rkmedia_vi_rknn_venc_rtsp_test执行失败
固件文件名称:CAM_CRV1126_1109S2U_UVCC_GPT_20220113_1518
Log日志:log.rar
[root@RV1126_RV1109:/]# rkmedia_vi_rknn_venc_rtsp_test -a /oem/etc/iqfiles/ -c /
oem/usr/share/rtsp-nn.cfg -b /oem/usr/share/rknn_model/box_priors.txt -l /oem/us
r/share/rknn_model/coco_labels_list.txt -p /oem/usr/share/rknn_model/ssd_incepti
on_v2_rv1109_rv1126.rknn
media get entity by name: stream_cif_dvp_id0 is null
media get entity by name: stream_cif_dvp_id1 is null
media get entity by name: stream_cif_dvp_id2 is null
media get entity by name: stream_cif_dvp_id3 is null
media get entity by name: rkcif-lvds-subdev is null
media get entity by name: rkcif-lite-lvds-subdev is null
media get entity by name: stream_cif is null
media get entity by name: rkcif-dvp-sof is null
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rkcif_dvp is null
media get entity by name: rkcif_mipi_lvds is null
media get entity by name: rkcif_lite_mipi_lvds is null
media get entity by name: rockchip-mipi-dphy-rx is null
[15:46:22.501123][CAMHW]:XCAM ERROR CamHwIsp20.cpp:1022: No free isp&ispp needed by fake camera!
register factory : rkmpp
register factory : live555_rtsp_server
register factory : video_enc
register factory : audio_enc
register factory : video_dec
register factory : file_read_flow
register factory : file_write_flow
register factory : filter
register factory : link_flow
register factory : source_stream
register factory : muxer_flow
register factory : audio_dec
register factory : output_stream
register factory : move_detec
register factory : occlusion_detec
register factory : file_write_stream
register factory : file_read_stream
register factory : alsa_playback_stream
register factory : alsa_capture_stream
register factory : v4l2_capture_stream
register factory : v4l2_output_stream
register factory : drm_output_stream
rga_api version 1.3.0_[11] (RGA is compiling with meson base: $PRODUCT_BASE)
register factory : rkrga
register factory : through_guard
register factory : ANR
register factory : AEC
register factory : rknn
register factory : rkaudio
register factory : rkaudio_aud
register factory : rkaudio_vid
register factory : rkaudio_resample
register factory : rkaudio_audio_fifo
cfg path is /oem/usr/share/rtsp-nn.cfg
BOX_PRIORS_TXT_PATH is /oem/usr/share/rknn_model/box_priors.txt
LABEL_NALE_TXT_PATH is /oem/usr/share/rknn_model/coco_labels_list.txt
MODEL_PATH is /oem/usr/share/rknn_model/ssd_inception_v2_rv1109_rv1126.rknn
#CameraIdx: 0
rtsp path = /live/main_stream.
video_type = 7.
width = 720.
height = 576.
video path =rkispp_scale1.
image type = 4.
rtsp path = /live/sub_stream.
video_type = 7.
width = 1920.
height = 1080.
video path =rkispp_scale0.
image type = 4.
xml dirpath: /oem/etc/iqfiles/
#bMultictx: 0
ID: 0, sensor_name is m00_f_gc2053 1-0037, iqfiles is /oem/etc/iqfiles/
[15:46:22.623057][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6920: calib_check_getID_by_name(6920): subtag: focusInfPosition from parent tag: zoomf
ocus_tbl is unknown, assert!!!
[15:46:22.623158][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6998: calib_check_tag_attrs(6998): parent_tag_id:439 tag_id:1201 — tag id is is wron
g: min:0 max:1201
[15:46:22.623207][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7044: calib_check_tag_attrs(7044): parent_tag_id:439 parent_tag_name:zoomfocus_tbl ta
g_id:1201 tag_name:unknown — ASSERT!!!
[15:46:22.623239][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7188: calib_check_tag_mark(7188): parent_tag_id:439 tag_id:1201 — tag_id is wrong:
min:0 max:1201
[15:46:22.623272][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6920: calib_check_getID_by_name(6920): subtag: focusMacroPosition from parent tag: zoo
mfocus_tbl is unknown, assert!!!
[15:46:22.623318][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6998: calib_check_tag_attrs(6998): parent_tag_id:439 tag_id:1201 — tag id is is wron
g: min:0 max:1201
[15:46:22.623376][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7044: calib_check_tag_attrs(7044): parent_tag_id:439 parent_tag_name:zoomfocus_tbl ta
[15:46:22.623436][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7188: calib_check_tag_mark(7188): parent_tag_id:439 tag_id:1201 — tag_id is wrong:
min:0 max:1201
[15:46:22.933508][XCORE]:XCAM ERROR v4l2_device.cpp:196: open device() failed
[15:46:22.936251][CAMHW]:XCAM ERROR LensHw.cpp:199: get vcm cfg failed
[15:46:22.960615][XCORE]:XCAM ERROR CamHwIsp20.cpp:3751: |||set DC-Iris PwmDuty: 100
[15:46:22.960715][CAMHW]:XCAM ERROR LensHw.cpp:411: iris is not supported
[15:46:22.960771][XCORE]:XCAM ERROR v4l2_device.cpp:657: device(/dev/video15) start failed
[15:46:22.960807][CAMHW]:XCAM ERROR CamHwIsp20.cpp:3319: prepare isp params dev err: -9
Segmentation fault (core dumped)
log.rar (1.44 KB)
