My Firefly is dead
Went to switch it on this morning and it is completely dead.
Hooked it up to my PC but it isn’t being recognised there either.
Checked the status of the ac unit and that is fine.
What had you done to it?
Try attach a serial adapter to it and see if anything comes out.
I just started it up as usual.
Tried a serial adapter but getting?absolutely nothing.
If the on board flash is trashed connect a micro usb cable from the otg port to a PC as the device may be in MaskRom Mode.?Then use something like RKAndroidTool, RKBatchTool?to see if the device is detected.
I tried to see if it was in maskrom mode and used all of the available tools but none see the firefly in any way, shape or form.
Please use a?multimeter to measure the voltages described in the attached picture, and post the result.
(The full?component reference file is at
http://www.t-firefly.com/download/firef … 30_pos.pdf
Took it to a local sparky, who ran the multimeter tests over it and found no life whatsoever.
if no power and no log, you should check you hardware.
It was a truly rewarding and enlightening piece of writing. Ready to take on the AZ-204 updated demo exam! Fingers crossed!
Your article is brilliant, thank you for providing this amazing share! Elevate your IT skills and grab free Valid study questions Ind-Dev-201 free download. Good luck with everything!
