I’ve built an Android image as per the wiki instructions and flashed the follow to replace the exsiting emmc partitions from the directory rockdev/Image-rk3288.
misc.img
boot.img
system.img
resource.img
kernel.img
Android fails to start, boot output is below. Unfortunately the instructions are vague about what need be flashed.
U-Boot 2014.10-RK3288-02 (Dec 19 2014 - 19:50:49)
CPU: rk3288
CPU's clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
can't find dts node for ricoh619
pmic:act8846
#Boot ver: 2014-12-19#2.17
sn:1006120001000110
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
failed to load fdt from boot!
kernel @ 0x02000000 (0x005f05b0)
ramdisk @ 0x04bf0000 (0x00120f7d)
Secure Boot state: 0
bootrk: do_bootm_linux...
Loading Device Tree to 0480c000, end 04827200 ... OK
Starting kernel ...[ 0.000000] Booting Linux on physical CPU 0x500
[ 0.000000] Linux version 3.10.0 (mtx512@mtx512-Inspiron-620) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #4 SMP PREEMP4
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1e86000 s13952 r8192 d14720 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 0
[ 0.000000] Memory: 2047276k/2047276k available, 49876k reserved, 1318912K highmem
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a3b784 (10446 kB)
[ 0.000000] .init : 0xc0a3c000 - 0xc0c8c680 (2370 kB)
[ 0.000000] .data : 0xc0c8e000 - 0xc0d30f18 ( 652 kB)
[ 0.000000] .bss : 0xc0d30f18 - 0xc0e4d9cc (1139 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rkclk_init_clks: cnt_rate = 32
[ 0.000000] Architected local timer running at 24.00MHz (phys).
[ 0.000000] process version: 0
[ 0.000000] channel:0, lkg:0
[ 0.000000] target-temp:95
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:0
[ 0.000000] Console: colour dummy device 80x30
[ 0.542594] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.542644] pid_max: default: 32768 minimum: 301
[ 0.542987] Security Framework initialized
[ 0.543027] SELinux: Initializing.
[ 0.543256] Mount-cache hash table entries: 512
[ 0.545284] Initializing cgroup subsys debug
[ 0.545329] Initializing cgroup subsys freezer
[ 0.545417] CPU: Testing write buffer coherency: ok
[ 0.546163] /cpus/cpu@0 missing clock-frequency property
[ 0.546205] /cpus/cpu@1 missing clock-frequency property
[ 0.546238] /cpus/cpu@2 missing clock-frequency property
[ 0.546271] /cpus/cpu@3 missing clock-frequency property
[ 0.546391] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.546501] Setting up static identity map for 0xc0765120 - 0xc0765178
[ 0.550878] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x154a (version 3.0)
[ 0.630146] CPU1: Booted secondary processor
[ 0.630234] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.649879] CPU2: Booted secondary processor
[ 0.649962] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.669663] CPU3: Booted secondary processor
[ 0.669744] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.670097] Brought up 4 CPUs
[ 0.670197] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.670227] CPU: All CPU(s) started in SVC mode.
[ 0.672448] devtmpfs: initialized
[ 0.690429] pinctrl core: initialized pinctrl subsystem
[ 0.691179] regulator-dummy: no parameters
[ 0.692795] NET: Registered protocol family 16
[ 0.698470] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.699425] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0e28c94 (version 0.1)
[ 0.699916] Registered FIQ tty driver
[ 0.703401] console [ttyFIQ0] enabled
[ 0.703949] Registered fiq debugger ttyFIQ0
[ 0.706299] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.706387] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.706476] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.706549] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.706821] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.707059] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.707291] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.707520] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.707748] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.707977] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.708204] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.708506] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.708762] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.709002] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.709061] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.709114] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.709167] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.710909] rockchip_interrupts_register:bank_num=7
[ 0.717596] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.717683] of_get_gpio_init_config:gpio[1] = 233, value = 0
[ 0.717768] of_get_gpio_init_config:gpio[2] = 136, value = 0
[ 0.717978] rockchip_pinctrl_probe:init ok
[ 0.738644] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.739003] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.739062] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.739652] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.739980] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.740034] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.740584] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.740910] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.740964] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.741531] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.741857] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.741911] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.742494] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.742882] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.742937] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.743513] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.743836] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.743890] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.744507] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.744887] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.744941] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.750711] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.750765] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.751403] DDR DEBUG: version 1.00 20140603
[ 0.751487] DDR DEBUG: Channel a:
[ 0.751524] DDR DEBUG: DDR3 Device
[ 0.751572] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.751614] DDR DEBUG: Channel b:
[ 0.751646] DDR DEBUG: DDR3 Device
[ 0.751693] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.751736] DDR DEBUG: addr=0xd36000
[ 0.751776] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.751817] DDR DEBUG: socAddr[0]=0xd36000, socAddr[1]=0xd36100
[ 0.751859] DDR DEBUG: chAddr[0]=0xd36000, chAddr[1]=0xd36000
[ 0.751904] DDR DEBUG: dtar[0]=0x601a6000, dtar[1]=0x601a6000
[ 0.752063] DDR DEBUG: init success!!! freq=200MHz
[ 0.752100] DDR DEBUG: Channel a:
[ 0.752149] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.752208] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.752268] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.752326] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.752380] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.752424] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.752463] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.752499] DDR DEBUG: Channel b:
[ 0.752546] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.752606] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.752664] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.752722] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.752776] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.752818] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.752857] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.829554] bio: create slabat 0
[ 0.831405] Enter firefly_noatx8_init
[ 0.831894] firefly_noatx8_probe 51
[ 0.832614] SCSI subsystem initialized
[ 0.833104] usbcore: registered new interface driver usbfs
[ 0.833255] usbcore: registered new interface driver hub
[ 0.833532] usbcore: registered new device driver usb
[ 0.836598] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.840937] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.842403] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.843851] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.844681] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.847570] media: Linux media interface: v0.10
[ 0.847712] Linux video capture interface: v2.00
[ 0.847870] pps_core: LinuxPPS API ver. 1 registered
[ 0.847914] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[ 0.847997] PTP clock support registered
[ 0.848442] rockchip_temp_probe,line=362
[ 0.849225] tsadc ff280000.tsadc: initialized
[ 0.850442] rockchip_ion_parse_dt: num_heaps = 1
[ 0.850503] 0: 0 3 vmalloc 0x (null)
[ 0.851288] Rockchip ion module is successfully loaded (v1.0)
[ 0.851817] Advanced Linux Sound Architecture Driver Initialized.
[ 0.853034] Bluetooth: Core ver 2.16
[ 0.853161] NET: Registered protocol family 31
[ 0.853203] Bluetooth: HCI device and connection manager initialized
[ 0.853264] Bluetooth: HCI socket layer initialized
[ 0.853315] Bluetooth: L2CAP socket layer initialized
[ 0.853408] Bluetooth: SCO socket layer initialized
[ 0.854059] cfg80211: Calling CRDA to update world regulatory domain
[ 0.856302] act8846_i2c_probe,line=898
[ 0.857695] act8846_parse_dt,line=746
[ 0.859217] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.859290] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.859349] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.859407] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.861867] act_dcdc1: 1200 mV
[ 0.865546] vccio: 3300 mV
[ 0.868194] vdd_logic: 7001500 mV at 1100 mV
[ 0.871886] act_dcdc4: 2000 mV
[ 0.873702] vccio_sd: 18003300 mV at 3300 mV
[ 0.876612] act_ldo2: 1050 mV
[ 0.879470] act_ldo3: 1800 mV
[ 0.882325] act_ldo4: 3300 mV
[ 0.885164] act_ldo5: 3300 mV
[ 0.888000] act_ldo6: 1100 mV
[ 0.890872] vcc_18: 1800 mV
[ 0.893771] act_ldo8: 1850 mV
[ 0.900298] vdd_arm: 7121500 mV at 1000 mV
[ 0.906662] vdd_gpu: 7121500 mV at 1000 mV
[ 0.907615] rk808_i2c_probe,line=1368
[ 0.909257] The device is not rk808 -11
[ 0.909516] rk808: probe of 0-001b failed with error -11
[ 0.914423] Switching to clocksource arch_sys_counter
[ 0.934962] usb_battery_charger_detect_synop , battery_charger_detect 1, pass DCD, dcd_state = 1
[ 0.980284] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.980353] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.981431] rk-screen rk_screen.9: rockchip screen probe success
[ 0.982219] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.982952] rk32-edp ff970000.edp: screen is not edp!
[ 0.983022] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.984273] rk3288-lcdc lcdc0: can't find power_ctr node for lcdc0
[ 0.985028] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.986050] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.986582] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.987134] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.987676] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.989427] rk_iommu ff930300.vopb_mmu: (vopb) Enabled
[ 0.989853] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.989925] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.111728] alloc_buffer:ion_phy_addr=0x10000000
[ 1.155043] fb0:phy:10000000>>vir:f0191000>>len:0x1800000
[ 1.297568] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 1.298803] rockchip_set_mux:warning ignore bank num 15
[ 1.299248] rockchip_set_mux:warning ignore bank num 15
[ 1.299642] rockchip_set_mux:warning ignore bank num 15
[ 1.300029] rockchip_set_mux:warning ignore bank num 15
[ 1.300425] rockchip_set_mux:warning ignore bank num 15
[ 1.300817] rockchip_set_mux:warning ignore bank num 15
[ 1.301708] rockchip_set_mux:warning ignore bank num 15
[ 1.302248] rockchip_set_mux:warning ignore bank num 15
[ 1.303078] rockchip_set_mux:warning ignore bank num 15
[ 1.303573] rockchip_set_mux:warning ignore bank num 15
[ 1.304397] rockchip_set_mux:warning ignore bank num 15
[ 1.304887] rockchip_set_mux:warning ignore bank num 15
[ 1.305724] rockchip_set_mux:warning ignore bank num 15
[ 1.306223] rockchip_set_mux:warning ignore bank num 15
[ 1.329074] NET: Registered protocol family 2
[ 1.330487] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.330977] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.331473] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.331628] TCP: reno registered
[ 1.331681] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.331810] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.332450] NET: Registered protocol family 1
[ 1.333048] Unpacking initramfs...
[ 1.559100] Freeing initrd memory: 1152K (c4bf0000 - c4d10000)
[ 1.561393] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.562923] probe device ff9a0000.vpu_service
[ 1.563389] vpu_service: power on
[ 1.564542] checking hw id 4831
[ 1.565528] vpu_service set to auto frequency mode
[ 1.565693] vcodec vpu_service: vcodec ion client create success!
[ 1.566847] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled
[ 1.566952] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled
[ 1.567006] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e277000
[ 1.567053] vpu_service: power off...
[ 1.567137] done
[ 1.567170] init success
[ 1.567328] probe device ff9c0000.hevc_service
[ 1.567962] hevc_service: power on
[ 1.569084] checking hw id 6867
[ 1.569892] vcodec hevc_service: vcodec ion client create success!
[ 1.570836] rk_iommu ff9c0440.hevc_mmu: (hevc) Enabled
[ 1.570942] rk_iommu ff9c0440.hevc_mmu: (hevc) Disabled
[ 1.570995] rk_iommu ff9c0440.hevc_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e274000
[ 1.571043] hevc_service: power off...
[ 1.571130] done
[ 1.571163] init success
[ 1.571517] rknandbase v1.0 2014-03-31
[ 1.572164] rknand_probe clk rate = 148500000
[ 1.572542] rknand_driver:ret = 0
[ 1.573619] audit: initializing netlink socket (disabled)
[ 1.573731] type=2000 audit(1.030:1): initialized
[ 1.575977] bounce pool size: 64 pages
[ 1.591466] fuse init (API version 7.22)
[ 1.592685] msgmni has been set to 1456
[ 1.598572] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.598637] io scheduler noop registered
[ 1.598678] io scheduler deadline registered
[ 1.599023] io scheduler cfq registered (default)
[ 1.600486] Console: switching to colour frame buffer device 240x67
[ 1.655372] rga ff920000.rga: rga ion client create success!
[ 1.655806] rga: Driver loaded succesfully
[ 1.657276] IEP Power ON
[ 1.657391] iep ion client create success!
[ 1.658416] rk_iommu ff900800.iep_mmu: (iep) Enabled
[ 1.658507] IEP Power OFF
[ 1.658552] rk_iommu ff900800.iep_mmu: (iep) Disabled
[ 1.658604] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26a000
[ 1.658667] IEP Driver loaded succesfully
[ 1.658965] Module initialized.
[ 1.661407] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.661480] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.665745] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.665816] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.666572] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
[ 1.666637] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
[ 1.666679] pwm_regulator_probe:error
[ 1.666751] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
[ 1.667818] rk_serial.c v1.8 2014-03-04
[ 1.668464] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.669060] serial ff180000.serial: membase 0xf0172000
[ 1.678615] loop: module loaded
[ 1.680478] SCSI Media Changer driver v0.25
[ 1.681562] tun: Universal TUN/TAP device driver, 1.6
[ 1.681610] tun: (C) 1999-2004 Max Krasnyansky
[ 1.683334] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.683393] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 1.683442] stmmac_probe_config_dt: clock input or output? (input).
[ 1.683488] stmmac_probe_config_dt: TX delay(0x30).
[ 1.683529] stmmac_probe_config_dt: RX delay(0x10).
[ 1.683653] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 1.683694] stmmc_pltfr_init:
[ 1.683730] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.683805] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed.
[ 1.683845] stmmc_pltfr_init: init for RGMII
[ 1.683885] tx delay=0x30
[ 1.683885] rx delay=0x10
[ 1.685414] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.685456] Normal descriptors
[ 1.685487] Ring mode enabled
[ 1.685520] DMA HW capability register supported
[ 1.685558] RX Checksum Offload Engine supported (type 2)
[ 1.685596] TX Checksum insertion supported
[ 1.685630] Wake-Up On Lan supported
[ 1.685761] Enable RX Mitigation via HW Watchdog Timer
[ 1.687104] PPP generic driver version 2.4.2
[ 1.687585] PPP BSD Compression module registered
[ 1.687631] PPP Deflate Compression module registered
[ 1.687696] PPP MPPE Compression module registered
[ 1.687738] NET: Registered protocol family 24
[ 1.687833] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.687882] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.687927] Rockchip WiFi SYS interface (V1.00) ...
[ 1.688165] usbcore: registered new interface driver catc
[ 1.688294] usbcore: registered new interface driver kaweth
[ 1.688340] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.688468] usbcore: registered new interface driver pegasus
[ 1.688605] usbcore: registered new interface driver rtl8150
[ 1.688733] usbcore: registered new interface driver r8152
[ 1.688775] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.688972] usbcore: registered new interface driver hso
[ 1.689119] usbcore: registered new interface driver asix
[ 1.689243] usbcore: registered new interface driver ax88179_178a
[ 1.689368] usbcore: registered new interface driver cdc_ether
[ 1.689530] usbcore: registered new interface driver cdc_eem
[ 1.689658] usbcore: registered new interface driver dm9601
[ 1.689781] usbcore: registered new interface driver dm9620
[ 1.689937] usbcore: registered new interface driver smsc75xx
[ 1.690091] usbcore: registered new interface driver smsc95xx
[ 1.690217] usbcore: registered new interface driver gl620a
[ 1.690352] usbcore: registered new interface driver net1080
[ 1.690483] usbcore: registered new interface driver plusb
[ 1.690614] usbcore: registered new interface driver rndis_host
[ 1.690740] usbcore: registered new interface driver cdc_subset
[ 1.690860] usbcore: registered new interface driver zaurus
[ 1.690993] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.691170] usbcore: registered new interface driver int51x1
[ 1.691299] usbcore: registered new interface driver kalmia
[ 1.691450] usbcore: registered new interface driver ipheth
[ 1.691595] usbcore: registered new interface driver sierra_net
[ 1.691727] usbcore: registered new interface driver cx82310_eth
[ 1.691886] usbcore: registered new interface driver cdc_ncm
[ 1.692087] usbcore: registered new interface driver qmi_wwan
[ 1.692221] usbcore: registered new interface driver cdc_mbim
[ 1.692265] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.695554] ehci_rk_probe f1a00000 f1a00010
[ 1.695613] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
[ 1.695710] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 1.696712] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 1.711695] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
[ 1.711929] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.711993] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.712048] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
[ 1.712100] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.712147] usb usb1: SerialNumber: ff500000.usb
[ 1.713526] hub 1-0:1.0: USB hub found
[ 1.713608] hub 1-0:1.0: 1 port detected
[ 1.741183] ehci_rk_probe ok
[ 1.741629] usbcore: registered new interface driver cdc_acm
[ 1.741675] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.741878] usbcore: registered new interface driver usblp
[ 1.742027] usbcore: registered new interface driver cdc_wdm
[ 1.742239] usbcore: registered new interface driver usb-storage
[ 1.742371] usbcore: registered new interface driver ums-alauda
[ 1.742513] usbcore: registered new interface driver ums-cypress
[ 1.742645] usbcore: registered new interface driver ums-datafab
[ 1.742772] usbcore: registered new interface driver ums_eneub6250
[ 1.742912] usbcore: registered new interface driver ums-freecom
[ 1.743042] usbcore: registered new interface driver ums-isd200
[ 1.743169] usbcore: registered new interface driver ums-jumpshot
[ 1.743295] usbcore: registered new interface driver ums-karma
[ 1.743422] usbcore: registered new interface driver ums-onetouch
[ 1.743548] usbcore: registered new interface driver ums-sddr09
[ 1.743673] usbcore: registered new interface driver ums-sddr55
[ 1.743799] usbcore: registered new interface driver ums-usbat
[ 1.744086] usbcore: registered new interface driver usbserial
[ 1.744225] usbcore: registered new interface driver usbserial_generic
[ 1.744335] usbserial: USB Serial support registered for generic
[ 1.744472] usbcore: registered new interface driver option
[ 1.744579] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.744834] usbcore: registered new interface driver trancevibrator
[ 1.744879] usb20_otg: version 3.10a 21-DEC-2012
[ 1.745935] f1a80040
[ 1.745984] Core Release: 3.10a
[ 1.746023] Setting default values for core params
[ 1.746435] Using Buffer DMA mode
[ 1.746477] Periodic Transfer Interrupt Enhancement - disabled
[ 1.746518] Multiprocessor Interrupt Enhancement - disabled
[ 1.746560] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.746597] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.746641] Dedicated Tx FIFOs mode
[ 1.746698] pcd_init otg_dev = ed9b2b40
[ 1.747194] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.747291] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.747399] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.747584] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.747644] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.747698] usb usb2: Product: DWC OTG Controller
[ 1.747745] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.747793] usb usb2: SerialNumber: ff580000.usb
[ 1.749115] hub 2-0:1.0: USB hub found
[ 1.749195] hub 2-0:1.0: 1 port detected
[ 1.750116] usb20_host: version 3.10a 21-DEC-2012
[ 1.753673] f1b00040
[ 1.753722] Core Release: 3.10a
[ 1.753761] Setting default values for core params
[ 1.754206] Using Buffer DMA mode
[ 1.754248] Periodic Transfer Interrupt Enhancement - disabled
[ 1.754286] Multiprocessor Interrupt Enhancement - disabled
[ 1.754327] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.754363] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.754446] usb20_host ff540000.usb: DWC OTG Controller
[ 1.754536] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 1.754639] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.754801] Init: Power Port (0)
[ 1.754984] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.755045] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.755099] usb usb3: Product: DWC OTG Controller
[ 1.755147] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.755195] usb usb3: SerialNumber: ff540000.usb
[ 1.756547] hub 3-0:1.0: USB hub found
[ 1.756624] hub 3-0:1.0: 1 port detected
[ 1.758270] .. rk pwm remotectl v1.0 init
[ 1.758536] remotectl probe j=0x0
[ 1.759035] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 1.759667] pwm enable val=0x646205
[ 1.760549] usbcore: registered new interface driver xpad
[ 1.760720] usbcore: registered new interface driver usb_acecad
[ 1.760955] usbcore: registered new interface driver aiptek
[ 1.761131] usbcore: registered new interface driver gtco
[ 1.761293] usbcore: registered new interface driver hanwang
[ 1.761447] usbcore: registered new interface driver kbtab
[ 1.761625] usbcore: registered new interface driver wacom
[ 1.762739] sensor_register_slave:mma8452,id=17
[ 1.762788] sensor_register_slave:cm3217,id=44
[ 1.762828] sensor_register_slave:cm3218,id=45
[ 1.769220] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.769382] i2c /dev entries driver
[ 1.771614] IR NEC protocol handler initialized
[ 1.771664] IR RC5(x) protocol handler initialized
[ 1.771702] IR RC6 protocol handler initialized
[ 1.771738] IR JVC protocol handler initialized
[ 1.771774] IR Sony protocol handler initialized
[ 1.771809] IR RC5 (streamzap) protocol handler initialized
[ 1.771847] IR SANYO protocol handler initialized
[ 1.771884] IR MCE Keyboard/mouse protocol handler initialized
[ 1.772133] usbcore: registered new interface driver uvcvideo
[ 1.772175] USB Video Class driver (1.1.1)
[ 1.772222] CamSys driver version: v0.19.0, CamSys head file version: v0.8.0
[ 1.775380] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236
[ 1.775469] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request
[ 1.775533] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0
[ 1.775598] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high
[ 1.775823] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.776327] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf19b0000 size)
[ 1.778569] D1:camsys_platform_probe(1208): ff910000.isp memory:
[ 1.778632] D1:camsys_platform_probe(1218): Register memory (phy: 0xff910000 vir: 0xf19e0000 size: 0x10000)
[ 1.778691] D1:camsys_platform_probe(1213): I2c memory (phy: 0x2da43000 vir: 0xeda43000 size: 0x1000)
[ 1.778744] D1:camsys_platform_probe(1233): Probe ff910000.isp device success
[ 1.781685] device-mapper: uevent: version 1.0.3
[ 1.782420] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.783342] Bluetooth: HCI UART driver ver 2.2
[ 1.783396] Bluetooth: HCI H4 protocol initialized
[ 1.783436] Bluetooth: HCILL protocol initialized
[ 1.789324] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.789906] cpuidle: using governor ladder
[ 1.789952] cpuidle: using governor menu
[ 1.790070] Synopsys Designware Multimedia Card Interface Driver
[ 1.790900] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.791772] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.792273] 3230..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.792329] Line3235..dw_mci_init_slot: The rk_sdmmc Ver 1.12 2014-07-08
[ 1.792739] 1357..dw_mci_set_ios: no card. [mmc0]
[ 1.810037] 1357..dw_mci_set_ios: no card. [mmc0]
[ 1.829765] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.829797] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.829822] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.830184] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.830950] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.831134] 3224..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.831666] 1357..dw_mci_set_ios: no card. [mmc1]
[ 1.849389] 1357..dw_mci_set_ios: no card. [mmc1]
[ 1.861880] mmc0: BKOPS_EN bit is not set
[ 1.863798] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.866107] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.866135] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.869239] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.869258] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.869607] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.869838] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.869993] 3230..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.870110] 1357..dw_mci_set_ios: no card. [mmc2]
[ 1.881165] rk_sdmmc: BOOT
[ 1.881165] execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_0 SDMMC_SHIFT_DEGREE_90 SDMMC_SHIFT_DEGREE_180 SDM]
[ 1.881268] mmc0: new HS200 MMC card at address 0001
[ 1.881527] mmcblk0: mmc0:0001 AWMB3R 14.5 GiB
[ 1.881838] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 1.881851] misc: 0x000800000 -- 0x000c00000 (4 MB)
[ 1.881861] resource: 0x000c00000 -- 0x001c00000 (16 MB)
[ 1.881869] kernel: 0x001c00000 -- 0x002c00000 (16 MB)
[ 1.881878] boot: 0x002c00000 -- 0x004c00000 (32 MB)
[ 1.881887] recovery: 0x004c00000 -- 0x006c00000 (32 MB)
[ 1.881896] backup: 0x006c00000 -- 0x00a000000 (52 MB)
[ 1.881905] cache: 0x00a000000 -- 0x012000000 (128 MB)
[ 1.881914] kpanic: 0x012000000 -- 0x012400000 (4 MB)
[ 1.881923] system: 0x012400000 -- 0x042400000 (768 MB)
[ 1.881932] metadata: 0x042400000 -- 0x042800000 (4 MB)
[ 1.881941] userdata: 0x042800000 -- 0x082800000 (1024 MB)
[ 1.881950] linuxroot: 0x082800000 -- 0x146800000 (3136 MB)
[ 1.881959] user: 0x146800000 -- 0x3a3a00000 (9682 MB)
[ 1.881982] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141357..dw_mci_set_ios: no card. [mmc1]
[ 1.888736] 1357..dw_mci_set_ios: no card. [mmc2]
[ 1.908414] 1357..dw_mci_set_ios: no card. [mmc2]
[ 1.908611] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.908623] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.908872] leds-gpio leds.31: pins are not configured from the driver
[ 1.909099] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.910394] usbcore: registered new interface driver usbhid
[ 1.910405] usbhid: USB HID core driver
[ 1.910716] ashmem: initialized
[ 1.910819] logger: created 256K log 'log_main'
[ 1.910918] logger: created 256K log 'log_events'
[ 1.911005] logger: created 256K log 'log_radio'
[ 1.911096] logger: created 256K log 'log_system'
[ 1.912100] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input1
[ 1.912674] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by smp; cannot claim for 2-0010
[ 1.912690] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.912702] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.912714] ES8323 2-0010: Error applying setting, reverse things back
[ 1.912999] es8323 probe i2c recv ok
[ 1.913217] i2c-core: driver [ES8323] using legacy suspend method
[ 1.913228] i2c-core: driver [ES8323] using legacy resume method
[ 1.913552] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
[ 1.913583] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 1.913602] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
[ 1.913828] es8323_probe
[ 1.913913] es8323_probe:register ISR (irq=194)
[ 2.548366] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> NULL --> Left Line Mux
[ 2.548378] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> NULL -> Left Line Mux
[ 2.548390] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> NULL --> Left Line Mux
[ 2.548399] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> NULL -> Left Line Mux
[ 2.548409] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> NULL --> Left Line Mux
[ 2.548418] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> NULL -> Left Line Mux
[ 2.548428] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> NULL --> Right Line Mux
[ 2.548436] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> NULL -> Right Line Mux
[ 2.548446] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> NULL --> Right Line Mux
[ 2.548454] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> NULL -> Right Line Mux
[ 2.548463] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> NULL --> Right Line Mux
[ 2.548472] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> NULL -> Right Line Mux
[ 2.548481] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left PGA Mux
[ 2.548489] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left PGA Mux
[ 2.548498] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left PGA Mux
[ 2.548506] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left PGA Mux
[ 2.548514] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> LAMP --> Left PGA Mux
[ 2.548523] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> LAMP -> Left PGA Mux
[ 2.548532] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right PGA Mux
[ 2.548540] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right PGA Mux
[ 2.548549] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right PGA Mux
[ 2.548556] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right PGA Mux
[ 2.548566] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> RAMP --> Right PGA Mux
[ 2.548574] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> RAMP -> Right PGA Mux
[ 2.548583] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Differential Mux
[ 2.548591] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Differential Mux
[ 2.548600] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Differential Mux
[ 2.548608] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Differential Mux
[ 2.548617] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Differential Mux
[ 2.548625] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Differential Mux
[ 2.548634] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Differential Mux
[ 2.548642] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Differential Mux
[ 2.548663] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left Line Mux
[ 2.548671] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left Line Mux
[ 2.548680] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left Line Mux
[ 2.548688] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left Line Mux
[ 2.548697] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> LAMP --> Left Line Mux
[ 2.548706] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> LAMP -> Left Line Mux
[ 2.548715] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right Line Mux
[ 2.548724] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right Line Mux
[ 2.548733] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right Line Mux
[ 2.548741] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right Line Mux
[ 2.548750] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> RAMP --> Right Line Mux
[ 2.548758] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> RAMP -> Right Line Mux
[ 2.548884] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 2.548896] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 2.548906] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 2.548915] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 2.548947] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 2.551789] Enter::rk29_es8323_init----135
[ 2.555158] rockchip-es8323 rockchip-es8323.29: ES8323 HiFirockchip-i2s.0 mapping ok
[ 2.555657] u32 classifier
[ 2.555665] Actions configured
[ 2.555676] Netfilter messages via NETLINK v0.30.
[ 2.555727] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.556006] ctnetlink v0.93: registering with nfnetlink.
[ 2.556069] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.556076] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.556303] xt_time: kernel timezone is -0000
[ 2.556476] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.556590] arp_tables: (C) 2002 David S. Miller
[ 2.556627] TCP: cubic registered
[ 2.556635] Initializing XFRM netlink socket
[ 2.556813] NET: Registered protocol family 10
[ 2.557239] mip6: Mobile IPv6
[ 2.557261] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.557368] sit: IPv6 over IPv4 tunneling driver
[ 2.557644] NET: Registered protocol family 17
[ 2.557668] NET: Registered protocol family 15
[ 2.557720] Bridge firewalling registered
[ 2.557732] Ebtables v2.0 registered
[ 2.557890] Bluetooth: RFCOMM TTY layer initialized
[ 2.557920] Bluetooth: RFCOMM socket layer initialized
[ 2.557927] Bluetooth: RFCOMM ver 1.11
[ 2.557934] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.557939] Bluetooth: BNEP filters: protocol multicast
[ 2.557949] Bluetooth: BNEP socket layer initialized
[ 2.557956] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.557965] Bluetooth: HIDP socket layer initialized
[ 2.557986] l2tp_core: L2TP core driver, V2.0
[ 2.557998] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.558005] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.558204] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.558213] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 2.558221] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.558229] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 2.558237] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.558258] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 2.558276] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 2.558284] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.558307] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 2.558345] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.558388] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.558497] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 2.558512] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 2.558525] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 2.558537] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 2.558550] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 2.558595] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.558684] [BT_RFKILL]: ** disable irq
[ 2.558757] [BT_RFKILL]: ap6335 device registered.
[ 2.559366] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 2.559759] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 2.559779] rk3288_init_suspend
[ 2.559787] rk3288_suspend_init enter
[ 2.559908] rk3288_suspend_init: pm_ctrbits =40017
[ 2.559938] gpio_get_dts_info suspend:8
[ 2.559944] gpio_get_dts_info resume:8
[ 2.559950] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.559974] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.560091] clks_gating_suspend_init:clkgt info ok
[ 2.560183] Registering SWP/SWPB emulation handler
[ 2.560469] ddrfreq: verion 1.2 20140526
[ 2.560480] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 2.560489] ddrfreq: auto-freq=0
[ 2.560494] ddrfreq: auto-freq-table[0] 240MHz
[ 2.560500] ddrfreq: auto-freq-table[1] 324MHz
[ 2.560505] ddrfreq: auto-freq-table[2] 456MHz
[ 2.560510] ddrfreq: auto-freq-table[3] 528MHz
[ 2.562091] act_ldo3: operation not allowed
[ 2.562329] vga_edid_probe: turn on ldo3 done.
[ 2.562353] act_ldo4: operation not allowed
[ 2.562586] vga_edid_probe: turn on ldo done.
[ 2.562606] act_ldo2: operation not allowed
[ 2.562833] vga_edid_probe: turn on ldo2 done.
[ 2.562854] act_ldo8: operation not allowed
[ 2.563081] vga_edid_probe: turn on ldo done.
[ 2.588168] vga-ddc: read and parse vga edid success.
[ 2.588177] vga-ddc: max mode 1680x1050@59[pixclock-119005 KHZ]
[ 2.588194] vga-ddc: best mode 1680x1050@60[pixclock-6 KHZ]
[ 2.588200] vga_edid_probe: success. 9
[ 2.588294] firefly_vga_get_enable 180, 0
[ 2.588301] firefly_vga_get_status 186
[ 2.588312] firefly_vga_set_enable 159 enable:1
[ 2.588328] firefly_vga_enable 130 start
[ 2.588335] firefly_switch_fb 55
[ 2.588342]
[ 2.588342] rk_fb_switch_screen lcdc_id 0 type 1 enable 1
[ 2.588352] fb0 win id 1 state 1
[ 2.588362] regulator-dummy: disabling
[ 2.588386] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:61
[ 2.588407] fb1 win id 0 state 0
[ 2.588413] fb2 win id 2 state 0
[ 2.588418] fb3 win id 3 state 0
[ 2.588424] fb4 win id 4 state 0
[ 2.588429]
[ 2.588429] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done
[ 2.588429]
[ 2.588459] VGA ENABLE
[ 2.588719] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
[ 2.588744] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 2.588757] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
[ 2.588832] pcd_pullup, is_on 0
[ 2.588864] file system registered
[ 2.589357] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.589365] android_usb gadget: Number of LUNs=2
[ 2.589372] lun0: LUN: removable file: (no medium)
[ 2.589379] lun1: LUN: removable file: (no medium)
[ 2.589495] android_usb gadget: android_usb ready
[ 2.589569] sensor_init: Probe name sensors
[ 2.589583] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.590104] rtc_hym8563 0-0051: setting system clock to 2014-12-26 20:16:49 UTC (1419625009)
[ 2.595336] usbcore: registered new interface driver snd-usb-audio
[ 2.595362] ALSA device list:
[ 2.595368] #0: RK_ES8323
[ 2.596651] Freeing unused kernel memory: 2368K (c0a3c000 - c0c8c000)
[ 2.596907] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: rk-hdmi-spdif-hifirockchip-spdif mapping ok
[ 2.601414] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 2.601427] SELinux: the above unknown classes and permissions will be denied
[ 2.826458] type=1403 audit(1419625009.730:2): policy loaded auid=4294967295 ses=4294967295
[ 2.826553] SELinux: Loaded policy from /sepolicy
[ 2.827969] type=1404 audit(1419625009.730:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 3.204881] vga-ddc: read and parse vga edid success.
[ 3.204894] vga-ddc: max mode 1680x1050@59[pixclock-119005 KHZ]
[ 3.204910] vga-ddc: best mode 1680x1050@60[pixclock-6 KHZ]
[ 3.204916] VGA Devie connected 9
[ 3.204921] firefly_vga_set_mode 203
[ 3.204927] firefly_vga_set_mode 219 1680 1050 60 146200000
[ 3.204933] firefly_vga_enable 130 start
[ 3.204938] firefly_switch_fb 55
[ 3.204945]
[ 3.204945] rk_fb_switch_screen lcdc_id 0 type 1 enable 1
[ 3.204955] fb0 win id 1 state 1
[ 3.204997] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:61
[ 3.205019] fb1 win id 0 state 0
[ 3.205024] fb2 win id 2 state 0
[ 3.205030] fb3 win id 3 state 0
[ 3.205035] fb4 win id 4 state 0
[ 3.205040]
[ 3.205040] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done
[ 3.205040]
[ 3.728799] dwc_otg_hcd_enable, enable host controller
[ 3.832476] Using Buffer DMA mode
[ 3.832486] Periodic Transfer Interrupt Enhancement - disabled
[ 3.832493] Multiprocessor Interrupt Enhancement - disabled
[ 3.832499] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.832505] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.847006] init: init.rk30board.bootmode.emmc.rc: 8: invalid command '/devices/ff0f0000.rksdmmc/mmc_host/mmc'
[ 3.847025] init: init.rk30board.bootmode.emmc.rc: 9: invalid command '/devices/ff0c0000.rksdmmc/mmc_host/mmc'
[ 3.847038] init: init.rk30board.bootmode.emmc.rc: 10: invalid command '/devices/ff580000.usb'
[ 3.847048] init: init.rk30board.bootmode.emmc.rc: 11: invalid command '/devices/ff580000.usb'
[ 3.847058] init: init.rk30board.bootmode.emmc.rc: 12: invalid command '/devices/ff500000.usb'
[ 3.847068] init: init.rk30board.bootmode.emmc.rc: 13: invalid command '/devices/ff500000.usb'
[ 3.847077] init: init.rk30board.bootmode.emmc.rc: 14: invalid command '/devices/ff540000.usb'
[ 3.847087] init: init.rk30board.bootmode.emmc.rc: 15: invalid command '/devices/ff540000.usb'
[ 3.847376] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 3.876492] Init: Power Port (0)
[ 3.907716] init: /dev/hw_random not found
[ 3.907773] keychord: using input dev ff680000.pwm for fevent
[ 3.907782] keychord: using input dev rk29-keypad for fevent
[ 3.907936] init: cannot open '/initlogo.rle'
[ 3.920169] fs_mgr: parse_link_device : path = NULL
[ 3.920192] fs_mgr: parse_link_device : path = NULL
[ 3.920209] fs_mgr: parse_link_device : path = NULL
[ 3.920225] fs_mgr: parse_link_device : path = NULL
[ 3.920241] fs_mgr: parse_link_device : path = NULL
[ 3.920257] fs_mgr: parse_link_device : path = NULL
[ 3.920273] fs_mgr: parse_link_device : path = NULL
[ 3.920288] fs_mgr: parse_link_device : path = NULL
[ 3.920343] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Runnim
[ 3.921113] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!re
[ 3.927764] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 3.941577] EXT4-fs (mmcblk0p8): recovery complete
[ 3.945343] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.947457] EXT4-fs (mmcblk0p11): recovery complete
[ 3.947469] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.955089] EXT4-fs (mmcblk0p12): recovery complete
[ 3.955665] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.960589] drmboot: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 '
[ 3.965686] mali pd enabled
[ 3.965699] clk enabled
[ 3.965708] MALI_DVFS_STEP=4,div_dvfs=10
[ 3.965715] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 3.965722] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 3.965729] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 3.965736] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 3.966851] turn on mali power
[ 3.966875] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 3.967241] mali ffa30000.gpu: Probed as mali0
[ 4.191280] Indeed it is in host mode hprt0 = 00021501
[ 4.368390] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 4.368454] Indeed it is in host mode hprt0 = 00001101
[ 4.565389] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 4.565400] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.565408] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 4.565711] hub 3-1:1.0: USB hub found
[ 4.565765] hub 3-1:1.0: 4 ports detected
[ 4.840799] usb 3-1.1: new full-speed USB device number 3 using usb20_host
[ 4.940291] usb 3-1.1: New USB device found, idVendor=058f, idProduct=9254
[ 4.940305] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.940313] usb 3-1.1: Product: Generic USB Hub
[ 4.940319] usb 3-1.1: Manufacturer: ALCOR
[ 4.940661] hub 3-1.1:1.0: USB hub found
[ 4.940909] hub 3-1.1:1.0: 4 ports detected
[ 5.214718] usb 3-1.1.3: new low-speed USB device number 4 using usb20_host
[ 5.319076] usb 3-1.1.3: New USB device found, idVendor=413c, idProduct=3016
[ 5.319090] usb 3-1.1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 5.319098] usb 3-1.1.3: Product: Dell Premium USB Optical Mouse
[ 5.324981] input: Dell Premium USB Optical Mouse as /devices/ff540000.usb/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3:1.0/input/input2
[ 5.325451] hid-generic 0003:413C:3016.0001: input,hidraw0: USB HID v1.11 Mouse [Dell Premium USB Optical Mouse] on usb-ff5400000
[ 5.401728] usb 3-1.1.4: new low-speed USB device number 5 using usb20_host
[ 5.507779] usb 3-1.1.4: New USB device found, idVendor=413c, idProduct=2107
[ 5.507793] usb 3-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.507801] usb 3-1.1.4: Product: Dell USB Entry Keyboard
[ 5.507808] usb 3-1.1.4: Manufacturer: Dell
[ 5.512370] input: Dell Dell USB Entry Keyboard as /devices/ff540000.usb/usb3/3-1/3-1.1/3-1.1.4/3-1.1.4:1.0/input/input3
[ 5.512512] keychord: using input dev Dell Dell USB Entry Keyboard for fevent
[ 5.512840] hid-generic 0003:413C:2107.0002: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-ff540000
[ 5.598384] iep dpi mode inactivity
[ 9.800881] es8323_mic_state_ctrl read: 0
[ 9.800892] mic_state_switch 0
[ 9.800898] hp_det = 0,insert hp
[ 9.800903] hp mic use intern
[ 17.514622] *****************vbus detect*******************
