Server enviroment
How to disable X window on image and run Linux such as Ubuntu server - with console only?
Maybe it will be good to prepare the assembly image of Ubuntu Server.
It is possible. One workaround for a working framebuffer console is compiling it as kernel module and loading the modules at startup.
On Ubuntu you can change init mode by editing /etc/default/grub
More info here:
http://ubuntuhandbook.org/index.php/201 … nux-14-04/
HTH
비스를 제공해드려 아무런 걱정없이 NSE5_FNC_AD_7.6시험에 도전하도록 힘이 되어드립니다. Fast2test덤프를 사용하여 시험에서 통과하신 분이 전해주신 희소식이 Fast2test 덤프품질을 증명해드립니다.
This is truly a magnificent article, thank you for sharing. Unlock the door to promotions and salary raises with the free MuleSoft-Integration-Architect-I trustworthy pdf questions!
