Network Performance problem (with Gigabyte Lan)
Hi ,
I compiled an android image using instructions on the wiki. Compilation is ok but after flash there is no vidéo on hdmi nor on vga.
I plugged the board with serial connection, boot process seems ?k. I can access the prompt
What did i miss with kernel compil ??
Thx for answer
Pacopad
Could you please show us the log?
Hi Andy, here is the output?
http://pastebin.com/9TJcG62d
Actually , there is no display connected for the logs because my computer is too far away my tv set . Is it important ??
Thank you for you help?
Pacopad
The log seems not complete.
Did it stop at this point??[ ? 38.07457t? ?f???}???734): camsys_marvin(ed8e9510) is closed
Please revert back to factory firmware, and flash your self compiled kernel.img and resource.img to see if it works.
BTW, your kernel log is strange. We do not have “D1:camsys …” lines in normal boot.
Hi all,
i solved this problem by building a full upgrade.mg file.
I got a new problem
Wired Network performances are very very poor. Same as factory image.
I tried some other TV Box images and i found one , i dont remember which one, that offers good network speed.
Which side must i check , kernel or software ? My image is based on the latest SDK provided by Firefly.
Thx for return
Pacopad
Have you?plunged? the Antenna yet?
Hi
I got matter with wired (ethernet) network. I got ip from dhcp but transfer rates are very bad
Pacopad
Hi pacopad,  please do a iperf test on the wired ethernet and post the result here.
Hi Guys,?
i done iperf test on saturday , here is the report i got about 3,5 Mbits/s on a gigabyte switch (which work correctly with other devices like my ps3 and ps4) and i got 95 MBits/s when plugged on a 100MBps port of my internet box. I got about 30Mbps with wifi.?
I think there it is a kernel bug with mac part …
is it possible to force 100Mbps Full duplex on the board with android ??
Thank you for return ??
I got about 600-700 Mbits/s on a gigabyte switch
is it use 2.4G or 5G wifi when got?30Mbps with wifi.?
Hi ,?
it’s a 2.4Ghz wifi network
My giga switch is an airport extreme, there might be a incompatibility with the chipset inside , i’ll try this an other one?
Best regards
This content is outstanding, and my like is locked in. This DOP-C02 valid braindumps pdf helped me get promoted and earn more. Now, it’s free for everyone. Wishing you all success in reaching your promotions!
Pass4Test는CompTIA인증220-1102시험에 대하여 가이드를 해줄 수 있는 사이트입니다. Pass4Test는 여러분의 전업지식을 업그레이드시켜줄 수 잇고 또한 한번에CompTIA인증220-1102시험을 패스하도록 도와주는 사이트입니다. Pass4Test제공하는 자료들은 모두 it업계전문가들이 자신의 지식과 끈임없은 경헌등으로 만들어낸 퍼펙트 자료들입니다. 품질은 정확도 모두 보장되는 문제집입니다.CompTIA인증220-1102시험은 여러분이 it지식을 한층 업할수 잇는 시험이며 우리 또한 일년무료 업데이트서비스를 제공합니다.
This is an inspiring article, and I’m grateful for your share! Strengthen your IT expertise with free Latest ICF-ACC test report. Best of luck in your exams!
