运行unity游戏,不定时,可能几天或者几小时,出现问题,画面定住,但没有退出,大量报错
adb报错信息如下,请问可能会是什么问题,花了很多时间了还没找到原因
2025/04/03 09:47:59.732 0 0 Warn [ C0] CS_FAULT_INFO.EXCEPTION_DATA 0x5fffca9880
2025/04/03 09:47:59.749 0 0 Warn : [ C0] mali fb000000.gpu Ctx 2259_6 Group 0 CSG 0 CSI: 3
2025/04/03 09:47:59.749 0 0 Warn [ C0] CS_FAULT.EXCEPTION_TYPE 0x4b (CS_INHERIT_FAULT)
2025/04/03 09:47:59.749 0 0 Warn [ C0] CS_FAULT.EXCEPTION_DATA 0x0
2025/04/03 09:47:59.749 0 0 Warn [ C0] CS_FAULT_INFO.EXCEPTION_DATA 0x5fffca9880
2025/04/03 09:47:59.765 0 0 Warn : [ C0] mali fb000000.gpu Ctx 2259_6 Group 0 CSG 0 CSI: 3
2025/04/03 09:47:59.765 0 0 Warn [ C0] CS_FAULT.EXCEPTION_TYPE 0x4b (CS_INHERIT_FAULT)
2025/04/03 09:47:59.765 0 0 Warn [ C0] CS_FAULT.EXCEPTION_DATA 0x0
2025/04/03 09:47:59.765 0 0 Warn [ C0] CS_FAULT_INFO.EXCEPTION_DATA 0x5fffca9880
2025/04/03 09:47:59.780 0 0 Warn : [ C0] mali fb000000.gpu Ctx 2259_6 Group 0 CSG 0 CSI: 3
2025/04/03 09:47:59.780 0 0 Warn [ C0] CS_FAULT.EXCEPTION_TYPE 0x4b (CS_INHERIT_FAULT)
2025/04/03 09:47:59.780 0 0 Warn [ C0] CS_FAULT.EXCEPTION_DATA 0x0
2025/04/03 09:47:59.780 0 0 Warn [ C0] CS_FAULT_INFO.EXCEPTION_DATA 0x5fffca9880
2025/04/03 09:47:59.796 0 0 Warn : [ C0] mali fb000000.gpu Ctx 2259_6 Group 0 CSG 0 CSI: 3
2025/04/03 09:47:59.796 0 0 Warn [ C0] CS_FAULT.EXCEPTION_TYPE 0x4b (CS_INHERIT_FAULT)
2025/04/03 09:47:59.796 0 0 Warn [ C0] CS_FAULT.EXCEPTION_DATA 0x0
2025/04/03 09:47:59.796 0 0 Warn [ C0] CS_FAULT_INFO.EXCEPTION_DATA 0x5fffca9880
2025/04/03 09:47:59.817 0 0 Warn : [ C0] mali fb000000.gpu Ctx 2259_6 Group 0 CSG 0 CSI: 3
2025/04/03 09:47:59.817 0 0 Warn [ C0] CS_FAULT.EXCEPTION_TYPE 0x4b (CS_INHERIT_FAULT)
2025/04/03 09:47:59.817 0 0 Warn [ C0] CS_FAULT.EXCEPTION_DATA 0x0
