RK3568未找到ttysWK设备节点
SDK包名称:rk356x_linux_release_20211019
SDK修改内容:DTS使能spi1和spi_wk2xxx
Log日志:log.zip
在使能相应设备节点后,烧录内核镜像,在/dev中找不到ttysWK*
执行dmesg | grep wk 的日志如下:
root@firefly:/home/firefly# dmesg|grep wk
[    1.698273] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    1.698333] wk2xxx_probe() Can not read property power-gpio
[    1.915310] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    1.915394] wk2xxx_probe() Can not read property power-gpio
[    1.973897] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    1.973941] wk2xxx_probe() Can not read property power-gpio
[    2.326726] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    2.326762] wk2xxx_probe() Can not read property power-gpio
[    4.145193] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    4.145266] wk2xxx_probe() Can not read property power-gpio
[    4.163622] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    4.163664] wk2xxx_probe() Can not read property power-gpio
[    6.227995] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    6.228073] wk2xxx_probe() Can not read property power-gpio
[    6.239275] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    6.239326] wk2xxx_probe() Can not read property power-gpio
[    6.289764] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    6.289905] wk2xxx_probe() Can not read property power-gpio
[    8.293450] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    8.293474] wk2xxx_probe() Can not read property power-gpio
[    8.341840] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    8.341863] wk2xxx_probe() Can not read property power-gpio
null.zip (150 Bytes)
log.zip (3.66 KB)
若最新的5.10版本固件,使能spi1和spi_wk2xxx 后,仍无法找到/dev/ttysWK,但是内核打印信息不同:
[    5.944042] wk2xxx_init: SPI driver for spi to Uart chip WK2XXX, etc.
[    5.944058] wk2xxx_init: V2.4 On 2022.07.24
