i’m trying to wire a 6 inches DSI LCD, i know where are the the 4 channel pins in the expansion headers, but i can’t find the following pins:
TE, RES (reset pin) HSYNC, AVDD+, AVDD-
Backlight input pins: LEDA1, LEDA2, LEDK1, LEDK2
plus, i need a VCC of 1.8V or 2.8V, i see that the camera inerface has output pins with this voltage (plus all the pins i can’t find in the expansion header), so, the expansion headers have it somewhere or i need to use the 5V and step it down to 1.8?
power is not a problem if i can’t supply it directly from the firefly, but what about RES, that is used to initialize the lcd? and AVDD+/- ? this needs to be also done apart from firefly? (i hope this is not true)?
What an insightful article, I truly appreciate your sharing it! Explore the rich content of 1z0-1080-25 latest real test answers, offered free to assist you.
The viewpoints in the article have been very insightful, and I’ve learned a great deal. Study MB-335 plan provides quality resources, and they’re free for you to use.
