migration not required
[ 1.896790] psci: SMC Calling Convention v1.2
[ 1.897570] percpu: Embedded 31 pages/cpu s88296 r8192 d30488 u126976
[ 1.898351] Detected VIPT I-cache on CPU0
[ 1.898761] CPU features: detected: GIC system register CPU interface
[ 1.899345] CPU features: detected: Virtualization Host Extensions
[ 1.899907] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 1.900541] alternatives: patching kernel code
[ 1.901337] Built 1 zonelists, mobility grouping on. Total pages: 4058188
type=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 1.907477] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 1.908961] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 1.909676] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 1.916425] software IO TLB: mapped [mem 0x00000000e9f00000-0x00000000edf00000] (64MB)
93K bss, 455736K reserved, 262144K cma-reserved)
[ 2.058188] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 2.058807] ftrace: allocating 65879 entries in 258 pages
[ 2.167714] ftrace: allocated 258 pages with 2 groups
[ 2.168460] rcu: Hierarchical RCU implementation.
[ 2.168888] rcu: RCU event tracing is enabled.
[ 2.169295] Rude variant of Tasks RCU enabled.
[ 2.169706] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 2.176560] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 2.179312] GICv3: GIC: Using split EOI/Deactivate mode
[ 2.179784] GICv3: 480 SPIs implemented
[ 2.180131] GICv3: 0 Extended SPIs implemented
[ 2.180558] GICv3: Distributor has no Range Selector support
[ 2.181072] GICv3: 16 PPIs implemented
[ 2.181451] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000
[ 2.182190] ITS [mem 0xfe640000-0xfe65ffff]
[ 2.182619] ITS@0x00000000fe640000: allocated 8192 Devices @1001d0000 (indirect, esz 8, psz 64K, shr 0)
0)
[ 2.184417] ITS: using cache flushing for cmd queue
[ 2.184891] ITS [mem 0xfe660000-0xfe67ffff]
[ 2.185311] ITS@0x00000000fe660000: allocated 8192 Devices @100200000 (indirect, esz 8, psz 64K, shr 0)
0)
[ 2.187106] ITS: using cache flushing for cmd queue
[ 2.187708] GICv3: using LPI property table @0x0000000100220000
[ 2.188360] GIC: using cache flushing for LPI property table
[ 2.188876] GICv3: CPU0: using allocated LPI pending table @0x0000000100230000
[ 2.189702] random: get_random_bytes called from start_kernel+0x3dc/0x5d0 with crng_init=0
[ 2.316298] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
2592 ns
[ 2.318551] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 2.320400] Console: colour dummy device 80x25
[ 2.321741] pid_max: default: 32768 minimum: 301
[ 2.322313] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 2.323019] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 2.325461] rcu: Hierarchical SRCU implementation.
[ 2.326807] Platform MSI: msi-controller@fe640000 domain created
[ 2.327379] Platform MSI: msi-controller@fe660000 domain created
[ 2.328216] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created
[ 2.328975] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created
[ 2.329841] EFI services will not be available.
[ 2.330581] smp: Bringing up secondary CPUs …
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
[ 2.332239] Detected VIPT I-cache on CPU1
[ 2.332274] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000
[ 2.332292] GICv3: CPU1: using allocated LPI pending table @0x0000000100240000
[ 2.332335] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 2.333621] Detected VIPT I-cache on CPU2
[ 2.333652] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000
[ 2.333669] GICv3: CPU2: using allocated LPI pending table @0x0000000100250000
[ 2.333710] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 2.334990] Detected VIPT I-cache on CPU3
[ 2.335017] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000
[ 2.335034] GICv3: CPU3: using allocated LPI pending table @0x0000000100260000
[ 2.335071] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 2.336344] CPU features: detected: Spectre-v4
[ 2.336348] Detected PIPT I-cache on CPU4
[ 2.336362] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000
[ 2.336372] GICv3: CPU4: using allocated LPI pending table @0x0000000100270000
[ 2.336396] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0]
[ 2.337613] Detected PIPT I-cache on CPU5
[ 2.337628] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000
[ 2.337638] GICv3: CPU5: using allocated LPI pending table @0x0000000100280000
[ 2.337662] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0]
[ 2.338926] Detected PIPT I-cache on CPU6
[ 2.338941] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000
[ 2.338951] GICv3: CPU6: using allocated LPI pending table @0x0000000100290000
[ 2.338974] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0]
[ 2.340179] Detected PIPT I-cache on CPU7
[ 2.340194] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000
[ 2.340204] GICv3: CPU7: using allocated LPI pending table @0x00000001002a0000
[ 2.340228] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0]
[ 2.340296] smp: Brought up 1 node, 8 CPUs
[ 2.356477] SMP: Total of 8 processors activated.
[ 2.356900] CPU features: detected: Privileged Access Never
[ 2.357397] CPU features: detected: User Access Override
[ 2.357874] CPU features: detected: 32-bit EL0 Support
[ 2.358334] CPU features: detected: Common not Private translations
[ 2.358903] CPU features: detected: RAS Extension Support
[ 2.359385] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 2.360151] CPU features: detected: CRC32 instructions
[ 2.360609] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 2.361235] CPU features: detected: RCpc load-acquire (LDAPR)
[ 2.361829] CPU: All CPU(s) started at EL2
[ 2.364775] devtmpfs: initialized
[ 2.375851] Registered cp15_barrier emulation handler
[ 2.376314] Registered setend emulation handler
[ 2.376810] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 2.377696] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 2.378398] pinctrl core: initialized pinctrl subsystem
[ 2.379143] DMI not present or invalid.
[ 2.379601] NET: Registered protocol family 16
[ 2.380746] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 2.381461] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 2.382737] thermal_sys: Registered thermal governor ‘fair_share’
[ 2.382739] thermal_sys: Registered thermal governor ‘step_wise’
[ 2.383294] thermal_sys: Registered thermal governor ‘user_space’
[ 2.383849] thermal_sys: Registered thermal governor ‘power_allocator’
[ 2.384529] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 2.385875] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 2.386632] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
[ 2.387389] thermal thermal_zone4: power_allocator: sustainable_power will be estimated
[ 2.388143] thermal thermal_zone5: power_allocator: sustainable_power will be estimated
[ 2.388897] thermal thermal_zone6: power_allocator: sustainable_power will be estimated
[ 2.389641] cpuidle: using governor menu
[ 2.390008] Registered FIQ tty driver
[ 2.390603] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 2.391338] ASID allocator initialised with 65536 entries
[ 2.393267] printk: console [ramoops-1] enabled
[ 2.393680] pstore: Registered ramoops as persistent store backend
[ 2.394242] ramoops: using 0xf0000@0x110000, ecc: 0
[ 2.438688] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000
[ 2.439500] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000
[ 2.440300] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000
[ 2.441116] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000
[ 2.441921] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000
[ 2.442542] rockchip-pinctrl pinctrl: probed pinctrl
[ 2.509319] raid6: neonx8 gen() 5608 MB/s
[ 2.566076] raid6: neonx8 xor() 4333 MB/s
[ 2.622832] raid6: neonx4 gen() 5657 MB/s
[ 2.679591] raid6: neonx4 xor() 4365 MB/s
[ 2.736350] raid6: neonx2 gen() 5322 MB/s
[ 2.793110] raid6: neonx2 xor() 4160 MB/s
[ 2.849870] raid6: neonx1 gen() 4386 MB/s
[ 2.906626] raid6: neonx1 xor() 3422 MB/s
[ 2.963390] raid6: int64x8 gen() 1340 MB/s
[ 3.020149] raid6: int64x8 xor() 860 MB/s
[ 3.076902] raid6: int64x4 gen() 1695 MB/s
[ 3.133663] raid6: int64x4 xor() 947 MB/s
[ 3.190418] raid6: int64x2 gen() 2498 MB/s
[ 3.247181] raid6: int64x2 xor() 1375 MB/s
[ 3.303941] raid6: int64x1 gen() 2070 MB/s
[ 3.360705] raid6: int64x1 xor() 1128 MB/s
[ 3.361094] raid6: using algorithm neonx4 gen() 5657 MB/s
[ 3.361584] raid6: … xor() 4365 MB/s, rmw enabled
[ 3.362039] raid6: using neon recovery algorithm
[ 3.362975] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 3.363481] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 3.364002] fiq_debugger_probe: could not install nmi irq handler
[ [ 3.364595] printk: console [ttyFIQ0] enabled
[ 3.365371] printk: bootconsole [uart8250] disabled
[ 3.365915] Registered fiq debugger ttyFIQ0
[ 3.366258] vcc5v0_sys: supplied by vcc12v_dcin
[ 3.366386] vcc5v0_usbdcin: supplied by vcc12v_dcin
[ 3.366504] vcc5v0_usb: supplied by vcc12v_dcin
[ 3.366625] vcc_1v1_nldo_s3: supplied by vcc5v0_sys
[ 3.366765] vcc5v0_host: supplied by vcc5v0_usb
[ 3.367037] vcc3v3_pcie30: supplied by vcc12v_dcin
[ 3.367129] vcc5v0_host2: supplied by vcc5v0_usb
[ 3.367438] iommu: Default domain type: Passthrough
[ 3.367515] rk_iommu fdab9000.iommu: version = 2
[ 3.367874] rk_iommu fdb50800.iommu: version = 2
[ 3.368109] rk_iommu fdb60f00.iommu: version = 2
[ 3.368292] rk_iommu fdb70f00.iommu: version = 2
[ 3.368456] rk_iommu fdb90480.iommu: version = 2
[ 3.368637] rk_iommu fdba0800.iommu: version = 2
[ 3.368816] rk_iommu fdba4800.iommu: version = 2
[ 3.368999] rk_iommu fdba8800.iommu: version = 2
[ 3.369200] rk_iommu fdbac800.iommu: version = 2
[ 3.369387] rk_iommu fdbb0800.iommu: version = 2
[ 3.369577] rk_iommu fdbdf000.iommu: version = 2
[ 3.369844] rk_iommu fdbef000.iommu: version = 2
[ 3.370122] rk_iommu fdc38700.iommu: version = 2
[ 3.370399] rk_iommu fdc48700.iommu: version = 2
[ 3.370608] rk_iommu fdce0800.iommu: version = 2
[ 3.370726] rk_iommu fdd97e00.iommu: version = 2
[ 3.371009] usbcore: registered new interface driver usbfs
[ 3.371027] usbcore: registered new interface driver hub
[ 3.371042] usbcore: registered new device driver usb
[ 3.371080] mc: Linux media interface: v0.10
[ 3.371092] videodev: Linux video capture interface: v2.00
[ 3.371123] pps_core: LinuxPPS API ver. 1 registered
[ 3.371127] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 3.371134] PTP clock support registered
[ 3.371376] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 3.371408] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 3.372516] Advanced Linux Sound Architecture Driver Initialized.
[ 3.372705] Bluetooth: Core ver 2.22
[ 3.372719] NET: Registered protocol family 31
[ 3.372722] Bluetooth: HCI device and connection manager initialized
[ 3.372728] Bluetooth: HCI socket layer initialized
[ 3.372733] Bluetooth: L2CAP socket layer initialized
[ 3.372741] Bluetooth: SCO socket layer initialized
[ 3.374030] rockchip-cpuinfo cpuinfo: SoC : 35881000
[ 3.374036] rockchip-cpuinfo cpuinfo: Serial : 1ab5e7e5815859b0
[ 3.374443] clocksource: Switched to clocksource arch_sys_counter
[ 3.688414] NET: Registered protocol family 2
[ 3.688583] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 3.692117] tcp_listen_portaddr_hash hash table entries: 8192 (order: 6, 327680 bytes, linear)
[ 3.692278] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 3.692922] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 3.693654] TCP: Hash tables configured (established 131072 bind 65536)
[ 3.693711] UDP hash table entries: 8192 (order: 7, 786432 bytes, linear)
[ 3.694001] UDP-Lite hash table entries: 8192 (order: 7, 786432 bytes, linear)
[ 3.694342] NET: Registered protocol family 1
[ 3.694581] RPC: Registered named UNIX socket transport module.
[ 3.694588] RPC: Registered udp transport module.
[ 3.694592] RPC: Registered tcp transport module.
[ 3.694595] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.694942] PCI: CLS 0 bytes, default 64
[ 3.695198] Trying to unpack rootfs image as initramfs…
[ 4.250080] Freeing initrd memory: 36064K
[ 4.250923] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 4.251455] kvm [1]: IPA Size Limit: 40 bits
[ 4.251468] kvm [1]: GICv3: no GICV resource entry
[ 4.251472] kvm [1]: disabling GICv2 emulation
[ 4.251476] kvm [1]: GIC system register CPU interface enabled
[ 4.251611] kvm [1]: vgic interrupt IRQ9
[ 4.251777] kvm [1]: VHE mode initialized successfully
[ 4.253845] Initialise system trusted keyrings
[ 4.253902] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 4.256265] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 4.256539] NFS: Registering the id_resolver key type
[ 4.256550] Key type id_resolver registered
[ 4.256554] Key type id_legacy registered
[ 4.256561] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 4.257100] Key type cifs.spnego registered
[ 4.257108] Key type cifs.idmap registered
[ 4.257115] ntfs: driver 2.1.32 [Flags: R/O].
[ 4.257197] jffs2: version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
[ 4.257290] fuse: init (API version 7.32)
[ 4.257456] SGI XFS with security attributes, no debug enabled
[ 4.278099] NET: Registered protocol family 38
[ 4.278109] xor: measuring software checksum speed
[ 4.279643] 8regs : 6438 MB/sec
[ 4.280797] 32regs : 8569 MB/sec
[ 4.281763] arm64_neon : 10316 MB/sec
[ 4.281769] xor: using function: arm64_neon (10316 MB/sec)
[ 4.281775] Key type asymmetric registered
[ 4.281779] Asymmetric key parser ‘x509’ registered
[ 4.281795] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 4.281844] io scheduler mq-deadline registered
[ 4.281851] io scheduler kyber registered
[ 4.282391] rockchip-csi2-dphy-hw fedc0000.csi2-dphy0-hw: csi2 dphy hw probe successfully!
[ 4.282636] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 4.290802] rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy init success
[ 4.292048] Firefly gpio driver init!
[ 4.292147] Firefly gpio driver register return : 0
[ 4.293420] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node
[ 4.293476] rk-pcie fe170000.pcie: no vpcie3v3 regulator found
embers when release buffer
[ 4.293494] mpp_service mpp-srv: probe start
[ 4.293824] rk-pcie fe170000.pcie: missing legacy IRQ resource
[ 4.293845] rk-pcie fe170000.pcie: IRQ msi not found
[ 4.293855] rk-pcie fe170000.pcie: use outband MSI support
[ 4.293864] rk-pcie fe170000.pcie: Missing config reg space
[ 4.293882] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges:
[ 4.293908] rk-pcie fe170000.pcie: err 0x00f2000000..0x00f20fffff → 0x00f2000000
[ 4.293929] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff → 0x00f2100000
[ 4.293951] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff → 0x00f2200000
[ 4.293968] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff → 0x0980000000
[ 4.294003] rk-pcie fe170000.pcie: Missing config reg space
[ 4.294037] rk-pcie fe170000.pcie: invalid resource
[ 4.294822] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1
MAIN_DMA
[ 4.295036] mpp_vdpu2 fdb50400.vdpu: probe device
[ 4.295142] mpp_vdpu2 fdb50400.vdpu: reset group is empty!
[ 4.295146] vdpu_init:501: No aclk reset resource define
[ 4.295151] mpp_vdpu2 fdb50400.vdpu: reset group is empty!
[ 4.295155] vdpu_init:504: No hclk reset resource define
[ 4.295245] mpp_vdpu2 fdb50400.vdpu: probing finish
[ 4.295451] mpp_vepu2 jpege-ccu: probing start
[ 4.295457] mpp_vepu2 jpege-ccu: probing finish
[ 4.295566] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5
MAIN_DMA
[ 4.295709] mpp_vepu2 fdba0000.jpege-core: probing start
[ 4.295818] mpp_vepu2 fdba0000.jpege-core: attach ccu success
[ 4.295901] mpp_vepu2 fdba0000.jpege-core: probing finish
[ 4.296006] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6
MAIN_DMA
[ 4.296147] mpp_vepu2 fdba4000.jpege-core: probing start
[ 4.296250] mpp_vepu2 fdba4000.jpege-core: attach ccu success
[ 4.296332] mpp_vepu2 fdba4000.jpege-core: probing finish
[ 4.296435] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7
MAIN_DMA
[ 4.296577] mpp_vepu2 fdba8000.jpege-core: probing start
[ 4.296676] mpp_vepu2 fdba8000.jpege-core: attach ccu success
[ 4.296756] mpp_vepu2 fdba8000.jpege-core: probing finish
[ 4.296858] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8
MAIN_DMA
[ 4.297002] mpp_vepu2 fdbac000.jpege-core: probing start
[ 4.297100] mpp_vepu2 fdbac000.jpege-core: attach ccu success
[ 4.297179] mpp_vepu2 fdbac000.jpege-core: probing finish
[ 4.297454] mpp-iep2 fdbb0000.iep: Adding to iommu group 9
MAIN_DMA
[ 4.297600] mpp-iep2 fdbb0000.iep: probe device
[ 4.297720] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 4.297798] mpp-iep2 fdbb0000.iep: probing finish
[ 4.298007] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4
MAIN_DMA
[ 4.298230] mpp_jpgdec fdb90000.jpegd: probe device
[ 4.298443] mpp_jpgdec fdb90000.jpegd: probing finish
[ 4.298787] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start
[ 4.298844] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish
[ 4.298936] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12
MAIN_DMA
[ 4.299185] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start
[ 4.299301] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
[ 4.299306] rkvdec2_init:697: No niu aclk reset resource define
[ 4.299311] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
[ 4.299314] rkvdec2_init:700: No niu hclk reset resource define
[ 4.299375] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001
[ 4.299379] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0
[ 4.299517] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000
[ 4.299521] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000
[ 4.299525] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520
[ 4.299529] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576
[ 4.299535] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512
[ 4.299563] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish
[ 4.299635] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13
MAIN_DMA
[ 4.299854] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start
[ 4.299967] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
[ 4.299972] rkvdec2_init:697: No niu aclk reset resource define
[ 4.299977] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
[ 4.299980] rkvdec2_init:700: No niu hclk reset resource define
[ 4.300028] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002
[ 4.300045] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1
[ 4.300211] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000
[ 4.300216] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000
[ 4.300220] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424
[ 4.300224] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576
[ 4.300229] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512
[ 4.300259] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish
[ 4.300442] mpp_rkvenc2 rkvenc-ccu: probing start
[ 4.300448] mpp_rkvenc2 rkvenc-ccu: probing finish
[ 4.300564] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10
MAIN_DMA
[ 4.300742] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start
[ 4.300761] mpp_rkvenc2 fdbd0000.rkvenc-core: link mode task capacity 8
[ 4.300904] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0
[ 4.301012] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish
[ 4.301073] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11
MAIN_DMA
[ 4.301308] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start
[ 4.301327] mpp_rkvenc2 fdbe0000.rkvenc-core: link mode task capacity 8
[ 4.301493] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1
[ 4.301578] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish
[ 4.302085] mpp_av1dec: Adding child /av1d@fdc70000
[ 4.302156] mpp_av1dec: register device av1d-master
[ 4.302173] mpp_av1dec av1d-master: av1_iommu_of_xlate,784
[ 4.302192] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu
[ 4.302223] mpp_av1dec av1d-master: Adding to iommu group 16
MAIN_DMA
[ 4.302452] mpp_av1dec av1d-master: probing start
[ 4.302664] mpp_av1dec av1d-master: probing finish
[ 4.302701] mpp_service mpp-srv: probe success
[ 4.310484] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 4.310494] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 4.311413] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 4.311421] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 4.312339] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 4.312347] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 4.312779] rockchip-pvtm fda40000.pvtm: pvtm@0 probed
[ 4.312845] rockchip-pvtm fda50000.pvtm: pvtm@1 probed
[ 4.312901] rockchip-pvtm fda60000.pvtm: pvtm@2 probed
[ 4.312958] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed
[ 4.313011] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed
[ 4.313602] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 4.314685] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 4.315191] feb40000.serial: ttyS1 at MMIO 0xfeb40000 (irq = 81, base_baud = 1500000) is a 16550A
[ 4.315571] feb90000.serial: ttyS6 at MMIO 0xfeb90000 (irq = 82, base_baud = 1500000) is a 16550A
[ 4.315825] feba0000.serial: ttyS7 at MMIO 0xfeba0000 (irq = 83, base_baud = 1500000) is a 16550A
[ 4.317062] random: fast init done
[ 4.317161] random: crng init done
[ 4.317810] rockchip-vop2 fdd90000.vop: Adding to iommu group 15
MAIN_DMA
[ 4.324058] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 2
[ 4.324074] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 3
[ 4.324090] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 8
[ 4.324099] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 9
[ 4.324133] rockchip-drm display-subsystem: failed to get hdmi0_phy_pll: -517
[ 4.324384] [drm] failed to init overlay plane Cluster0-win1
[ 4.324418] [drm] failed to init overlay plane Cluster1-win1
[ 4.324462] [drm] failed to init overlay plane Cluster2-win1
[ 4.324492] [drm] failed to init overlay plane Cluster3-win1
[ 4.335150] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffffffc0112829b0)
[ 4.335884] dwhdmi-rockchip fdea0000.hdmi: registered ddc I2C bus driver
[ 4.336080] rockchip-drm display-subsystem: bound fdea0000.hdmi (ops 0xffffffc01128a710)
[ 4.442694] dwhdmi-rockchip fdea0000.hdmi: use tmds mode
[ 4.442728] dwhdmi-rockchip fdea0000.hdmi: use tmds mode
[ 4.554478] rk-pcie fe170000.pcie: PCIe Link up, LTSSM is 0x30011
[ 4.554680] rk-pcie fe170000.pcie: PCI host bridge to bus 0002:20
[ 4.554700] pci_bus 0002:20: root bus resource [bus 20-2f]
[ 4.554715] pci_bus 0002:20: root bus resource [??? 0xf2000000-0xf20fffff flags 0x0]
[ 4.554731] pci_bus 0002:20: root bus resource [io 0x0000-0xfffff] (bus address [0xf2100000-0xf21fffff])
[ 4.554744] pci_bus 0002:20: root bus resource [mem 0xf2200000-0xf2ffffff]
[ 4.554757] pci_bus 0002:20: root bus resource [mem 0x980000000-0x9bfffffff pref]
[ 4.554807] pci 0002:20:00.0: [1d87:3588] type 01 class 0x060400
[ 4.554843] pci 0002:20:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 4.554927] pci 0002:20:00.0: supports D1 D2
[ 4.554940] pci 0002:20:00.0: PME# supported from D0 D1 D3hot
[ 4.565395] pci 0002:20:00.0: Primary bus is hard wired to 0
[ 4.565424] pci 0002:20:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring
[ 4.565703] pci 0002:21:00.0: [14e4:449d] type 00 class 0x028000
[ 4.565811] pci 0002:21:00.0: reg 0x10: [mem 0x00000000-0x0000ffff 64bit]
[ 4.565878] pci 0002:21:00.0: reg 0x18: [mem 0x00000000-0x003fffff 64bit]
[ 4.566460] pci 0002:21:00.0: supports D1 D2
[ 4.566474] pci 0002:21:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 4.571785] dwhdmi-rockchip fdea0000.hdmi: use tmds mode
[ 4.572385] dwhdmi-rockchip fdea0000.hdmi: use tmds mode
[ 4.572479] Freeing drm_logo memory: 1236K
[ 4.584360] pci_bus 0002:21: busn_res: [bus 21-2f] end is updated to 21
[ 4.584392] pci 0002:20:00.0: BAR 8: assigned [mem 0xf2200000-0xf27fffff]
[ 4.584402] pci 0002:20:00.0: BAR 6: assigned [mem 0xf2800000-0xf280ffff pref]
[ 4.584415] pci 0002:21:00.0: BAR 2: assigned [mem 0xf2400000-0xf27fffff 64bit]
[ 4.584493] pci 0002:21:00.0: BAR 0: assigned [mem 0xf2200000-0xf220ffff 64bit]
[ 4.584543] pci 0002:20:00.0: PCI bridge to [bus 21]
[ 4.584552] pci 0002:20:00.0: bridge window [mem 0xf2200000-0xf27fffff]
[ 4.587745] pcieport 0002:20:00.0: PME: Signaling with IRQ 122
[ 4.598923] Console: switching to colour frame buffer device 240x67
[ 4.598950] dwhdmi-rockchip fdea0000.hdmi: use tmds mode
[ 4.615616] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[ 4.616057] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[ 4.622568] brd: module loaded
[ 4.625776] loop: module loaded
[ 4.625999] zram: Added device: zram0
[ 4.626138] lkdtm: No crash points registered, enable through debugfs
[ 4.626228] sysheap: system_heap: orders[0] = 6
[ 4.626233] sysheap: system_heap: orders[1] = 4
[ 4.626237] sysheap: system_heap: orders[2] = 0
[ 4.627808] rockchip-spi feb20000.spi: no high_speed pinctrl state
[ 4.629009] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1
[ 4.629150] rk806 spi2.0: ON: 0x40 OFF:0x0
[ 4.630957] vdd_gpu_s0: supplied by vcc5v0_sys
[ 4.632136] vdd_cpu_lit_s0: supplied by vcc5v0_sys
[ 4.632843] vdd_log_s0: supplied by vcc5v0_sys
[ 4.633501] vdd_vdenc_s0: supplied by vcc5v0_sys
[ 4.634158] vdd_ddr_s0: supplied by vcc5v0_sys
[ 4.634577] vdd2_ddr_s3: supplied by vcc5v0_sys
[ 4.635224] vdd_2v0_pldo_s3: supplied by vcc5v0_sys
[ 4.635765] vcc_3v3_s3: supplied by vcc5v0_sys
[ 4.636290] vddq_ddr_s0: supplied by vcc5v0_sys
[ 4.636937] vcc_1v8_s3: supplied by vcc5v0_sys
[ 4.637486] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3
[ 4.638086] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3
[ 4.638619] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3
[ 4.639168] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3
[ 4.639700] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3
[ 4.640234] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 4.640975] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 4.641741] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3
[ 4.642472] vcc_3v3_s0: supplied by vcc5v0_sys
[ 4.643020] vccio_sd_s0: supplied by vcc5v0_sys
[ 4.643563] pldo6_s3: supplied by vcc5v0_sys
[ 4.644069] rk806 spi2.0: no sleep-setting state
[ 4.644078] rk806 spi2.0: no reset-setting pinctrl state
[ 4.644083] rk806 spi2.0: no dvs-setting pinctrl state
[ 4.646257] register firefly_spi_init spi return v = :0
[ 4.646598] wireguard: allowedips self-tests: pass
[ 4.651172] wireguard: nonce counter self-tests: pass
[ 4.928449] wireguard: ratelimiter self-tests: pass
[ 4.928555] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 4.928561] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[ 4.928863] libphy: Fixed MDIO Bus: probed
[ 4.928978] tun: Universal TUN/TAP device driver, 1.6
[ 4.929090] CAN device driver interface
[ 4.930993] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found
[ 4.931179] rk_gmac-dwmac fe1c0000.ethernet: no regulator found
[ 4.931187] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output).
[ 4.931193] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42).
[ 4.931198] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay.
[ 4.931204] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff
[ 4.931213] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no).
[ 4.931220] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx
[ 4.931227] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx
[ 4.931244] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed
[ 4.931465] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID
[ 4.931561] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 4.931568] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5
[ 4.931574] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported
[ 4.931579] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported
[ 4.931584] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported
[ 4.931588] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported
[ 4.931624] rk_gmac-dwmac fe1c0000.ethernet: TSO supported
[ 4.931629] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 4.931636] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2)
[ 4.931641] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled
[ 4.931646] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width
[ 5.064448] libphy: stmmac: probed
[ 5.069420] usbcore: registered new interface driver rtl8150
[ 5.069446] usbcore: registered new interface driver r8152
[ 5.069467] usbcore: registered new interface driver asix
[ 5.069484] usbcore: registered new interface driver ax88179_178a
[ 5.069499] usbcore: registered new interface driver cdc_ether
[ 5.069515] usbcore: registered new interface driver net1080
[ 5.069530] usbcore: registered new interface driver cdc_subset
[ 5.069545] usbcore: registered new interface driver zaurus
[ 5.069567] usbcore: registered new interface driver cdc_ncm
[ 5.069585] usbcore: registered new interface driver qmi_wwan_q
[ 5.069601] usbcore: registered new interface driver qmi_wwan
[ 5.077847] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 5.077861] ehci-pci: EHCI PCI platform driver
[ 5.077893] ehci-platform: EHCI generic platform driver
[ 5.080320] ehci-platform fc800000.usb: EHCI Host Controller
[ 5.080406] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1
[ 5.080474] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000
[ 5.091125] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00
[ 5.091222] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.091229] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.091234] usb usb1: Product: EHCI Host Controller
[ 5.091240] usb usb1: Manufacturer: Linux 5.10.66 ehci_hcd
[ 5.091245] usb usb1: SerialNumber: fc800000.usb
[ 5.091456] hub 1-0:1.0: USB hub found
[ 5.091478] hub 1-0:1.0: 1 port detected
[ 5.094049] ehci-platform fc880000.usb: EHCI Host Controller
[ 5.094125] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2
[ 5.094186] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000
[ 5.104458] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00
[ 5.104545] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.104552] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.104557] usb usb2: Product: EHCI Host Controller
[ 5.104562] usb usb2: Manufacturer: Linux 5.10.66 ehci_hcd
[ 5.104567] usb usb2: SerialNumber: fc880000.usb
[ 5.104774] hub 2-0:1.0: USB hub found
[ 5.104790] hub 2-0:1.0: 1 port detected
[ 5.105143] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 5.105154] ohci-platform: OHCI generic platform driver
[ 5.105328] ohci-platform fc840000.usb: Generic Platform OHCI controller
[ 5.105413] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3
[ 5.105461] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000
[ 5.165201] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 5.165210] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.165215] usb usb3: Product: Generic Platform OHCI controller
[ 5.165220] usb usb3: Manufacturer: Linux 5.10.66 ohci_hcd
[ 5.165225] usb usb3: SerialNumber: fc840000.usb
[ 5.165419] hub 3-0:1.0: USB hub found
[ 5.165437] hub 3-0:1.0: 1 port detected
[ 5.165744] ohci-platform fc8c0000.usb: Generic Platform OHCI controller
[ 5.165819] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4
[ 5.165870] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000
[ 5.225198] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 5.225207] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.225212] usb usb4: Product: Generic Platform OHCI controller
[ 5.225218] usb usb4: Manufacturer: Linux 5.10.66 ohci_hcd
[ 5.225223] usb usb4: SerialNumber: fc8c0000.usb
[ 5.225414] hub 4-0:1.0: USB hub found
[ 5.225431] hub 4-0:1.0: 1 port detected
[ 5.226004] phy phy-fd5d4000.syscon:usb2-phy@4000.3: illegal mode
[ 5.226014] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 5.226088] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 5
[ 5.226190] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[ 5.226215] xhci-hcd xhci-hcd.6.auto: irq 128, io mem 0xfc400000
[ 5.226361] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.226367] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.226373] usb usb5: Product: xHCI Host Controller
[ 5.226378] usb usb5: Manufacturer: Linux 5.10.66 xhci-hcd
[ 5.226383] usb usb5: SerialNumber: xhci-hcd.6.auto
[ 5.226579] hub 5-0:1.0: USB hub found
[ 5.226599] hub 5-0:1.0: 1 port detected
[ 5.226744] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 5.226810] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 6
[ 5.226819] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
[ 5.226850] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 5.226903] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.226909] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.226914] usb usb6: Product: xHCI Host Controller
[ 5.226919] usb usb6: Manufacturer: Linux 5.10.66 xhci-hcd
[ 5.226924] usb usb6: SerialNumber: xhci-hcd.6.auto
[ 5.227112] hub 6-0:1.0: USB hub found
[ 5.227128] hub 6-0:1.0: 1 port detected
[ 5.227323] usbcore: registered new interface driver cdc_acm
[ 5.227328] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 5.227347] usbcore: registered new interface driver cdc_wdm
[ 5.227388] usbcore: registered new interface driver usbserial_generic
[ 5.227401] usbserial: USB Serial support registered for generic
[ 5.227420] usbcore: registered new interface driver ch341
[ 5.227431] usbserial: USB Serial support registered for ch341-uart
[ 5.227450] usbcore: registered new interface driver cp210x
[ 5.227461] usbserial: USB Serial support registered for cp210x
[ 5.227495] usbcore: registered new interface driver ftdi_sio
[ 5.227505] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 5.227592] usbcore: registered new interface driver keyspan
[ 5.227605] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 5.227615] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 5.227626] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 5.227637] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 5.227658] usbcore: registered new interface driver option
[ 5.227668] usbserial: USB Serial support registered for GSM modem (1-port)
[ 5.227805] usbcore: registered new interface driver oti6858
[ 5.227816] usbserial: USB Serial support registered for oti6858
[ 5.227835] usbcore: registered new interface driver pl2303
[ 5.227847] usbserial: USB Serial support registered for pl2303
[ 5.227872] usbcore: registered new interface driver qcserial
[ 5.227882] usbserial: USB Serial support registered for Qualcomm USB modem
[ 5.227912] usbcore: registered new interface driver sierra
[ 5.227922] usbserial: USB Serial support registered for Sierra USB modem
[ 5.228298] [HXTP] himax_hx83102_init
[ 5.228304] [HXTP] himax_hx83102_probe:Enter
[ 5.228308] [HXTP] Himax common touch panel driver init
[ 5.228366] usbcore: registered new interface driver usbtouchscreen
ut/input0
[ 5.229922] i2c /dev entries driver
[ 5.233463] vdd_cpu_big0_s0: supplied by vcc5v0_sys
[ 5.242065] vdd_cpu_big1_s0: supplied by vcc5v0_sys
[ 5.250680] rtc-hym8563 7-0051: rtc information is invalid
[ 5.252651] rtc-hym8563 7-0051: registered as rtc0
[ 5.252941] rtc-hym8563 7-0051: setting system clock to 2021-01-01T12:00:00 UTC (1609502400)
[ 5.254963] rkcifhw fdce0000.rkcif: Adding to iommu group 14
MAIN_DMA
[ 5.255245] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF
[ 5.255332] rkcif rkcif-mipi-lvds2: Adding to iommu group 14
[ 5.255348] rkcif rkcif-mipi-lvds2: rkcif driver version: v00.01.0a
[ 5.255403] rkcif rkcif-mipi-lvds2: attach to cif hw node
[ 5.255408] rkcif rkcif-mipi-lvds2: rkcif wait line 0
[ 5.255413] rkcif rkcif-mipi-lvds2: Is yuv camera
[ 5.255419] : terminal subdev does not exist
[ 5.255423] : terminal subdev does not exist
[ 5.255428] : terminal subdev does not exist
[ 5.255432] : terminal subdev does not exist
[ 5.255437] : get_remote_sensor: video pad[0] is null
[ 5.255442] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 5.255447] : get_remote_sensor: video pad[0] is null
[ 5.255451] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 5.255456] : get_remote_sensor: video pad[0] is null
[ 5.255460] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 5.255465] : get_remote_sensor: video pad[0] is null
[ 5.255469] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 5.256884] rkcif rkcif-mipi-lvds2: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 5.256893] rockchip-mipi-csi2: Async registered subdev
[ 5.256902] rockchip-mipi-csi2: probe success, v4l2_dev:rkcif-mipi-lvds2!
[ 5.258396] usbcore: registered new interface driver uvcvideo
[ 5.258401] USB Video Class driver (1.1.1)
[ 5.259680] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property
[ 5.260221] rockchip-thermal fec00000.tsadc: tsadc is probed successfully!
[ 5.260602] device-mapper: ioctl: 4.44.0-ioctl (2021-02-01) initialised: dm-devel@redhat.com
[ 5.260777] Bluetooth: HCI UART driver ver 2.3
[ 5.260783] Bluetooth: HCI UART protocol H4 registered
[ 5.260788] Bluetooth: HCI UART protocol ATH3K registered
[ 5.260817] usbcore: registered new interface driver bfusb
[ 5.261176] cpu cpu0: leakage=12
[ 5.262677] cpu cpu0: pvtm=1447
[ 5.262776] cpu cpu0: pvtm-volt-sel=2
[ 5.263287] cpu cpu4: leakage=9
[ 5.269803] cpu cpu4: pvtm=1678
[ 5.273755] cpu cpu4: pvtm-volt-sel=4
[ 5.275014] cpu cpu6: leakage=9
[ 5.281553] cpu cpu6: pvtm=1697
[ 5.285527] cpu cpu6: pvtm-volt-sel=4
[ 5.287160] cpu cpu0: avs=0
[ 5.287886] cpu cpu4: avs=0
[ 5.288584] cpu cpu6: avs=0
[ 5.288830] cpu cpu0: EM: created perf domain
[ 5.288885] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0
[ 5.289513] cpu cpu4: EM: created perf domain
[ 5.289557] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
[ 5.297994] cpu cpu6: EM: created perf domain
[ 5.298428] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
[ 5.309149] sdhci: Secure Digital Host Controller Interface driver
[ 5.309174] sdhci: Copyright(c) Pierre Ossman
[ 5.309183] Synopsys Designware Multimedia Card Interface Driver
[ 5.309561] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.311729] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 5.311797] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping …
[ 5.312733] cryptodev: driver 1.12 loaded.
[ 5.312805] hid: raw HID events driver (C) Jiri Kosina
[ 5.313084] usbcore: registered new interface driver usbhid
[ 5.313093] usbhid: USB HID core driver
[ 5.323003] Firefly adc init
[ 5.323023] Firefly adc–>FIREFLY_ADC_SAMPLE_JIFFIES: 16
[ 5.323028] Firefly adc–>MSEC_PER_SEC: 1000
[ 5.323034] Firefly adc–>HZ: 300
[ 5.323229] Firefly adc–>ret: 0
[ 5.323398] optee: probing for conduit method.
[ 5.323419] optee: revision 3.13 (87d94c5e)
[ 5.324042] optee: initialized driver
[ 5.324978] usbcore: registered new interface driver snd-usb-audio
[ 5.333210] input: rockchip-hdmi1 rockchip-hdmi1 as /devices/platform/hdmi1-sound/sound/card0/input1
[ 5.335506] Initializing XFRM netlink socket
[ 5.335899] NET: Registered protocol family 10
[ 5.336833] Segment Routing with IPv6
[ 5.337132] NET: Registered protocol family 17
[ 5.337157] NET: Registered protocol family 15
[ 5.337205] Bridge firewalling registered
[ 5.337214] can: controller area network core
[ 5.337260] NET: Registered protocol family 29
[ 5.337269] can: raw protocol
[ 5.337279] can: broadcast manager protocol
[ 5.337293] can: netlink gateway - max_hops=1
[ 5.337488] Bluetooth: RFCOMM TTY layer initialized
[ 5.337505] Bluetooth: RFCOMM socket layer initialized
[ 5.337530] Bluetooth: RFCOMM ver 1.11
[ 5.337545] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.337552] Bluetooth: BNEP filters: protocol multicast
[ 5.337564] Bluetooth: BNEP socket layer initialized
[ 5.337572] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.337582] Bluetooth: HIDP socket layer initialized
[ 5.337625] [BT_RFKILL]: Enter rfkill_rk_init
[ 5.337633] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 5.338017] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 5.338049] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 5.338059] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275p
[ 5.338067] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 5.338075] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 5.338102] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 20 flags = 0.
[ 5.338132] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 5.338140] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 5.338149] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 5.338157] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 5.338844] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 34.
[ 5.338875] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 22.
[ 5.338894] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 21.
[ 5.338913] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 0.
[ 5.339284] [BT_RFKILL]: Request irq for bt wakeup host
[ 5.339361] [BT_RFKILL]: ** disable irq
[ 5.339451] [BT_RFKILL]: bt_default device registered.
[ 5.339543] Key type dns_resolver registered
[ 5.341063] registered taskstats version 1
[ 5.341073] Loading compiled-in X.509 certificates
[ 5.342548] Btrfs loaded, crc32c=crc32c-generic
[ 5.342682] pstore: Using crash dump compression: deflate
[ 5.343061] rga3_core0 fdb60000.rga: Adding to iommu group 2
MAIN_DMA
[ 5.343233] rga: rga3_core0_irq, irq = 33, match scheduler
[ 5.343700] rga: rga3_core0 driver loaded successfully ver:3.0.76831
[ 5.343719] rga: rga3_core0 probe successfully
[ 5.344012] rga3_core1 fdb70000.rga: Adding to iommu group 3
MAIN_DMA
[ 5.344165] rga: rga3_core1_irq, irq = 34, match scheduler
[ 5.344482] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA
[ 5.344511] rga: rga3_core1 driver loaded successfully ver:3.0.76831
[ 5.344528] rga: rga3_core1 probe successfully
[ 5.344845] rga: rga2_irq, irq = 35, match scheduler
[ 5.345252] rga: rga2 driver loaded successfully ver:3.2.63318
[ 5.345267] rga: rga2 probe successfully
[ 5.345878] rga: Module initialized. v1.2.15
[ 5.369596] pcie30_avdd1v8: supplied by avcc_1v8_s0
[ 5.369904] mali fb000000.gpu: Kernel DDK version g12p0-01eac0
[ 5.370234] pcie30_avdd0v75: supplied by avdd_0v75_s0
[ 5.370637] mali fb000000.gpu: leakage=15
[ 5.372271] mali fb000000.gpu: pvtm=858
[ 5.372417] mali fb000000.gpu: pvtm-volt-sel=2
[ 5.373131] rockchip-dmc dmc: leakage=37
[ 5.373149] rockchip-dmc dmc: leakage-volt-sel=1
[ 5.373362] mali fb000000.gpu: avs=0
[ 5.373491] rockchip-dmc dmc: avs=0
[ 5.373504] rockchip-dmc dmc: current ATF version 0x100
[ 5.373594] rockchip-dmc dmc: normal_rate = 1560000000
[ 5.373600] rockchip-dmc dmc: reboot_rate = 2112000000
[ 5.373614] rockchip-dmc dmc: suspend_rate = 528000000
[ 5.373620] rockchip-dmc dmc: video_4k_rate = 1560000000
[ 5.373626] rockchip-dmc dmc: video_4k_10b_rate = 1560000000
[ 5.373631] rockchip-dmc dmc: boost_rate = 2112000000
[ 5.373637] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000
[ 5.373643] rockchip-dmc dmc: performance_rate = 2112000000
[ 5.373652] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 5.373657] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 5.373787] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 5.373822] rockchip-dmc dmc: could not find power_model node
e_platform_rk_init(); power-off-delay-ms not available.
[ 5.375281] mali fb000000.gpu: GPU hardware issue table may need updating:
[ 5.375281] r0p0 status 5 is unknown; treating as r0p0 status 0
[ 5.375295] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0
[ 5.375383] mali fb000000.gpu: No priority control manager is configured
[ 5.375395] mali fb000000.gpu: No memory group manager is configured
[ 5.375426] mali fb000000.gpu: Protected memory allocator not available
[ 5.376815] mali fb000000.gpu: Couldn’t find power_model DT node matching ‘arm,mali-simple-power-model’
[ 5.376836] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0]
[ 5.377032] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0]
[ 5.377220] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0]
[ 5.377408] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = ‘’
[ 5.378286] register spi return v = :0
r-model
[ 5.380301] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
[ 5.380602] rkcif rkcif-mipi-lvds2: clear unready subdev num: 1
[ 5.380611] rockchip-csi2-dphy0: No link between dphy and sensor
[ 5.380852] rockchip-csi2-dphy0: No link between dphy and sensor
[ 5.380864] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 5.380874] rkcif-mipi-lvds2: Async subdev notifier completed
[ 5.380879] rockchip-csi2-dphy0: No link between dphy and sensor
[ 5.380887] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 5.380892] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
[ 5.380900] rockchip-csi2-dphy0: No link between dphy and sensor
[ 5.380922] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 5.380929] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
[ 5.381456] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.381822] mali fb000000.gpu: Probed as mali0
[ 5.382005] mmcblk0: mmc0:0001 Y0S128 116 GiB
[ 5.382134] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.382163] mmcblk0boot0: mmc0:0001 Y0S128 partition 1 4.00 MiB
[ 5.382295] mmcblk0boot1: mmc0:0001 Y0S128 partition 2 4.00 MiB
[ 5.382414] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[ 5.382431] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[ 5.382439] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[ 5.382466] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 69,32 bit host data width,256 deep fifo
[ 5.382518] mmcblk0rpmb: mmc0:0001 Y0S128 partition 3 16.0 MiB, chardev (234:0)
[ 5.385068] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 5.387401] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.387938] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.387946] cfg80211: failed to load regulatory.db
[ 5.388183] rockchip-pm rockchip-suspend: not set pwm-regulator-config
ule_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘16:32:33’, on ‘Apr 11 2023’.
[ 5.389219] Mali:
[ 5.389221] Mali device driver loaded
v? 5.390766]
[ 5.394643] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 5.473355] vendor storage:20190527 ret = 0
[END] 2024/9/24 14:02:24
