I would like to use Firefly as main media player for all my content up to 4K on Samsung HU7000 series TV from QNAP NAS. Initially I had a problem with HDMI connection to my TV in 4K/60Hz mode. It works only if HDMI input renamed to PC, HDMI 2.0 cable has length not longer than 3ft and UltraHD colors enabled in Samsung TV menu.Built-in player show video correctly only from USB drive but when I try to watch anything over Gigabit Ethernet network I see “green noise” picture instead 4K Astra demo video or video without any sound for regular HD movies.
So I’ve installed SPMC from http://spmc.semperpax.com and now can watch almost everything over network (NFS,Samba). I have only two problems now:
video showing not smoothly (it looks like very fast slide-show) like 10-20fps in any screen resolution. I can compare video from different HDMI sources and there no any problem with TV here.
Full UHD resolution (3840x2160x60) works fine in Home Screen but if I run SPMC from any resolution higher than 1920x1080x60 screen automatically change resolution to 1280x720. Android still think it has original UHD resolution. SPMC always show 3840x2160x60 in system settings even if screen is 3840x2160x25 only. See screenshot…
The second problem , you need to ?close spmc completely and restart it, then you can find it change. I think this is spmc’s problem.
close spmc completely,just click this button:
After reading this article, I feel I have grown a lot. The New study SC-400 questions book test questions are now free. Wishing you all the best of luck!
Thank you for your article, it truly broadened my mind and vision. It’s nearly time for my Generative-AI-Leader valid dumps demo exam – wish me all the best!
