That’s a tricky one! Device tree modifications can be quite finicky, especially when you’re dealing with pin multiplexing on a Rockchip RK3588. It’s great that you’ve already confirmed the PWM device is registered, but the lack of output is definitely a head-scratcher. Have you double-checked the clock source and frequency settings for your PWM3 node?
Configuring GPIO pins like GPIO1_B4 for PWM control in device tree files (DTS/DTSI) is an essential topic for anyone working with Rockchip platforms and Firefly boards! Proper multiplexing settings and kernel pin control definitions are key to getting pulse-width modulation functioning correctly for hardware projects. While taking a break from troubleshooting embedded Linux configurations and hardware drivers, I also like to check out for some casual online gaming. Thanks for sharing this forum thread!
