SDK包名称:rk3588_linux_release_20250114_v1.4.0g
SDK修改内容:关闭了pcie3.0
Log日志:rk3588JQusb转网口.rar
将核心板放在官方底板上,插上typec转网口的模块可以识别到网口,但是插在自制底板上usb转网口识别不到。
这个是否和底板没有pcie有关?
这是我换为usb2.0之后串口的输出
=================begin===================
288308 bytes read in 7 ms (39.3 MiB/s)
DTB(Distro): rk-kernel.dtb
boot mode: None
I2c0 speed: 100000Hz
vsel-gpios- not found!
en-gpios- not found!
vdd_cpu_big0_s0 800000 uV
vdd_cpu_big1_s0 800000 uV
I2c1 speed: 100000Hz
vdd_npu_s0 800000 uV
spi2: RK806: 2
ON=0x40, OFF=0x00
vdd_gpu_s0 750000 uV
vdd_cpu_lit_s0 750000 uV
vdd_log_s0 750000 uV
vdd_vdenc_s0 init 750000 uV
vdd_ddr_s0 850000 uV
I2c6 speed: 400000Hz
Error reading output register
Firefly fixed_regulator_set_enable: dev=‘vcc-hub-reset-regulator’, enable=1, delay=0, has_gpio=0
Firefly fixed_regulator_set_enable: dev=‘vcc-sdcard-pwr-en-regulator’, enable=1, delay=0, has_gpio=0
serdes_power_init failed to get serdes misc device
rockchip_panel_probe: Cannot get enable GPIO: -110
get vp0 plane mask:0x5, primary id:2, cursor_plane:-1, from dts
get vp1 plane mask:0xa, primary id:3, cursor_plane:-1, from dts
get vp2 plane mask:0x140, primary id:8, cursor_plane:-1, from dts
get vp3 plane mask:0x280, primary id:9, cursor_plane:-1, from dts
Model: Firefly AIO-3588Q MIPI101(Linux)
MPIDR: 0x81000000
Minidump: init…
No resource file: logo.bmp
512 bytes read in 2 ms (250 KiB/s)
logo(Distro): logo.bmp
751554 bytes read in 7 ms (102.4 MiB/s)
vp0 have layer nr:2[0 2 ], primary plane: 2
vp1 have layer nr:2[1 3 ], primary plane: 3
vp2 have layer nr:2[6 8 ], primary plane: 8
vp3 have layer nr:2[7 9 ], primary plane: 9
ERROR: VP3: unsupported display timing
hdmi@fde80000 disconnected
dp@fde60000 disconnected
CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 24000 KHz
b1pll 24000 KHz
lpll 24000 KHz
v0pll 24000 KHz
aupll 786431 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 850000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 750000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Can’t find cluster_uid_key offset! Error code: -1
Net: eth1: ethernet@fe1c0000, eth0: ethernet@fe1b0000
Not AVB images, AVB skip
No valid android hdr
Android image load failed
## Booting FIT Image FIT: No fit blob
FIT: No FIT image
Unknown command ‘bootrkp’ - try ‘help’
MMC: no card present
mmc_init: -123, time 0
switch to partitions #0, OK
Scanning mmc 0:3…
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
104 bytes read in 2 ms (50.8 KiB/s)
FIREFLY: use /rk-kernel.dtb
1: rk-kernel.dtb linux-5.10.198
Retrieving file: /initrd-5.10.198
9204398 bytes read in 30 ms (292.6 MiB/s)
Retrieving file: /Image-5.10.198
42512896 bytes read in 163 ms (248.7 MiB/s)
Retrieving file: /rk-kernel.dtb
Fdt Ramdisk skip relocation
## Flattened Device Tree blob at 0x08300000
Booting using the fdt blob at 0x08300000
Using Device Tree in place at 0000000008300000, end 0000000008349633
No resource file: logo_kernel.bmp
logo(Distro): logo_kernel.bmp
751554 bytes read in 8 ms (89.6 MiB/s)
## reserved-memory:
cma: addr=10000000 size=10000000
drm-logo@00000000: addr=edf00000 size=2e0000
ramoops@110000: addr=110000 size=e0000
Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000)
Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000)
Adding bank: 0x4f0000000 - 0x500000000 (size: 0x10000000)
Total: 2617.506/2975.695 ms
[ 2.981177] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 2.981199] Linux version 5.10.198 (cly@ubuntu) (firefly: 11a3d9327b6f/2510152343) (sdk version: rk3588_linux_release_20250114_v1.4.0g.xml) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #6 SMP Wed Oct 15 23:43:16 PDT 2025
[ 2.984846] random: crng init done
[ 2.993242] Machine model: Firefly AIO-3588Q MIPI101(Linux)
[ 3.024576] earlycon: uart8250 at MMIO32 0x00000000feb50000 (options ‘’)
[ 3.029705] printk: bootconsole [uart8250] enabled
[ 3.032591] efi: UEFI not found.
[ 3.038716] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 3.039877] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB
[ 3.040619] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[ 3.269846] Zone ranges:
[ 3.270089] DMA [mem 0x0000000000200000-0x00000000ffffffff]
[ 3.270662] DMA32 empty
[ 3.270929] Normal [mem 0x0000000100000000-0x00000004ffffffff]
[ 3.271499] Movable zone start for each node
[ 3.271891] Early memory node ranges
[ 3.272221] node 0: [mem 0x0000000000200000-0x00000000083fffff]
[ 3.272796] node 0: [mem 0x0000000009400000-0x00000000efffffff]
[ 3.273373] node 0: [mem 0x0000000100000000-0x00000003fbffffff]
[ 3.273951] node 0: [mem 0x00000003fc500000-0x00000003ffefffff]
[ 3.274526] node 0: [mem 0x00000004f0000000-0x00000004ffffffff]
[ 3.275103] Initmem setup node 0 [mem 0x0000000000200000-0x00000004ffffffff]
[ 3.374352] On node 0, zone Normal: 256 pages in unavailable ranges
[ 3.374543] psci: probing for conduit method from DT.
[ 3.375588] psci: PSCIv1.1 detected in firmware.
[ 3.376012] psci: Using standard PSCI v0.2 function IDs
[ 3.376494] psci: Trusted OS migration not required
[ 3.376944] psci: SMC Calling Convention v1.2
[ 3.377752] percpu: Embedded 32 pages/cpu s93736 r8192 d29144 u131072
[ 3.378553] Detected VIPT I-cache on CPU0
[ 3.378956] CPU features: detected: GIC system register CPU interface
[ 3.379547] CPU features: detected: Virtualization Host Extensions
[ 3.380117] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 3.380805] alternatives: patching kernel code
[ 3.383111] Built 1 zonelists, mobility grouping on. Total pages: 4122720
[ 3.383749] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=/mmc@fe2e0000 androidboot.verifiedbootstate=orange ro rootwait earlycon=uart8250,mmio32,0xfeb50000 console=ttyFIQ0 irqchip.gicv3_pseudo_nmi=0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1 net.ifnames=0 rcupdate.rcu_expedited=1 rcu_nocbs=all comm-10/15/2025 androidboot.fwver=ddr-v1.15-d5483af87d,spl-v1.13,bl31-v1.44,bl32-v1.15,uboot–boot
[ 3.390308] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 3.391830] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 3.392557] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 3.399506] software IO TLB: mapped [mem 0x00000000e9f00000-0x00000000edf00000] (64MB)
[ 3.514444] Memory: 16048272K/16752640K available (21696K kernel code, 4076K rwdata, 7784K rodata, 7808K init, 706K bss, 442224K reserved, 262144K cma-reserved)
[ 3.515868] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 3.516498] ftrace: allocating 68312 entries in 267 pages
[ 3.612437] ftrace: allocated 267 pages with 4 groups
[ 3.613142] rcu: Hierarchical RCU implementation.
[ 3.613578] rcu: RCU event tracing is enabled.
[ 3.613994] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 3.614609] All grace periods are expedited (rcu_expedited).
[ 3.615136] Rude variant of Tasks RCU enabled.
[ 3.615551] Tracing variant of Tasks RCU enabled.
[ 3.615992] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 3.621490] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 3.624886] GICv3: GIC: Using split EOI/Deactivate mode
[ 3.625369] GICv3: 480 SPIs implemented
[ 3.625722] GICv3: 0 Extended SPIs implemented
[ 3.626152] GICv3: Distributor has no Range Selector support
[ 3.626676] GICv3: 16 PPIs implemented
[ 3.627061] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000
[ 3.627786] ITS [mem 0xfe640000-0xfe65ffff]
[ 3.628221] ITS@0x00000000fe640000: allocated 8192 Devices @100120000 (indirect, esz 8, psz 64K, shr 0)
[ 3.629102] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100130000 (flat, esz 2, psz 64K, shr 0)
[ 3.630053] ITS: using cache flushing for cmd queue
[ 3.630529] ITS [mem 0xfe660000-0xfe67ffff]
[ 3.630954] ITS@0x00000000fe660000: allocated 8192 Devices @100150000 (indirect, esz 8, psz 64K, shr 0)
[ 3.631834] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100160000 (flat, esz 2, psz 64K, shr 0)
[ 3.632785] ITS: using cache flushing for cmd queue
[ 3.633464] GICv3: using LPI property table @0x0000000100170000
[ 3.634124] GIC: using cache flushing for LPI property table
[ 3.634649] GICv3: CPU0: using allocated LPI pending table @0x0000000100180000
[ 3.635356] rcu: Offload RCU callbacks from CPUs: 0-7.
[ 3.749295] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 3.749851] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 3.750827] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 3.752900] Console: colour dummy device 80x25
[ 3.753332] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 3.754263] pid_max: default: 32768 minimum: 301
[ 3.754754] LSM: Security Framework initializing
[ 3.755246] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 3.755966] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 3.758274] rcu: Hierarchical SRCU implementation.
[ 3.759589] Platform MSI: msi-controller@fe640000 domain created
[ 3.760166] Platform MSI: msi-controller@fe660000 domain created
[ 3.761087] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created
[ 3.761846] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created
[ 3.762797] EFI services will not be available.
[ 3.763480] smp: Bringing up secondary CPUs …
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
[ 3.765108] Detected VIPT I-cache on CPU1
[ 3.765133] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000
[ 3.765149] GICv3: CPU1: using allocated LPI pending table @0x0000000100190000
[ 3.765189] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 3.766454] Detected VIPT I-cache on CPU2
[ 3.766473] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000
[ 3.766489] GICv3: CPU2: using allocated LPI pending table @0x00000001001a0000
[ 3.766526] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 3.767776] Detected VIPT I-cache on CPU3
[ 3.767794] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000
[ 3.767809] GICv3: CPU3: using allocated LPI pending table @0x00000001001b0000
[ 3.767843] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 3.769116] CPU features: detected: Spectre-v4
[ 3.769118] CPU features: detected: Spectre-BHB
[ 3.769120] Detected PIPT I-cache on CPU4
[ 3.769131] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000
[ 3.769139] GICv3: CPU4: using allocated LPI pending table @0x00000001001c0000
[ 3.769161] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0]
[ 3.770350] Detected PIPT I-cache on CPU5
[ 3.770361] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000
[ 3.770370] GICv3: CPU5: using allocated LPI pending table @0x00000001001d0000
[ 3.770393] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0]
[ 3.771584] Detected PIPT I-cache on CPU6
[ 3.771596] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000
[ 3.771604] GICv3: CPU6: using allocated LPI pending table @0x00000001001e0000
[ 3.771626] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0]
[ 3.772834] Detected PIPT I-cache on CPU7
[ 3.772845] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000
[ 3.772854] GICv3: CPU7: using allocated LPI pending table @0x00000001001f0000
[ 3.772876] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0]
[ 3.772934] smp: Brought up 1 node, 8 CPUs
[ 3.789737] SMP: Total of 8 processors activated.
[ 3.790164] CPU features: detected: Privileged Access Never
[ 3.790666] CPU features: detected: LSE atomic instructions
[ 3.791166] CPU features: detected: User Access Override
[ 3.791644] CPU features: detected: 32-bit EL0 Support
[ 3.792107] CPU features: detected: Common not Private translations
[ 3.792673] CPU features: detected: RAS Extension Support
[ 3.793165] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 3.793941] CPU features: detected: CRC32 instructions
[ 3.794404] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 3.795033] CPU features: detected: RCpc load-acquire (LDAPR)
[ 3.819559] CPU: All CPU(s) started at EL2
[ 3.824297] devtmpfs: initialized
[ 3.835675] Registered cp15_barrier emulation handler
[ 3.836135] Registered setend emulation handler
[ 3.836602] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 3.837481] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 3.838213] pinctrl core: initialized pinctrl subsystem
[ 3.838856] DMI not present or invalid.
[ 3.839293] NET: Registered protocol family 16
[ 3.840163] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 3.840867] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 3.841582] audit: initializing netlink subsys (disabled)
[ 3.842116] audit: type=2000 audit(0.086:1): state=initialized audit_enabled=0 res=1
[ 3.842543] Registered FIQ tty driver
[ 3.843246] thermal_sys: Registered thermal governor ‘fair_share’
[ 3.843248] thermal_sys: Registered thermal governor ‘step_wise’
[ 3.843797] thermal_sys: Registered thermal governor ‘user_space’
[ 3.844339] thermal_sys: Registered thermal governor ‘power_allocator’
[ 3.845003] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 3.846329] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 3.847071] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
[ 3.847809] thermal thermal_zone4: power_allocator: sustainable_power will be estimated
[ 3.848544] thermal thermal_zone5: power_allocator: sustainable_power will be estimated
[ 3.849277] thermal thermal_zone6: power_allocator: sustainable_power will be estimated
[ 3.850010] cpuidle: using governor menu
[ 3.850493] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 3.851192] ASID allocator initialised with 65536 entries
[ 3.852933] ramoops: dmesg-0 0x18000@0x0000000000110000
[ 3.853401] ramoops: dmesg-1 0x18000@0x0000000000128000
[ 3.853884] ramoops: console 0x80000@0x0000000000140000
[ 3.854358] ramoops: pmsg 0x30000@0x00000000001c0000
[ 3.855041] printk: console [ramoops-1] enabled
[ 3.855449] pstore: Registered ramoops as persistent store backend
[ 3.856004] ramoops: using 0xe0000@0x110000, ecc: 0
[ 3.893598] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000
[ 3.894352] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000
[ 3.895087] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000
[ 3.895839] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000
[ 3.896573] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000
[ 3.897195] rockchip-pinctrl pinctrl: probed pinctrl
[ 3.906630] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 3.907234] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 3.907840] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 3.908443] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 3.966776] raid6: neonx8 gen() 5642 MB/s
[ 4.023495] raid6: neonx8 xor() 4461 MB/s
[ 4.080218] raid6: neonx4 gen() 5571 MB/s
[ 4.136941] raid6: neonx4 xor() 4467 MB/s
[ 4.193664] raid6: neonx2 gen() 5322 MB/s
[ 4.250386] raid6: neonx2 xor() 4261 MB/s
[ 4.307110] raid6: neonx1 gen() 4333 MB/s
[ 4.363832] raid6: neonx1 xor() 3592 MB/s
[ 4.420560] raid6: int64x8 gen() 2635 MB/s
[ 4.477279] raid6: int64x8 xor() 1561 MB/s
[ 4.533999] raid6: int64x4 gen() 2932 MB/s
[ 4.590722] raid6: int64x4 xor() 1549 MB/s
[ 4.647450] raid6: int64x2 gen() 2516 MB/s
[ 4.704166] raid6: int64x2 xor() 1356 MB/s
[ 4.760892] raid6: int64x1 gen() 2065 MB/s
[ 4.817615] raid6: int64x1 xor() 1082 MB/s
[ 4.817999] raid6: using algorithm neonx8 gen() 5642 MB/s
[ 4.818487] raid6: … xor() 4461 MB/s, rmw enabled
[ 4.818934] raid6: using neon recovery algorithm
[ 4.819398] Lontium LT9211C driver installing…
[ 4.820382] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 4.820881] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 4.821401] fiq_debugger_probe: could not install nmi irq handler
[ [ 4.821989] printk: console [ttyFIQ0] enabled
[ 4.822756] printk: bootconsole [uart8250] disabled
[ 4.823245] Registered fiq debugger ttyFIQ0
[ 4.823528] vcc5v0_sys: supplied by vcc12v_dcin
[ 4.823612] vcc5v0_usbdcin: supplied by vcc12v_dcin
[ 4.823688] vcc5v0_usb: supplied by vcc12v_dcin
[ 4.823769] vcc_1v1_nldo_s3: supplied by vcc5v0_sys
[ 4.823940] vcc3v3_pcie30: supplied by vcc12v_dcin
[ 4.824172] iommu: Default domain type: Passthrough
[ 4.826884] usbcore: registered new interface driver usbfs
[ 4.826897] usbcore: registered new interface driver hub
[ 4.826909] usbcore: registered new device driver usb
[ 4.826939] mc: Linux media interface: v0.10
[ 4.826947] videodev: Linux video capture interface: v2.00
[ 4.826967] pps_core: LinuxPPS API ver. 1 registered
[ 4.826970] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 4.826976] PTP clock support registered
[ 4.826990] EDAC MC: Ver: 3.0.0
[ 4.827268] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 4.827297] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 4.828265] Advanced Linux Sound Architecture Driver Initialized.
[ 4.828412] Bluetooth: Core ver 2.22
[ 4.828422] NET: Registered protocol family 31
[ 4.828425] Bluetooth: HCI device and connection manager initialized
[ 4.828430] Bluetooth: HCI socket layer initialized
[ 4.828434] Bluetooth: L2CAP socket layer initialized
[ 4.828440] Bluetooth: SCO socket layer initialized
[ 4.829688] rockchip-cpuinfo cpuinfo: SoC : 35881000
[ 4.829693] rockchip-cpuinfo cpuinfo: Serial : 5324db0eddd879a5
[ 4.829957] clocksource: Switched to clocksource arch_sys_counter
[ 5.088952] NET: Registered protocol family 2
[ 5.089115] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 5.092775] tcp_listen_portaddr_hash hash table entries: 8192 (order: 6, 327680 bytes, linear)
[ 5.092919] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 5.093583] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 5.094355] TCP: Hash tables configured (established 131072 bind 65536)
[ 5.094401] UDP hash table entries: 8192 (order: 7, 786432 bytes, linear)
[ 5.094678] UDP-Lite hash table entries: 8192 (order: 7, 786432 bytes, linear)
[ 5.094995] NET: Registered protocol family 1
[ 5.095191] RPC: Registered named UNIX socket transport module.
[ 5.095196] RPC: Registered udp transport module.
[ 5.095199] RPC: Registered tcp transport module.
[ 5.095202] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 5.095532] PCI: CLS 0 bytes, default 64
[ 5.095813] Trying to unpack rootfs image as initramfs…
[ 5.304254] Freeing initrd memory: 8988K
[ 5.304938] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property
[ 5.305391] rockchip-thermal fec00000.tsadc: tsadc is probed successfully!
[ 5.306075] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 5.306651] kvm [1]: IPA Size Limit: 40 bits
[ 5.306662] kvm [1]: GICv3: no GICV resource entry
[ 5.306665] kvm [1]: disabling GICv2 emulation
[ 5.306677] kvm [1]: GIC system register CPU interface enabled
[ 5.306813] kvm [1]: vgic interrupt IRQ9
[ 5.306959] kvm [1]: VHE mode initialized successfully
[ 5.309322] Initialise system trusted keyrings
[ 5.309399] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 5.311060] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 5.311332] NFS: Registering the id_resolver key type
[ 5.311341] Key type id_resolver registered
[ 5.311344] Key type id_legacy registered
[ 5.311349] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 5.311937] Key type cifs.spnego registered
[ 5.311943] Key type cifs.idmap registered
[ 5.311948] ntfs: driver 2.1.32 [Flags: R/O].
[ 5.311993] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 5.312071] fuse: init (API version 7.32)
[ 5.312178] SGI XFS with security attributes, no debug enabled
[ 5.333097] NET: Registered protocol family 38
[ 5.333104] xor: measuring software checksum speed
[ 5.334514] 8regs : 7039 MB/sec
[ 5.335683] 32regs : 8440 MB/sec
[ 5.336517] arm64_neon : 11863 MB/sec
[ 5.336520] xor: using function: arm64_neon (11863 MB/sec)
[ 5.336525] Key type asymmetric registered
[ 5.336529] Asymmetric key parser ‘x509’ registered
[ 5.336544] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 5.336629] io scheduler mq-deadline registered
[ 5.336634] io scheduler kyber registered
[ 5.337118] rockchip-csi2-dphy-hw fedc0000.csi2-dphy0-hw: csi2 dphy hw probe successfully!
[ 5.337182] rockchip-csi2-dphy-hw fedc8000.csi2-dphy1-hw: csi2 dphy hw probe successfully!
[ 5.339329] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 5.339694] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 5.340209] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 5.342413] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success
[ 5.343188] Firefly gpio driver init!
[ 5.343270] Firefly gpio driver register return : 0
[ 5.343363] Firefly detect position driver init!
[ 5.343444] Firefly detect position driver register return : 0
[ 5.343447] Firefly pca953x hpd driver init!
[ 5.343527] Firefly pca953x hpd driver register return : 0
[ 5.344584] rk-pcie fe150000.pcie: invalid prsnt-gpios property in node
[ 5.344688] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node
[ 5.344701] rk-pcie fe170000.pcie: no vpcie3v3 regulator found
[ 5.344911] iep: Module initialized.
[ 5.344940] rk-pcie fe170000.pcie: IRQ msi not found
[ 5.344942] mpp_service mpp-srv: ea89a0945141 author: Yandong Lin 2023-12-20 video: rockchip: mpp: fix watch dog interrupt storm issue
[ 5.344945] mpp_service mpp-srv: probe start
[ 5.344948] rk-pcie fe170000.pcie: use outband MSI support
[ 5.344950] rk-pcie fe170000.pcie: Missing config reg space
[ 5.344956] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges:
[ 5.344965] rk-pcie fe170000.pcie: err 0x00f2000000..0x00f20fffff → 0x00f2000000
[ 5.344972] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff → 0x00f2100000
[ 5.344979] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff → 0x00f2200000
[ 5.344984] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff → 0x0980000000
[ 5.345004] rk-pcie fe170000.pcie: Missing config reg space
[ 5.345024] rk-pcie fe170000.pcie: invalid resource
[ 5.346353] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1
[ 5.346371] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.346530] mpp_vdpu2 fdb50400.vdpu: probe device
[ 5.346629] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 5.346635] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 5.346740] mpp_vdpu2 fdb50400.vdpu: probing finish
[ 5.346914] mpp_vepu2 jpege-ccu: probing start
[ 5.346918] mpp_vepu2 jpege-ccu: probing finish
[ 5.347020] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5
[ 5.347030] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.347129] mpp_vepu2 fdba0000.jpege-core: probing start
[ 5.347214] mpp_vepu2 fdba0000.jpege-core: attach ccu success
[ 5.347322] mpp_vepu2 fdba0000.jpege-core: probing finish
[ 5.347398] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6
[ 5.347407] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.347501] mpp_vepu2 fdba4000.jpege-core: probing start
[ 5.347577] mpp_vepu2 fdba4000.jpege-core: attach ccu success
[ 5.347672] mpp_vepu2 fdba4000.jpege-core: probing finish
[ 5.347759] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7
[ 5.347768] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.347862] mpp_vepu2 fdba8000.jpege-core: probing start
[ 5.347938] mpp_vepu2 fdba8000.jpege-core: attach ccu success
[ 5.348029] mpp_vepu2 fdba8000.jpege-core: probing finish
[ 5.348101] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8
[ 5.348109] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.348202] mpp_vepu2 fdbac000.jpege-core: probing start
[ 5.348276] mpp_vepu2 fdbac000.jpege-core: attach ccu success
[ 5.348365] mpp_vepu2 fdbac000.jpege-core: probing finish
[ 5.348605] mpp-iep2 fdbb0000.iep: Adding to iommu group 9
[ 5.348614] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.348710] mpp-iep2 fdbb0000.iep: probe device
[ 5.348804] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 5.348895] mpp-iep2 fdbb0000.iep: probing finish
[ 5.349081] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4
[ 5.349090] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.349250] mpp_jpgdec fdb90000.jpegd: probe device
[ 5.349442] mpp_jpgdec fdb90000.jpegd: probing finish
[ 5.349735] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start
[ 5.349754] rk-pcie fe150000.pcie: phy init failed
[ 5.349779] mpp_rkvdec2 fdc30000.rkvdec-ccu: ccu-mode: 1
[ 5.349782] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish
[ 5.349875] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12
[ 5.349884] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.350065] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start
[ 5.350161] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
[ 5.350165] rkvdec2_init:1022: No niu aclk reset resource define
[ 5.350168] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
[ 5.350171] rkvdec2_init:1025: No niu hclk reset resource define
[ 5.350186] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled
[ 5.350236] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001
[ 5.350239] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0
[ 5.350375] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000
[ 5.350379] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000
[ 5.350382] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520
[ 5.350385] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576
[ 5.350389] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512
[ 5.350394] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_info_count 20
[ 5.350397] mpp_rkvdec2 fdc38100.rkvdec-core: [136, 24576]
[ 5.350400] mpp_rkvdec2 fdc38100.rkvdec-core: [137, 49152]
[ 5.350403] mpp_rkvdec2 fdc38100.rkvdec-core: [141, 90112]
[ 5.350406] mpp_rkvdec2 fdc38100.rkvdec-core: [140, 49152]
[ 5.350409] mpp_rkvdec2 fdc38100.rkvdec-core: [139, 180224]
[ 5.350412] mpp_rkvdec2 fdc38100.rkvdec-core: [133, 49152]
[ 5.350415] mpp_rkvdec2 fdc38100.rkvdec-core: [134, 8192]
[ 5.350418] mpp_rkvdec2 fdc38100.rkvdec-core: [135, 4352]
[ 5.350421] mpp_rkvdec2 fdc38100.rkvdec-core: [138, 13056]
[ 5.350424] mpp_rkvdec2 fdc38100.rkvdec-core: [142, 291584]
[ 5.350447] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish
[ 5.350509] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13
[ 5.350518] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.350666] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start
[ 5.350755] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
[ 5.350759] rkvdec2_init:1022: No niu aclk reset resource define
[ 5.350762] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
[ 5.350765] rkvdec2_init:1025: No niu hclk reset resource define
[ 5.350778] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled
[ 5.350814] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002
[ 5.350830] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1
[ 5.350990] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000
[ 5.350994] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000
[ 5.350997] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424
[ 5.351000] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576
[ 5.351004] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512
[ 5.351008] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_info_count 20
[ 5.351012] mpp_rkvdec2 fdc48100.rkvdec-core: [136, 24576]
[ 5.351015] mpp_rkvdec2 fdc48100.rkvdec-core: [137, 49152]
[ 5.351018] mpp_rkvdec2 fdc48100.rkvdec-core: [141, 90112]
[ 5.351021] mpp_rkvdec2 fdc48100.rkvdec-core: [140, 49152]
[ 5.351024] mpp_rkvdec2 fdc48100.rkvdec-core: [139, 180224]
[ 5.351027] mpp_rkvdec2 fdc48100.rkvdec-core: [133, 49152]
[ 5.351030] mpp_rkvdec2 fdc48100.rkvdec-core: [134, 8192]
[ 5.351033] mpp_rkvdec2 fdc48100.rkvdec-core: [135, 4352]
[ 5.351036] mpp_rkvdec2 fdc48100.rkvdec-core: [138, 13056]
[ 5.351039] mpp_rkvdec2 fdc48100.rkvdec-core: [142, 291584]
[ 5.351060] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish
[ 5.351252] mpp_rkvenc2 rkvenc-ccu: probing start
[ 5.351256] mpp_rkvenc2 rkvenc-ccu: probing finish
[ 5.351364] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10
[ 5.351372] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.351482] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start
[ 5.351594] mpp_rkvenc2 fdbd0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19
[ 5.351607] rkvenc_init:1905: failed to add venc devfreq
[ 5.351631] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0
[ 5.351738] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish
[ 5.351787] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11
[ 5.351795] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.351909] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start
[ 5.352006] mpp_rkvenc2 fdbe0000.rkvenc-core: dev_pm_opp_set_regulators: no regulator (venc) found: -19
[ 5.352016] rkvenc_init:1905: failed to add venc devfreq
[ 5.352060] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1
[ 5.352159] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish
[ 5.352584] mpp_av1dec: Adding child /av1d@fdc70000
[ 5.352641] mpp_av1dec: register device av1d-master
[ 5.352667] mpp_av1dec av1d-master: av1_iommu_of_xlate,784
[ 5.352683] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu
[ 5.352708] mpp_av1dec av1d-master: Adding to iommu group 18
[ 5.352717] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.352860] mpp_av1dec av1d-master: probing start
[ 5.353042] mpp_av1dec av1d-master: probing finish
[ 5.353065] mpp_service mpp-srv: probe success
[ 5.353165] Lontium LT9211C driver installing…
[ 5.353169] Error: Driver ‘LT9211C’ is already registered, aborting…
[ 5.360437] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 5.360444] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 5.361065] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 5.361070] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 5.361686] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 5.361692] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 5.362226] rockchip-pvtm fda40000.pvtm: pvtm@0 probed
[ 5.362269] rockchip-pvtm fda50000.pvtm: pvtm@1 probed
[ 5.362310] rockchip-pvtm fda60000.pvtm: pvtm@2 probed
[ 5.362349] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed
[ 5.362386] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed
[ 5.362846] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 5.363782] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 5.364146] fd890000.serial: ttyS0 at MMIO 0xfd890000 (irq = 27, base_baud = 1500000) is a 16550A
[ 5.364429] feb40000.serial: ttyS1 at MMIO 0xfeb40000 (irq = 113, base_baud = 1500000) is a 16550A
[ 5.364606] feb80000.serial: ttyS5 at MMIO 0xfeb80000 (irq = 114, base_baud = 1500000) is a 16550A
[ 5.364794] feb90000.serial: ttyS6 at MMIO 0xfeb90000 (irq = 115, base_baud = 1500000) is a 16550A
[ 5.366582] rockchip-vop2 fdd90000.vop: Adding to iommu group 17
[ 5.366595] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.378566] brd: module loaded
[ 5.381003] loop: module loaded
[ 5.381167] zram: Added device: zram0
[ 5.381268] lkdtm: No crash points registered, enable through debugfs
[ 5.381909] system_heap: orders[0] = 6
[ 5.381914] system_heap: orders[1] = 4
[ 5.381917] system_heap: orders[2] = 0
[ 5.383260] rockchip-spi feb10000.spi: no high_speed pinctrl state
[ 5.383543] rockchip-spi feb10000.spi: probed, poll=0, rsd=0, cs-inactive=0, ready=0
[ 5.383823] rockchip-spi feb20000.spi: no high_speed pinctrl state
[ 5.384908] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1
[ 5.385041] rk806 spi2.0: ON: 0x40 OFF:0x0
[ 5.386587] vdd_gpu_s0: supplied by vcc5v0_sys
[ 5.387614] vdd_cpu_lit_s0: supplied by vcc5v0_sys
[ 5.388177] vdd_log_s0: supplied by vcc5v0_sys
[ 5.388700] vdd_vdenc_s0: supplied by vcc5v0_sys
[ 5.389284] vdd_ddr_s0: supplied by vcc5v0_sys
[ 5.389620] vdd2_ddr_s3: supplied by vcc5v0_sys
[ 5.390151] vdd_2v0_pldo_s3: supplied by vcc5v0_sys
[ 5.390623] vcc_3v3_s3: supplied by vcc5v0_sys
[ 5.391077] vddq_ddr_s0: supplied by vcc5v0_sys
[ 5.391602] vcc_1v8_s3: supplied by vcc5v0_sys
[ 5.392153] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3
[ 5.392690] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3
[ 5.393151] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3
[ 5.393632] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3
[ 5.394108] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3
[ 5.394634] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 5.395219] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 5.395748] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3
[ 5.396339] vcc_3v3_s0: supplied by vcc5v0_sys
[ 5.396822] vccio_sd_s0: supplied by vcc5v0_sys
[ 5.397307] pldo6_s3: supplied by vcc5v0_sys
[ 5.397493] rk806 spi2.0: no sleep-setting state
[ 5.397498] rk806 spi2.0: no reset-setting pinctrl state
[ 5.397501] rk806 spi2.0: no dvs-setting pinctrl state
[ 5.398808] rockchip-spi feb20000.spi: probed, poll=0, rsd=0, cs-inactive=0, ready=0
[ 5.399358] register firefly_spi_init spi return v = :0
[ 5.399658] wireguard: allowedips self-tests: pass
[ 5.403011] wireguard: nonce counter self-tests: pass
[ 5.527595] wireguard: ratelimiter self-tests: pass
[ 5.527681] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 5.527684] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[ 5.528033] tun: Universal TUN/TAP device driver, 1.6
[ 5.528100] CAN device driver interface
[ 5.529599] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found
[ 5.529729] rk_gmac-dwmac fe1c0000.ethernet: supply phy not found, using dummy regulator
[ 5.529784] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output).
[ 5.529789] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x4f).
[ 5.529794] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay.
[ 5.529798] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff
[ 5.529812] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no).
[ 5.529819] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx
[ 5.529823] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx
[ 5.529834] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed
[ 5.530055] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID
[ 5.530131] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 5.530137] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5
[ 5.530141] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported
[ 5.530146] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported
[ 5.530149] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported
[ 5.530153] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported
[ 5.530178] rk_gmac-dwmac fe1c0000.ethernet: TSO supported
[ 5.530182] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 5.530187] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2)
[ 5.530190] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled
[ 5.530195] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width
[ 5.551073] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.576627] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.603291] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.629959] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.656624] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.666821] RTL8211F Gigabit Ethernet stmmac-1:01: [phy_probe-2990] led_status_value normal
[ 5.667642] rk_gmac-dwmac fe1b0000.ethernet: IRQ eth_lpi not found
[ 5.667880] rk_gmac-dwmac fe1b0000.ethernet: supply phy not found, using dummy regulator
[ 5.667929] rk_gmac-dwmac fe1b0000.ethernet: clock input or output? (output).
[ 5.667935] rk_gmac-dwmac fe1b0000.ethernet: TX delay(0x47).
[ 5.667939] rk_gmac-dwmac fe1b0000.ethernet: Can not read property: rx_delay.
[ 5.667943] rk_gmac-dwmac fe1b0000.ethernet: set rx_delay to 0xffffffff
[ 5.667951] rk_gmac-dwmac fe1b0000.ethernet: integrated PHY? (no).
[ 5.667957] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_rx
[ 5.667961] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_tx
[ 5.667974] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock clk_mac_speed
[ 5.668191] rk_gmac-dwmac fe1b0000.ethernet: init for RGMII_RXID
[ 5.668263] rk_gmac-dwmac fe1b0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 5.668269] rk_gmac-dwmac fe1b0000.ethernet: DWMAC4/5
[ 5.668273] rk_gmac-dwmac fe1b0000.ethernet: DMA HW capability register supported
[ 5.668277] rk_gmac-dwmac fe1b0000.ethernet: RX Checksum Offload Engine supported
[ 5.668281] rk_gmac-dwmac fe1b0000.ethernet: TX Checksum insertion supported
[ 5.668284] rk_gmac-dwmac fe1b0000.ethernet: Wake-Up On Lan supported
[ 5.668309] rk_gmac-dwmac fe1b0000.ethernet: TSO supported
[ 5.668313] rk_gmac-dwmac fe1b0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 5.668317] rk_gmac-dwmac fe1b0000.ethernet: Enabled Flow TC (entries=2)
[ 5.668321] rk_gmac-dwmac fe1b0000.ethernet: TSO feature enabled
[ 5.668325] rk_gmac-dwmac fe1b0000.ethernet: Using 32 bits DMA width
[ 5.683295] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.709959] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.736625] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.763292] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.789959] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.802759] phy_rtl8211f_led_fixup in
[ 5.823410] hcq : phy_rtl8211e_eee_fixup in
[ 5.844635] RTL8211F Gigabit Ethernet stmmac-0:01: [phy_probe-2990] led_status_value normal
[ 5.845495] usbcore: registered new interface driver asix
[ 5.845522] usbcore: registered new interface driver ax88179_178a
[ 5.845534] usbcore: registered new interface driver cdc_ether
[ 5.845546] usbcore: registered new interface driver net1080
[ 5.845557] usbcore: registered new interface driver cdc_subset
[ 5.845570] usbcore: registered new interface driver zaurus
[ 5.845592] usbcore: registered new interface driver cdc_ncm
[ 5.845605] usbcore: registered new interface driver qmi_wwan_q
[ 5.845617] usbcore: registered new interface driver qmi_wwan
[ 5.848295] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 5.848309] ehci-pci: EHCI PCI platform driver
[ 5.848335] ehci-platform: EHCI generic platform driver
[ 5.848544] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 5.848550] ohci-platform: OHCI generic platform driver
[ 5.848921] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 5.848983] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[ 5.849056] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000800002010010
[ 5.849081] xhci-hcd xhci-hcd.3.auto: irq 154, io mem 0xfcd00000
[ 5.849141] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 5.849190] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[ 5.849196] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[ 5.849249] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.849254] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.849258] usb usb1: Product: xHCI Host Controller
[ 5.849262] usb usb1: Manufacturer: Linux 5.10.198 xhci-hcd
[ 5.849266] usb usb1: SerialNumber: xhci-hcd.3.auto
[ 5.849423] hub 1-0:1.0: USB hub found
[ 5.849435] hub 1-0:1.0: 1 port detected
[ 5.849553] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 5.849587] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.849591] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.849595] usb usb2: Product: xHCI Host Controller
[ 5.849599] usb usb2: Manufacturer: Linux 5.10.198 xhci-hcd
[ 5.849603] usb usb2: SerialNumber: xhci-hcd.3.auto
[ 5.849736] hub 2-0:1.0: USB hub found
[ 5.849747] hub 2-0:1.0: 1 port detected
[ 5.849879] usbcore: registered new interface driver cdc_acm
[ 5.849883] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 5.849898] usbcore: registered new interface driver cdc_wdm
[ 5.849925] usbcore: registered new interface driver usbserial_generic
[ 5.849933] usbserial: USB Serial support registered for generic
[ 5.849946] usbcore: registered new interface driver ch341
[ 5.849964] usbserial: USB Serial support registered for ch341-uart
[ 5.849977] usbcore: registered new interface driver cp210x
[ 5.849985] usbserial: USB Serial support registered for cp210x
[ 5.850002] usbcore: registered new interface driver ftdi_sio
[ 5.850009] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 5.850036] usbcore: registered new interface driver keyspan
[ 5.850044] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 5.850051] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 5.850058] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 5.850066] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 5.850078] usbcore: registered new interface driver option
[ 5.850086] usbserial: USB Serial support registered for GSM modem (1-port)
[ 5.850120] usbcore: registered new interface driver oti6858
[ 5.850128] usbserial: USB Serial support registered for oti6858
[ 5.850140] usbcore: registered new interface driver pl2303
[ 5.850148] usbserial: USB Serial support registered for pl2303
[ 5.850163] usbcore: registered new interface driver qcserial
[ 5.850171] usbserial: USB Serial support registered for Qualcomm USB modem
[ 5.850185] usbcore: registered new interface driver sierra
[ 5.850193] usbserial: USB Serial support registered for Sierra USB modem
[ 5.850592] [HXTP] himax_hx83102_init
[ 5.850597] [HXTP] himax_hx83102_probe:Enter
[ 5.850600] [HXTP] Himax common touch panel driver init
[ 5.850638] usbcore: registered new interface driver usbtouchscreen
[ 5.850641] Gt9xx driver installing..
[ 5.851539] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.1.auto/input/input0
[ 5.851733] i2c /dev entries driver
[ 5.855102] vdd_cpu_big0_s0: supplied by vcc5v0_sys
[ 5.863552] vdd_cpu_big1_s0: supplied by vcc5v0_sys
[ 5.872504] vdd_npu_s0: supplied by vcc5v0_sys
[ 5.879164] i2c i2c-3: 1 i2c clients have been registered at 0x37
[ 5.880071] pca953x 6-0021: Can not read pca953x_suspend_io_state
[ 5.880076] pca953x 6-0021: Can not read pca953x_resume_io_state
[ 5.880081] pca953x 6-0021: Can not read pca953x_hold_io_state
[ 5.880095] pca953x 6-0021: supply vcc not found, using dummy regulator
[ 5.880138] pca953x 6-0021: using no AI
[ 5.880146] pca953x 6-0021: no det-supply !
[ 6.083293] rk3x-i2c fec80000.i2c: timeout, ipd: 0x00, state: 3
[ 6.083302] pca953x 6-0021: failed writing register
[ 6.083368] pca953x: probe of 6-0021 failed with error -110
[ 6.286629] rk3x-i2c fec80000.i2c: timeout, ipd: 0x00, state: 3
[ 6.489961] rk3x-i2c fec80000.i2c: timeout, ipd: 0x00, state: 3
[ 6.489969] rtc-hym8563 6-0051: could not init device, -110
[ 6.490023] rtc-hym8563: probe of 6-0051 failed with error -110
[ 6.490387] pca953x 6-0020: Can not read pca953x_suspend_io_state
[ 6.490391] pca953x 6-0020: Can not read pca953x_resume_io_state
[ 6.490395] pca953x 6-0020: Can not read pca953x_hold_io_state
[ 6.490408] pca953x 6-0020: supply vcc not found, using dummy regulator
[ 6.490446] pca953x 6-0020: using no AI
[ 6.490453] pca953x 6-0020: no det-supply !
[ 6.693294] rk3x-i2c fec80000.i2c: timeout, ipd: 0x00, state: 3
[ 6.693302] pca953x 6-0020: failed writing register
[ 6.693363] pca953x: probe of 6-0020 failed with error -110
[ 6.693950] rk628-csi-v4l2 3-0050: RK628 I2C driver version: 00.00.08
[ 6.939961] rk3x-i2c feab0000.i2c: timeout, ipd: 0x00, state: 2
[ 6.939970] rk628_i2c_read: i2c err reg=0x120, val=0xffffff81 ret=-110
[ 6.939974] rk628-csi-v4l2 3-0050: RK628 MCU + I2C Mode
[ 7.143299] rk3x-i2c feab0000.i2c: timeout, ipd: 0x00, state: 2
[ 7.143307] rk628_i2c_read: i2c err reg=0x40008, val=0x0 ret=-110
[ 7.143310] : i2c access failed! err:-110
[ 7.143903] rkcifhw fdce0000.rkcif: Adding to iommu group 16
[ 7.143917] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.144708] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF
[ 7.144783] rkcif rkcif-mipi-lvds2: Adding to iommu group 16
[ 7.144794] rkcif rkcif-mipi-lvds2: rkcif driver version: v00.02.00
[ 7.144841] rkcif rkcif-mipi-lvds2: attach to cif hw node
[ 7.144845] rkcif rkcif-mipi-lvds2: rkcif wait line 0
[ 7.144851] : terminal subdev does not exist
[ 7.144854] : terminal subdev does not exist
[ 7.144857] : terminal subdev does not exist
[ 7.144861] : terminal subdev does not exist
[ 7.144866] : get_remote_sensor: video pad[0] is null
[ 7.144870] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 7.144874] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 7.144878] : get_remote_sensor: video pad[0] is null
[ 7.144881] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 7.144885] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 7.144888] : get_remote_sensor: video pad[0] is null
[ 7.144891] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 7.144895] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 7.144898] : get_remote_sensor: video pad[0] is null
[ 7.144901] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 7.144905] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 7.145447] rkcif rkcif-mipi-lvds2: No memory-region-thunderboot specified
[ 7.145507] rkcif rkcif-mipi-lvds3: Adding to iommu group 16
[ 7.145518] rkcif rkcif-mipi-lvds3: rkcif driver version: v00.02.00
[ 7.145550] rkcif rkcif-mipi-lvds3: attach to cif hw node
[ 7.145555] rkcif rkcif-mipi-lvds3: rkcif wait line 0
[ 7.145558] : terminal subdev does not exist
[ 7.145562] : terminal subdev does not exist
[ 7.145565] : terminal subdev does not exist
[ 7.145568] : terminal subdev does not exist
[ 7.145572] : get_remote_sensor: video pad[0] is null
[ 7.145575] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 7.145579] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 7.145583] : get_remote_sensor: video pad[0] is null
[ 7.145585] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 7.145589] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 7.145592] : get_remote_sensor: video pad[0] is null
[ 7.145595] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 7.145599] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 7.145602] : get_remote_sensor: video pad[0] is null
[ 7.145605] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 7.145609] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 7.146116] rkcif rkcif-mipi-lvds3: No memory-region-thunderboot specified
[ 7.146907] rockchip-mipi-csi2-hw fdd10000.mipi0-csi2-hw: enter mipi csi2 hw probe!
[ 7.146970] rockchip-mipi-csi2-hw fdd10000.mipi0-csi2-hw: probe success, v4l2_dev:mipi0-csi2-hw!
[ 7.146997] rockchip-mipi-csi2-hw fdd20000.mipi1-csi2-hw: enter mipi csi2 hw probe!
[ 7.147038] rockchip-mipi-csi2-hw fdd20000.mipi1-csi2-hw: probe success, v4l2_dev:mipi1-csi2-hw!
[ 7.147060] rockchip-mipi-csi2-hw fdd30000.mipi2-csi2-hw: enter mipi csi2 hw probe!
[ 7.147100] rockchip-mipi-csi2-hw fdd30000.mipi2-csi2-hw: probe success, v4l2_dev:mipi2-csi2-hw!
[ 7.147122] rockchip-mipi-csi2-hw fdd40000.mipi3-csi2-hw: enter mipi csi2 hw probe!
[ 7.147161] rockchip-mipi-csi2-hw fdd40000.mipi3-csi2-hw: probe success, v4l2_dev:mipi3-csi2-hw!
[ 7.147184] rockchip-mipi-csi2-hw fdd50000.mipi4-csi2-hw: enter mipi csi2 hw probe!
[ 7.147221] rockchip-mipi-csi2-hw fdd50000.mipi4-csi2-hw: probe success, v4l2_dev:mipi4-csi2-hw!
[ 7.147243] rockchip-mipi-csi2-hw fdd60000.mipi5-csi2-hw: enter mipi csi2 hw probe!
[ 7.147280] rockchip-mipi-csi2-hw fdd60000.mipi5-csi2-hw: probe success, v4l2_dev:mipi5-csi2-hw!
[ 7.147677] rockchip-mipi-csi2 mipi2-csi2: attach to csi2 hw node
[ 7.147702] rkcif rkcif-mipi-lvds2: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 7.147708] rockchip-mipi-csi2: Async registered subdev
[ 7.147712] rockchip-mipi-csi2: probe success, v4l2_dev:rkcif-mipi-lvds2!
[ 7.147828] rockchip-mipi-csi2 mipi3-csi2: attach to csi2 hw node
[ 7.147844] rkcif rkcif-mipi-lvds3: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 7.147848] rockchip-mipi-csi2: Async registered subdev
[ 7.147851] rockchip-mipi-csi2: probe success, v4l2_dev:rkcif-mipi-lvds3!
[ 7.148609] rkisp_hw fdcb0000.rkisp: Adding to iommu group 14
[ 7.148623] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.148740] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0
[ 7.148747] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property
[ 7.148761] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps
[ 7.148819] rkisp_hw fdcb0000.rkisp: no find phandle sram
[ 7.148913] rkisp_hw fdcc0000.rkisp: Adding to iommu group 15
[ 7.148922] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.149056] rkisp_hw fdcc0000.rkisp: is_thunderboot: 0
[ 7.149063] rkisp_hw fdcc0000.rkisp: Missing rockchip,grf property
[ 7.149075] rkisp_hw fdcc0000.rkisp: max input:0x0@0fps
[ 7.149127] rkisp_hw fdcc0000.rkisp: no find phandle sram
[ 7.149359] rkisp rkisp0-vir2: rkisp driver version: v02.04.00
[ 7.149421] rkisp rkisp0-vir2: No memory-region-thunderboot specified
[ 7.149473] rkisp rkisp0-vir2: Entity type for entity rkisp-isp-subdev was not initialized!
[ 7.149884] rkisp rkisp1-vir0: rkisp driver version: v02.04.00
[ 7.149941] rkisp rkisp1-vir0: No memory-region-thunderboot specified
[ 7.149995] rkisp rkisp1-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 7.151251] rk_hdmirx fdee0000.hdmirx-controller: No reserved memory for HDMIRX, use default CMA
[ 7.151273] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_probe: cpu_aff:0x500, Bound_cpu:5, wdt_cfg_bound_cpu:6, phy_cpuid:5
[ 7.151761] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 0
[ 7.152357] rk_hdmirx fdee0000.hdmirx-controller: rk_hdmirx_hdcp_register success
[ 7.152375] rk_hdmirx fdee0000.hdmirx-controller: fdee0000.hdmirx-controller driver probe ok!
[ 7.152452] usbcore: registered new interface driver uvcvideo
[ 7.152456] USB Video Class driver (1.1.1)
[ 7.154277] device-mapper: ioctl: 4.44.0-ioctl (2021-02-01) initialised: dm-devel@redhat.com
[ 7.154385] Bluetooth: HCI UART driver ver 2.3
[ 7.154389] Bluetooth: HCI UART protocol H4 registered
[ 7.154393] Bluetooth: HCI UART protocol ATH3K registered
[ 7.154414] usbcore: registered new interface driver bfusb
[ 7.155201] cpu cpu0: bin=2
[ 7.155416] cpu cpu0: leakage=11
[ 7.156831] cpu cpu0: pvtm=1442
[ 7.156958] cpu cpu0: pvtm-volt-sel=4
[ 7.158867] cpu cpu4: bin=2
[ 7.159078] cpu cpu4: leakage=9
[ 7.165537] cpu cpu4: pvtm=1664
[ 7.169454] cpu cpu4: pvtm-volt-sel=5
[ 7.172118] cpu cpu6: bin=2
[ 7.172328] cpu cpu6: leakage=9
[ 7.178805] cpu cpu6: pvtm=1678
[ 7.182739] cpu cpu6: pvtm-volt-sel=6
[ 7.184603] cpu cpu0: avs=0
[ 7.185550] cpu cpu4: avs=0
[ 7.186333] cpu cpu6: avs=0
[ 7.186528] cpu cpu0: EM: created perf domain
[ 7.186557] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0
[ 7.186872] cpu cpu4: EM: created perf domain
[ 7.186896] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
[ 7.195257] cpu cpu6: EM: created perf domain
[ 7.195712] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
[ 7.210421] sdhci: Secure Digital Host Controller Interface driver
[ 7.210455] sdhci: Copyright(c) Pierre Ossman
[ 7.210464] Synopsys Designware Multimedia Card Interface Driver
[ 7.210850] sdhci-pltfm: SDHCI platform and OF driver helper
[ 7.214870] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 7.214974] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping …
[ 7.216305] cryptodev: driver 1.12 loaded.
[ 7.216384] hid: raw HID events driver (C) Jiri Kosina
[ 7.216664] usbcore: registered new interface driver usbhid
[ 7.216671] usbhid: USB HID core driver
[ 7.216907] ashmem: initialized
[ 7.221683] Firefly adc init
[ 7.221711] Firefly adc–>FIREFLY_ADC_SAMPLE_JIFFIES: 16
[ 7.221717] Firefly adc–>MSEC_PER_SEC: 1000
[ 7.221722] Firefly adc–>HZ: 300
[ 7.221960] Firefly adc–>ret: 0
[ 7.222201] optee: probing for conduit method.
[ 7.222222] optee: revision 3.13 (62aa10b7)
[ 7.222533] optee: dynamic shared memory is enabled
[ 7.222671] optee: initialized driver
[ 7.223312] usbcore: registered new interface driver snd-usb-audio
[ 7.245274] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA
[ 7.287828] mmc0: Host Software Queue enabled
[ 7.287854] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 7.288216] mmcblk0: mmc0:0001 DJUD4R 119 GiB
[ 7.288340] mmcblk0boot0: mmc0:0001 DJUD4R partition 1 31.9 MiB
[ 7.288462] mmcblk0boot1: mmc0:0001 DJUD4R partition 2 31.9 MiB
[ 7.288549] mmcblk0rpmb: mmc0:0001 DJUD4R partition 3 4.00 MiB, chardev (511:0)
[ 7.291871] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 7.426962] rk3x-i2c feab0000.i2c: timeout, ipd: 0x00, state: 3
[ 7.427008] ES8323 3-0011: i2c recv Failed
[ 7.427174] ES8323: probe of 3-0011 failed with error -110
[ 7.433745] rockchip-i2s-tdm fddf0000.i2s: CLK-ALWAYS-ON: mclk: 12288000, bclk: 3072000, fsync: 48000
[ 7.434800] rockchip-i2s-tdm fe470000.i2s: Register PCM for TRCM mode
[ 7.435562] rockchip-i2s-tdm fe480000.i2s: Register PCM for TRCM mode
[ 7.436267] rockchip-i2s-tdm fddf4000.i2s: CLK-ALWAYS-ON: mclk: 12288000, bclk: 3072000, fsync: 48000
[ 7.441294] debugfs: File ‘Capture’ in directory ‘dapm’ already present!
[ 7.454700] input: rockchip,hdmiin rockchip,hdmiin as /devices/platform/hdmiin-sound/sound/card0/input1
[ 7.460116] Initializing XFRM netlink socket
[ 7.461093] NET: Registered protocol family 10
[ 7.462789] Segment Routing with IPv6
[ 7.462851] NET: Registered protocol family 17
[ 7.462915] NET: Registered protocol family 15
[ 7.462956] Bridge firewalling registered
[ 7.462965] can: controller area network core
[ 7.462999] NET: Registered protocol family 29
[ 7.463007] can: raw protocol
[ 7.463046] can: broadcast manager protocol
[ 7.463058] can: netlink gateway - max_hops=1
[ 7.463294] Bluetooth: RFCOMM TTY layer initialized
[ 7.463311] Bluetooth: RFCOMM socket layer initialized
[ 7.463345] Bluetooth: RFCOMM ver 1.11
[ 7.463356] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.463362] Bluetooth: BNEP filters: protocol multicast
[ 7.463371] Bluetooth: BNEP socket layer initialized
[ 7.463378] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 7.463386] Bluetooth: HIDP socket layer initialized
[ 7.463417] 8021q: 802.1Q VLAN Support v1.8
[ 7.463434] [BT_RFKILL]: Enter rfkill_rk_init
[ 7.463440] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 7.463921] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 7.463949] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 7.463957] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275p
[ 7.463963] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 7.463969] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 7.463987] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 20 flags = 0.
[ 7.464008] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 10, flags = 0.
[ 7.464016] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 7.464022] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 7.464029] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 7.464035] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 7.464344] Key type dns_resolver registered
[ 7.465423] gc2053 3-0037-1: driver version: 00.01.02
[ 7.465442] gc2053 3-0037-1: could not get sync mode!
[ 7.465462] gc2053 3-0037-1: Failed to get reset-gpios
[ 7.465541] gc2053 3-0037-1: supply dovdd not found, using dummy regulator
[ 7.465635] gc2053 3-0037-1: supply avdd not found, using dummy regulator
[ 7.465679] gc2053 3-0037-1: supply dvdd not found, using dummy regulator
[ 7.465714] gc2053 3-0037-1: lane_num(2) pixel_rate(118800000)
[ 7.465724] gc2053 3-0037-1: could not get default pinstate
[ 7.465730] gc2053 3-0037-1: could not get sleep pinstate
[ 7.466819] vendor storage:20190527 ret = 0
[ 7.673621] rk3x-i2c feab0000.i2c: timeout, ipd: 0x00, state: 3
[ 7.673730] gc2053 3-0037-1: gc2053 read reg(0xf0 val:0x0) failed !
[ 7.876845] rk3x-i2c feab0000.i2c: timeout, ipd: 0x00, state: 3
[ 7.876944] gc2053 3-0037-1: gc2053 read reg(0xf1 val:0x0) failed !
[ 7.876969] gc2053 3-0037-1: gc2053_read_reg failed (-110)
[ 7.877811] gc2053: probe of 3-0037-1 failed with error -110
[ 7.878159] gc2093 3-007e: driver version: 00.01.02
[ 7.878345] gc2093 3-007e: Failed to get reset-gpios
[ 7.878460] gc2093 3-007e: supply dovdd not found, using dummy regulator
[ 7.878725] gc2093 3-007e: supply avdd not found, using dummy regulator
[ 7.878854] gc2093 3-007e: supply dvdd not found, using dummy regulator
[ 8.103537] rk3x-i2c feab0000.i2c: timeout, ipd: 0x00, state: 3
[ 8.103636] gc2093 3-007e: i2c read failed at addr: 3f0
[ 8.216865] rk-pcie fe170000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=0
[ 8.306799] rk3x-i2c feab0000.i2c: timeout, ipd: 0x00, state: 3
[ 8.306898] gc2093 3-007e: i2c read failed at addr: 3f1
[ 8.306921] gc2093 3-007e: Failed to read sensor id, (-110)
[ 8.307771] gc2093: probe of 3-007e failed with error -110
[ 8.308371] imx415 3-0037: driver version: 00.01.08
[ 8.308414] imx415 3-0037: Get hdr mode failed! no hdr default
[ 8.308456] imx415 3-0037: detect imx415 lane 4
[ 8.308578] imx415 3-0037: could not get default pinstate
[ 8.308601] imx415 3-0037: could not get sleep pinstate
[ 8.308665] imx415 3-0037: supply dvdd not found, using dummy regulator
[ 8.308936] imx415 3-0037: supply dovdd not found, using dummy regulator
[ 8.309076] imx415 3-0037: supply avdd not found, using dummy regulator
[ 8.580209] rk3x-i2c feab0000.i2c: timeout, ipd: 0x00, state: 3
[ 8.580308] imx415 3-0037: Unexpected sensor id(000000), ret(-5)
[ 8.581656] xc7160 3-001b: T-chip firefly camera driver version: 00.01.04
[ 8.581862] xc7160 3-001b: supply avdd not found, using dummy regulator
[ 8.582043] xc7160 3-001b: supply dovdd not found, using dummy regulator
[ 8.582130] xc7160 3-001b: supply dvdd not found, using dummy regulator
[ 8.582197] xc7160 3-001b: could not get default pinstate
[ 8.582212] xc7160 3-001b: could not get sleep pinstate
[ 8.582238] xc7160 3-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 8.800207] rk3x-i2c feab0000.i2c: timeout, ipd: 0x00, state: 3
[ 8.800304] xc7160 3-001b: write XC7160_REG_HIGH_SELECT failed
[ 8.801104] xc7160: probe of 3-001b failed with error -5
[ 8.802496] registered taskstats version 1
[ 8.802600] Loading compiled-in X.509 certificates
[ 8.807034] Btrfs loaded, crc32c=crc32c-generic
[ 8.807440] pstore: Using crash dump compression: deflate
[ 8.809337] rga3_core0 fdb60000.rga: Adding to iommu group 2
[ 8.809467] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.810242] rga: rga3_core0, irq = 35, match scheduler
[ 8.811023] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831.
[ 8.811132] rga: rga3_core0 probe successfully
[ 8.811527] rga3_core1 fdb70000.rga: Adding to iommu group 3
[ 8.811558] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.811701] rga: rga3_core1, irq = 36, match scheduler
[ 8.812023] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831.
[ 8.812076] rga: rga3_core1 probe successfully
[ 8.812518] rga: rga2, irq = 37, match scheduler
[ 8.812869] rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
[ 8.812958] rga: rga2 probe successfully
[ 8.813208] rga_iommu: IOMMU binding successfully, default mapping core[0x1]
[ 8.813443] rga: Module initialized. v1.3.1
[ 8.813452]
[ 8.813457] ********************************************************************
[ 8.813463] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 8.813468] ** **
[ 8.813474] ** WRITEABLE clk DebugFS SUPPORT HAS BEEN ENABLED IN THIS KERNEL **
[ 8.813479] ** **
[ 8.813483] ** This means that this kernel is built to expose clk operations **
[ 8.813488] ** such as parent or rate setting, enabling, disabling, etc. **
[ 8.813493] ** to userspace, which may compromise security on your system. **
[ 8.813498] ** **
[ 8.813503] ** If you see this message and you are not debugging the **
[ 8.813507] ** kernel, report this immediately to your vendor! **
[ 8.813512] ** **
[ 8.813517] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 8.813522] ********************************************************************
[ 8.851455] mali fb000000.gpu: Kernel DDK version g18p0-01eac0
[ 8.851526] pcie30_avdd1v8: supplied by avcc_1v8_s0
[ 8.852208] pcie30_avdd0v75: supplied by avdd_0v75_s0
[ 8.852247] mali fb000000.gpu: bin=2
[ 8.852549] mali fb000000.gpu: leakage=15
[ 8.852616] debugfs: Directory ‘fb000000.gpu-mali’ with parent ‘vdd_gpu_s0’ already present!
[ 8.853411] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 8.853770] rockchip-csi2-dphy csi2-dphy1: csi2 dphy1 probe successfully!
[ 8.854119] rockchip-csi2-dphy csi2-dphy2: csi2 dphy2 probe successfully!
[ 8.854186] mali fb000000.gpu: pvtm=884
[ 8.854446] mali fb000000.gpu: pvtm-volt-sel=4
[ 8.854597] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 8.855156] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 8.855688] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 8.855789] mali fb000000.gpu: avs=0
[ 8.855825] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 143; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 8.856378] mali fb000000.gpu: r0p0 status 5 not found in HW issues table;
[ 8.856388] mali fb000000.gpu: falling back to closest match: r0p0 status 0
[ 8.856395] mali fb000000.gpu: Execution proceeding normally with fallback match
[ 8.856403] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0
[ 8.856445] mali fb000000.gpu: No priority control manager is configured
[ 8.856717] mali fb000000.gpu: No memory group manager is configured
[ 8.856744] mali fb000000.gpu: Protected memory allocator not available
[ 8.857488] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT
[ 8.857641] input: adc-keys as /devices/platform/adc-keys/input/input2
[ 8.857860] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
[ 8.858722] mali fb000000.gpu: Probed as mali0, this is r1_on_g18_on_linux-5.10-gen-rkr4.1_for_defect_414343
[ 8.861502] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 8.861992] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 8.862463] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 8.866561] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 8.867043] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 8.867513] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 8.869727] wk2xxx_init: SPI driver for spi to Uart chip WK2XXX, etc.
[ 8.869735] wk2xxx_init: V2.7 On 2024.12.03 firefly
[ 8.870180] rkcif rkcif-mipi-lvds2: clear unready subdev num: 4
[ 8.872307] : get_remote_sensor: remote pad is null
[ 8.872338] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 8.872345] : There is not terminal subdev, not synchronized with ISP
[ 8.872354] rkcif rkcif-mipi-lvds3: clear unready subdev num: 1
[ 8.873832] : get_remote_sensor: remote pad is null
[ 8.873841] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 8.873847] : There is not terminal subdev, not synchronized with ISP
[ 8.873911] pc9202-wdt 0-003c: Version: firefly 1.0.0 04/15/2023
[ 8.874445] pc9202: sw2001_read(0x1) return 0x1
[ 8.874455] status=0x1
[ 8.874462] (NULL device *): ====== i2c detect success watchdog init ======
[ 8.875893] dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state
[ 8.875903] dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state
[ 8.876030] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[ 8.876053] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[ 8.876064] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[ 8.876097] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 98,32 bit host data width,256 deep fifo
[ 8.877021] RKNPU fdab0000.npu: Adding to iommu group 0
[ 8.877043] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 8.877200] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 8.878239] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 8.878591] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdab0000-0xfdabffff]
[ 8.878613] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdac0000-0xfdacffff]
[ 8.878648] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdad0000-0xfdadffff]
[ 8.878757] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 8.879151] [drm] Initialized rknpu 0.9.8 20240828 for fdab0000.npu on minor 0
[ 8.879299] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 8.883074] RKNPU fdab0000.npu: RKNPU: bin=2
[ 8.883301] RKNPU fdab0000.npu: leakage=9
[ 8.883343] debugfs: Directory ‘fdab0000.npu-rknpu’ with parent ‘vdd_npu_s0’ already present!
[ 8.889390] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 8.890530] RKNPU fdab0000.npu: pvtm=875
[ 8.895287] RKNPU fdab0000.npu: pvtm-volt-sel=4
[ 8.896385] RKNPU fdab0000.npu: avs=0
[ 8.896545] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
[ 8.903190] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 8.905815] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 8.906880] RKNPU fdab0000.npu: failed to find power_model node
[ 8.906889] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 8.906915] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
[ 8.906921] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 8.907984] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.911557] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 8.912090] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 8.912607] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 8.918461] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 8.919643] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 8.920118] rockchip-suspend not set sleep-mode-config for mem-lite
[ 8.920125] rockchip-suspend not set wakeup-config for mem-lite
[ 8.920133] rockchip-suspend not set sleep-mode-config for mem-ultra
[ 8.920139] rockchip-suspend not set wakeup-config for mem-ultra
[ 8.921357] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘14:25:41’, on ‘Oct 15 2025’.
[ 8.921932] Mali:
[ 8.921934] Mali device driver loaded
[ 8.921950] rkisp rkisp0-vir2: clear unready subdev num: 1
[ 8.922130] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 8.922139] cfg80211: failed to load regulatory.db
[ 8.923147] rkisp rkisp1-vir0: clear unready subdev num: 1
[ 8.924915] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 8.925222] ret 1024 0
[ 8.925384] ALSA device list:
[ 8.925392] #0: rockchip,hdmiin
[ 8.925399] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 8.925880] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 8.929199] Freeing unused kernel memory: 7808K
[ 8.953762] Run /init as init process
Loading, please wait…
/dev/console is Ok
starting version 237
[ 9.364418] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_cancel_cpu_limit_freq freq qos nod add
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Begin: Will now check root file system … fsck from util-linux 2.36.1-4309-dirty
[/sbin/fsck.ext4 (1) – /dev/mmcblk0p6] fsck.ext4 -a -C0 /dev/mmcblk0p6
rootfs: clean, 447308/468000 files, 2396890/2431622 blocks
done.
[ 10.542162] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … [ 10.573383] rk_pcie_establish_link: 132 callbacks suppressed
[ 10.573391] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 10.600053] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 10.626712] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts=‘dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ per kernel cmdline
[ 10.653390] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 10.680060] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 10.691916] EXT4-fs (mmcblk0p7): 1 orphan inode deleted
[ 10.691949] EXT4-fs (mmcblk0p7): 1 truncate cleaned up
[ 10.691956] EXT4-fs (mmcblk0p7): recovery complete
[ 10.696290] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 10.706657] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
Success: overlayroot: configured root with ‘device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ using overlay per kernel cmdline
Warning: Something odd, no /lib/modules/5.10.198 in initramfs.
[ 10.733330] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
done.
[ 10.759999] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 10.778012] EXT4-fs (mmcblk0p3): recovery complete
[ 10.778721] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 10.786718] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 10.813494] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 10.890785] systemd[1]: System time before build time, advancing clock.
[ 10.903472] systemd[1]: Failed to find module ‘autofs4’
[ 10.922972] systemd[1]: systemd 249.11-0ubuntu4.16 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 10.924493] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 22.04.5 LTS!
[ 10.926418] systemd[1]: Hostname set to .
[ 11.099756] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[ 11.230647] systemd[1]: Configuration file /lib/systemd/system/rkaiq_3A.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 11.238532] systemd[1]: Queued start job for default target Graphical Interface.
[ 11.239596] systemd[1]: Created slice Slice /system/modprobe.
[ 11.240075] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/modprobe.
[ 11.240362] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice Slice /system/serial-getty.
[ 11.240470] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Created slice User and Session Slice.
[ 11.240574] systemd[1]: Starting of Arbitrary Executable File Formats File System Automount Point unsupported.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 11.240666] systemd[1]: Reached target User and Group Name Lookups.
[UNSUPP] Starting of Arbitrary Exec…m Automount Point unsupported.
[ 11.240703] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target User and Group Name Lookups.
[ 11.240735] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Remote File Systems.
[ 11.240772] systemd[1]: Reached target Swaps.
[ OK ] Reached target Slice Units.
[ 11.240811] systemd[1]: Reached target Local Verity Protected Volumes.
[ OK ] Reached target Swaps.
[ 11.240958] systemd[1]: Listening on Syslog Socket.
[ OK ] Reached target Local Verity Protected Volumes.
[ 11.241048] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on Syslog Socket.
[ 11.241267] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 11.241383] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Audit Socket.
[ 11.241515] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket (/dev/log).
[ 11.241674] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on Journal Socket.
[ 11.241787] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Control Socket.
[ 11.241825] systemd[1]: Reached target Socket Units.
[ OK ] Listening on udev Kernel Socket.
[ 11.242625] systemd[1]: Mounting Huge Pages File System…
[ OK ] Reached target Socket Units.
[ 11.243422] systemd[1]: Mounting POSIX Message Queue File System…
[ 11.244208] systemd[1]: Mounting Kernel Debug File System…
[ 11.244990] systemd[1]: Mounting Kernel Trace File System…
[ 11.246369] systemd[1]: Starting Journal Service…
[ 11.247735] systemd[1]: Starting Set the console keyboard layout…
[ 11.248706] systemd[1]: Starting Create List of Static Device Nodes…
[ 11.249649] systemd[1]: Starting Load Kernel Module configfs…
[ 11.250558] systemd[1]: Starting Load Kernel Module drm…
[ 11.251495] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 11.252457] systemd[1]: Starting Load Kernel Module fuse…
[ 11.253460] systemd[1]: Starting Enable Rockchip camera engine rkaiq…
[ 11.255278] systemd[1]: Starting Load Kernel Modules…
[ 11.256326] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 11.257429] systemd[1]: Starting Coldplug All udev Devices…
[ 11.259260] systemd[1]: Mounted Huge Pages File System.
[ 11.259442] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted Huge Pages File System.
[ 11.259571] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 11.259693] systemd[1]: Mounted Kernel Trace File System.
[ OK ] Mounted Kernel Debug File System.
[ 11.260079] systemd[1]: Finished Create List of Static Device Nodes.
[ OK ] Mounted Kernel Trace File System.
[ 11.260495] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ OK ] Finished Create List of Static Device Nodes.
[ 11.260752] systemd[1]: Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module configfs.
[ 11.261084] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ OK ] Finished Load Kernel Module drm.
[ 11.261328] systemd[1]: Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module efi_pstore.
[ 11.261642] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ OK ] Finished Load Kernel Module fuse.
[ 11.261883] systemd[1]: Finished Load Kernel Module efi_pstore.
Mounting FUSE Control File System…
[ 11.262200] systemd[1]: modprobe@fuse.service: Deactivated successfully.
Mounting Kernel Configuration File System…
[ 11.262432] systemd[1]: Finished Load Kernel Module fuse.
[ OK ] Finished Remount Root and Kernel File Systems.
[ 11.263535] systemd[1]: Mounting FUSE Control File System…
[ OK ] Mounted FUSE Control File System.
[ 11.264553] systemd[1]: Mounting Kernel Configuration File System…
[ OK ] Mounted Kernel Configuration File System.
[ 11.267541] systemd[1]: Finished Remount Root and Kernel File Systems.
Starting Load/Save Random Seed…
[ 11.267747] systemd[1]: Mounted FUSE Control File System.
Starting Create System Users…
[ 11.267860] systemd[1]: Mounted Kernel Configuration File System.
[ OK ] Started Enable Rockchip camera engine rkaiq.
[ 11.267971] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ OK ] Finished Load Kernel Modules.
[ 11.268974] systemd[1]: Starting Load/Save Random Seed…
Starting Apply Kernel Variables…
[ 11.270011] systemd[1]: Starting Create System Users…
[ OK ] Finished Load/Save Random Seed.
[ 11.270721] systemd[1]: Started Enable Rockchip camera engine rkaiq.
[ OK ] Finished Apply Kernel Variables.
[ 11.271156] systemd[1]: Finished Load Kernel Modules.
[ 11.273361] systemd[1]: Starting Apply Kernel Variables…
[ OK ] Finished Create System Users.
Starting Create Static Device Nodes in /dev…
[ OK ] Finished Create Static Device Nodes in /dev.
Starting Rule-based Manage…for Device Events and Files…
[ OK ] Finished Set the console keyboard layout.
[ OK ] Reached target Preparation for Local File Systems.
[ OK ] Reached target Local File Systems.
Starting Enable support fo…l executable binary formats…
Starting Set console font and keymap…
Starting Tell Plymouth To Write Out Runtime Data…
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage…
[ OK ] Finished Set console font and keymap.
[ OK ] Finished Enable support fo…nal executable binary formats.
[ OK ] Finished Tell Plymouth To Write Out Runtime Data.
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Finished Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories…
[ OK ] Finished Create Volatile Files and Directories.
Starting Network Name Resolution…
Starting Network Time Synchronization…
Starting Record System Boot/Shutdown in UTMP…
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Reached target Path Units.
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Basic System.
[ OK ] Reached target System Time Set.
[ OK ] Started Trigger anacron every hour.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Daily dpkg database backup timer.
[ OK ] Started Periodic ext4 Onli…ata Check for All Filesystems.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Started Daily rotation of log files.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Accounts Service…
[ 11.631708] debugfs: File ‘Playback’ in directory ‘dapm’ already present!
[ 11.631731] debugfs: File ‘Capture’ in directory ‘dapm’ already present!
[ 11.634942] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 11.635558] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 11.636158] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
Starting Adbd for linux…
[ OK ] Started Run anacron jobs.
Starting enable ASYNC for Debian Display…
Starting Bluetooth management mechanism…
Starting bootcontrol…
[ OK ] Started D-Bus System Message Bus.
Starting Network Manager…
[ OK ] Started Save initial kernel messages after boot.
Starting Remove Stale Onli…t4 Metadata Check Snapshots…
Starting dblspace…
[ OK ] Started start firefly-fan service.
[ OK ] Started start/stop firefly-watchdog service.
Starting LSB: Load kernel …d to enable cpufreq scaling…
Starting Authorization Manager…
[ OK ] Started start rknn_server service.[ 11.699623] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 11.700412] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 11.701152] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
Starting System Logging Service…
Starting User Login Management…
[ OK ] Started Switch uart modes.
Starting Disk Manager…
Starting WPA supplicant…
[ OK ] Started Network Name Resolution.
[ OK ] Started dblspace.
[ OK ] Started bootcontrol.
[ OK ] Started enable ASYNC for Debian Display.
[ OK ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started System Logging Service.
[ OK ] Found device /dev/ttyFIQ0.
[ OK ] Started User Login Management.
[ OK ] Started WPA supplicant.
[ OK ] Started Network Manager.
[ OK ] Started Authorization Manager.
[ OK ] Started LSB: Load kernel m…ded to enable cpufreq scaling.
[ OK ] Reached target Network.
[ OK ] Started Download data for …ailed at package install time.
[ OK ] Started Check to see wheth…w version of Ubuntu available.
[ OK ] Reached target Timer Units.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting Modem Manager…
Starting Save/Restore Sound Card State…
Starting LSB: set CPUFreq kernel parameters…
Starting Net-Smp-Affinity…
Starting OpenBSD Secure Shell server…
Starting Hostname Service…
Starting Permit User Sessions…
Starting xrdp session manager…
[ OK ] Started Net-Smp-Affinity.
[ OK ] Finished Permit User Sessions.
Starting Auto X11VNC (detect real or virtual display)…
Starting Hold until boot process finishes up…
[ OK ] Started xrdp session manager.
Starting xrdp daemon…
[ OK ] Finished Save/Restore Sound Card State.
[ OK ] Reached target Sound Card.
[ OK ] Finished Hold until boot process finishes up.
[ OK ] Started Serial Getty on ttyFIQ0.
Starting Set console scheme…
[ OK ] Started Accounts Service.
[ OK ] Finished Set console scheme.
[ OK ] Created slice Slice /system/getty.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started LSB: set CPUFreq kernel parameters.
[ OK ] Started Hostname Service.
[ OK ] Started Disk Manager.
[ OK ] Started OpenBSD Secure Shell server.
Starting Network Manager Script Dispatcher Service…
[ OK ] Started Network Manager Script Dispatcher Service.
[ OK ] Started Modem Manager.
[ 12.146651] rk-pcie fe170000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=1
[ OK ] Started Bluetooth management mechanism.
[FAILED] Failed to start Adbd for linux.
See ‘systemctl status adbd.service’ for details.
[ OK ] Started Setup rockchip platform environment.
Starting Light Display Manager…
[ OK ] Started Light Display Manager.
[ OK ] Started WHGSBK Application.
[ OK ] Started xrdp daemon.
[ 13.166702] rk-pcie fe170000.pcie: failed to initialize host
[ OK ] Stopped Light Display Manager.
[ OK ] Started Auto X11VNC (detect real or virtual display).
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Record Runlevel Change in UTMP…
[ OK ] Finished Record Runlevel Change in UTMP.
rk3588JQusb转网口.rar (344 KB)
