用Ubuntu编译Android12.0报错
按照wiki教程,在ROC-RK3588S-PC下编译[b]Android12.0报错,执行的命令是:./FFTools/make.sh -d roc-rk3588s-pc -j8 -l roc_rk3588s_pc-userdebug
以下为执行命令的过程:[/b]
test@ubuntu:~/Desktop/rk3588/RK3588_Android12$ ./FFTools/make.sh -d roc-rk3588s-pc -j8 -l roc_rk3588s_pc-userdebug
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=12
TARGET_PRODUCT=roc_rk3588s_pc
TARGET_BUILD_VARIANT=userdebug
TARGET_BUILD_TYPE=release
TARGET_ARCH=arm64
TARGET_ARCH_VARIANT=armv8-a
TARGET_CPU_VARIANT=generic
TARGET_2ND_ARCH=arm
TARGET_2ND_ARCH_VARIANT=armv8-a
TARGET_2ND_CPU_VARIANT=generic
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-5.15.0-139-generic-x86_64-Ubuntu-20.04.6-LTS
HOST_CROSS_OS=windows
HOST_CROSS_ARCH=x86
HOST_CROSS_2ND_ARCH=x86_64
HOST_BUILD_TYPE=release
BUILD_ID=SQ3A.220705.003.A1
OUT_DIR=out
lunch ok!
Force use clang and llvm to build kernel-5.10
====== start build uboot
make clean && make mrproper && make distclean
build/envsetup.sh: line 1680: make: command not found
#### failed to build some targets ####
./make.sh rk3588
grep: .config: No such file or directory
## make rk3588_defconfig -j8
[b]./make.sh: line 246: make: command not found
请大佬帮忙解答,是什么问题,如何解决[/b]
缺命令
请详细阅读环境搭建维基
zhangzhenzhao 发表于 2025-8-29 16:50
缺命令
你的意思是,缺环境吗,具体缺哪个
“build/envsetup.sh: line 1680: make: command not found”
这个信息,已经告诉了哪个脚本的哪行执行失败了,根据错误信息安装软件,如果看不出来,就在脚本里添加 set -x 看
