AIO-3588jd4编译rtlinux镜像,内核崩溃无法启动
我买的AIO-3588JD4主板,根据客服提供的rtlinux源码,编译出来的实时操作系统镜像,在安装后,内核崩溃无法启动
[ 74.418731] pwr 0x014c: 0000fffe 00002411 00000000 00000000
[ 74.418740] status 0x0180: 2411fffe 00000000 00000000 00000000
[ 74.418749] req 0x010c: 000017f0 0000000a 00000000 000a1ffe
[ 74.418757] idle 0x0120: 000a1ffe 00000000 0000ffff 0000ffff
[ 74.418765] ack 0x0118: 000a1ffe 00000000 000a1ffe 00000000
[ 74.418773] mem_pwr 0x01a0: 00000000 00000000 00000000 00000000
[ 74.418780] chain_st 0x01f0: ee0001ff 000003db 11fffe00 00000024
[ 74.418788] mem_st 0x01f8: 11fffe00 00000024 00000203 0000ffff
[ 74.418796] repair_st 0x0290: faf70003 000381ff 00000000 00000000
[ 74.418806] rockchip-thermal fec00000.tsadc: channal 0: temperature(61 C)
[ 74.418812] THERMAL REGS:
[ 74.418819] 00000000: 00000100 00000001 0000000f 0000007f 00000000 00000001 00000000 0000007f
[ 74.418828] 00000020: 00000000 0000007e 00000000 00000144 00000144 00000144 00000144 00000143
[ 74.418837] 00000040: 00000143 00000144 00000000 00000000 00000000 00000000 00000000 00000000
[ 74.418846] 00000060: 00000000 00000000 00000000 00000153 00000000 00000000 00000000 00000000
[ 74.418851] 00000080: 00000000 00000000
[ 74.418854] Kernel Offset: disabled
[ 74.418856] CPU features: 0x000,48000026,6a00aa18
[ 74.418860] Memory Limit: none
[ 74.418868] cpu cpu6: cur_freq: 408000000 Hz, volt_vdd: 675000 uV, volt_mem: 675000 uV
[ 74.418874] cpu cpu4: cur_freq: 408000000 Hz, volt_vdd: 675000 uV, volt_mem: 675000 uV
[ 74.418880] cpu cpu0: cur_freq: 1416000000 Hz, volt_vdd: 737500 uV, volt_mem: 737500 uV
[ 253.435427] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[ 253.435433] rcu: 0-…0: (1 GPs behind) idle=4e6/1/0x4000000000000000 softirq=83/84 fqs=24003
[ 253.435453] (detected by 6, t=72009 jiffies, g=-991, q=114)
[ 253.435461] Task dump for CPU 0:
[ 253.435465] task:kworker/u16:2 state:R running task stack: 0 pid: 229 ppid: 2 flags:0x0000000a
[ 253.435483] Workqueue: events_unbound async_run_entry_fn
[ 253.435498] Call trace:
[ 253.435501] __switch_to+0xf8/0x170
[ 253.435515] __device_attach_async_helper+0x94/0x100
[ 253.435531] CPU0 online:1
[ 253.435537] EL2(NS) PC: <0xffffffc008bfadec> regmap_mmio_read32le+0xc/0x30
[ 253.435686]
[ 253.435688] CPU1 online:1
[ 253.435693] EL2(NS) PC: <0xffffffc0094b2d74> __cpu_do_idle+0x4/0x10
[ 253.435841]
[ 253.435842] CPU2 online:1
[ 253.435848] EL2(NS) PC: <0xffffffc0094b2d74> __cpu_do_idle+0x4/0x10
[ 253.435993]
[ 253.435994] CPU3 online:1
[ 253.435999] EL2(NS) PC: <0xffffffc008269954> unmap_kernel_range+0x54/0x90
[ 253.436149]
[ 253.436151] CPU4 online:1
[ 253.436156] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 253.436310]
[ 253.436312] CPU5 online:1
[ 253.436316] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 253.436471]
[ 253.436472] CPU6 online:1
[ 253.436477] EL2(NS) PC: <0xffffffc00898ceb4> rockchip_panic_notify+0x364/0x440
[ 253.436633]
[ 253.436634] CPU7 online:1
[ 253.436639] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 253.436793]
[ 253.436802] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 253.436819] 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic
[ 253.436831] 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer
[ 253.436842] 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer
[ 253.436854] 13: 693 75595 76734 1349 3621 3892 75560 25511 GICv3 26 Level arch_timer
[ 253.436864] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 253.436875] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 253.436889] 23: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 253.436901] 26: 274 0 0 0 0 0 0 0 GICv3 349 Level fd880000.i2c
[ 253.436912] 27: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 253.436922] 28: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 253.436932] 29: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 253.436943] 30: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 253.436953] 31: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 253.436964] 32: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu, rga3_core0
[ 253.436975] 33: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu, rga3_core1
[ 253.436985] 34: 0 0 0 0 0 0 0 0 GICv3 148 Level rga2
[ 253.436996] 35: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 253.437006] 36: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 253.437017] 37: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 253.437027] 38: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 253.437037] 39: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 253.437047] 40: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 253.437058] 41: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 253.437068] 42: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 253.437078] 43: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 253.437088] 44: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 253.437099] 45: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 253.437110] 46: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 253.437120] 47: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 253.437130] 48: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 253.437141] 49: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 253.437151] 50: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 253.437161] 51: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 253.437171] 52: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 253.437181] 53: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 253.437191] 54: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 253.437202] 55: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 253.437212] 56: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 253.437224] 59: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 253.437234] 60: 0 0 0 0 0 0 0 0 GICv3 163 Level rkisp_hw
[ 253.437244] 61: 0 0 0 0 0 0 0 0 GICv3 165 Level rkisp_hw
[ 253.437254] 62: 0 0 0 0 0 0 0 0 GICv3 166 Level rkisp_hw
[ 253.437264] 63: 0 0 0 0 0 0 0 0 GICv3 164 Level fdcb7f00.iommu
[ 253.437274] 64: 0 0 0 0 0 0 0 0 GICv3 187 Level rkcifhw
[ 253.437284] 65: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 253.437295] 66: 0 0 0 0 0 0 0 0 GICv3 175 Level rockchip-mipi-csi2-hw
[ 253.437305] 67: 0 0 0 0 0 0 0 0 GICv3 176 Level rockchip-mipi-csi2-hw
[ 253.437316] 68: 0 0 0 0 0 0 0 0 GICv3 177 Level rockchip-mipi-csi2-hw
[ 253.437326] 69: 0 0 0 0 0 0 0 0 GICv3 178 Level rockchip-mipi-csi2-hw
[ 253.437337] 70: 0 0 0 0 0 0 0 0 GICv3 179 Level rockchip-mipi-csi2-hw
[ 253.437347] 71: 0 0 0 0 0 0 0 0 GICv3 180 Level rockchip-mipi-csi2-hw
[ 253.437357] 72: 0 0 0 0 0 0 0 0 GICv3 181 Level rockchip-mipi-csi2-hw
[ 253.437368] 73: 0 0 0 0 0 0 0 0 GICv3 182 Level rockchip-mipi-csi2-hw
[ 253.437378] 74: 0 0 0 0 0 0 0 0 GICv3 183 Level rockchip-mipi-csi2-hw
[ 253.437388] 75: 0 0 0 0 0 0 0 0 GICv3 184 Level rockchip-mipi-csi2-hw
[ 253.437398] 76: 0 0 0 0 0 0 0 0 GICv3 185 Level rockchip-mipi-csi2-hw
[ 253.437409] 77: 0 0 0 0 0 0 0 0 GICv3 186 Level rockchip-mipi-csi2-hw
[ 253.437420] 78: 52 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu, fdd90000.vop
[ 253.437430] 79: 0 0 0 0 0 0 0 0 GICv3 217 Level i2s
[ 253.437440] 80: 0 0 0 0 0 0 0 0 GICv3 201 Level fde80000.hdmi
[ 253.437451] 82: 0 0 0 0 0 0 0 0 GICv3 203 Level fde80000.hdmi
[ 253.437461] 83: 264 0 0 0 0 0 0 0 GICv3 204 Level fde80000.hdmi
[ 253.437471] 84: 0 0 0 0 0 0 0 0 GICv3 392 Level dw-hdmi-qp-hpd
[ 253.437484] 89: 89 0 0 0 0 0 0 0 GICv3 237 Level mmc0
[ 253.437495] 91: 0 0 0 0 0 0 0 0 GICv3 212 Level i2s
[ 253.437505] 92: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 253.437516] 93: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 253.437526] 94: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 253.437537] 95: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 253.437547] 96: 0 0 0 0 0 0 0 0 GICv3 374 Level can0
[ 253.437557] 97: 18 0 0 0 0 0 0 0 GICv3 350 Level fea90000.i2c
[ 253.437568] 98: 20 0 0 0 0 0 0 0 GICv3 352 Level feab0000.i2c
[ 253.437578] 99: 0 0 0 0 0 0 0 0 GICv3 353 Level feac0000.i2c
[ 253.437588] 100: 0 0 0 0 0 0 0 0 GICv3 347 Edge feaf0000.watchdog
[ 253.437599] 101: 415 0 0 0 0 0 0 0 GICv3 360 Level feb20000.spi
[ 253.437611] 105: 0 0 0 0 0 0 0 0 GICv3 429 Level rockchip_thermal
[ 253.437621] 106: 0 0 0 0 0 0 0 0 GICv3 430 Level fec10000.saradc
[ 253.437632] 107: 56 0 0 0 0 0 0 0 GICv3 355 Level fec80000.i2c
[ 253.437642] 108: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 253.437652] 109: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 253.437663] 110: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 253.437673] 111: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 253.437683] 112: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 253.437693] 113: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 253.437703] 114: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 253.437714] 116: 0 0 0 0 0 0 0 0 GICv3 218 Level i2s
[ 253.437724] 117: 0 0 0 0 0 0 0 0 GICv3 219 Level i2s
[ 253.437737] 123: 0 0 0 0 0 0 0 0 GICv3 290 Level pcie-sys
[ 253.437748] 126: 0 0 0 0 0 0 0 0 GICv3 287 Level (null)
[ 253.437760] 130: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 253.437771] 131: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 253.437782] 132: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 7 Level rk806
[ 253.437793] 133: 0 0 0 0 0 0 0 0 rk806 0 Edge rk805_pwrkey_fall
[ 253.437803] 134: 0 0 0 0 0 0 0 0 rk806 1 Edge rk805_pwrkey_rise
[ 253.437814] 135: 0 0 0 0 0 0 0 0 rk806 7 Level rk806_vb_low
[ 253.437825] 136: 0 0 0 0 0 0 0 0 GICv3 252 Level xhci-hcd:usb1
[ 253.437836] 138: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 8 Level hym8563
[ 253.437847] 139: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 19 Edge headset_detect
[ 254.438109] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 254.438121] 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic
[ 254.438131] 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer
[ 254.438142] 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer
[ 254.438153] 13: 693 75895 77039 1349 3630 3892 75560 25611 GICv3 26 Level arch_timer
[ 254.438163] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 254.438173] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 254.438187] 23: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 254.438199] 26: 274 0 0 0 0 0 0 0 GICv3 349 Level fd880000.i2c
[ 254.438209] 27: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 254.438219] 28: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 254.438229] 29: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 254.438239] 30: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 254.438250] 31: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 254.438260] 32: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu, rga3_core0
[ 254.438271] 33: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu, rga3_core1
[ 254.438281] 34: 0 0 0 0 0 0 0 0 GICv3 148 Level rga2
[ 254.438291] 35: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 254.438301] 36: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 254.438311] 37: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 254.438322] 38: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 254.438332] 39: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 254.438342] 40: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 254.438352] 41: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 254.438362] 42: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 254.438372] 43: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 254.438383] 44: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 254.438393] 45: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 254.438404] 46: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 254.438414] 47: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 254.438424] 48: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 254.438434] 49: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 254.438444] 50: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 254.438454] 51: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 254.438465] 52: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 254.438475] 53: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 254.438486] 54: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 254.438495] 55: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 254.438506] 56: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 254.438517] 59: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 254.438527] 60: 0 0 0 0 0 0 0 0 GICv3 163 Level rkisp_hw
[ 254.438537] 61: 0 0 0 0 0 0 0 0 GICv3 165 Level rkisp_hw
[ 254.438547] 62: 0 0 0 0 0 0 0 0 GICv3 166 Level rkisp_hw
[ 254.438557] 63: 0 0 0 0 0 0 0 0 GICv3 164 Level fdcb7f00.iommu
[ 254.438567] 64: 0 0 0 0 0 0 0 0 GICv3 187 Level rkcifhw
[ 254.438577] 65: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 254.438587] 66: 0 0 0 0 0 0 0 0 GICv3 175 Level rockchip-mipi-csi2-hw
[ 254.438598] 67: 0 0 0 0 0 0 0 0 GICv3 176 Level rockchip-mipi-csi2-hw
[ 254.438608] 68: 0 0 0 0 0 0 0 0 GICv3 177 Level rockchip-mipi-csi2-hw
[ 254.438619] 69: 0 0 0 0 0 0 0 0 GICv3 178 Level rockchip-mipi-csi2-hw
[ 254.438629] 70: 0 0 0 0 0 0 0 0 GICv3 179 Level rockchip-mipi-csi2-hw
[ 254.438639] 71: 0 0 0 0 0 0 0 0 GICv3 180 Level rockchip-mipi-csi2-hw
[ 254.438649] 72: 0 0 0 0 0 0 0 0 GICv3 181 Level rockchip-mipi-csi2-hw
[ 254.438659] 73: 0 0 0 0 0 0 0 0 GICv3 182 Level rockchip-mipi-csi2-hw
[ 254.438669] 74: 0 0 0 0 0 0 0 0 GICv3 183 Level rockchip-mipi-csi2-hw
[ 254.438680] 75: 0 0 0 0 0 0 0 0 GICv3 184 Level rockchip-mipi-csi2-hw
[ 254.438690] 76: 0 0 0 0 0 0 0 0 GICv3 185 Level rockchip-mipi-csi2-hw
[ 254.438700] 77: 0 0 0 0 0 0 0 0 GICv3 186 Level rockchip-mipi-csi2-hw
[ 254.438710] 78: 52 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu, fdd90000.vop
[ 254.438721] 79: 0 0 0 0 0 0 0 0 GICv3 217 Level i2s
[ 254.438731] 80: 0 0 0 0 0 0 0 0 GICv3 201 Level fde80000.hdmi
[ 254.438742] 82: 0 0 0 0 0 0 0 0 GICv3 203 Level fde80000.hdmi
[ 254.438752] 83: 264 0 0 0 0 0 0 0 GICv3 204 Level fde80000.hdmi
[ 254.438762] 84: 0 0 0 0 0 0 0 0 GICv3 392 Level dw-hdmi-qp-hpd
[ 254.438775] 89: 89 0 0 0 0 0 0 0 GICv3 237 Level mmc0
[ 254.438786] 91: 0 0 0 0 0 0 0 0 GICv3 212 Level i2s
[ 254.438796] 92: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 254.438806] 93: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 254.438817] 94: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 254.438827] 95: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 254.438837] 96: 0 0 0 0 0 0 0 0 GICv3 374 Level can0
[ 254.438847] 97: 18 0 0 0 0 0 0 0 GICv3 350 Level fea90000.i2c
[ 254.438857] 98: 20 0 0 0 0 0 0 0 GICv3 352 Level feab0000.i2c
[ 254.438868] 99: 0 0 0 0 0 0 0 0 GICv3 353 Level feac0000.i2c
[ 254.438878] 100: 0 0 0 0 0 0 0 0 GICv3 347 Edge feaf0000.watchdog
[ 254.438889] 101: 415 0 0 0 0 0 0 0 GICv3 360 Level feb20000.spi
[ 254.438900] 105: 0 0 0 0 0 0 0 0 GICv3 429 Level rockchip_thermal
[ 254.438911] 106: 0 0 0 0 0 0 0 0 GICv3 430 Level fec10000.saradc
[ 254.438921] 107: 56 0 0 0 0 0 0 0 GICv3 355 Level fec80000.i2c
[ 254.438931] 108: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 254.438941] 109: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 254.438952] 110: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 254.438962] 111: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 254.438971] 112: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 254.438982] 113: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 254.438992] 114: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 254.439002] 116: 0 0 0 0 0 0 0 0 GICv3 218 Level i2s
[ 254.439012] 117: 0 0 0 0 0 0 0 0 GICv3 219 Level i2s
[ 254.439025] 123: 0 0 0 0 0 0 0 0 GICv3 290 Level pcie-sys
[ 254.439036] 126: 0 0 0 0 0 0 0 0 GICv3 287 Level (null)
[ 254.439048] 130: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 254.439058] 131: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 254.439068] 132: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 7 Level rk806
[ 254.439078] 133: 0 0 0 0 0 0 0 0 rk806 0 Edge rk805_pwrkey_fall
[ 254.439088] 134: 0 0 0 0 0 0 0 0 rk806 1 Edge rk805_pwrkey_rise
[ 254.439098] 135: 0 0 0 0 0 0 0 0 rk806 7 Level rk806_vb_low
[ 254.439109] 136: 0 0 0 0 0 0 0 0 GICv3 252 Level xhci-hcd:usb1
[ 254.439119] 138: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 8 Level hym8563
[ 254.439130] 139: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 19 Edge headset_detect
[ 254.439134] PMU:
[ 254.439136] pwr 0x014c: 0000fffe 00002411 00000000 00000000
[ 254.439151] status 0x0180: 2411fffe 00000000 00000000 00000000
[ 254.439164] req 0x010c: 000017f0 0000000a 00000000 000a1ffe
[ 254.439174] idle 0x0120: 000a1ffe 00000000 0000ffff 0000ffff
[ 254.439185] ack 0x0118: 000a1ffe 00000000 000a1ffe 00000000
[ 254.439195] mem_pwr 0x01a0: 00000000 00000000 00000000 00000000
[ 254.439205] chain_st 0x01f0: ee0001ff 000003db 11fffe00 00000024
[ 254.439216] mem_st 0x01f8: 11fffe00 00000024 00000203 0000ffff
[ 254.439225] repair_st 0x0290: faf70003 000381ff 00000000 00000000
[ 254.439237] rockchip-thermal fec00000.tsadc: channal 0: temperature(61 C)
[ 254.439246] THERMAL REGS:
[ 254.439255] 00000000: 00000100 00000001 0000000f 0000007f 00000000 00000001 00000000 0000007f
[ 254.439268] 00000020: 00000000 0000007e 00000000 0000012a 0000012a 0000012a 0000012a 0000012a
[ 254.439279] 00000040: 00000129 00000129 00000000 00000000 00000000 00000000 00000000 00000000
[ 254.439289] 00000060: 00000000 00000000 00000000 00000153 00000000 00000000 00000000 00000000
[ 254.439295] 00000080: 00000000 00000000
[ 254.439299] Kernel Offset: disabled
[ 254.439301] CPU features: 0x000,48000026,6a00aa18
[ 254.439308] Memory Limit: none
[ 254.439316] cpu cpu6: cur_freq: 408000000 Hz, volt_vdd: 675000 uV, volt_mem: 675000 uV
[ 254.439325] cpu cpu4: cur_freq: 408000000 Hz, volt_vdd: 675000 uV, volt_mem: 675000 uV
[ 254.439333] cpu cpu0: cur_freq: 1416000000 Hz, volt_vdd: 737500 uV, volt_mem: 737500 uV
[ 433.458723] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[ 433.458729] rcu: 0-…0: (1 GPs behind) idle=4e6/1/0x4000000000000000 softirq=83/84 fqs=42006
[ 433.458741] (detected by 2, t=126016 jiffies, g=-991, q=132)
[ 433.458746] Task dump for CPU 0:
[ 433.458749] task:kworker/u16:2 state:R running task stack: 0 pid: 229 ppid: 2 flags:0x0000000a
[ 433.458760] Workqueue: events_unbound async_run_entry_fn
[ 433.458770] Call trace:
[ 433.458772] __switch_to+0xf8/0x170
[ 433.458779] __device_attach_async_helper+0x94/0x100
[ 433.458788] CPU0 online:1
[ 433.458793] EL2(NS) PC: <0xffffffc008bfadec> regmap_mmio_read32le+0xc/0x30
[ 433.458914]
[ 433.458915] CPU1 online:1
[ 433.458919] EL2(NS) PC: <0xffffffc0094b2d74> __cpu_do_idle+0x4/0x10
[ 433.459040]
[ 433.459041] CPU2 online:1
[ 433.459045] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 433.459056] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 433.459064] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 433.459074] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 433.459082] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 433.459092] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 433.459199]
[ 433.459201] CPU3 online:1
[ 433.459204] EL2(NS) PC: <0xffffffc008269954> unmap_kernel_range+0x54/0x90
[ 433.459326]
[ 433.459327] CPU4 online:1
[ 433.459331] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 433.459461]
[ 433.459462] CPU5 online:1
[ 433.459465] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 433.459595]
[ 433.459596] CPU6 online:1
[ 433.459600] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 433.459731]
[ 433.459732] CPU7 online:1
[ 433.459736] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 433.459865]
[ 433.459871] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 433.459883] 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic
[ 433.459893] 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer
[ 433.459903] 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer
[ 433.459912] 13: 693 129602 131741 1349 40142 4658 129266 43514 GICv3 26 Level arch_timer
[ 433.459921] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 433.459931] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 433.459944] 23: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 433.459954] 26: 274 0 0 0 0 0 0 0 GICv3 349 Level fd880000.i2c
[ 433.459963] 27: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 433.459972] 28: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 433.459981] 29: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 433.459991] 30: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 433.460000] 31: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 433.460009] 32: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu, rga3_core0
[ 433.460019] 33: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu, rga3_core1
[ 433.460027] 34: 0 0 0 0 0 0 0 0 GICv3 148 Level rga2
[ 433.460037] 35: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 433.460046] 36: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 433.460055] 37: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 433.460064] 38: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 433.460073] 39: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 433.460082] 40: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 433.460091] 41: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 433.460100] 42: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 433.460109] 43: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 433.460118] 44: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 433.460128] 45: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 433.460138] 46: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 433.460147] 47: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 433.460156] 48: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 433.460165] 49: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 433.460174] 50: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 433.460183] 51: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 433.460192] 52: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 433.460201] 53: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 433.460210] 54: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 433.460219] 55: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 433.460228] 56: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 433.460239] 59: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 433.460247] 60: 0 0 0 0 0 0 0 0 GICv3 163 Level rkisp_hw
[ 433.460256] 61: 0 0 0 0 0 0 0 0 GICv3 165 Level rkisp_hw
[ 433.460265] 62: 0 0 0 0 0 0 0 0 GICv3 166 Level rkisp_hw
[ 433.460274] 63: 0 0 0 0 0 0 0 0 GICv3 164 Level fdcb7f00.iommu
[ 433.460283] 64: 0 0 0 0 0 0 0 0 GICv3 187 Level rkcifhw
[ 433.460292] 65: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 433.460301] 66: 0 0 0 0 0 0 0 0 GICv3 175 Level rockchip-mipi-csi2-hw
[ 433.460310] 67: 0 0 0 0 0 0 0 0 GICv3 176 Level rockchip-mipi-csi2-hw
[ 433.460319] 68: 0 0 0 0 0 0 0 0 GICv3 177 Level rockchip-mipi-csi2-hw
[ 433.460328] 69: 0 0 0 0 0 0 0 0 GICv3 178 Level rockchip-mipi-csi2-hw
[ 433.460337] 70: 0 0 0 0 0 0 0 0 GICv3 179 Level rockchip-mipi-csi2-hw
[ 433.460346] 71: 0 0 0 0 0 0 0 0 GICv3 180 Level rockchip-mipi-csi2-hw
[ 433.460355] 72: 0 0 0 0 0 0 0 0 GICv3 181 Level rockchip-mipi-csi2-hw
[ 433.460364] 73: 0 0 0 0 0 0 0 0 GICv3 182 Level rockchip-mipi-csi2-hw
[ 433.460373] 74: 0 0 0 0 0 0 0 0 GICv3 183 Level rockchip-mipi-csi2-hw
[ 433.460382] 75: 0 0 0 0 0 0 0 0 GICv3 184 Level rockchip-mipi-csi2-hw
[ 433.] 138: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 8 Level hym8563
[ 433.460790] 139: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 19 Edge headset_detect
[ 434.460922] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 434.460932] 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic
[ 434.460942] 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer
[ 434.460950] 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer
[ 434.460960] 13: 693 129902 131741 1349 40442 4658 129566 43614 GICv3 26 Level arch_timer
[ 434.460969] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 434.460977] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 434.460989] 23: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 434.460999] 26: 274 0 0 0 0 0 0 0 GICv3 349 Level fd880000.i2c
[ 434.461008] 27: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 434.461016] 28: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 434.461025] 29: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 434.461033] 30: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 434.461042] 31: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 434.461051] 32: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu, rga3_core0
[ 434.461060] 33: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu, rga3_core1
[ 434.461069] 34: 0 0 0 0 0 0 0 0 GICv3 148 Level rga2
[ 434.461078] 35: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 434.461086] 36: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 434.461095] 37: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 434.461104] 38: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 434.461112] 39: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 434.461121] 40: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 434.461130] 41: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 434.461139] 42: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 434.461147] 43: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 434.461156] 44: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 434.461165] 45: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 434.461174] 46: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 434.461183] 47: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 434.461192] 48: 0 0 0 0 0 [ 613.478686] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[ 613.478692] rcu: 0-…0: (1 GPs behind) idle=4e6/1/0x4000000000000000 softirq=83/84 fqs=60009
[ 613.478704] (detected by 2, t=180022 jiffies, g=-991, q=132)
[ 613.478709] Task dump for CPU 0:
[ 613.478712] task:kworker/u16:2 state:R running task stack: 0 pid: 229 ppid: 2 flags:0x0000000a
[ 613.478721] Workqueue: events_unbound async_run_entry_fn
[ 613.478729] Call trace:
[ 613.478730] __switch_to+0xf8/0x170
[ 613.478737] __device_attach_async_helper+0x94/0x100
[ 613.478746] CPU0 online:1
[ 613.478750] EL2(NS) PC: <0xffffffc008bfadec> regmap_mmio_read32le+0xc/0x30
[ 613.478870]
[ 613.478871] CPU1 online:1
[ 613.478875] EL2(NS) PC: <0xffffffc0094b2d74> __cpu_do_idle+0x4/0x10
[ 613.478995]
[ 613.478996] CPU2 online:1
[ 613.479000] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479011] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479019] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479029] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479038] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479045] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479054] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479062] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479070] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479078] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479086] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479094] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479103] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479111] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479121] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479129] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479139] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479147] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479157] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479165] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479176] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479183] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479194] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479201] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479212] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479220] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479230] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479238] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479248] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479256] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479266] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 613.479274] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 613.479281]
[ 613.479282] CPU3 online:1
[ 613.479285] EL2(NS) PC: <0xffffffc008269954> unmap_kernel_range+0x54/0x90
[ 613.479406]
[ 613.479407] CPU4 online:1
[ 613.479411] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 613.479541]
[ 613.479542] CPU5 online:1
[ 613.479546] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 613.479675]
[ 613.479676] CPU6 online:1
[ 613.479680] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 613.479810]
[ 613.479812] CPU7 online:1
[ 613.479815] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 613.479945]
[ 613.479950] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 613.479962] 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic
[ 613.479971] 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer
[ 613.479981] 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer
[ 613.479990] 13: 693 183608 186440 1349 94148 5210 183272 61516 GICv3 26 Level arch_timer
[ 613.479999] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 613.480008] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 613.480020] 23: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 613.480030] 26: 274 0 0 0 0 0 0 0 GICv3 349 Level fd880000.i2c
[ 613.480039] 27: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 613.480047] 28: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 613.480056] 29: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 613.480065] 30: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 613.480074] 31: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 613.480083] 32: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu, rga3_core0
[ 613.480092] 33: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu, rga3_core1
[ 613.480101] 34: 0 0 0 0 0 0 0 0 GICv3 148 Level rga2
[ 613.480110] 35: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 613.480118] 36: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 613.480128] 37: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 613.480137] 38: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 613.480146] 39: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 613.480154] 40: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 613.480163] 41: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 613.480172] 42: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 613.480181] 43: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 613.480189] 44: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 613.480198] 45: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 613.480208] 46: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 613.480216] 47: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 613.480225] 48: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 613.480234] 49: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 613.480243] 50: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 613.480251] 51: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 613.480261] 52: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 613.480269] 53: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 613.480278] 54: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 613.480287] 55: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 613.480296] 56: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 613.480305] 59: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 613.480314] 60: 0 0 0 0 0 0 0 0 GICv3 163 Level rkisp_hw
[ 613.480322] 61: 0 0 0 0 0 0 0 0 GICv3 165 Level rkisp_hw
[ 613.480331] 62: 0 0 0 0 0 0 0 0 GICv3 166 Level rkisp_hw
[ 613.480340] 63: 0 0 0 0 0 0 0 0 GICv3 164 Level fdcb7f00.iommu
[ 613.480349] 64: 0 0 0 0 0 0 0 0 GICv3 187 Level rkcifhw
[ 613.480357] 65: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 613.480366] 66: 0 0 0 0 0 0 0 0 GICv3 175 Level rockchip-mipi-csi2-hw
[ 613.480375] 67: 0 0 0 0 0 0 0 0 GICv3 176 Level rockchip-mipi-csi2-hw
[ 613.480384] 68: 0 0 0 0 0 0 0 0 GICv3 177 Level rockchip-mipi-csi2-hw
[ 613.480393] 69: 0 0 0 0 0 0 0 0 GICv3 178 Level rockchip-mipi-csi2-hw
[ 613.480401] 70: 0 0 0 0 0 0 0 0 GICv3 179 Level rockchip-mipi-csi2-hw
[ 613.480410] 71: 0 0 0 0 0 0 0 0 GICv3 180 Level rockchip-mipi-csi2-hw
[ 613.480419] 72: 0 0 0 0 0 0 0 0 GICv3 181 Level rockchip-mipi-csi2-hw
[ 613.480428] 73: 0 0 0 0 0 0 0 0 GICv3 182 Level rockchip-mipi-csi2-hw
[ 613.480437] 74: 0 0 0 0 0 0 0 0 GICv3 183 Level rockchip-mipi-csi2-hw
[ 613.480446] 75: 0 0 0 0 0 0 0 0 GICv3 184 Level rockchip-mipi-csi2-hw
[ 613.480454] 76: 0 0 0 0 0 0 0 0 GICv3 185 Level rockchip-mipi-csi2-hw
[ 613.480463] 77: 0 0 0 0 0 0 0 0 GICv3 186 Level rockchip-mipi-csi2-hw
[ 613.480473] 78: 52 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu, fdd90000.vop
[ 613.480481] 79: 0 0 0 0 0 0 0 0 GICv3 217 Level i2s
[ 613.480491] 80: 0 0 0 0 0 0 0 0 GICv3 201 Level fde80000.hdmi
[ 613.480500] 82: 0 0 0 0 0 0 0 0 GICv3 203 Level fde80000.hdmi
[ 613.480509] 83: 264 0 0 0 0 0 0 0 GICv3 204 Level fde80000.hdmi
[ 613.480517] 84: 0 0 0 0 0 0 0 0 GICv3 392 Level dw-hdmi-qp-hpd
[ 613.480528] 89: 89 0 0 0 0 0 0 0 GICv3 237 Level mmc0
[ 613.480537] 91: 0 0 0 0 0 0 0 0 GICv3 212 Level i2s
[ 613.480546] 92: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 613.480555] 93: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 613.480565] 94: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 613.480574] 95: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 613.480583] 96: 0 0 0 0 0 0 0 0 GICv3 374 Level can0
[ 613.480591] 97: 18 0 0 0 0 0 0 0 GICv3 350 Level fea90000.i2c
[ 613.480600] 98: 20 0 0 0 0 0 0 0 GICv3 352 Level feab0000.i2c
[ 613.480609] 99: 0 0 0 0 0 0 0 0 GICv3 353 Level feac0000.i2c
[ 613.480618] 100: 0 0 0 0 0 0 0 0 GICv3 347 Edge feaf0000.watchdog
[ 613.480627] 101: 415 0 0 0 0 0 0 0 GICv3 360 Level feb20000.spi
[ 613.480638] 105: 0 0 0 0 0 0 0 0 GICv3 429 Level rockchip_thermal
[ 613.480646] 106: 0 0 0 0 0 0 0 0 GICv3 430 Level fec10000.saradc
[ 613.480655] 107: 56 0 0 0 0 0 0 0 GICv3 355 Level fec80000.i2c
[ 613.480664] 108: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 613.480673] 109: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 613.480682] 110: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 613.480690] 111: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 613.480699] 112: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 613.480708] 113: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 613.480717] 114: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 613.480726] 116: 0 0 0 0 0 0 0 0 GICv3 218 Level i2s
[ 613.480735] 117: 0 0 0 0 0 0 0 0 GICv3 219 Level i2s
[ 613.480746] 123: 0 0 0 0 0 0 0 0 GICv3 290 Level pcie-sys
[ 613.480755] 126: 0 0 0 0 0 0 0 0 GICv3 287 Level (null)
[ 613.480766] 130: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 613.480775] 131: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 613.480784] 132: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 7 Level rk806
[ 613.480793] 133: 0 0 0 0 0 0 0 0 rk806 0 Edge rk805_pwrkey_fall
[ 613.480802] 134: 0 0 0 0 0 0 0 0 rk806 1 Edge rk805_pwrkey_rise
[ 613.480811] 135: 0 0 0 0 0 0 0 0 rk806 7 Level rk806_vb_low
[ 613.480820] 136: 0 0 0 0 0 0 0 0 GICv3 252 Level xhci-hcd:usb1
[ 613.480830] 138: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 8 Level hym8563
[ 613.480839] 139: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 19 Edge headset_detect
[ 614.480971] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 614.480982] 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic
[ 614.480991] 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer
[ 614.481000] 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer
[ 614.481009] 13: 693 183908 186440 1349 94448 5210 183572 61616 GICv3 26 Level arch_timer
[ 614.481018] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 614.481027] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 614.481039] 23: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 614.481048] 26: 274 0 0 0 0 0 0 0 GICv3 349 Level fd880000.i2c
[ 614.481058] 27: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 614.481067] 28: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 614.481075] 29: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 614.481084] 30: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 614.481093] 31: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 614.481102] 32: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu, rga3_core0
[ 614.481111] 33: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu, rga3_core1
[ 614.481120] 34: 0 0 0 0 0 0 0 0 GICv3 148 Level rga2
[ 614.481129] 35: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 614.481138] 36: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 614.481147] 37: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 614.481156] 38: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 614.481165] 39: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 614.481174] 40: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 614.481182] 41: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 614.481191] 42: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 614.481200] 43: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 614.481209] 44: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 614.481218] 45: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 614.481227] 46: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 614.481236] 47: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 614.481245] 48: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 614.481254] 49: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 614.481263] 50: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 614.481272] 51: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 614.481281] 52: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 614.481289] 53: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 614.481298] 54: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 614.481307] 55: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 614.481316] 56: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 614.481326] 59: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 614.481335] 60: 0 0 0 0 0 0 0 0 GICv3 163 Level rkisp_hw
[ 614.481343] 61: 0 0 0 0 0 0 0 0 GICv3 165 Level rkisp_hw
[ 614.481352] 62: 0 0 0 0 0 0 0 0 GICv3 166 Level rkisp_hw
[ 614.481361] 63: 0 0 0 0 0 0 0 0 GICv3 164 Level fdcb7f00.iommu
[ 614.481370] 64: 0 0 0 0 0 0 0 0 GICv3 187 Level rkcifhw
[ 614.481378] 65: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 614.481387] 66: 0 0 0 0 0 0 0 0 GICv3 175 Level rockchip-mipi-csi2-hw
[ 614.481396] 67: 0 0 0 0 0 0 0 0 GICv3 176 Level rockchip-mipi-csi2-hw
[ 614.481405] 68: 0 0 0 0 0 0 0 0 GICv3 177 Level rockchip-mipi-csi2-hw
[ 614.481414] 69: 0 0 0 0 0 0 0 0 GICv3 178 Level rockchip-mipi-csi2-hw
[ 614.481423] 70: 0 0 0 0 0 0 0 0 GICv3 179 Level rockchip-mipi-csi2-hw
[ 614.481432] 71: 0 0 0 0 0 0 0 0 GICv3 180 Level rockchip-mipi-csi2-hw
[ 614.481441] 72: 0 0 0 0 0 0 0 0 GICv3 181 Level rockchip-mipi-csi2-hw
[ 614.481450] 73: 0 0 0 0 0 0 0 0 GICv3 182 Level rockchip-mipi-csi2-hw
[ 614.481459] 74: 0 0 0 0 0 0 0 0 GICv3 183 Level rockchip-mipi-csi2-hw
[ 614.481468] 75: 0 0 0 0 0 0 0 0 GICv3 184 Level rockchip-mipi-csi2-hw
[ 614.481477] 76: 0 0 0 0 0 0 0 0 GICv3 185 Level rockchip-mipi-csi2-hw
[ 614.481486] 77: 0 0 0 0 0 0 0 0 GICv3 186 Level rockchip-mipi-csi2-hw
[ 614.481496] 78: 52 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu, fdd90000.vop
[ 614.481505] 79: 0 0 0 0 0 0 0 0 GICv3 217 Level i2s
[ 614.481513] 80: 0 0 0 0 0 0 0 0 GICv3 201 Level fde80000.hdmi
[ 614.481522] 82: 0 0 0 0 0 0 0 0 GICv3 203 Level fde80000.hdmi
[ 614.481531] 83: 264 0 0 0 0 0 0 0 GICv3 204 Level fde80000.hdmi
[ 614.481540] 84: 0 0 0 0 0 0 0 0 GICv3 392 Level dw-hdmi-qp-hpd
[ 614.481551] 89: 89 0 0 0 0 0 0 0 GICv3 237 Level mmc0
[ 614.481560] 91: 0 0 0 0 0 0 0 0 GICv3 212 Level i2s
[ 614.481569] 92: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 614.481578] 93: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 614.481587] 94: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 614.481596] 95: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 614.481605] 96: 0 0 0 0 0 0 0 0 GICv3 374 Level can0
[ 614.481613] 97: 18 0 0 0 0 0 0 0 GICv3 350 Level fea90000.i2c
[ 614.481622] 98: 20 0 0 0 0 0 0 0 GICv3 352 Level feab0000.i2c
[ 614.481631] 99: 0 0 0 0 0 0 0 0 GICv3 353 Level feac0000.i2c
[ 614.481640] 100: 0 0 0 0 0 0 0 0 GICv3 347 Edge feaf0000.watchdog
[ 614.481649] 101: 415 0 0 0 0 0 0 0 GICv3 360 Level feb20000.spi
[ 614.481659] 105: 0 0 0 0 0 0 0 0 GICv3 429 Level rockchip_thermal
[ 614.481668] 106: 0 0 0 0 0 0 0 0 GICv3 430 Level fec10000.saradc
[ 614.481677] 107: 56 0 0 0 0 0 0 0 GICv3 355 Level fec80000.i2c
[ 614.481685] 108: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 614.481695] 109: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 614.481704] 110: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 614.481713] 111: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 614.481721] 112: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 614.481730] 113: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 614.481739] 114: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 614.481748] 116: 0 0 0 0 0 0 0 0 GICv3 218 Level i2s
[ 614.481756] 117: 0 0 0 0 0 0 0 0 GICv3 219 Level i2s
[ 614.481767] 123: 0 0 0 0 0 0 0 0 GICv3 290 Level pcie-sys
[ 614.481777] 126: 0 0 0 0 0 0 0 0 GICv3 287 Level (null)
[ 614.481787] 130: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 614.481796] 131: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 614.481804] 132: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 7 Level rk806
[ 614.481813] 133: 0 0 0 0 0 0 0 0 rk806 0 Edge rk805_pwrkey_fall
[ 614.481822] 134: 0 0 0 0 0 0 0 0 rk806 1 Edge rk805_pwrkey_rise
[ 614.481831] 135: 0 0 0 0 0 0 0 0 rk806 7 Level rk806_vb_low
[ 614.481840] 136: 0 0 0 0 0 0 0 0 GICv3 252 Level xhci-hcd:usb1
[ 614.481849] 138: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 8 Level hym8563
[ 614.481858] 139: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 19 Edge headset_detect
[ 614.481861] PMU:
[ 614.481863] pwr 0x014c: 0000fffe 00002411 00000000 00000000
[ 614.481872] status 0x0180: 2411fffe 00000000 00000000 00000000
[ 614.481880] req 0x010c: 000017f0 0000000a 00000000 000a1ffe
[ 614.481888] idle 0x0120: 000a1ffe 00000000 0000ffff 0000ffff
[ 614.481896] ack 0x0118: 000a1ffe 00000000 000a1ffe 00000000
[ 614.481904] mem_pwr 0x01a0: 00000000 00000000 00000000 00000000
[ 614.481912] chain_st 0x01f0: ee0001ff 000003db 11fffe00 00000024
[ 614.481919] mem_st 0x01f8: 11fffe00 00000024 00000203 0000ffff
[ 614.481927] repair_st 0x0290: faf70003 000381ff 00000000 00000000
[ 614.481936] rockchip-thermal fec00000.tsadc: channal 0: temperature(61 C)
[ 614.481941] THERMAL REGS:
[ 614.481948] 00000000: 00000100 00000001 0000000f 0000007f 00000000 00000001 00000000 0000007f
[ 614.481957] 00000020: 00000000 0000007e 00000000 0000012a 0000012a 0000012a 0000012a 0000012a
[ 614.481966] 00000040: 0000012a 00000129 00000000 00000000 00000000 00000000 00000000 00000000
[ 614.481975] 00000060: 00000000 00000000 00000000 00000153 00000000 00000000 00000000 00000000
[ 614.481980] 00000080: 00000000 00000000
[ 614.481983] Kernel Offset: disabled
[ 614.481985] CPU features: 0x000,48000026,6a00aa18
[ 614.481988] Memory Limit: none
[ 614.481993] cpu cpu6: cur_freq: 408000000 Hz, volt_vdd: 675000 uV, volt_mem: 675000 uV
[ 614.481999] cpu cpu4: cur_freq: 408000000 Hz, volt_vdd: 675000 uV, volt_mem: 675000 uV
[ 614.482005] cpu cpu0: cur_freq: 1416000000 Hz, volt_vdd: 737500 uV, volt_mem: 737500 uV
[ 793.501983] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[ 793.501988] rcu: 0-…0: (1 GPs behind) idle=4e6/1/0x4000000000000000 softirq=83/84 fqs=78012
[ 793.502001] (detected by 1, t=234029 jiffies, g=-991, q=132)
[ 793.502006] Task dump for CPU 0:
[ 793.502009] task:kworker/u16:2 state:R running task stack: 0 pid: 229 ppid: 2 flags:0x0000000a
[ 793.502019] Workqueue: events_unbound async_run_entry_fn
[ 793.502027] Call trace:
[ 793.502028] __switch_to+0xf8/0x170
[ 793.502035] __device_attach_async_helper+0x94/0x100
[ 793.502044] CPU0 online:1
[ 793.502048] EL2(NS) PC: <0xffffffc008bfadec> regmap_mmio_read32le+0xc/0x30
[ 793.502169]
[ 793.502170] CPU1 online:1
[ 793.502174] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 793.502185] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 793.502193] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 793.502204] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 793.502212] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 793.502221] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 793.502230] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 793.502239] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 793.502247] EL2(NS) PC: <0xffffffc00898ce5c> rockchip_panic_notify+0x30c/0x440
[ 793.502256] EL2(NS) PC: <0xffffffc00898ce58> rockchip_panic_notify+0x308/0x440
[ 793.502357]
[ 793.502359] CPU2 online:1
[ 793.502362] EL2(NS) PC: <0xffffffc0094b2d74> __cpu_do_idle+0x4/0x10
[ 793.502482]
[ 793.502483] CPU3 online:1
[ 793.502487] EL2(NS) PC: <0xffffffc008269954> unmap_kernel_range+0x54/0x90
[ 793.502608]
[ 793.502609] CPU4 online:1
[ 793.502613] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 793.502743]
[ 793.502744] CPU5 online:1
[ 793.502748] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 793.502877]
[ 793.502878] CPU6 online:1
[ 793.502882] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 793.503012]
[ 793.503014] CPU7 online:1
[ 793.503017] EL2(NS) PC: <0xffffffc0094b2d70> __cpu_do_idle+0x0/0x10
[ 793.503147]
[ 793.503153] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 793.503165] 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic
[ 793.503174] 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer
[ 793.503184] 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer
[ 793.503194] 13: 693 237615 241139 1349 148155 5235 237279 79518 GICv3 26 Level arch_timer
[ 793.503203] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 793.503212] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 793.503224] 23: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 793.503234] 26: 274 0 0 0 0 0 0 0 GICv3 349 Level fd880000.i2c
[ 793.503243] 27: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 793.503252] 28: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 793.503261] 29: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 793.503271] 30: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 793.503280] 31: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 793.503289] 32: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu, rga3_core0
[ 793.503299] 33: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu, rga3_core1
[ 793.503308] 34: 0 0 0 0 0 0 0 0 GICv3 148 Level rga2
[ 793.503317] 35: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 793.503326] 36: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 793.503335] 37: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 793.503344] 38: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 793.503353] 39: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 793.503362] 40: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 793.503371] 41: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 793.503380] 42: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 793.503389] 43: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 793.503398] 44: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 793.503407] 45: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 793.503416] 46: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 793.503425] 47: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 793.503434] 48: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 793.503443] 49: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 793.503452] 50: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 793.503461] 51: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 793.503470] 52: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 793.503479] 53: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 793.503488] 54: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 793.503497] 55: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 793.503506] 56: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 793.503515] 59: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 793.503524] 60: 0 0 0 0 0 0 0 0 GICv3 163 Level rkisp_hw
[ 793.503533] 61: 0 0 0 0 0 0 0 0 GICv3 165 Level rkisp_hw
[ 793.503542] 62: 0 0 0 0 0 0 0 0 GICv3 166 Level rkisp_hw
[ 793.503551] 63: 0 0 0 0 0 0 0 0 GICv3 164 Level fdcb7f00.iommu
[ 793.503559] 64: 0 0 0 0 0 0 0 0 GICv3 187 Level rkcifhw
[ 793.503568] 65: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 793.503577] 66: 0 0 0 0 0 0 0 0 GICv3 175 Level rockchip-mipi-csi2-hw
[ 793.503586] 67: 0 0 0 0 0 0 0 0 GICv3 176 Level rockchip-mipi-csi2-hw
[ 793.503595] 68: 0 0 0 0 0 0 0 0 GICv3 177 Level rockchip-mipi-csi2-hw
[ 793.503605] 69: 0 0 0 0 0 0 0 0 GICv3 178 Level rockchip-mipi-csi2-hw
[ 793.503613] 70: 0 0 0 0 0 0 0 0 GICv3 179 Level rockchip-mipi-csi2-hw
[ 793.503622] 71: 0 0 0 0 0 0 0 0 GICv3 180 Level rockchip-mipi-csi2-hw
[ 793.503631] 72: 0 0 0 0 0 0 0 0 GICv3 181 Level rockchip-mipi-csi2-hw
[ 793.503640] 73: 0 0 0 0 0 0 0 0 GICv3 182 Level rockchip-mipi-csi2-hw
[ 793.503649] 74: 0 0 0 0 0 0 0 0 GICv3 183 Level rockchip-mipi-csi2-hw
[ 793.503658] 75: 0 0 0 0 0 0 0 0 GICv3 184 Level rockchip-mipi-csi2-hw
[ 793.503668] 76: 0 0 0 0 0 0 0 0 GICv3 185 Level rockchip-mipi-csi2-hw
[ 793.503677] 77: 0 0 0 0 0 0 0 0 GICv3 186 Level rockchip-mipi-csi2-hw
[ 793.503686] 78: 52 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu, fdd90000.vop
[ 793.503695] 79: 0 0 0 0 0 0 0 0 GICv3 217 Level i2s
[ 793.503704] 80: 0 0 0 0 0 0 0 0 GICv3 201 Level fde80000.hdmi
[ 793.503714] 82: 0 0 0 0 0 0 0 0 GICv3 203 Level fde80000.hdmi
[ 793.503722] 83: 264 0 0 0 0 0 0 0 GICv3 204 Level fde80000.hdmi
[ 793.503731] 84: 0 0 0 0 0 0 0 0 GICv3 392 Level dw-hdmi-qp-hpd
[ 793.503742] 89: 89 0 0 0 0 0 0 0 GICv3 237 Level mmc0
[ 793.503752] 91: 0 0 0 0 0 0 0 0 GICv3 212 Level i2s
[ 793.503760] 92: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 793.503769] 93: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 793.503779] 94: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 793.503788] 95: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 793.503797] 96: 0 0 0 0 0 0 0 0 GICv3 374 Level can0
[ 793.503805] 97: 18 0 0 0 0 0 0 0 GICv3 350 Level fea90000.i2c
[ 793.503814] 98: 20 0 0 0 0 0 0 0 GICv3 352 Level feab0000.i2c
[ 793.503823] 99: 0 0 0 0 0 0 0 0 GICv3 353 Level feac0000.i2c
[ 793.503832] 100: 0 0 0 0 0 0 0 0 GICv3 347 Edge feaf0000.watchdog
[ 793.503841] 101: 415 0 0 0 0 0 0 0 GICv3 360 Level feb20000.spi
[ 793.503851] 105: 0 0 0 0 0 0 0 0 GICv3 429 Level rockchip_thermal
[ 793.503861] 106: 0 0 0 0 0 0 0 0 GICv3 430 Level fec10000.saradc
[ 793.503869] 107: 56 0 0 0 0 0 0 0 GICv3 355 Level fec80000.i2c
[ 793.503878] 108: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 793.503887] 109: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 793.503897] 110: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 793.503906] 111: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 793.503914] 112: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 793.503923] 113: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 793.503932] 114: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 793.503941] 116: 0 0 0 0 0 0 0 0 GICv3 218 Level i2s
[ 793.503950] 117: 0 0 0 0 0 0 0 0 GICv3 219 Level i2s
[ 793.503961] 123: 0 0 0 0 0 0 0 0 GICv3 290 Level pcie-sys
[ 793.503970] 126: 0 0 0 0 0 0 0 0 GICv3 287 Level (null)
[ 793.503980] 130: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 793.503990] 131: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 793.503999] 132: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 7 Level rk806
[ 793.504008] 133: 0 0 0 0 0 0 0 0 rk806 0 Edge rk805_pwrkey_fall
[ 793.504018] 134: 0 0 0 0 0 0 0 0 rk806 1 Edge rk805_pwrkey_rise
[ 793.504027] 135: 0 0 0 0 0 0 0 0 rk806 7 Level rk806_vb_low
[ 793.504036] 136: 0 0 0 0 0 0 0 0 GICv3 252 Level xhci-hcd:usb1
[ 793.504046] 138: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 8 Level hym8563
[ 793.504055] 139: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 19 Edge headset_detect
[ 794.504187] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 794.504198] 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic
[ 794.504207] 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer
[ 794.504216] 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer
[ 794.504226] 13: 693 237615 241444 1349 148455 5235 237579 79618 GICv3 26 Level arch_timer
[ 794.504234] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 794.504243] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 794.504255] 23: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 794.504265] 26: 274 0 0 0 0 0 0 0 GICv3 349 Level fd880000.i2c
[ 794.504274] 27: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 794.504283] 28: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 794.504292] 29: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 794.504301] 30: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 794.504309] 31: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 794.504318] 32: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu, rga3_core0
[ 794.504328] 33: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu, rga3_core1
[ 794.504336] 34: 0 0 0 0 0 0 0 0 GICv3 148 Level rga2
[ 794.504345] 35: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 794.504354] 36: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 794.504363] 37: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 794.504372] 38: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 794.504381] 39: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 794.504390] 40: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 794.504399] 41: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 794.504408] 42: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 794.504417] 43: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 794.504426] 44: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 794.504435] 45: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 794.504444] 46: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 794.504453] 47: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 794.504462] 48: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 794.504471] 49: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 794.504480] 50: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 794.504489] 51: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 794.504498] 52: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 794.504507] 53: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 794.504516] 54: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 794.504525] 55: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 794.504534] 56: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 794.504544] 59: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 794.504552] 60: 0 0 0 0 0 0 0 0 GICv3 163 Level rkisp_hw
[ 794.504561] 61: 0 0 0 0 0 0 0 0 GICv3 165 Level rkisp_hw
[ 794.504570] 62: 0 0 0 0 0 0 0 0 GICv3 166 Level rkisp_hw
[ 794.504579] 63: 0 0 0 0 0 0 0 0 GICv3 164 Level fdcb7f00.iommu
[ 794.504587] 64: 0 0 0 0 0 0 0 0 GICv3 187 Level rkcifhw
[ 794.504596] 65: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 794.504605] 66: 0 0 0 0 0 0 0 0 GICv3 175 Level rockchip-mipi-csi2-hw
[ 794.504614] 67: 0 0 0 0 0 0 0 0 GICv3 176 Level rockchip-mipi-csi2-hw
[ 794.504623] 68: 0 0 0 0 0 0 0 0 GICv3 177 Level rockchip-mipi-csi2-hw
[ 794.504631] 69: 0 0 0 0 0 0 0 0 GICv3 178 Level rockchip-mipi-csi2-hw
[ 794.504640] 70: 0 0 0 0 0 0 0 0 GICv3 179 Level rockchip-mipi-csi2-hw
[ 794.504649] 71: 0 0 0 0 0 0 0 0 GICv3 180 Level rockchip-mipi-csi2-hw
[ 794.504658] 72: 0 0 0 0 0 0 0 0 GICv3 181 Level rockchip-mipi-csi2-hw
[ 794.504667] 73: 0 0 0 0 0 0 0 0 GICv3 182 Level rockchip-mipi-csi2-hw
[ 794.504676] 74: 0 0 0 0 0 0 0 0 GICv3 183 Level rockchip-mipi-csi2-hw
[ 794.504685] 75: 0 0 0 0 0 0 0 0 GICv3 184 Level rockchip-mipi-csi2-hw
[ 794.504694] 76: 0 0 0 0 0 0 0 0 GICv3 185 Level rockchip-mipi-csi2-hw
[ 794.504703] 77: 0 0 0 0 0 0 0 0 GICv3 186 Level rockchip-mipi-csi2-hw
[ 794.504712] 78: 52 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu, fdd90000.vop
[ 794.504722] 79: 0 0 0 0 0 0 0 0 GICv3 217 Level i2s
[ 794.504731] 80: 0 0 0 0 0 0 0 0 GICv3 201 Level fde80000.hdmi
[ 794.504740] 82: 0 0 0 0 0 0 0 0 GICv3 203 Level fde80000.hdmi
[ 794.504749] 83: 264 0 0 0 0 0 0 0 GICv3 204 Level fde80000.hdmi
[ 794.504758] 84: 0 0 0 0 0 0 0 0 GICv3 392 Level dw-hdmi-qp-hpd
[ 794.504768] 89: 89 0 0 0 0 0 0 0 GICv3 237 Level mmc0
[ 794.504777] 91: 0 0 0 0 0 0 0 0 GICv3 212 Level i2s
[ 794.504787] 92: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 794.504796] 93: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 794.504805] 94: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 794.504813] 95: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 794.504822] 96: 0 0 0 0 0 0 0 0 GICv3 374 Level can0
[ 794.504831] 97: 18 0 0 0 0 0 0 0 GICv3 350 Level fea90000.i2c
[ 794.504840] 98: 20 0 0 0 0 0 0 0 GICv3 352 Level feab0000.i2c
[ 794.504849] 99: 0 0 0 0 0 0 0 0 GICv3 353 Level feac0000.i2c
[ 794.504858] 100: 0 0 0 0 0 0 0 0 GICv3 347 Edge feaf0000.watchdog
[ 794.504867] 101: 415 0 0 0 0 0 0 0 GICv3 360 Level feb20000.spi
[ 794.504877] 105: 0 0 0 0 0 0 0 0 GICv3 429 Level rockchip_thermal
[ 794.504886] 106: 0 0 0 0 0 0 0 0 GICv3 430 Level fec10000.saradc
[ 794.504895] 107: 56 0 0 0 0 0 0 0 GICv3 355 Level fec80000.i2c
[ 794.504904] 108: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 794.504913] 109: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 794.504922] 110: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 794.504931] 111: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 794.504940] 112: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 794.504948] 113: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 794.504957] 114: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 794.504966] 116: 0 0 0 0 0 0 0 0 GICv3 218 Level i2s
[ 794.504975] 117: 0 0 0 0 0 0 0 0 GICv3 219 Level i2s
[ 794.504986] 123: 0 0 0 0 0 0 0 0 GICv3 290 Level pcie-sys
[ 794.504995] 126: 0 0 0 0 0 0 0 0 GICv3 287 Level (null)
[ 794.505006] 130: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 794.505015] 131: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 794.505023] 132: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 7 Level rk806
[ 794.505032] 133: 0 0 0 0 0 0 0 0 rk806 0 Edge rk805_pwrkey_fall
[ 794.505041] 134: 0 0 0 0 0 0 0 0 rk806 1 Edge rk805_pwrkey_rise
[ 794.505050] 135: 0 0 0 0 0 0 0 0 rk806 7 Level rk806_vb_low
[ 794.505059] 136: 0 0 0 0 0 0 0 0 GICv3 252 Level xhci-hcd:usb1
[ 794.505069] 138: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 8 Level hym8563
[ 794.505078] 139: 0 0 0 0 0 0 0 0 rockchip_gpio_irq 19 Edge headset_detect
[ 794.505081] PMU:
[ 794.505083] pwr 0x014c: 0000fffe 00002411 00000000 00000000
[ 794.505092] status 0x0180: 2411fffe 00000000 00000000 00000000
[ 794.505101] req 0x010c: 000017f0 0000000a 00000000 000a1ffe
[ 794.505109] idle 0x0120: 000a1ffe 00000000 0000ffff 0000ffff
[ 794.505116] ack 0x0118: 000a1ffe 00000000 000a1ffe 00000000
[ 794.505124] mem_pwr 0x01a0: 00000000 00000000 00000000 00000000
[ 794.505132] chain_st 0x01f0: ee0001ff 000003db 11fffe00 00000024
[ 794.505139] mem_st 0x01f8: 11fffe00 00000024 00000203 0000ffff
[ 794.505147] repair_st 0x0290: faf70003 000381ff 00000000 00000000
[ 794.505156] rockchip-thermal fec00000.tsadc: channal 0: temperature(61 C)
[ 794.505161] THERMAL REGS:
[ 794.505168] 00000000: 00000100 00000001 0000000f 0000007f 00000000 00000001 00000000 0000007f
[ 794.505177] 00000020: 00000000 0000007e 00000000 0000012b 0000012a 0000012a 0000012b 0000012b
[ 794.505186] 00000040: 0000012a 0000012a 00000000 00000000 00000000 00000000 00000000 00000000
[ 794.505195] 00000060: 00000000 00000000 00000000 00000153 00000000 00000000 00000000 00000000
[ 794.505200] 00000080: 00000000 00000000
[ 794.505203] Kernel Offset: disabled
[ 794.505204] CPU features: 0x000,48000026,6a00aa18
[ 794.505208] Memory Limit: none
[ 794.505213] cpu cpu6: cur_freq: 408000000 Hz, volt_vdd: 675000 uV, volt_mem: 675000 uV
[ 794.505219] cpu cpu4: cur_freq: 408000000 Hz, volt_vdd: 675000 uV, volt_mem: 675000 uV
[ 794.505225] cpu cpu0: cur_freq: 1416000000 Hz, volt_vdd: 737500 uV, volt_mem: 737500 uV
提供完整的 log
这是报错日志,重新安装没有上面那个报错,但是还是无法启动
com6_2025-03-13_16_03_31.log (861 KB)
把整个 kernel/arch/arm64/boot/dts/rockchip 文件夹都替换掉试试看
