大家好,我是11月初就买了firefly-RK3288的板,从你们站上下载了android源代码编译后下载进去,系统反复重启。
开始以为是没有更新最新代码(因为我git pull bitbucket master:master重来没有完成过,速度很慢都是中途就断开了),
昨天又下载了最新的代码 (git clone -b firefly/master git://git.us.linux-rockchip.org/rk3288_r-box_android4.4.2_sdk.git)
但是今天把最新代码编译出来的img烧进去,还是系统反复重新启动,请高手指点,启动串口信息如下:
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-02 (Oct 30 2014 - 09:27:41)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2014-10-30#2.17
sn:1006110001000029
no fuel gauge found
no fuel gauge found
checkKey
vbus = 0
no fuel gauge found
failed to load fdt from boot!
kernel @ 0x02000000 (0x005f3cf0)
ramdisk @ 0x059fc000 (0x00120f04)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0561c000, end 05636f1c … OK
[ 0.000000] Linux version 3.10.0 (leo@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Thu Nov 20 17:24:20 CST 2014
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1eac000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2014-10-30_09:27:41 androidboot.serialno=1006110001000029
[ 0.000000] Memory: 2047124k/2047124k available, 50028k reserved, 1318912K highmem
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a6ea3c (10651 kB)
[ 0.000000] .init : 0xc0a6f000 - 0xc0cbd6c0 (2362 kB)
[ 0.000000] .data : 0xc0cbe000 - 0xc0d5ab48 ( 627 kB)
[ 0.000000] .bss : 0xc0d5ab48 - 0xc0e74d84 (1129 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rkclk_init_clks: cnt_rate = 32
[ 0.000000] Architected local timer running at 24.00MHz (phys).
[ 0.446564] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.446580] pid_max: default: 32768 minimum: 301
[ 0.446686] Security Framework initialized
[ 0.446701] SELinux: Initializing.
[ 0.446777] Mount-cache hash table entries: 512
[ 0.447408] Initializing cgroup subsys debug
[ 0.447423] Initializing cgroup subsys freezer
[ 0.447450] CPU: Testing write buffer coherency: ok
[ 0.447763] [url=]/cpus/cpu@0[/url] missing clock-frequency property
[ 0.447775] [url=]/cpus/cpu@1[/url] missing clock-frequency property
[ 0.447784] [url=]/cpus/cpu@2[/url] missing clock-frequency property
[ 0.447794] [url=]/cpus/cpu@3[/url] missing clock-frequency property
[ 0.447840] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.447891] Setting up static identity map for 0xc0785160 - 0xc07851b8
[ 0.450158] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x1368 (version 3.0)
[ 0.525257] CPU1: Booted secondary processor
[ 0.525290] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.544950] CPU2: Booted secondary processor
[ 0.544974] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.564652] CPU3: Booted secondary processor
[ 0.564675] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.564777] Brought up 4 CPUs
[ 0.564805] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.564815] CPU: All CPU(s) started in SVC mode.
[ 0.565549] devtmpfs: initialized
[ 0.570712] pinctrl core: initialized pinctrl subsystem
[ 0.570954] regulator-dummy: no parameters
[ 0.571457] NET: Registered protocol family 16
[ 0.573016] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.573273] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0e503d4 (version 0.1)
[ 0.573575] Registered FIQ tty driver
[ 0.574718] console [ttyFIQ0] enabled
[ 0.574929] Registered fiq debugger ttyFIQ0
[ 0.575437] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.575461] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.575481] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.575508] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.575605] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.575670] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.575733] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.575797] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.575858] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.575920] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.575982] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.576045] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.576114] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.576179] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.576195] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.576209] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.576224] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.576723] rockchip_interrupts_register:bank_num=7
[ 0.578617] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.578640] of_get_gpio_init_config:gpio[1] = 233, value = 0
[ 0.578663] of_get_gpio_init_config:gpio[2] = 136, value = 0
[ 0.578736] rockchip_pinctrl_probe:init ok
[ 0.584368] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.584487] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.584503] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.584668] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.584774] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.584789] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.584947] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.585052] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.585067] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.585224] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.585336] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.585352] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.585513] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.585639] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.585654] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.585808] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.585914] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.585930] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.586097] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.586220] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.586235] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.587833] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.587849] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.588053] DDR DEBUG: version 1.00 20140603
[ 0.588087] DDR DEBUG: Channel a:
[ 0.588098] DDR DEBUG: DDR3 Device
[ 0.588113] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.588125] DDR DEBUG: Channel b:
[ 0.588134] DDR DEBUG: DDR3 Device
[ 0.588147] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.588160] DDR DEBUG: addr=0xd60000
[ 0.588171] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.588183] DDR DEBUG: socAddr[0]=0xd60000, socAddr[1]=0xd60100
[ 0.588194] DDR DEBUG: chAddr[0]=0xd60000, chAddr[1]=0xd60000
[ 0.588207] DDR DEBUG: dtar[0]=0x1ac000, dtar[1]=0x1ac000
[ 0.588263] DDR DEBUG: init success!!! freq=200MHz
[ 0.588272] DDR DEBUG: Channel a:
[ 0.588286] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.588303] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.588319] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.588335] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.588350] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.588363] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.588375] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.588384] DDR DEBUG: Channel b:
[ 0.588397] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.588413] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.588429] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.588445] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.588460] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.588472] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.588483] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.609301] bio: create slab at 0
[ 0.609941] Enter firefly_noatx8_init
[ 0.610100] firefly_noatx8_probe 51
[ 0.610327] SCSI subsystem initialized
[ 0.610478] usbcore: registered new interface driver usbfs
[ 0.610522] usbcore: registered new interface driver hub
[ 0.610617] usbcore: registered new device driver usb
[ 0.611594] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.613024] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.613473] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.613944] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.614192] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.615066] media: Linux media interface: v0.10
[ 0.615110] Linux video capture interface: v2.00
[ 0.615158] pps_core: LinuxPPS API ver. 1 registered
[ 0.615171] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.615195] PTP clock support registered
[ 0.615427] rockchip_ion_parse_dt: num_heaps = 1
[ 0.615445] 0: 0 3 vmalloc 0x (null)
[ 0.615712] Rockchip ion module is successfully loaded (v1.0)
[ 0.615878] Advanced Linux Sound Architecture Driver Initialized.
[ 0.616270] Bluetooth: Core ver 2.16
[ 0.616311] NET: Registered protocol family 31
[ 0.616322] Bluetooth: HCI device and connection manager initialized
[ 0.616342] Bluetooth: HCI socket layer initialized
[ 0.616357] Bluetooth: L2CAP socket layer initialized
[ 0.616386] Bluetooth: SCO socket layer initialized
[ 0.616615] cfg80211: Calling CRDA to update world regulatory domain
[ 0.617203] act8846_i2c_probe,line=898
[ 0.618182] act8846_parse_dt,line=746
[ 0.618619] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.618643] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.618661] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.618678] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.620494] act_dcdc1: 1200 mV
[ 0.623189] vccio: 3300 mV
[ 0.625046] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.627728] act_dcdc4: 2000 mV
[ 0.628970] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.631023] act_ldo2: 1050 mV
[ 0.633083] act_ldo3: 1800 mV
[ 0.635142] act_ldo4: 3300 mV
[ 0.637190] act_ldo5: 3300 mV
[ 0.639245] act_ldo6: 1100 mV
[ 0.641313] vcc_18: 1800 mV
[ 0.643379] act_ldo8: 1850 mV
[ 0.648089] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.652737] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.653174] rk808_i2c_probe,line=1368
[ 0.654497] The device is not rk808 -11
[ 0.654585] rk808: probe of 0-001b failed with error -11
[ 0.655946] Switching to clocksource arch_sys_counter
[ 0.677367] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.677396] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.677881] rk-screen rk_screen.9: rockchip screen probe success
[ 0.678162] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.678379] rk32-edp ff970000.edp: screen is not edp!
[ 0.678402] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.678760] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.679077] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.679473] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.679654] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.679808] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.679960] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.680621] rk_iommu ff930300.vopb_mmu: (vopb) Enabled
[ 0.680775] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.680802] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.726434] alloc_buffer:ion_phy_addr=0x10000000
[ 0.739138] fb0:phy:10000000>>vir:f0191000>>len:0x1800000
[ 0.768886] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.769392] rockchip_set_mux:warning ignore bank num 15
[ 0.769533] rockchip_set_mux:warning ignore bank num 15
[ 0.769645] rockchip_set_mux:warning ignore bank num 15
[ 0.769765] rockchip_set_mux:warning ignore bank num 15
[ 0.769873] rockchip_set_mux:warning ignore bank num 15
[ 0.769986] rockchip_set_mux:warning ignore bank num 15
[ 0.770601] rockchip_set_mux:warning ignore bank num 15
[ 0.770775] rockchip_set_mux:warning ignore bank num 15
[ 0.771341] rockchip_set_mux:warning ignore bank num 15
[ 0.771487] rockchip_set_mux:warning ignore bank num 15
[ 0.772031] rockchip_set_mux:warning ignore bank num 15
[ 0.772173] rockchip_set_mux:warning ignore bank num 15
[ 0.772738] rockchip_set_mux:warning ignore bank num 15
[ 0.772893] rockchip_set_mux:warning ignore bank num 15
[ 0.774396] NET: Registered protocol family 2
[ 0.774893] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.775033] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.775170] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.775230] TCP: reno registered
[ 0.775248] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.775285] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.775496] NET: Registered protocol family 1
[ 0.775692] Unpacking initramfs…
[ 0.838504] Freeing initrd memory: 1152K (c59fc000 - c5b1c000)
[ 0.839125] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.839624] probe device ff9a0000.vpu_service
[ 0.839849] vpu_service: power on
[ 0.840920] checking hw id 4831
[ 0.841373] vpu_service set to auto frequency mode
[ 0.841436] vcodec vpu_service: vcodec ion client create success!
[ 0.841899] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 0.841932] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 0.841947] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26e000
[ 0.841962] vpu_service: power off…
[ 0.842002] done
[ 0.842012] init success
[ 0.842076] probe device ff9c0000.hevc_service
[ 0.842266] hevc_service: power on
[ 0.843330] checking hw id 6867
[ 0.843617] vcodec hevc_service: vcodec ion client create success!
[ 0.843902] rk_iommu ff9c0440.hevc_mmu: (hevc) Enabled
[ 0.843932] rk_iommu ff9c0440.hevc_mmu: (hevc) Disabled
[ 0.843947] rk_iommu ff9c0440.hevc_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26c000
[ 0.843960] hevc_service: power off…
[ 0.843998] done
[ 0.844007] init success
[ 0.844125] rknandbase v1.0 2014-03-31
[ 0.844340] rknand_probe clk rate = 148500000
[ 0.844451] rknand_driver:ret = 0
[ 0.844837] audit: initializing netlink socket (disabled)
[ 0.844884] type=2000 audit(0.400:1): initialized
[ 0.845705] bounce pool size: 64 pages
[ 0.850163] fuse init (API version 7.22)
[ 0.850558] msgmni has been set to 1456
[ 0.852544] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.852564] io scheduler noop registered
[ 0.852576] io scheduler deadline registered
[ 0.852669] io scheduler cfq registered (default)
[ 0.853530] rga ff920000.rga: rga ion client create success!
[ 0.853674] rga: Driver loaded succesfully
[ 0.854118] IEP Power ON
[ 0.854157] iep ion client create success!
[ 0.854525] rk_iommu ff900800.iep_mmu: (iep) Enabled
[ 0.854551] IEP Power OFF
[ 0.854565] rk_iommu ff900800.iep_mmu: (iep) Disabled
[ 0.854580] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e261000
[ 0.854598] IEP Driver loaded succesfully
[ 0.854702] Module initialized.
[ 0.855452] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.855472] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.856700] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.856720] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.856991] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
[ 0.857011] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
[ 0.857023] pwm_regulator_probe:error
[ 0.857047] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
[ 0.857390] rk_serial.c v1.8 2014-03-04
[ 0.857605] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.857798] serial ff180000.serial: membase 0xf015e000
[ 0.860564] loop: module loaded
[ 0.861170] SCSI Media Changer driver v0.25
[ 0.861462] tun: Universal TUN/TAP device driver, 1.6
[ 0.861476] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.862029] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.862048] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 0.862062] stmmac_probe_config_dt: clock input or output? (input).
[ 0.862075] stmmac_probe_config_dt: TX delay(0x30).
[ 0.862086] stmmac_probe_config_dt: RX delay(0x10).
[ 0.862125] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.862136] stmmc_pltfr_init:
[ 0.862146] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.862169] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed.
[ 0.862180] stmmc_pltfr_init: init for RGMII
[ 0.862192] tx delay=0x30
[ 0.862192] rx delay=0x10
[ 0.862628] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.862678] Normal descriptors
[ 0.862689] Ring mode enabled
[ 0.862699] DMA HW capability register supported
[ 0.862711] RX Checksum Offload Engine supported (type 2)
[ 0.862722] TX Checksum insertion supported
[ 0.862731] Wake-Up On Lan supported
[ 0.862775] Enable RX Mitigation via HW Watchdog Timer
[ 0.863190] PPP generic driver version 2.4.2
[ 0.863352] PPP BSD Compression module registered
[ 0.863365] PPP Deflate Compression module registered
[ 0.863388] PPP MPPE Compression module registered
[ 0.863401] NET: Registered protocol family 24
[ 0.863441] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.863455] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.863469] Rockchip WiFi SYS interface (V1.00) …
[ 0.863557] usbcore: registered new interface driver catc
[ 0.863596] usbcore: registered new interface driver kaweth
[ 0.863610] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.863646] usbcore: registered new interface driver pegasus
[ 0.863681] usbcore: registered new interface driver rtl8150
[ 0.863716] usbcore: registered new interface driver r8152
[ 0.863727] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.863798] usbcore: registered new interface driver hso
[ 0.863841] usbcore: registered new interface driver asix
[ 0.863879] usbcore: registered new interface driver ax88179_178a
[ 0.863916] usbcore: registered new interface driver cdc_ether
[ 0.863952] usbcore: registered new interface driver cdc_eem
[ 0.863986] usbcore: registered new interface driver dm9601
[ 0.864021] usbcore: registered new interface driver dm9620
[ 0.864078] usbcore: registered new interface driver smsc75xx
[ 0.864124] usbcore: registered new interface driver smsc95xx
[ 0.864160] usbcore: registered new interface driver gl620a
[ 0.864196] usbcore: registered new interface driver net1080
[ 0.864231] usbcore: registered new interface driver plusb
[ 0.864268] usbcore: registered new interface driver rndis_host
[ 0.864308] usbcore: registered new interface driver cdc_subset
[ 0.864345] usbcore: registered new interface driver zaurus
[ 0.864383] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.864442] usbcore: registered new interface driver int51x1
[ 0.864478] usbcore: registered new interface driver kalmia
[ 0.864514] usbcore: registered new interface driver ipheth
[ 0.864556] usbcore: registered new interface driver sierra_net
[ 0.864599] usbcore: registered new interface driver cx82310_eth
[ 0.864646] usbcore: registered new interface driver cdc_ncm
[ 0.864683] usbcore: registered new interface driver qmi_wwan
[ 0.864719] usbcore: registered new interface driver cdc_mbim
[ 0.864732] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.867123] ehci_rk_probe f1a00000 f1a00010
[ 0.867142] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
[ 0.867174] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.867516] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 0.882352] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
[ 0.882453] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.882471] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.882487] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
[ 0.882501] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 0.882515] usb usb1: SerialNumber: ff500000.usb
[ 0.882935] hub 1-0:1.0: USB hub found
[ 0.882962] hub 1-0:1.0: 1 port detected
[ 0.911861] ehci_rk_probe ok
[ 0.912012] usbcore: registered new interface driver cdc_acm
[ 0.912026] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.912079] usbcore: registered new interface driver usblp
[ 0.912121] usbcore: registered new interface driver cdc_wdm
[ 0.912188] usbcore: registered new interface driver usb-storage
[ 0.912227] usbcore: registered new interface driver ums-alauda
[ 0.912264] usbcore: registered new interface driver ums-cypress
[ 0.912300] usbcore: registered new interface driver ums-datafab
[ 0.912336] usbcore: registered new interface driver ums_eneub6250
[ 0.912371] usbcore: registered new interface driver ums-freecom
[ 0.912408] usbcore: registered new interface driver ums-isd200
[ 0.912443] usbcore: registered new interface driver ums-jumpshot
[ 0.912484] usbcore: registered new interface driver ums-karma
[ 0.912525] usbcore: registered new interface driver ums-onetouch
[ 0.912563] usbcore: registered new interface driver ums-sddr09
[ 0.912600] usbcore: registered new interface driver ums-sddr55
[ 0.912636] usbcore: registered new interface driver ums-usbat
[ 0.912723] usbcore: registered new interface driver usbserial
[ 0.912763] usbcore: registered new interface driver usbserial_generic
[ 0.912796] usbserial: USB Serial support registered for generic
[ 0.912835] usbcore: registered new interface driver option
[ 0.912871] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.912943] usbcore: registered new interface driver trancevibrator
[ 0.912956] usb20_otg: version 3.10a 21-DEC-2012
[ 0.913367] f1a80040
[ 0.913381] Core Release: 3.10a
[ 0.913393] Setting default values for core params
[ 0.913553] Using Buffer DMA mode
[ 0.913565] Periodic Transfer Interrupt Enhancement - disabled
[ 0.913577] Multiprocessor Interrupt Enhancement - disabled
[ 0.913589] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.913600] ^^^^^^^^^^^^^^^^^Device Mode
[ 0.913616] Dedicated Tx FIFOs mode
[ 0.913636] pcd_init otg_dev = ed9a2580
[ 0.913796] usb20_otg ff580000.usb: DWC OTG Controller
[ 0.913825] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 0.913859] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 0.913923] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.913940] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.913955] usb usb2: Product: DWC OTG Controller
[ 0.913968] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.913981] usb usb2: SerialNumber: ff580000.usb
[ 0.914385] hub 2-0:1.0: USB hub found
[ 0.914409] hub 2-0:1.0: 1 port detected
[ 0.914689] usb20_host: version 3.10a 21-DEC-2012
[ 0.917130] f1b00040
[ 0.917143] Core Release: 3.10a
[ 0.917153] Setting default values for core params
[ 0.917275] Using Buffer DMA mode
[ 0.917286] Periodic Transfer Interrupt Enhancement - disabled
[ 0.917297] Multiprocessor Interrupt Enhancement - disabled
[ 0.917309] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.917320] ^^^^^^^^^^^^^^^^^^Host Mode
[ 0.917346] usb20_host ff540000.usb: DWC OTG Controller
[ 0.917372] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 0.917407] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 0.917500] Init: Power Port (0)
[ 0.917559] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.917576] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.917590] usb usb3: Product: DWC OTG Controller
[ 0.917603] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.917616] usb usb3: SerialNumber: ff540000.usb
[ 0.917988] hub 3-0:1.0: USB hub found
[ 0.918010] hub 3-0:1.0: 1 port detected
[ 0.918544] .. rk pwm remotectl v1.0 init
[ 0.918640] remotectl probe j=0x0
[ 0.918796] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 0.918993] pwm enable val=0x646205
[ 0.919271] usbcore: registered new interface driver xpad
[ 0.919322] usbcore: registered new interface driver usb_acecad
[ 0.919364] usbcore: registered new interface driver aiptek
[ 0.919406] usbcore: registered new interface driver gtco
[ 0.919454] usbcore: registered new interface driver hanwang
[ 0.919497] usbcore: registered new interface driver kbtab
[ 0.919545] usbcore: registered new interface driver wacom
[ 0.919902] sensor_register_slave:mma8452,id=17
[ 0.919917] sensor_register_slave:cm3217,id=44
[ 0.919929] sensor_register_slave:cm3218,id=45
[ 0.924710] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 0.924762] i2c /dev entries driver
[ 0.925453] IR NEC protocol handler initialized
[ 0.925467] IR RC5(x) protocol handler initialized
[ 0.925478] IR RC6 protocol handler initialized
[ 0.925488] IR JVC protocol handler initialized
[ 0.925498] IR Sony protocol handler initialized
[ 0.925509] IR RC5 (streamzap) protocol handler initialized
[ 0.925519] IR SANYO protocol handler initialized
[ 0.925529] IR MCE Keyboard/mouse protocol handler initialized
[ 0.925622] usbcore: registered new interface driver uvcvideo
[ 0.925635] USB Video Class driver (1.1.1)
[ 0.926376] rockchip_temp_probe,line=362
[ 0.926717] tsadc ff280000.tsadc: initialized
[ 0.927105] device-mapper: uevent: version 1.0.3
[ 0.927358] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 0.927654] Bluetooth: HCI UART driver ver 2.2
[ 0.927670] Bluetooth: HCI H4 protocol initialized
[ 0.927682] Bluetooth: HCILL protocol initialized
[ 0.930745] cpufreq version 1.0, suspend freq 816 MHz
[ 0.930936] cpuidle: using governor ladder
[ 0.930951] cpuidle: using governor menu
[ 0.930988] Synopsys Designware Multimedia Card Interface Driver
[ 0.931236] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 0.931565] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 0.931728] 3230..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 0.931745] Line3235..dw_mci_init_slot: The rk_sdmmc Ver 1.12 2014-07-08
[ 0.931873] 1357..dw_mci_set_ios: no card. [mmc0]
[ 0.951211] 1357..dw_mci_set_ios: no card. [mmc0]
[ 0.970921] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 0.970942] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 0.970955] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 0.971164] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 0.972031] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 0.972149] 3224..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 0.972566] 1357..dw_mci_set_ios: no card. [mmc1]
[ 0.990575] 1357..dw_mci_set_ios: no card. [mmc1]
[ 1.003034] mmc0: BKOPS_EN bit is not set
[ 1.004920] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.007211] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.007234] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.010394] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.010407] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.010670] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.010842] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.010964] 3230..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.011046] 1357..dw_mci_set_ios: no card. [mmc2]
[ 1.022242] rk_sdmmc: BOOT
[ 1.022242] execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_0 SDMMC_SHIFT_DEGREE_90 SDMMC_SHIFT_DEGREE_180 SDMMC_SHIFT_DEGREE_INVALID[mmc0]
[ 1.022344] mmc0: new HS200 MMC card at address 0001
[ 1.022603] mmcblk0: mmc0:0001 AWMB3R 14.5 GiB
[ 1.022929] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.022941] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.022950] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.022959] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.022968] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.022977] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.022985] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.022994] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.023003] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.023012] system: 0x012400000 – 0x042400000 (768 MB)
[ 1.023020] metadata: 0x042400000 – 0x042800000 (4 MB)
[ 1.023029] userdata: 0x042800000 – 0x082800000 (1024 MB)
[ 1.023037] radical_update: 0x082800000 – 0x086800000 (64 MB)
[ 1.023046] user: 0x086800000 – 0x3a3a00000 (12754 MB)
[ 1.023077] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141357..dw_mci_set_ios: no card. [mmc1]
[ 1.029947] 1357..dw_mci_set_ios: no card. [mmc2]
[ 1.049625] 1357..dw_mci_set_ios: no card. [mmc2]
[ 1.049809] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.049823] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.050074] leds-gpio leds.31: pins are not configured from the driver
[ 1.050310] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.051591] usbcore: registered new interface driver usbhid
[ 1.051601] usbhid: USB HID core driver
[ 1.051904] ashmem: initialized
[ 1.052009] logger: created 256K log ‘log_main’
[ 1.052108] logger: created 256K log ‘log_events’
[ 1.052201] logger: created 256K log ‘log_radio’
[ 1.052293] logger: created 256K log ‘log_system’
[ 1.053286] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input1
[ 1.053866] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ; cannot claim for 2-0010
[ 1.053882] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.053894] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.053905] ES8323 2-0010: Error applying setting, reverse things back
[ 1.054199] es8323 probe i2c recv ok
[ 1.054407] i2c-core: driver [ES8323] using legacy suspend method
[ 1.054416] i2c-core: driver [ES8323] using legacy resume method
[ 1.054719] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
[ 1.054749] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 1.054768] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
[ 1.054998] es8323_probe
[ 1.055091] es8323_probe:register ISR (irq=194)
[ 1.689581] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 1.689594] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 1.689604] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 1.689613] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 1.689623] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 1.689631] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 1.689641] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 1.689649] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 1.689659] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 1.689667] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 1.689677] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 1.689685] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 1.689696] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 1.689704] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 1.689714] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 1.689723] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 1.689732] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 1.689742] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 1.689751] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 1.689759] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 1.689768] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 1.689776] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 1.689785] ES8323 2-0010: ASoC: no dapm match for Differentish Mu@rk->88AM $ → Right PGA Mux
[ 1.689793] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 1.689804] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 1.689812] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 1.689821] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 1.689829] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 1.689839] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 1.689847] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 1.689856] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 1.689864] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 1.689885] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 1.689894] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 1.689903] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 1.689911] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 1.689920] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 1.689928] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 1.689937] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 1.689946] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 1.689955] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 1.689963] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 1.689972] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 1.689980] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 1.690110] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 1.690122] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 1.690133] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 1.690143] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 1.690163] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 1.692713] Enter::rk29_es8323_init----123
[ 1.696086] rockchip-es8323 rockchip-es8323.29: ES8323 HiFi ↔ rockchip-i2s.0 mapping ok
[ 1.698188] u32 classifier
[ 1.698196] Actions configured
[ 1.698207] Netfilter messages via NETLINK v0.30.
[ 1.698262] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.698529] ctnetlink v0.93: registering with nfnetlink.
[ 1.698588] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.698595] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.698812] xt_time: kernel timezone is -0000
[ 1.698980] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.699113] arp_tables: (C) 2002 David S. Miller
[ 1.699145] TCP: cubic registered
[ 1.699152] Initializing XFRM netlink socket
[ 1.699338] NET: Registered protocol family 10
[ 1.699770] mip6: Mobile IPv6
[ 1.699793] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.699897] sit: IPv6 over IPv4 tunneling driver
[ 1.700192] NET: Registered protocol family 17
[ 1.700219] NET: Registered protocol family 15
[ 1.700266] Bridge firewalling registered
[ 1.700277] Ebtables v2.0 registered
[ 1.700427] Bluetooth: RFCOMM TTY layer initialized
[ 1.700461] Bluetooth: RFCOMM socket layer initialized
[ 1.700469] Bluetooth: RFCOMM ver 1.11
[ 1.700475] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.700481] Bluetooth: BNEP filters: protocol multicast
[ 1.700491] Bluetooth: BNEP socket layer initialized
[ 1.700498] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.700507] Bluetooth: HIDP socket layer initialized
[ 1.700532] l2tp_core: L2TP core driver, V2.0
[ 1.700544] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.700551] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.700739] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.700749] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.700756] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.700765] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.700773] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.700793] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.700812] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.700820] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.700844] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.700882] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.700928] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.701038] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 1.701053] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 1.701065] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 1.701078] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 1.701091] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 1.701134] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.701228] [BT_RFKILL]: ** disable irq
[ 1.701296] [BT_RFKILL]: ap6335 device registered.
[ 1.701896] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 1.702222] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 1.702242] rk3288_init_suspend
[ 1.702249] rk3288_suspend_init enter
[ 1.702373] rk3288_suspend_init: pm_ctrbits =40017
[ 1.702406] gpio_get_dts_info suspend:8
[ 1.702414] gpio_get_dts_info resume:8
[ 1.702419] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.702445] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.702568] clks_gating_suspend_init:clkgt info ok
[ 1.702642] Registering SWP/SWPB emulation handler
[ 1.702942] ddrfreq: verion 1.2 20140526
[ 1.702953] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 1.702961] ddrfreq: auto-freq=0
[ 1.702967] ddrfreq: auto-freq-table[0] 240MHz
[ 1.702972] ddrfreq: auto-freq-table[1] 324MHz
[ 1.702977] ddrfreq: auto-freq-table[2] 456MHz
[ 1.702983] ddrfreq: auto-freq-table[3] 528MHz
[ 1.704600] act_ldo3: operation not allowed
[ 1.704840] vga_edid_probe: turn on ldo3 done.
[ 1.704865] act_ldo4: operation not allowed
[ 1.705097] vga_edid_probe: turn on ldo done.
[ 1.705119] act_ldo2: operation not allowed
[ 1.705348] vga_edid_probe: turn on ldo2 done.
[ 1.705368] act_ldo8: operation not allowed
[ 1.705597] vga_edid_probe: turn on ldo done.
[ 1.708168] unable to read EDID block.
[ 1.708177] vga-ddc: read and parse edid failed errno:-5.
[ 1.708183] vga_edid_probe: success. 10
[ 1.708287] firefly_vga_get_enable 180, 0
[ 1.708294] firefly_vga_get_status 186
[ 1.708308] firefly_vga_set_enable 159 enable:1
[ 1.708323] firefly_vga_enable 130 start
[ 1.708329] firefly_switch_fb 55
[ 1.708335]
[ 1.708335] rk_fb_switch_screen lcdc_id 0 type 1 enable 1
[ 1.708346] fb0 win id 1 state 1
[ 1.708357] regulator-dummy: disabling
[ 1.708362] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 1.708379] fb1 win id 0 state 0
[ 1.708385] fb2 win id 2 state 0
[ 1.708390] fb3 win id 3 state 0
[ 1.708395] fb4 win id 4 state 0
[ 1.708400]
[ 1.708400] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done
[ 1.708400]
[ 1.708424] VGA ENABLE
[ 1.708617] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
[ 1.708640] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 1.708655] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
[ 1.708731] pcd_pullup, is_on 0
[ 1.708765] file system registered
[ 1.709332] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.709341] android_usb gadget: Number of LUNs=2
[ 1.709348] lun0: LUN: removable file: (no medium)
[ 1.709354] lun1: LUN: removable file: (no medium)
[ 1.709469] android_usb gadget: android_usb ready
[ 1.709543] sensor_init: Probe name sensors
[ 1.709557] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.710084] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:01:23 UTC (1293883283)
[ 1.715424] usbcore: registered new interface driver snd-usb-audio
[ 1.715445] ALSA device list:
[ 1.715451] #0: RK_ES8323
[ 1.716702] Freeing unused kernel memory: 2360K (c0a6f000 - c0cbd000)
[ 1.717077] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
[ 1.721249] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 1.721261] SELinux: the above unknown classes and permissions will be denied
[ 1.977549] type=1403 audit(1293883283.760:2): policy loaded auid=4294967295 ses=4294967295
[ 1.977649] SELinux: Loaded policy from /sepolicy
[ 1.979073] type=1404 audit(1293883283.760:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 2.889707] dwc_otg_hcd_enable, enable host controller
[ 2.919239] init: init.rk30board.bootmode.emmc.rc: 8: invalid command ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc’
[ 2.919256] init: init.rk30board.bootmode.emmc.rc: 9: invalid command ‘/devices/ff0c0000.rksdmmc/mmc_host/mmc’
[ 2.919268] init: init.rk30board.bootmode.emmc.rc: 10: invalid command ‘/devices/ff580000.usb’
[ 2.919279] init: init.rk30board.bootmode.emmc.rc: 11: invalid command ‘/devices/ff580000.usb’
[ 2.919289] init: init.rk30board.bootmode.emmc.rc: 12: invalid command ‘/devices/ff500000.usb’
[ 2.919299] init: init.rk30board.bootmode.emmc.rc: 13: invalid command ‘/devices/ff500000.usb’
[ 2.919309] init: init.rk30board.bootmode.emmc.rc: 14: invalid command ‘/devices/ff540000.usb’
[ 2.919318] init: init.rk30board.bootmode.emmc.rc: 15: invalid command ‘/devices/ff540000.usb’
[ 2.919604] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 2.970014] init: /dev/hw_random not found
[ 2.970071] keychord: using input dev ff680000.pwm for fevent
[ 2.970080] keychord: using input dev rk29-keypad for fevent
[ 2.974829] fs_mgr: parse_link_device : path = NULL
[ 2.974851] fs_mgr: parse_link_device : path = NULL
[ 2.974880] fs_mgr: parse_link_device : path = NULL
[ 2.974897] fs_mgr: parse_link_device : path = NULL
[ 2.974914] fs_mgr: parse_link_device : path = NULL
[ 2.974930] fs_mgr: parse_link_device : path = NULL
[ 2.974945] fs_mgr: parse_link_device : path = NULL
[ 2.974960] fs_mgr: parse_link_device : path = NULL
[ 2.975036] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.975793] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
[ 2.982575] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.993186] EXT4-fs (mmcblk0p8): recovery complete
[ 2.993667] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.995531] EXT4-fs (mmcblk0p11): recovery complete
[ 2.995542] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.004252] Using Buffer DMA mode
[ 3.004261] Periodic Transfer Interrupt Enhancement - disabled
[ 3.004267] Multiprocessor Interrupt Enhancement - disabled
[ 3.004273] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.004279] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.007039] EXT4-fs (mmcblk0p12): recovery complete
[ 3.007533] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.012815] drmboot: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 3.017966] mali pd enabled
[ 3.017978] clk enabled
[ 3.017988] MALI_DVFS_STEP=4,div_dvfs=10
[ 3.017995] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 3.018002] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 3.018009] mali_dvfs_infotbl[2].clock=313000,min_threshold=86,max_threshold=90
[ 3.018016] mali_dvfs_infotbl[3].clock=480000,min_threshold=88,max_threshold=100
[ 3.018115] turn on mali power
[ 3.018137] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 3.018512] mali ffa30000.gpu: Probed as mali0
[ 3.020793] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 3.029003] init: /dev/hw_random not found
[ 3.034672] binder: 136:136 transaction failed 29189, size 0-0
[ 3.035219] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
[ 3.037641] init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
[ 3.039202] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
[ 3.040154] init: cannot find ‘/system/bin/bindvbplayservice’, disabling ‘dvbdataserv’
[ 3.040538] init: cannot find ‘/system/bin/chrome.sh’, disabling ‘chrome’
[ 3.040849] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 3.047219] Init: Power Port (0)
[ 3.078924] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.078943] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 3.079096] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 3.101251] =======================================================
[ 3.101262] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 3.101268] =======================================================
[ 3.101274] WiFi driver (Powered by Rockchip,Ver 4.80.WFD.OOB) init.
[ 3.101298] ======== PULL WL_REG_ON HIGH! ========
[ 3.101304] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.101310] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 3.101316] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.177383] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 3.179147] fs_mgr: parse_link_device : path = NULL
[ 3.179173] fs_mgr: parse_link_device : path = NULL
[ 3.179191] fs_mgr: parse_link_device : path = NULL
[ 3.179208] fs_mgr: parse_link_device : path = NULL
[ 3.179224] fs_mgr: parse_link_device : path = NULL
[ 3.179241] fs_mgr: parse_link_device : path = NULL
[ 3.179269] fs_mgr: parse_link_device : path = NULL
[ 3.179288] fs_mgr: parse_link_device : path = NULL
[ 3.204583] [WLAN_RFKILL]: wifi turn on power. 156
[ 3.204596] mmc2:mmc host rescan start!
[ 3.204607] =========== WLAN placed in POWER ON ========
[ 3.204626] bcmsdh_register: Linux Kernel SDIO/MMC Driver
[ 3.204707]
[ 3.204707] Dongle Host Driver, version 1.88.45.3 (r420671)
[ 3.204707] Compiled in drivers/net/wireless/bcmdhd on Nov 20 2014 at 17:23:41
[ 3.275416] firefly_vga_get_enable 180, 1
[ 3.275506] firefly_vga_get_status 186
[ 3.304691] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
[ 3.304720] init: powerctl: cannot expand ‘${sys.powerctl}’
[ 3.3047
DDR Version 1.00 20141007
Memory OK
Memory OK
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
sn:1006110001000029
no fuel gauge found
no fuel gauge found
checkKey
vbus = 0
no fuel gauge found
[ 0.443972] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.443988] pid_max: default: 32768 minimum: 301
[ 0.444093] Security Framework initialized
[ 0.444110] SELinux: Initializing.
[ 0.444185] Mount-cache hash table entries: 512
[ 0.444823] Initializing cgroup subsys debug
[ 0.444838] Initializing cgroup subsys freezer
[ 0.444866] CPU: Testing write buffer coherency: ok
[ 0.445169] [url=]/cpus/cpu@0[/url] missing clock-frequency property
[ 0.445181] [url=]/cpus/cpu@1[/url] missing clock-frequency property
[ 0.445190] [url=]/cpus/cpu@2[/url] missing clock-frequency property
[ 0.445199] [url=]/cpus/cpu@3[/url] missing clock-frequency property
[ 0.445247] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.445297] Setting up static identity map for 0xc0785160 - 0xc07851b8
[ 0.447597] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x1368 (version 3.0)
[ 0.522678] CPU1: Booted secondary processor
[ 0.522711] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.542368] CPU2: Booted secondary processor
[ 0.542393] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.562066] CPU3: Booted secondary processor
[ 0.562090] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.562192] Brought up 4 CPUs
[ 0.562220] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.562229] CPU: All CPU(s) started in SVC mode.
[ 0.562965] devtmpfs: initialized
[ 0.568162] pinctrl core: initialized pinctrl subsystem
[ 0.568406] regulator-dummy: no parameters
[ 0.568909] NET: Registered protocol family 16
[ 0.570455] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.570711] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0e503d4 (version 0.1)
[ 0.571012] Registered FIQ tty driver
[ 0.572186] console [ttyFIQ0] enabled
[ 0.572394] Registered fiq debugger ttyFIQ0
[ 0.572901] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.572926] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.572946] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.572974] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.573070] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.573137] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.573200] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.573261] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.573323] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.573384] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.573446] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.573508] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.573578] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.573643] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.573659] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.573674] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.573688] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.574184] rockchip_interrupts_register:bank_num=7
[ 0.576084] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.576108] of_get_gpio_init_config:gpio[1] = 233, value = 0
[ 0.576131] of_get_gpio_init_config:gpio[2] = 136, value = 0
[ 0.576205] rockchip_pinctrl_probe:init ok
[ 0.581836] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.581958] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.581974] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.582138] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.582246] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.582262] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.582420] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.582526] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.582541] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.582697] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.582806] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.582822] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.582982] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.583107] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.583122] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.583279] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.583384] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.583400] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.583568] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.583692] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.583707] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.585314] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.585331] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.585536] DDR DEBUG: version 1.00 20140603
[ 0.585568] DDR DEBUG: Channel a:
[ 0.585578] DDR DEBUG: DDR3 Device
[ 0.585594] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.585606] DDR DEBUG: Channel b:
[ 0.585615] DDR DEBUG: DDR3 Device
[ 0.585628] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.585641] DDR DEBUG: addr=0xd60000
[ 0.585652] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.585663] DDR DEBUG: socAddr[0]=0xd60000, socAddr[1]=0xd60100
[ 0.585675] DDR DEBUG: chAddr[0]=0xd60000, chAddr[1]=0xd60000
[ 0.585688] DDR DEBUG: dtar[0]=0x1ac000, dtar[1]=0x1ac000
[ 0.585744] DDR DEBUG: init success!!! freq=200MHz
[ 0.585753] DDR DEBUG: Channel a:
[ 0.585767] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.585784] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.585801] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.585817] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.585833] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.585845] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.585857] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.585866] DDR DEBUG: Channel b:
[ 0.585879] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.585895] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.585911] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.585927] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.585942] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.585954] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.585965] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.606797] bio: create slab at 0
[ 0.607433] Enter firefly_noatx8_init
[ 0.607593] firefly_noatx8_probe 51
[ 0.607817] SCSI subsystem initialized
[ 0.607970] usbcore: registered new interface driver usbfs
[ 0.608015] usbcore: registered new interface driver hub
[ 0.608109] usbcore: registered new device driver usb
[ 0.609087] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.610518] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.610964] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.611445] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.611690] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.612556] media: Linux media interface: v0.10
[ 0.612599] Linux video capture interface: v2.00
[ 0.612648] pps_core: LinuxPPS API ver. 1 registered
[ 0.612661] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.612685] PTP clock support registered
[ 0.612912] rockchip_ion_parse_dt: num_heaps = 1
[ 0.612930] 0: 0 3 vmalloc 0x (null)
[ 0.613193] Rockchip ion module is successfully loaded (v1.0)
[ 0.613359] Advanced Linux Sound Architecture Driver Initialized.
[ 0.613747] Bluetooth: Core ver 2.16
[ 0.613786] NET: Registered protocol family 31
[ 0.613798] Bluetooth: HCI device and connection manager initialized
[ 0.613816] Bluetooth: HCI socket layer initialized
[ 0.613832] Bluetooth: L2CAP socket layer initialized
[ 0.613862] Bluetooth: SCO socket layer initialized
[ 0.614091] cfg80211: Calling CRDA to update world regulatory domain
[ 0.614681] act8846_i2c_probe,line=898
[ 0.615658] act8846_parse_dt,line=746
[ 0.616093] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.616115] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.616133] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.616151] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.617966] act_dcdc1: 1200 mV
[ 0.620660] vccio: 3300 mV
[ 0.622515] vdd_logic: 700 ↔ 1500 mV at 1125 mV
[ 0.625197] act_dcdc4: 2000 mV
[ 0.626440] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.628494] act_ldo2: 1050 mV
[ 0.630556] act_ldo3: 1800 mV
[ 0.632616] act_ldo4: 3300 mV
[ 0.634664] act_ldo5: 3300 mV
[ 0.636719] act_ldo6: 1100 mV
[ 0.638789] vcc_18: 1800 mV
[ 0.640854] act_ldo8: 1850 mV
[ 0.645560] vdd_arm: 712 ↔ 1500 mV at 1350 mV
[ 0.650206] vdd_gpu: 712 ↔ 1500 mV at 1150 mV
[ 0.650645] rk808_i2c_probe,line=1368
[ 0.651967] The device is not rk808 -11
[ 0.652052] rk808: probe of 0-001b failed with error -11
[ 0.653416] Switching to clocksource arch_sys_counter
[ 0.674974] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.675002] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.675482] rk-screen rk_screen.9: rockchip screen probe success
[ 0.675769] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.675993] rk32-edp ff970000.edp: screen is not edp!
[ 0.676016] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.676371] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.676682] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.677095] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.677276] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.677426] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.677581] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.678238] rk_iommu ff930300.vopb_mmu: (vopb) Enabled
[ 0.678394] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.678420] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.723875] alloc_buffer:ion_phy_addr=0x10000000
[ 0.736600] fb0:phy:10000000>>vir:f0191000>>len:0x1800000
[ 0.773688] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.774178] rockchip_set_mux:warning ignore bank num 15
[ 0.774318] rockchip_set_mux:warning ignore bank num 15
[ 0.774433] rockchip_set_mux:warning ignore bank num 15
[ 0.774561] rockchip_set_mux:warning ignore bank num 15
[ 0.774671] rockchip_set_mux:warning ignore bank num 15
[ 0.774784] rockchip_set_mux:warning ignore bank num 15
[ 0.775394] rockchip_set_mux:warning ignore bank num 15
[ 0.775567] rockchip_set_mux:warning ignore bank num 15
[ 0.776123] rockchip_set_mux:warning ignore bank num 15
[ 0.776269] rockchip_set_mux:warning ignore bank num 15
[ 0.776813] rockchip_set_mux:warning ignore bank num 15
[ 0.776956] rockchip_set_mux:warning ignore bank num 15
[ 0.777518] rockchip_set_mux:warning ignore bank num 15
[ 0.777672] rockchip_set_mux:warning ignore bank num 15
[ 0.779156] NET: Registered protocol family 2
[ 0.779655] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.779793] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.779930] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.779989] TCP: reno registered
[ 0.780006] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.780043] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.780256] NET: Registered protocol family 1
[ 0.780450] Unpacking initramfs…
[ 0.843202] Freeing initrd memory: 1152K (c59fc000 - c5b1c000)
[ 0.843821] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.844319] probe device ff9a0000.vpu_service
[ 0.844537] vpu_service: power on
[ 0.845607] checking hw id 4831
[ 0.846061] vpu_service set to auto frequency mode
[ 0.846125] vcodec vpu_service: vcodec ion client create success!
[ 0.846595] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 0.846626] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 0.846642] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26e000
[ 0.846656] vpu_service: power off…
[ 0.846696] done
[ 0.846706] init success
[ 0.846770] probe device ff9c0000.hevc_service
[ 0.846956] hevc_service: power on
[ 0.848019] checking hw id 6867
[ 0.848298] vcodec hevc_service: vcodec ion client create success!
[ 0.848580] rk_iommu ff9c0440.hevc_mmu: (hevc) Enabled
[ 0.848610] rk_iommu ff9c0440.hevc_mmu: (hevc) Disabled
[ 0.848625] rk_iommu ff9c0440.hevc_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26c000
[ 0.848638] hevc_service: power off…
[ 0.848676] done
[ 0.848686] init success
[ 0.848799] rknandbase v1.0 2014-03-31
[ 0.849000] rknand_probe clk rate = 148500000
[ 0.849110] rknand_driver:ret = 0
[ 0.849493] audit: initializing netlink socket (disabled)
[ 0.849541] type=2000 audit(0.400:1): initialized
[ 0.850386] bounce pool size: 64 pages
[ 0.854833] fuse init (API version 7.22)
[ 0.855235] msgmni has been set to 1456
[ 0.857206] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.857225] io scheduler noop registered
[ 0.857237] io scheduler deadline registered
[ 0.857329] io scheduler cfq registered (default)
[ 0.858175] rga ff920000.rga: rga ion client create success!
[ 0.858330] rga: Driver loaded succesfully
[ 0.858777] IEP Power ON
[ 0.858816] iep ion client create success!
[ 0.859186] rk_iommu ff900800.iep_mmu: (iep) Enabled
[ 0.859213] IEP Power OFF
[ 0.859227] rk_iommu ff900800.iep_mmu: (iep) Disabled
[ 0.859243] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e261000
[ 0.859261] IEP Driver loaded succesfully
[ 0.859354] Module initialized.
[ 0.860139] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.860159] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.861389] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.861410] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.861675] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
[ 0.861694] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
[ 0.861707] pwm_regulator_probe:error
[ 0.861730] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
[ 0.862086] rk_serial.c v1.8 2014-03-04
[ 0.862302] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.862491] serial ff180000.serial: membase 0xf015e000
[ 0.865248] loop: module loaded
[ 0.865857] SCSI Media Changer driver v0.25
[ 0.866165] tun: Universal TUN/TAP device driver, 1.6
[ 0.866179] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.866707] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.866725] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 0.866739] stmmac_probe_config_dt: clock input or output? (input).
[ 0.866752] stmmac_probe_config_dt: TX delay(0x30).
[ 0.866764] stmmac_probe_config_dt: RX delay(0x10).
[ 0.866802] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.866813] stmmc_pltfr_init:
[ 0.866823] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.866846] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed.
[ 0.866857] stmmc_pltfr_init: init for RGMII
[ 0.866869] tx delay=0x30
[ 0.866869] rx delay=0x10
[ 0.867306] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.867319] Normal descriptors
[ 0.867329] Ring mode enabled
[ 0.867339] DMA HW capability register supported
[ 0.867351] RX Checksum Offload Engine supported (type 2)
[ 0.867362] TX Checksum insertion supported
[ 0.867371] Wake-Up On Lan supported
[ 0.867407] Enable RX Mitigation via HW Watchdog Timer
[ 0.867826] PPP generic driver version 2.4.2
[ 0.867971] PPP BSD Compression module registered
[ 0.867985] PPP Deflate Compression module registered
[ 0.868008] PPP MPPE Compression module registered
[ 0.868021] NET: Registered protocol family 24
[ 0.868057] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.868071] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.868085] Rockchip WiFi SYS interface (V1.00) …
[ 0.868182] usbcore: registered new interface driver catc
[ 0.868220] usbcore: registered new interface driver kaweth
[ 0.868234] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.868276] usbcore: registered new interface driver pegasus
[ 0.868313] usbcore: registered new interface driver rtl8150
[ 0.868348] usbcore: registered new interface driver r8152
[ 0.868360] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.868427] usbcore: registered new interface driver hso
[ 0.868478] usbcore: registered new interface driver asix
[ 0.868515] usbcore: registered new interface driver ax88179_178a
[ 0.868552] usbcore: registered new interface driver cdc_ether
[ 0.868587] usbcore: registered new interface driver cdc_eem
[ 0.868621] usbcore: registered new interface driver dm9601
[ 0.868656] usbcore: registered new interface driver dm9620
[ 0.868713] usbcore: registered new interface driver smsc75xx
[ 0.868759] usbcore: registered new interface driver smsc95xx
[ 0.868795] usbcore: registered new interface driver gl620a
[ 0.868831] usbcore: registered new interface driver net1080
[ 0.868867] usbcore: registered new interface driver plusb
[ 0.868904] usbcore: registered new interface driver rndis_host
[ 0.868939] usbcore: registered new interface driver cdc_subset
[ 0.868979] usbcore: registered new interface driver zaurus
[ 0.869018] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.869079] usbcore: registered new interface driver int51x1
[ 0.869116] usbcore: registered new interface driver kalmia
[ 0.869152] usbcore: registered new interface driver ipheth
[ 0.869193] usbcore: registered new interface driver sierra_net
[ 0.869229] usbcore: registered new interface driver cx82310_eth
[ 0.869281] usbcore: registered new interface driver cdc_ncm
[ 0.869319] usbcore: registered new interface driver qmi_wwan
[ 0.869356] usbcore: registered new interface driver cdc_mbim
[ 0.869369] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.871752] ehci_rk_probe f1a00000 f1a00010
[ 0.871769] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
[ 0.871807] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.872211] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 0.889660] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
[ 0.889744] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.889762] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.889777] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
[ 0.889792] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 0.889805] usb usb1: SerialNumber: ff500000.usb
[ 0.890276] hub 1-0:1.0: USB hub found
[ 0.890301] hub 1-0:1.0: 1 port detected
[ 0.919170] ehci_rk_probe ok
[ 0.919325] usbcore: registered new interface driver cdc_acm
[ 0.919339] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.919394] usbcore: registered new interface driver usblp
[ 0.919437] usbcore: registered new interface driver cdc_wdm
[ 0.919505] usbcore: registered new interface driver usb-storage
[ 0.919544] usbcore: registered new interface driver ums-alauda
[ 0.919581] usbcore: registered new interface driver ums-cypress
[ 0.919617] usbcore: registered new interface driver ums-datafab
[ 0.919653] usbcore: registered new interface driver ums_eneub6250
[ 0.919689] usbcore: registered new interface driver ums-freecom
[ 0.919725] usbcore: registered new interface driver ums-isd200
[ 0.919761] usbcore: registered new interface driver ums-jumpshot
[ 0.919796] usbcore: registered new interface driver ums-karma
[ 0.919832] usbcore: registered new interface driver ums-onetouch
[ 0.919873] usbcore: registered new interface driver ums-sddr09
[ 0.919914] usbcore: registered new interface driver ums-sddr55
[ 0.919952] usbcore: registered new interface driver ums-usbat
[ 0.920040] usbcore: registered new interface driver usbserial
[ 0.920081] usbcore: registered new interface driver usbserial_generic
[ 0.920114] usbserial: USB Serial support registered for generic
[ 0.920152] usbcore: registered new interface driver option
[ 0.920183] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.920261] usbcore: registered new interface driver trancevibrator
[ 0.920274] usb20_otg: version 3.10a 21-DEC-2012
[ 0.920668] f1a80040
[ 0.920681] Core Release: 3.10a
[ 0.920693] Setting default values for core params
[ 0.920842] Using Buffer DMA mode
[ 0.920855] Periodic Transfer Interrupt Enhancement - disabled
[ 0.920867] Multiprocessor Interrupt Enhancement - disabled
[ 0.920879] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.920890] ^^^^^^^^^^^^^^^^^Device Mode
[ 0.920904] Dedicated Tx FIFOs mode
[ 0.920923] pcd_init otg_dev = ed9c1300
[ 0.921067] usb20_otg ff580000.usb: DWC OTG Controller
[ 0.921103] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 0.921135] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 0.921200] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.921218] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.921233] usb usb2: Product: DWC OTG Controller
[ 0.921246] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.921259] usb usb2: SerialNumber: ff580000.usb
[ 0.921663] hub 2-0:1.0: USB hub found
[ 0.921686] hub 2-0:1.0: 1 port detected
[ 0.921968] usb20_host: version 3.10a 21-DEC-2012
[ 0.924403] f1b00040
[ 0.924416] Core Release: 3.10a
[ 0.924427] Setting default values for core params
[ 0.924553] Using Buffer DMA mode
[ 0.924565] Periodic Transfer Interrupt Enhancement - disabled
[ 0.924576] Multiprocessor Interrupt Enhancement - disabled
[ 0.924588] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.924598] ^^^^^^^^^^^^^^^^^^Host Mode
[ 0.924623] usb20_host ff540000.usb: DWC OTG Controller
[ 0.924649] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 0.924684] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 0.924776] Init: Power Port (0)
[ 0.924833] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.924850] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.924865] usb usb3: Product: DWC OTG Controller
[ 0.924878] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.924891] usb usb3: SerialNumber: ff540000.usb
[ 0.925275] hub 3-0:1.0: USB hub found
[ 0.925302] hub 3-0:1.0: 1 port detected
[ 0.925845] .. rk pwm remotectl v1.0 init
[ 0.925941] remotectl probe j=0x0
[ 0.926099] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 0.926294] pwm enable val=0x646205
[ 0.926568] usbcore: registered new interface driver xpad
[ 0.926621] usbcore: registered new interface driver usb_acecad
[ 0.926664] usbcore: registered new interface driver aiptek
[ 0.926705] usbcore: registered new interface driver gtco
[ 0.926747] usbcore: registered new interface driver hanwang
[ 0.926787] usbcore: registered new interface driver kbtab
[ 0.926839] usbcore: registered new interface driver wacom
[ 0.927173] sensor_register_slave:mma8452,id=17
[ 0.927188] sensor_register_slave:cm3217,id=44
[ 0.927200] sensor_register_slave:cm3218,id=45
[ 0.931889] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 0.931942] i2c /dev entries driver
[ 0.932606] IR NEC protocol handler initialized
[ 0.932619] IR RC5(x) protocol handler initialized
[ 0.932631] IR RC6 protocol handler initialized
[ 0.932642] IR JVC protocol handler initialized
[ 0.932652] IR Sony protocol handler initialized
[ 0.932662] IR RC5 (streamzap) protocol handler initialized
[ 0.932673] IR SANYO protocol handler initialized
[ 0.932683] IR MCE Keyboard/mouse protocol handler initialized
[ 0.932768] usbcore: registered new interface driver uvcvideo
[ 0.932781] USB Video Class driver (1.1.1)
[ 0.933533] rockchip_temp_probe,line=362
[ 0.933854] tsadc ff280000.tsadc: initialized
[ 0.934222] device-mapper: uevent: version 1.0.3
[ 0.934466] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 0.934756] Bluetooth: HCI UART driver ver 2.2
[ 0.934772] Bluetooth: HCI H4 protocol initialized
[ 0.934784] Bluetooth: HCILL protocol initialized
[ 0.940003] cpufreq version 1.0, suspend freq 816 MHz
[ 0.940197] cpuidle: using governor ladder
[ 0.940210] cpuidle: using governor menu
[ 0.940248] Synopsys Designware Multimedia Card Interface Driver
[ 0.940493] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 0.940780] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 0.940943] 3230..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 0.940960] Line3235..dw_mci_init_slot: The rk_sdmmc Ver 1.12 2014-07-08
[ 0.941096] 1357..dw_mci_set_ios: no card. [mmc0]
[ 0.958541] 1357..dw_mci_set_ios: no card. [mmc0]
[ 0.978251] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 0.978294] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 0.978314] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 0.978604] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 0.979401] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 0.979568] 3224..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 0.980046] 1357..dw_mci_set_ios: no card. [mmc1]
[ 0.997897] 1357..dw_mci_set_ios: no card. [mmc1]
[ 1.010365] mmc0: BKOPS_EN bit is not set
[ 1.012252] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.014541] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.014565] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.017712] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.017726] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.017993] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.018163] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.018275] 3230..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.018355] 1357..dw_mci_set_ios: no card. [mmc2]
[ 1.029569] rk_sdmmc: BOOT
[ 1.029569] execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_0 SDMMC_SHIFT_DEGREE_90 SDMMC_SHIFT_DEGREE_180 SDMMC_SHIFT_DEGREE_INVALID[mmc0]
[ 1.029670] mmc0: new HS200 MMC card at address 0001
[ 1.029931] mmcblk0: mmc0:0001 AWMB3R 14.5 GiB
[ 1.030237] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.030250] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.030259] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.030269] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.030277] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.030286] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.030295] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.030303] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.030312] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.030320] system: 0x012400000 – 0x042400000 (768 MB)
[ 1.030329] metadata: 0x042400000 – 0x042800000 (4 MB)
[ 1.030337] userdata: 0x042800000 – 0x082800000 (1024 MB)
[ 1.030346] radical_update: 0x082800000 – 0x086800000 (64 MB)
[ 1.030355] user: 0x086800000 – 0x3a3a00000 (12754 MB)
[ 1.030380] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141357..dw_mci_set_ios: no card. [mmc1]
[ 1.037258] 1357..dw_mci_set_ios: no card. [mmc2]
[ 1.056934] 1357..dw_mci_set_ios: no card. [mmc2]
[ 1.057140] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.057154] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.057408] leds-gpio leds.31: pins are not configured from the driver
[ 1.057637] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.058926] usbcore: registered new interface driver usbhid
[ 1.058937] usbhid: USB HID core driver
[ 1.059236] ashmem: initialized
[ 1.059335] logger: created 256K log ‘log_main’
[ 1.059428] logger: created 256K log ‘log_events’
[ 1.059521] logger: created 256K log ‘log_radio’
[ 1.059613] logger: created 256K log ‘log_system’
[ 1.060591] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input1
[ 1.061178] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ; cannot claim for 2-0010
[ 1.061194] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.061205] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.061216] ES8323 2-0010: Error applying setting, reverse things back
[ 1.061501] es8323 probe i2c recv ok
[ 1.061709] i2c-core: driver [ES8323] using legacy suspend method
[ 1.061718] i2c-core: driver [ES8323] using legacy resume method
[ 1.062022] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
[ 1.062052] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 1.062071] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
[ 1.062311] es8323_probe
[ 1.062407] es8323_probe:register ISR (irq=194)
[ 1.696891] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 1.696903] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 1.696914] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 1.696923] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 1.696932] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 1.696940] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 1.696950] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 1.696958] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 1.696967] ES8323 2-0010: ASoC: no dapm match for RINellTrk3->8:UL$ → Right Line Mux
[ 1.696975] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 1.696983] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 1.696991] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 1.697001] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 1.697008] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 1.697017] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 1.697025] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 1.697034] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 1.697042] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 1.697051] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 1.697059] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 1.697068] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 1.697075] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 1.697084] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 1.697092] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 1.697102] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 1.697109] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 1.697118] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 1.697126] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 1.697134] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 1.697142] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 1.697151] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 1.697158] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 1.697178] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 1.697186] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 1.697194] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 1.697202] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 1.697210] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 1.697218] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 1.697227] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 1.697234] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 1.697243] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 1.697250] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 1.697259] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 1.697267] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 1.697405] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 1.697416] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 1.697426] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 1.697436] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 1.697461] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 1.700014] Enter::rk29_es8323_init----123
[ 1.703307] rockchip-es8323 rockchip-es8323.29: ES8323 HiFi ↔ rockchip-i2s.0 mapping ok
[ 1.705406] u32 classifier
[ 1.705413] Actions configured
[ 1.705425] Netfilter messages via NETLINK v0.30.
[ 1.705488] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.705765] ctnetlink v0.93: registering with nfnetlink.
[ 1.705822] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.705830] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.706059] xt_time: kernel timezone is -0000
[ 1.706225] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.706333] arp_tables: (C) 2002 David S. Miller
[ 1.706389] TCP: cubic registered
[ 1.706396] Initializing XFRM netlink socket
[ 1.706584] NET: Registered protocol family 10
[ 1.707017] mip6: Mobile IPv6
[ 1.707044] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.707150] sit: IPv6 over IPv4 tunneling driver
[ 1.707443] NET: Registered protocol family 17
[ 1.707465] NET: Registered protocol family 15
[ 1.707508] Bridge firewalling registered
[ 1.707519] Ebtables v2.0 registered
[ 1.707666] Bluetooth: RFCOMM TTY layer initialized
[ 1.707689] Bluetooth: RFCOMM socket layer initialized
[ 1.707695] Bluetooth: RFCOMM ver 1.11
[ 1.707702] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.707708] Bluetooth: BNEP filters: protocol multicast
[ 1.707718] Bluetooth: BNEP socket layer initialized
[ 1.707725] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.707734] Bluetooth: HIDP socket layer initialized
[ 1.707757] l2tp_core: L2TP core driver, V2.0
[ 1.707769] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.707776] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.707955] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.707964] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.707972] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.707981] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.707989] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.708008] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.708028] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.708035] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.708061] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.708099] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.708141] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.708256] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 1.708271] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 1.708283] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 1.708296] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 1.708308] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 1.708350] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.708441] [BT_RFKILL]: ** disable irq
[ 1.708511] [BT_RFKILL]: ap6335 device registered.
[ 1.709070] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 1.709385] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 1.709403] rk3288_init_suspend
[ 1.709411] rk3288_suspend_init enter
[ 1.709535] rk3288_suspend_init: pm_ctrbits =40017
[ 1.709564] gpio_get_dts_info suspend:8
[ 1.709571] gpio_get_dts_info resume:8
[ 1.709576] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.709601] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.709725] clks_gating_suspend_init:clkgt info ok
[ 1.709804] Registering SWP/SWPB emulation handler
[ 1.710104] ddrfreq: verion 1.2 20140526
[ 1.710117] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 1.710124] ddrfreq: auto-freq=0
[ 1.710130] ddrfreq: auto-freq-table[0] 240MHz
[ 1.710135] ddrfreq: auto-freq-table[1] 324MHz
[ 1.710141] ddrfreq: auto-freq-table[2] 456MHz
[ 1.710146] ddrfreq: auto-freq-table[3] 528MHz
[ 1.711802] act_ldo3: operation not allowed
[ 1.712039] vga_edid_probe: turn on ldo3 done.
[ 1.712074] act_ldo4: operation not allowed
[ 1.712307] vga_edid_probe: turn on ldo done.
[ 1.712330] act_ldo2: operation not allowed
[ 1.712560] vga_edid_probe: turn on ldo2 done.
[ 1.712581] act_ldo8: operation not allowed
[ 1.712809] vga_edid_probe: turn on ldo done.
[ 1.715380] unable to read EDID block.
[ 1.715390] vga-ddc: read and parse edid failed errno:-5.
[ 1.715396] vga_edid_probe: success. 10
[ 1.715497] firefly_vga_get_enable 180, 0
[ 1.715505] firefly_vga_get_status 186
[ 1.715518] firefly_vga_set_enable 159 enable:1
[ 1.715534] firefly_vga_enable 130 start
[ 1.715540] firefly_switch_fb 55
[ 1.715547]
[ 1.715547] rk_fb_switch_screen lcdc_id 0 type 1 enable 1
[ 1.715558] fb0 win id 1 state 1
[ 1.715568] regulator-dummy: disabling
[ 1.715574] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 1.715591] fb1 win id 0 state 0
[ 1.715597] fb2 win id 2 state 0
[ 1.715603] fb3 win id 3 state 0
[ 1.715608] fb4 win id 4 state 0
[ 1.715613]
[ 1.715613] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done
[ 1.715613]
[ 1.715637] VGA ENABLE
[ 1.715818] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
[ 1.715842] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 1.715856] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
[ 1.715932] pcd_pullup, is_on 0
[ 1.715969] file system registered
[ 1.716499] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.716508] android_usb gadget: Number of LUNs=2
[ 1.716515] lun0: LUN: removable file: (no medium)
[ 1.716521] lun1: LUN: removable file: (no medium)
[ 1.716634] android_usb gadget: android_usb ready
[ 1.716706] sensor_init: Probe name sensors
[ 1.716720] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.717245] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:01:31 UTC (1293883291)
[ 1.722601] usbcore: registered new interface driver snd-usb-audio
[ 1.722617] ALSA device list:
[ 1.722622] #0: RK_ES8323
[ 1.723897] Freeing unused kernel memory: 2360K (c0a6f000 - c0cbd000)
[ 1.724283] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
[ 1.728430] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 1.728442] SELinux: the above unknown classes and permissions will be denied
[ 2.004542] type=1403 audit(1293883291.780:2): policy loaded auid=4294967295 ses=4294967295
[ 2.004640] SELinux: Loaded policy from /sepolicy
[ 2.006072] type=1404 audit(1293883291.780:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 2.897004] dwc_otg_hcd_enable, enable host controller
[ 2.948782] init: init.rk30board.bootmode.emmc.rc: 8: invalid command ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc’
[ 2.948799] init: init.rk30board.bootmode.emmc.rc: 9: invalid command ‘/devices/ff0c0000.rksdmmc/mmc_host/mmc’
[ 2.948811] init: init.rk30board.bootmode.emmc.rc: 10: invalid command ‘/devices/ff580000.usb’
[ 2.948822] init: init.rk30board.bootmode.emmc.rc: 11: invalid command ‘/devices/ff580000.usb’
[ 2.948832] init: init.rk30board.bootmode.emmc.rc: 12: invalid command ‘/devices/ff500000.usb’
[ 2.948842] init: init.rk30board.bootmode.emmc.rc: 13: invalid command ‘/devices/ff500000.usb’
[ 2.948852] init: init.rk30board.bootmode.emmc.rc: 14: invalid command ‘/devices/ff540000.usb’
[ 2.948862] init: init.rk30board.bootmode.emmc.rc: 15: invalid command ‘/devices/ff540000.usb’
[ 2.949137] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 2.999521] init: /dev/hw_random not found
[ 2.999578] keychord: using input dev ff680000.pwm for fevent
[ 2.999587] keychord: using input dev rk29-keypad for fevent
[ 3.000370] Using Buffer DMA mode
[ 3.000378] Periodic Transfer Interrupt Enhancement - disabled
[ 3.000384] Multiprocessor Interrupt Enhancement - disabled
[ 3.000391] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.000396] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.004494] fs_mgr: parse_link_device : path = NULL
[ 3.004519] fs_mgr: parse_link_device : path = NULL
[ 3.004545] fs_mgr: parse_link_device : path = NULL
[ 3.004562] fs_mgr: parse_link_device : path = NULL
[ 3.004578] fs_mgr: parse_link_device : path = NULL
[ 3.004597] fs_mgr: parse_link_device : path = NULL
[ 3.004613] fs_mgr: parse_link_device : path = NULL
[ 3.004628] fs_mgr: parse_link_device : path = NULL
[ 3.004685] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 3.005821] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
[ 3.011489] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 3.017698] EXT4-fs (mmcblk0p8): recovery complete
[ 3.018184] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.020056] EXT4-fs (mmcblk0p11): recovery complete
[ 3.020067] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.037165] EXT4-fs (mmcblk0p12): recovery complete
[ 3.037656] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.042842] drmboot: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 3.044674] Init: Power Port (0)
[ 3.047958] mali pd enabled
[ 3.047972] clk enabled
[ 3.047982] MALI_DVFS_STEP=4,div_dvfs=10
[ 3.047988] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 3.047996] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 3.048002] mali_dvfs_infotbl[2].clock=313000,min_threshold=86,max_threshold=90
[ 3.048010] mali_dvfs_infotbl[3].clock=480000,min_threshold=88,max_threshold=100
[ 3.048103] turn on mali power
[ 3.048123] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 3.048488] mali ffa30000.gpu: Probed as mali0
[ 3.050806] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 3.059172] init: /dev/hw_random not found
[ 3.064811] binder: 135:135 transaction failed 29189, size 0-0
[ 3.065321] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
[ 3.067697] init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
[ 3.069270] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
[ 3.070166] init: cannot find ‘/system/bin/bindvbplayservice’, disabling ‘dvbdataserv’
[ 3.070510] init: cannot find ‘/system/bin/chrome.sh’, disabling ‘chrome’
[ 3.070862] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 3.072607] init: property ‘ro.serialno’ doesn’t exist
