more space for apps and root
any chance of a android rom with 4gig of apps space, Play Store and rooted ?
I am a newbie…lol…I’ve been playing with android tool 2.3 and managed to combine the firefly boot.img, kernel.img,resourses.img and misc.img with mo123’s HPHRK3288 rom v1.2 ( http://www.freaktab.com/showthread.php? … -(20141117
and am playing around with it…seems to work mostly, but wifi slow.
Also tried FinlessBob’s 3288 EZ Root Tool ( http://www.freaktab.com/showthread.php? … -Root-Tool )…it works.
You just need a modified parameter file.
Whenever I have flashed RK3288 ROM’s, I often place them into?RK3xxx_firmware_tools_5.10.28.00, which you can download here.
http://vondroid.com/threads/rk3xxx-firm … ony.14718/
Within the interface, there is a parameter tool that allows you to modify the partition to whatever size you want it to be.
You can also extract system and boot images should you want to make modifications there too.
Then you can repack ready for flashing.
If you look at the first post here
http://www.freaktab.com/showthread.php? … nsmart-R28
There are some root/unroot tools that you can apply which should work.
thanks…i’ll check that out
I have also read a post from a Firefly users that uses this easy to use root option.
Your article is so inspiring, thank you for sharing! New RCWA exam answers helped me get ahead in my career and earn more. Now, I’m offering it to you for free!
若者はより大きな雇用圧力に直面しています。競争力を高めることが不可欠です。私たちのSPLK-2002試験資料を選択することで、日々の仕事であなたの問題を解決できます。より実用的なスキルを得ることもできます。私たちのSPLK-2002試験資料には最新の知識と情報が含まれています。さらに、最も権威があるSPLK-2002認定試験資格証明書を取得することができます。だから、多くの人を引きつけます。
The article is truly an inspiration, thank you for posting it! The Plat-Admn-301 latest test labs questions are free—use them to unlock promotions and higher earnings!
I sincerely thank you for sharing such a powerful article! Study 1Z0-1056-24 tool offers valuable resources, made available to you free of charge.
