[root@tuhai:/oem/app]# ./syscore &
[1] 1160
[root@tuhai:/oem/app]# shmcfg_open 782
shmcfg_open 790
ascii [ascii.ttf]= 0x39180060
extra [hz.ttf]= 0x39182ed0
App Sysctrl Internal thread running …
[1] Syslog Service start …
[2] App Sysctrl UDP thread running [6000]…
register factory : rkmpp
register factory : video_enc
register factory : audio_enc
register factory : video_dec
register factory : file_read_flow
register factory : file_write_flow
register factory : filter
register factory : link_flow
register factory : source_stream
register factory : muxer_flow
register factory : audio_dec
register factory : output_stream
register factory : file_write_stream
register factory : file_read_stream
register factory : alsa_playback_stream
register factory : alsa_capture_stream
register factory : v4l2_capture_stream
register factory : v4l2_output_stream
register factory : drm_output_stream
rga_api version 1.10.0_[9]
register factory : rkrga
register factory : through_guard
[3] RK3588 Platform init …
rk-debug -----------------------Graphics so version=4.25.11-----------------------------
rk-debug init version=4.25.11,args[16,16,0], threadId=547931062688
arm_release_ver: g13p0-01eac0, rk_so_ver: 10
Failed creating base context during opening of kernel driver.
Kernel module may not have been loaded
eglInitialize() returned 0
[ 14.803597] tvp5150 2-005d: tvp5150_power: on 1
after eglInitialize() eglError (0x3001)
[ 14.803621] stream_cif_dvp_id0: open video, entity use_countt 1
eglInitialize failed
[ 14.805765] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[ 14.805802] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
rk-debug init version=4.25.11,args[16,16,0], threadId=547922608544
[ 14.805897] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[ 14.805907] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[ 14.805915] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[ 14.805923] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[ 14.805931] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[ 14.805940] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[ 14.805949] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[4] init sdk ok!
[ 14.805958] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[5] Module[./RK3588.so] load ok !
[ 14.805966] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
—vi->frame_width = 1024, vi->frame_height = 768 —
[ 14.806033] stream_cif_dvp_id0: open video, entity use_countt 2
---- VIDEO_INPUT_BT601 ----
[ 14.806142] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[6] – config dev 0 , vi->input_type = 1 –
[ 14.806155] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[7] — RK_MPI_VI_EnableDev success dev = 0 ----
[ 14.806165] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[8] Vi device init ok!
[ 14.806174] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
rockit log path (null), log_size = 0
[ 14.806183] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
log_file = (nil)
[ 14.806191] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
RTVersion 00:00:12-679 {dump :064} ---------------------------------------------------------
[ 14.806199] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
RTVersion 00:00:12-679 {dump :065} rockit version: git-e5c70ee41 Fri Sep 15 09:17:17 2023 +0800
[ 14.806207] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
RTVersion 00:00:12-679 {dump :066} rockit building: built-Chu 2023-09-15 11:40:17
[ 14.806215] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
RTVersion 00:00:12-679 {dump :067} ---------------------------------------------------------
[ 14.806225] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
–port = 0, ch = 0, video->width = 1024, video->height = 768
[ 14.806232] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[9] RK3588_vi_create port[0] ch[0] create ok!
[ 14.806287] stream_cif_dvp_id0: close video, entity use_count 1
[10] ---- port = 0, ch = 0—
[ 14.806510] tvp5150 2-005d: tvp5150_power: on 0
[ 14.806523] stream_cif_dvp_id0: close video, entity use_count 0
Using mplane plugin for capture
[ 14.808325] tvp5150 2-005d: tvp5150_power: on 1
[ 14.808336] stream_cif_dvp_id0: open video, entity use_countt 1
[ 14.808622] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
RKALG-I: InsertExtraBackendCreator 3
[ 14.808638] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
RKALG-I: --s-- rk_swcac_loglevl_set()
[ 14.808650] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
RTLibraryLoader 00:00:12-702 {load :080} failed to load library(librkAlgoDis.so) error: No such file or directory
[ 14.808660] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[11] RK3588_vi_start Port[0] Ch[0] start ok!
[ 14.808669] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[12] board setup ok!
[ 14.808682] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[ 14.808693] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
Start to feed watchdog!
[ 14.808702] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[13] Board Service start …
[ 14.808711] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[14] Module[./board.so] load ok !
[ 14.808719] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[15] Watchdog = On
[ 14.808728] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[ 14.809100] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[16] WATCH DOG ENABLED
[ 14.820215] rkcif-dvp: stream[0] start streaming
[ 14.820257] tvp5150 2-005d: tvp5150_get_fmt: 2001 1024x768
[17] Sys IR input thread running …
[ 14.824958] rkcif-dvp: Allocate dummy buffer, size: 0x01028000
— get frame succss port = 0, ch = 0, ret = 0 –
[ 14.831377] rkcif-dvp: set dual edge mode(off,0x200000)!!!
RTIsp3x 00:00:12-774 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:12-807 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:12-840 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:12-873 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:12-906 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:12-939 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:12-972 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-006 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-039 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-072 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-105 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-139 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-172 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-205 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-238 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-271 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-304 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-337 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-370 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-404 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-437 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-470 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-503 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-537 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-570 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-603 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-636 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-670 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-703 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-736 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-769 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-802 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-836 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-869 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-902 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-935 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:13-969 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:14-002 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:14-035 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:14-068 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:14-102 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:14-135 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:14-168 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:14-201 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:14-234 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:14-268 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:14-301 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
RTIsp3x 00:00:14-334 {getIspStreamInfo :342} request RKISP_CMD_GET_STREAM_INFO, err -1 : Invalid argument
[ 34.168384] vdd_gpu_s0: disabling
