Bord can't enter Loader Mode
Hi , after flashing an android omg my board wand get in loader mode
here is the debug output
U-Boot 2014.10-RK3288-02 (Oct 30 2014 - 09:27:41)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
can’t find dts node for act8846
can’t find dts node for rk808
can’t find dts node for rk818
#Boot ver: 2014-10-30#2.17
sn:100612000100004E
no fuel gauge found
no fuel gauge found
read logo_on switch from dts [1]
pll_src = 0, dclk_hz = 205000000, dclk_div = 2
edp pll locked
Aux Transaction fail!
hw lt err:1
link train failed!
unable to config video
checkKey
vbus = 1
rockusb key pressed.
When i let it boot normally It’s detected as MSC mode in rkandroidtool but when i select “switch” i got nearly the same result.
What can i do ?
best regards
Pacopad
I solved my problem ,
i burned a linux image on SDCard and i formated the flash.
Then i can flash it normal again
Pacopad
Hello,??pacopad, would you please share your story a little bit more in detail?
This is a good reference of a new way for system recovery.
I think use “EraseFlash” can fix this problem
Here is the story. I flashed an Android image from a TV Box (i dont remember which one).
When the Android started , the board was detected as MSC device so i could do nothing with AndroidTool. When i tried to select “SWITCH” on Android tool or boot in Loader Mode , the board was n’t recognized on my computer. Nothing in USB Logs.
So i burned a linux distro for rk3288 on a SD Card and i formatted the flash with gparted.
After that the board was recognized in Loader Mode with AndroidTool
Best regards
Pacopad
Hi Pacopad, how do you burn a Linux distro for rk3288 to a SD card?
Which Linux firmware file are you using?
Are you using the Rockchip SD Firmware tool, or just using the dd command?
We’d like hear more to complete the “Boot_Ubuntu_from_sd” wiki page. Thank you.
Hi BusyBee,
i googled and find this distro for rk3288 https://plus.google.com/+IanMORRISON. I burned it with dd on a sdcard and boot.
After that i was able to erase the flash with gparted.
Dont hesitate if you want more details
Pacopad
Your article is awe-inducing, I’m grateful for your sharing! With the Valid PRINCE2Practitioner test online, I achieved career growth through a promotion and salary increase. Now, it’s free for everyone. Best of luck!
