Hi everybody
My board has ethernet problems in 1000/full mode , iperf output indicates 1,5mbps in tcp. When i force 100/full i got 90mbps in iperf. Résults are the same under linux and android
Is it a kernel bug ??
Thx you
Pacopad
Hi everybody
Thx you
Pacopad
show the attachme which include kernel log when connect 1000 mode.
Hi Zhansb,
here is the full boot log http://pastebin.com/KhHqCQwb
Then when i put the wire in 100Mbps switch
[ 326.247106] libphy: stmmac-0:01 - Link is Down
[ 336.087163] stmmc_pltfr_fix_mac_speed: fix speed to 100
[ 336.087181] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
[ 336.087190] libphy: stmmac-0:01 - Link is Up - 100/Full
I got packet loss when i ping a computer on my network.
ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=0.874 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=0.499 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=0.417 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=0.622 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=0.495 ms
64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=0.390 ms
64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=0.415 ms
64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=0.461 ms
64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=0.415 ms
64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=0.469 ms
64 bytes from 192.168.1.1: icmp_seq=11 ttl=64 time=0.427 ms
64 bytes from 192.168.1.1: icmp_seq=12 ttl=64 time=0.491 ms
64 bytes from 192.168.1.1: icmp_seq=13 ttl=64 time=0.440 ms
64 bytes from 192.168.1.1: icmp_seq=17 ttl=64 time=0.611 ms
64 bytes from 192.168.1.1: icmp_seq=18 ttl=64 time=0.583 ms
64 bytes from 192.168.1.1: icmp_seq=19 ttl=64 time=0.441 ms
64 bytes from 192.168.1.1: icmp_seq=20 ttl=64 time=0.510 ms
64 bytes from 192.168.1.1: icmp_seq=21 ttl=64 time=0.579 ms
^C
— 192.168.1.1 ping statistics —
21 packets transmitted, 18 received, 14% packet loss, time 19994ms
rtt min/avg/max/mdev = 0.390/0.507/0.874/0.115 ms
I’m an IT Tech so i got all basic verifications, i changed switch and wires. My network is ok with other computers and devices.
Thx for your help
Pacopad
make sure your network cable and router support 1000M?
if they are correct ,the log will be like this:
[ 453.385496] stmmc_pltfr_fix_mac_speed: fix speed to 1000
[ 453.385735] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
[ 453.385844] libphy: stmmac-0:01 - Link is Up - 1000/Full
Hi,
The 1000/full logs are in the pastebin Line 1135.
My network is giga ok , working good with computer and PS3 and synology ds415
Please could you give me a réal way to Check ?? I tryed at office i got same matter, is my board défective ???
Pacopad
try connect device and computer directly .
set a static ip for device . make sure the same network segment and under the 1000/Full environment
try to ping your computer again .check the Packet loss rate and iperf your computer ip again.
Here are results of my tests
COMPUTER ↔ FIREFLY DIRECTLY CONNECTED 1000/FULL
Mac-Pro:~ pacopad$ iperf -c 192.168.1.151 -i2 -t120
Client connecting to 192.168.1.151, TCP port 5001
TCP window size: 129 KByte (default)
[ 4] local 192.168.1.1 port 50131 connected with 192.168.1.151 port 5001
[ ID] Interval Transfer Bandwidth
[ 4] 0.0- 2.0 sec 256 KBytes 1.05 Mbits/sec
[ 4] 2.0- 4.0 sec 256 KBytes 1.05 Mbits/sec
[ 4] 4.0- 6.0 sec 128 KBytes 524 Kbits/sec
[ 4] 6.0- 8.0 sec 128 KBytes 524 Kbits/sec
[ 4] 8.0-10.0 sec 0.00 Bytes 0.00 bits/sec
[ 4] 10.0-12.0 sec 128 KBytes 524 Kbits/sec
[ 4] 12.0-14.0 sec 0.00 Bytes 0.00 bits/sec
^C[ 4] 14.0-16.0 sec 128 KBytes 524 Kbits/sec
[ 4] 16.0-18.0 sec 0.00 Bytes 0.00 bits/sec
[ 4] 18.0-20.0 sec 0.00 Bytes 0.00 bits/sec
[ 4] 20.0-22.0 sec 0.00 Bytes 0.00 bits/sec
[ 4] 0.0-23.7 sec 1.12 MBytes 399 Kbits/sec
COMPUTER ↔ FIREFLY DIRECTLY CONNECTED 100/FULL FORCED ON FIREFLY
[ 4] local 192.168.1.1 port 50137 connected with 192.168.1.151 port 5001
[ 4] 0.0- 2.0 sec 22.8 MBytes 95.4 Mbits/sec
[ 4] 2.0- 4.0 sec 22.6 MBytes 94.9 Mbits/sec
[ 4] 4.0- 6.0 sec 22.5 MBytes 94.4 Mbits/sec
[ 4] 6.0- 8.0 sec 22.4 MBytes 93.8 Mbits/sec
[ 4] 8.0-10.0 sec 22.4 MBytes 93.8 Mbits/sec
[ 4] 10.0-12.0 sec 22.4 MBytes 93.8 Mbits/sec
[ 4] 12.0-14.0 sec 22.6 MBytes 94.9 Mbits/sec
[ 4] 14.0-16.0 sec 22.1 MBytes 92.8 Mbits/sec
[ 4] 16.0-18.0 sec 22.5 MBytes 94.4 Mbits/sec
^C[ 4] 0.0-19.4 sec 218 MBytes 94.3 Mbits/sec
COMPUTER ↔ NAS SYNOLOGY THROUGH NETWORK
Mac-Pro:~ pacopad$ iperf -c 192.168.1.2 -i2 -t120
Client connecting to 192.168.1.2, TCP port 5001
[ 4] local 192.168.1.1 port 50159 connected with 192.168.1.2 port 5001
[ 4] 0.0- 2.0 sec 223 MBytes 935 Mbits/sec
[ 4] 2.0- 4.0 sec 223 MBytes 934 Mbits/sec
[ 4] 4.0- 6.0 sec 223 MBytes 935 Mbits/sec
[ 4] 6.0- 8.0 sec 223 MBytes 934 Mbits/sec
[ 4] 8.0-10.0 sec 223 MBytes 934 Mbits/sec
[ 4] 10.0-12.0 sec 223 MBytes 935 Mbits/sec
[ 4] 12.0-14.0 sec 223 MBytes 934 Mbits/sec
[ 4] 14.0-16.0 sec 223 MBytes 934 Mbits/sec
[ 4] 16.0-18.0 sec 223 MBytes 935 Mbits/sec
^C[ 4] 0.0-18.7 sec 2.04 GBytes 935 Mbits/sec
It really think there is a problem and that’s not located on my network ![]()
I 'll try to compile a 3.17 kernel to see if there are changes
Thx
Pacopad
That article was a real treasure trove of knowledge. Here’s the New Cloud-Digital-Leader exam dumps test that helped me land my promotion and raise. It’s free today—good luck with your career progress!
