i have OTT-928 (cs928) Android TV box HELP,can be used to boot linux? Dual boot ? firefly .IMG can be used to boot linux on any rk3288 ?
CS928 / OTT928 hardware specifications:
SoC – Rockchip RK3288 quad core CortexA17 @ 1.8 GHz + Mali-T764 GPU with support for OpenGL ES 1.1/2.0 /3.0, and OpenCL 1.1
System Memory – 2GB DDR3
Storage
OTT928 – 16GB NAND Flash + micro SD ?slot (up to 32 GB)
Connectivity – 100M/1000M Ethernet, dual band WiFi 802.11 b/g/n (2.4GHz/5GHz) and 802.11 a/c using external Wi-Fi antenna, and Bluetooth 4.0
Video Output – HDMI output, AV output (3.5mm jack)
Audio Output – HDMI, AV, and optical S/PDIF
USB – 3x USB 2.0 host port, 1x micro USB OTG
Camera – 5MP retractable camera
Power Supply – 5V/2A
you might be able to use the source to make something for this device but it will most likely not work. If youre feeling brave you can give it a try and see if it does but dont blame me if you brick your device xP
No power over usb ports in firefly so we can?t test because any mouse or keyboard work in any usb port!!!
Only UM3 firmware work burt no ethernet av sound and 4k decoding, but this firmware is fantastic, very complet. I like it a lot.
Any solution for usb power?
Thanks
Did you try the U3T version of software, curious personally. Have flashed Ugoos on Firefly before, but I understand that this is an Android 4.4.4 which is out in the Ugoos line which I would be interested in. The Pad-SDK version needs a lot of serious work, so I am fine with Ugoos doing the work particularly for one reason, their development team is also a lot more concerned and dedicated with Tweaking for better performance, it is going to run, but it is going to run better, faster, and push the limits.
Yes UT3 firmware doesn?t work in firefly because no power on USB ports! thats a shame because THE NEW firmware v 0.2.1 with Ubuntu 14.10 and Android for UT3 and UM3 is realy amaising! Very complete!
I am running UM3 firmware and for me is the best available firmware for rk3288 in the world.
This article has truly inspired me, thank you for sharing it! Free Reliable new MuleSoft-Integration-Associate test format test materials are now available! Best of luck to all exam-takers!
최근 더욱 많은 분들이Salesforce인증Certified-Business-Analyst시험에 도전해보려고 합니다. Itexamdump에서는 여러분들의 시간돠 돈을 절약해드리기 위하여 저렴한 가격에 최고의 품질을 지닌 퍼펙트한Salesforce인증Certified-Business-Analyst시험덤플르 제공해드려 고객님의 시험준비에 편안함을 선물해드립니다. Itexamdump제품을 한번 믿어보세요.
