摄像头OV8858的log,大家帮助分析下为什么打不开?谢谢。
shell@rk3288:/ $ [ 49.983600] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 49.983639] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 49.983656] D1:camsys_open(739): camsys_marvin(c599d810) is opened!
[ 49.983816] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 49.983842] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x2000000 success!
[ 49.983905] rockchip_gpio_set:GPIO7-13 level = 1
[ 49.983917] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 49.983934] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 49.983951] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x2034,result=0x2034
[ 49.983966] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 49.983991] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
[ 49.989084] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 49.989104] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 49.989215] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 49.989260] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 49.990348] D1:camsys_sysctl_extdev(349): Sysctl 11 success, gpio(17) set 1
[ 49.991421] E:camsys_sysctl_extdev(356): Sysctl 8 failed, because gpio is NULL!
[ 49.992519] D1:camsys_sysctl_extdev(353): Sysctl 7 success, gpio(78) set 1
[ 49.995874] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 49.997221] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 49.997353] D1:camsys_sysctl_extdev(349): Sysctl 7 success, gpio(78) set 0
[ 49.997372] E:camsys_sysctl_extdev(356): Sysctl 8 failed, because gpio is NULL!
[ 49.997395] D1:camsys_sysctl_extdev(353): Sysctl 11 success, gpio(17) set 0
[ 49.998514] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 49.998567] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 50.000645] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 50.000671] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 50.000688] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 50.000702] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 50.000716] D1:camsys_release(763): camsys_marvin(c599d810) is closed
[ 50.006909] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 50.006931] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 50.006947] D1:camsys_open(739): camsys_marvin(c599d810) is opened!
[ 50.007101] E:camsys_extdev_register(208): Get NC鞣 regulator for dev_id 0x2000000 failed!
[ 50.007138] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 50.007156] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 50.007170] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 50.007184] D1:camsys_release(763): camsys_marvin(c599d810) is closed
<?xml version="1.0" ?> `
有解决了吗
i2c 不通
检查mclk
