Serial Console hang
I’ve noticed that the serial console will hang after a random period of time. The symptoms are that the firefly no longer accepts input from ‘minicom’ however output continues to be displayed. The hang can only be cleared by a reboot and happens in Android or Ubuntu. I noticed the same problem has been reported in the Chinese forums.
yeh.this is a common problem.
I’m experiencing the same, and it occurs every timeI boot into miniroot.
I can see new kernel messages when I e.g. insert a memory card, but I cannot type any commands.
Is there any known solution for this issue?
We are fixing this problem.
Please go, we wait for you !!! I am using the same usb serial adaptor for different platform, and never met this problem.!
CWNP CWNA-109 시험을 보시는 분이 점점 많아지고 있는데 하루빨리 다른 분들보다 CWNP CWNA-109시험을 패스하여 자격증을 취득하는 편이 좋지 않을가요? 자격증이 보편화되면 자격증의 가치도 그만큼 떨어지니깐요. CWNP CWNA-109덤프는 이미 많은분들의 시험패스로 검증된 믿을만한 최고의 시험자료입니다.
This article is a real eye-opener, thanks for sharing! Sharing the Latest EMEA-Advanced-Support exam dumps file test questions with you for free—promotions and salary boosts are within reach!
