Where is CPU/GPU clock set?
So ive been attempting to overclock this board, but ive never worked with Rockchip devices so i may be doing something wrong.
Ive adjusted the box-dts and dvfs.c but it doesnt recognize freq beyond 1800mhz. What else do i need to change? This seems to work a bit differently than the Qualcomm and Samsung chips im use to.
also is the GPU clock set in the mali/platform/ like with samsungs mali clk?
edit: might i also need to compile uboot aswell?
ok I think i have it figured out, i wasnt flashing the resource.img
Now I see new frequencies but when i select anything over 1800mhz my performance drops vs going up
Hi, Echoa. Please PM cappybob, who has rich experience of overclocking RK3288.
Already did, and i was doing it right but the problem was the the Safety Frequency wasnt allowing for the higher frequencies to be used. Currently I am running 2ghz on the CPU, 700mhz on the GPU, and 1333mhz (667 ddr) on the RAM. If anyone else is trying, make sure you set the kernels safety frequency to the one you want to run, default is 1.6ghz. Also, to reach 2ghz+ you will need to use 1.4v or higher and probably need a heatsink to keep it within respectable temperatures. Though with the current settings I have i get 46000 in Antutu Benchmark already.?
Also, keep in mind that 1.4v is that max within the chips spec, going beyond will risk reducing life of the CPU.
Way to go Echoa, WOW.?
—cappybob
Thanks Cappy
BTW I saw in the thread you linked my your going for 2.3ghz. Did you add it to the pll table? You can add it to the table in drivers/clk/rockchip and there should be a cpu pll file in there and it default lists to 2.208ghz but you should be able to add up to 2.4ghz assuming 100 is the divider/multiplier max. I haven’t tested it yet but if you’re hitting end of pll/freq table that’s probably why.
Echoa
Ole Master of the clock, forgot to say only 42000 for my o/c, but the true magic I do not know.? Again great results?would still like to?see if we can say the rk3288, can be the workhorse for RK (2.3MHZ).? Have you found the core temp yet.? This might cause a problem down the line.? I think ugoos-Sam may boost core voltage for his Ut3?extreme no promise your?kernel to survive without cooling of some sort..
Thanks CappyBTW I saw in the thread you linked my your going for 2.3ghz. Did you add it to the pll table? You can add it to the table in drivers/clk/rockchip and there should be a cpu pll file in there and it default lists to 2.208ghz but you should be able to add up to 2.4ghz assuming 100 is the divider/multiplier max. I haven’t tested it yet but if you’re hitting end of pll/freq table that’s probably why.
@Echoa
Tried it and there is no100, but there is a 99 and running the 2.376 MHZ. Still have not seen any bragging Antutu scores yet. How about some help, would like to find out what I am missing. I know that I am not missing my beer, needing some as I increase voltages, sorry engineers. Just running 1.50 uv on cpu, needing more beverage before going for more. 2.376 MHZ seems to be it for the CPU. Voltages not sure, so will run stress tests to see if things will survive.
I really appreciate your article, it left a strong impression. I hope the Professional-Data-Engineer valid study guide book materials prove useful to you, and they’re free of charge.
I gained a lot from reading that article. Get the CKYCA test king exam materials for free—the key to promotions and higher pay!
Fast2test的專家團隊利用他們的經驗和知識終於研究出了關於Axis ANVE 認證考試的培訓資料。我們的Axis ANVE 認證考試培訓資料很受客戶歡迎,這是Fast2test的專家團隊勤勞勞動的結果。他們研究出來的模擬測試題及答案有很高的品質,和真實的考試題目有95%的相似性,是很值得你依賴的。如果你使用了Fast2test的培訓工具,你可以100%通過你的第一次參加的Axis ANVE認證考試。
