Using GCC compile your code in Linux environment
As a beginner on programming, it’s better to use GCC to compile the program. Then you can know more about the
process of a program compile and link. I advice you to using vi/vim to edit the code.
GCC provide so many command option. However, you don’t have to learn all the option. As a beginner, you only need
to be familiar with several option. Then you can begin to write your program.
  1. Common compiler command options
For example, the source file is test.c
(1). Compile and link with no option
<font color="rgb(88, 88, 88)"><font face="Arial, Helvetica, sans-serif"><font style="font-size: 13px">#gcc test.c</font></font></font>
Function: pretreatment, assemble, compile and link to an executable program.There is no output specified. “a.out” is
the default output file. After compiling successfully ,there will be a new file “a.out” in the current path. You can execute
the command to run the program.
<font color="rgb(88, 88, 88)"><font face="Arial, Helvetica, sans-serif"><font style="font-size: 13px">#./a.out</font></font></font>
(2). Option -o
<font color="rgb(88, 88, 88)"><font face="Arial, Helvetica, sans-serif"><font style="font-size: 13px">#gcc test.c -o test</font></font></font>
Function: pretreatment, assemble, compile and link to an executable program. The “-o” option is used to specify
the output file. After compiling successfully , there will be a new file “test” in the current path. You can execute the
#./test
(3). Option -E
#gcc -E test.c -o test.i
Fuction: pretreatment the “test.c” and assemble to “test.s”.
(5). Option -c
#gcc -c test.s
Function: compile the “test.s” to “test.o”
(6). Option -o
#gcc test.o -o test
Function: link “test.o” to “test”
(7). Option -O
#gcc -O1 test.c -o test
Using the level 1 to compile the file. The levels are 1 to 3. Higher level with
(8). Compile the C++ program file using the std libs..
#gcc test.cpp -o test -lstdc++
Function: compile the test.cpp and link to test execute file. -lstdc++ means the std libs.
  1. Compile more than one files.
If you want to compile more than one files. You can do it as the follow ways:
For example, you are going to compile these two files test.c and testfun.c
(1). Compile all files at once.
#gcc testfunc.c test.c -o test
Function: compile the testfun.c and test.c, link to an executive file.
(2). Compile the files respectively and link them to an output file.
#gcc -c testfun.c //compile testfun.c to testfun.o
#gcc -c test.c //compile test.c to test.o
#gcc -o testfun.o test.o -o test // link testfun.o and test.o to test file.
Comparing the two ways above, the fist way need to compile all files at every compile. The second way just compile
the files that have been modified, so it don’t have to compile all files at every compile.
“test” is a bad name for an application on *nix, since there is mostly already a program called “test”-
Your article is absolutely brilliant, thank you for sharing! Wishing you success! Here are the free Reliable Data-Con-101 test guide materials resources for you!
I’m really grateful for your article, it left an indelible mark. This GH-100 latest visual cert test helped me move up in my career and get a raise. Now it’s free to all. Wishing you success in your career journey!
Your article is magnificent, thank you for sharing it with us! This is the Top AP-215 questions exam that led to my promotion and salary increase, and it’s free today for all. Best of luck on your career path!
I sincerely thank you for sharing this heart-shaking article! This Valid MB-820 test materials helped me get promoted and earn more. Now, it’s free for everyone. Wishing you all success in reaching your promotions!
Itexamdump의 ISA 인증 ISA-IEC-62443시험덤프공부자료는 pdf버전과 소프트웨어버전 두가지 버전으로 제공되는데 ISA 인증 ISA-IEC-62443실제시험예상문제가 포함되어있습니다.덤프의 예상문제는 ISA 인증 ISA-IEC-62443실제시험의 대부분 문제를 적중하여 높은 통과율과 점유율을 자랑하고 있습니다. Itexamdump의 ISA 인증 ISA-IEC-62443덤프를 선택하시면 IT자격증 취득에 더할것 없는 힘이 될것입니다.
