Power Connector Size?
Im looking at getting a heavy duty power adapter here for overclocking and heavy stress testing
http://www.adafruit.com/products/658
What I want to know is does the board already have a 2.1mm plug or should i purchase the usb converter for the Power adapter?
http://www.adafruit.com/products/988
if this is in the wiki im sorry i missed it
From the pictures you can see the board has a female dc connector. But i do not know the size, i would like to know the size as well
The power interface on Firefly is DC4.0 standard.
Thanks, but in mm?
It’s not a standard 2.5/2.1mm DC socket (see my comment) ?so you will need the usb adapter.
Thanks again Jas :] alright i was hoping i didnt but its not a big deal
Want to try for 2.5ghz so need to make sure power isnt an issue
ECHOA:
just replaced mine with a 5v 3a supply and the plug I used was a 1.7mm X 4mm.? I wouldn’t go past the 3amp. Couldn’t find the usb type had to buy the one piece molded unit.
ECHOA:
just replaced mine with a 5v 3a supply and the plug I used was a 1.7mm X 4mm.? I wouldn’t go past the 3amp. Couldn’t find the usb type had to buy the one piece molded unit.I need a charger 5v 3a as well. Where can i buy a good one shipped to italy? I only saw usb chargers 5v 3a on aliexpress, but thy do not seem quite good fron feedback. So any suggestion? Can i buy one with 1.7mm x 4.4 mm, is it sure?
ECHOA:
i decided the 4amp one would be enough for my needs :] its cheaper too
any reason you wouldnt go beyond 3amp? as im aware the board will only pull what it needs so going beyond 3 would only mean more headroom.
http://www.adafruit.com/products/1466
Echoa:
The Firefly is internally protected at the dc plug with a 3 Amp fusible link. So if pull over 3 amps on the board you will be learning how to solder a new power plug on the board. Look at the schematics third page power supply upper right hand corner.
Echoa:
The Firefly is internally protected at the dc plug with a 3 Amp fusible link.? So if pull over 3 amps on the board?you will be?learning?how to solder a new power plug on the board.? Look at the schematics third page power supply upper right hand corner.
Ah ok, ty for the info
4amp shouldnt be a problem do you think? could you link me the 3amp you used?
edit: Nevermind found one
For anyone in the States looking for a 5v 3amp Power supply here is one
http://tinyurl.com/otmztokhttp://tinyurl.com/otmztokhttp://tinyurl.com/otmztok
and a usb adapter for it
http://www.adafruit.com/products/988http://www.adafruit.com/products/988http://www.adafruit.com/products/988http://www.adafruit.com/products/988http://www.adafruit.com/products/988http://www.adafruit.com/products/988http://www.adafruit.com/products/988http://www.adafruit.com/products/988
Outside US Aliexpress has them
http://tinyurl.com/note2uc
im not sure where to get the usb plug anywhere but adafruit though
so, is it right a power adapter with a standard 1.7x4.0 mm dc plug in line?
http://www.ebay.it/itm/360674178616
Please…
That was the size of the plug I ordered from EBAY with my new power supply and it worked perfectly.? Are you sure you need this or are you ordering your first one.? As I have mentioned I am not a normal user of the power for a normal user and the 2.5 amp if you have one should be fine.? Me I power everything from the board and with my pins in and pins out at times looks like noodle soup.
Im going to be attempting some heavy overclocking and using it as a micro console and media machine so itll see some decent loads so i want to make sure i dont have any power issues. Right now the highest i have is a 2.1amp which will have to work till i can order the 3amp plug.?
Your article is awe-inducing, I’m grateful for your sharing! Best wishes for your exams! Here’s the free New-Jersey-Real-Estate-Salesperson valid test sample questions material.
Thank you for your article, it really opened my eyes! I’m about to take the New study DP-600 questions ebook exam. Wishing for a great result!
The content is impressive, definitely worthy of a like. Upgrade your IT knowledge with free AZ-900 latest associate level test. Best wishes for success!
Your article is absolutely stunning, I’m so grateful for your share! Ready to face the RePA_Sales_S reliable exam book exam! Pray for good results!
This article made me realize many details that I had previously overlooked. The AI-900 latest real exam answers was my key to success—promotion and salary raise. It’s now free for everyone. Wishing you all a fast track to promotions!
