GPU/VPU acceleration with ARM Mali driver for the firefly ?
Hello,
Is it possible to enable GPU/VPU acceleration for Ubuntu with the MALI drivers from ARM ?
There is already a discussion about this issue here:
http://community.arm.com/message/21330
Best Regards,
Peter Bauer
http://bitkistl.blogspot.com
It will take some time to fix the VPG/GPU driver.
Is there any chance of getting hold a detailed datasheet/reference manual for RK3288? I suspect Rockchip aren’t too friendly to such requests.
I had a quick look at the some of the code patches floating around its going to be an up hill struggle on the VPU side because its not related to Mali.?On the GPU side it may be more positive?however given the SOC is undocumented doesn’t help.
According to my knowledge, GPU/VPU acceleration with ARM Mali is only available in Android now.
If only libhybris (
https://github.com/libhybris/libhybris
) works on RK3288, we can take the full power of Android
to Linux.
"According to my knowledge, GPU/VPU acceleration with ARM Mali is only available in Android now.
If only libhybris (
https://github.com/libhybris/libhybris[\[i\] [/i]](https://github.com/libhybris/libhybris)[i]https://github.com/libhybris/libhybrishttps://github.com/libhybris/libhybris
[/i]
to Linux."
That statement is not completely correct although it does beg the question whether?fly-fire?is being marketed as ?‘Android development board’? Which may limit its appeal.?Some form GPU acceleration has to be?available for chromeOS to work under Linux which isn’t Android.
Android and Chrome OS are both variants of Linux. In the near future, Android/Chrome OS/Linux might meld into ONE.
Your article was so refreshing, I really appreciate it. Test Arch-302 discount has great content, and it’s provided to you without any fees.
It really broadened my horizons. Time to take the Valid exam L4M7 simulator fee exam. Hope I pass with flying colors!
Thank you for sharing this breathtaking article, it’s truly amazing! The Latest test CKS discount voucher exam questions are available for free—unlock your promotion and salary increase!
