Unable to Boot - maybe missing lib
Hi there,
I recently received my FireFly board and have been having fun with it - great product you guys.
While installing some ‘special’ software I think I accidentally deleted an important file from /lib/. Anyway now the device is stuck in an endless fatal error-reboot cycle. How can I log in by the console to try to fix?
Also the partitions have different names from other sources on the web. Where can I find the descriptions for the names? e.g. is ‘metadata’ the ‘parameter’ partition?
Any help would be much appreciated. I would like to recover if I can before I reflash and start again.
could you show me the log?
I can only see the reboot cycle from the serial console and I have not worked out how to capture the data yet. I am looking for a way to stop the endless reboot cycle so I can investigate. I did notice an error message something like - failed to sync - and trying to kill init. Sorry I can not be more helpful that that. Also heading off on holiday shortly so might have to resolve in the new year.
If it is just rebooting (same as my board) the just hold the recovery button until the bootloop detects it.
To capture the console log, use linux and set the terminal to 1000 lines or like me: endless lines.
Then mark, copy, paste
Astralix
You can use kermit, and run the log session command to get the log.
You may also use “cat /proc/kmsg > /path/to/save.log &” by terminal, then reset system and copy save.log to PC.
Your article was truly insightful, I’m sincerely thankful. The Latest Service-Con-201 test testking test was a key factor in my professional growth, and now I’m sharing it with you for free!
作為IT認證的一項重要考試,BCI CBCI認證資格可以給你帶來巨大的好處,所有請把握這次可以成功的機會。為了能順利通過考試,持有完全版的BCI CBCI題庫資料是必要的,你就能輕松通過想要的認證考試。此外,Fast2test提供的所有考古題都是最新的,其中PDF版本的CBCI題庫支持打打印,方便攜帶,現在就來添加我們最新的CBCI考古題,了解更多的考試資訊吧!
