Tizen for Firefly-RK3288
Hi,
Tizen is a Linux-based open-source software platform which supports HTML5 application development for all device areas.
I am happy to announce that was able to boot Tizen:Common from microSD card on Firefly-RK3288 development board with Linux kernel 3.10, Wayland and framebuffer support.
The Tizen:Common image for Firefly-RK3288 is available for download at: http://pc.cd/cNU
It is recommend to update the bootloader of the development board to RK3288Loader_uboot_V2.17.02.bin to ensure that it will be capable of booting images from microSD card. After that you copy the provided Tizen:Common image on micro SD with 8GB or more capacity. To do it replace X with the letter corresponding to the micro SD card and execute the following commands to copy the image on micro SD card using a personal computer with Ubuntu (another Unix-like OS or Linux distribution):
umount /dev/sdX*
tar -jxvf tizen-rockchip-firefly-rk3288-20141226.tar.bz2
sudo dd if=tizen-rockchip-firefly-rk3288-20141226.img of=/dev/sdX
sync
Configuration files required to get Tizen:Common running Firefly-RK3288 has been shared at the Tizen-rockchip project at GitHub:https://github.com/leon-anavi/tizen-rockchip
Best regards,
Leon
Is there a way to install it to internal EMMC?
See it’s 7GB free space.
Is it possible to mount the image in Linux and reduce the free space to eg. 1-2GB?
When I try to mount it complains about vfat or filesystem not correct.
What filesystem is used for the image?
The SD-Card mounts correctly.
When I boot it the only thing i see are 4 Windows with names and inside
Ternimal - it runs
Webcam - Does nothing
Video - Does nothing
Web Browser - Does nothing
Is there anything else to do in Tizen?
Thanks
Looks interesting, I guess there is no gpu acceleration because of fbdev?
wonderful
Thanks for sharing. It is booting.. but.. not much can do with this OS. Only terminal and one video file is working..
Anyone know what next? How to open browser…
This article has helped me understand many complex concepts, and I’ve gained a lot. Free CPMAI pass exam available for improving your IT skills. Wishing you the best!
IT인증자격증은 국제적으로 승인받는 자격증이기에 많이 취득해두시면 취업이나 승진이나 이직이나 모두 편해집니다. 다른 사람이 없는 자격증을 내가 가지고 있다는것은 실력을 증명해주는 수단입니다. Amazon인증 AIF-C01-KR시험은 널리 승인받는 자격증의 시험과목입니다. Amazon인증 AIF-C01-KR덤프로Amazon인증 AIF-C01-KR시험공부를 하시면 시험패스 난이도가 낮아지고 자격증 취득율이 높이 올라갑니다.자격증을 많이 취득하여 취업이나 승진의 문을 두드려 보시면 빈틈없이 닫힌 문도 활짝 열릴것입니다.
Das Prüfungszertifikat für Nutanix NCP-BC-7.5 wird immer wichtiger in dieser schärf konkurrierten IT-Branche als denn je. Wählen Sie DeutschPrüfung, garantiern wir Ihnen, dass Sie die Nutanix NCP-BC-7.5 Prüfung einmalig zu bestehen. Wir werden Ihnen alle Ihren bezahlten Summe zurückgeben, entweder Sie die Nutanix NCP-BC-7.5 Prüfung nicht bestehen, oder die Testaufgaben von Nutanix NCP-BC-7.5 irgend ein Qualitätsproblem haben. Worauf warten Sie noch? Für Ihren IT-Traum bitte ergreifen Sie schnell Maßnahmen.
Thank you for your article, it was incredibly enlightening. New EX380 exam discount test questions are now free. Good luck with your exams!
